samsung JU7100 - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 4827Likes
post #8731 of 10380 Old 09-29-2016, 06:23 PM
p5browne's Avatar
Quoted: 4008 Post(s)
Liked: 3182
I don't think my 7100 is really trying too hard to find the FW update. I think it just goes out, runs around the block and comes back and says, nope, 1460.4 is current!
tampa8 and dilipb like this.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #8732 of 10380 Old 09-29-2016, 10:56 PM
Quoted: 59 Post(s)
Liked: 26
Originally Posted by Mats Sturtewagen View Post
What are you settings then ? Its very dark here and dull colours not bright
Have to check when I get home tonight!
Verstuurd vanaf mijn SM-G930F met Tapatalk
Bouncernl90 is offline
post #8733 of 10380 Old 09-30-2016, 09:30 AM
Liked: 0
Same issue here. Mine wouldnt even find 1460, I had to download it from the samsung website and put it on a usb drive.
magRT496 is offline
post #8734 of 10380 Old 09-30-2016, 09:57 AM
Liked: 0
Originally Posted by wildgator25 View Post
Non JS Mod Calibration
New Calibration
Firmware 1461.2
** Adjustments Made in Service Menu 1st **
White Balance Offsets changed from 128/128/128 to 114/114/114
White Balance Gains changed from 123/128/130 to 123/128/139
How do you access the service menu to make these adjustments?
And my TV is only version 1460, will these calibrations still work?
magRT496 is offline
post #8735 of 10380 Old 09-30-2016, 11:13 AM
JC7727's Avatar
Quoted: 29 Post(s)
HDR on xbox one s, does it work on this TV?
JC7727 is offline
post #8736 of 10380 Old 09-30-2016, 11:34 AM
wildgator25's Avatar
Quoted: 694 Post(s)
Liked: 508
Search for posts on this thread by @ml2517 . He has the Service Menu information in his signature.
No, you do not need the latest firmware and it's doubtful you'll see a visual difference between the latest firmware and the version you have.
wildgator25 is offline
post #8737 of 10380 Old 09-30-2016, 11:41 AM
ml2517's Avatar
Quoted: 337 Post(s)
Liked: 154
See my signature.
wildgator25 likes this.
ml2517 is offline
post #8738 of 10380 Old 09-30-2016, 03:14 PM
p5browne's Avatar
Liked: 3182
Fw # 1462
Now available from the Korean Website: (Note a Member mentioned Korean FW updates will void warranty?) (Personally, have never had issues.)
FW # 1462.1 - I assume the JU7100 has taken a different turn from the other sets, that went from 1460.4 to 1461.1 to now 1463.0
http://www.samsung.com/sec/consumer/...tv/UN75JU7000F
UN65KS9800 - Mine
p5browne is offline
post #8739 of 10380 Old 09-30-2016, 06:39 PM
Quoted: 694 Post(s)
Liked: 508
My set has 1462 now, automatic download came sometime earlier this week.
post #8740 of 10380 Old 09-30-2016, 07:35 PM
Quoted: 91 Post(s)
Odd occurrence this morning. Turned on the set and two or three seconds later, the tv shut off. Turned the set back on and again, it shut off. Did this time after time and at this point, I was convinced that there was something wrong with the tv. Gave it the old college try once more (actually my wife did) and the set stayed on. Has been fine all day, with no further issues. Does turn on and off normally. Any ideas as to what might be wrong??
Javaman12 is offline
post #8741 of 10380 Old 09-30-2016, 10:27 PM
p5browne's Avatar
Liked: 3182
Unplug from wall, and leave it this way till morning.
UN65KS9800 - Mine
p5browne is offline
post #8742 of 10380 Old 09-30-2016, 11:17 PM
Quoted: 91 Post(s)
It's working fine now - are you still recommending I unplug it?
post #8743 of 10380 Old 09-30-2016, 11:58 PM
MikeCortez's Avatar
I am having the same problem as well. It looks like there is a general issue with the console and HDR. A lot of people in the Xbox one subreddit have been complaining about it. Supposedly Microsoft is looking into it.
https://www.reddit.com/r/xboxone/com...on_xbox_one_s/
MikeCortez is offline
post #8744 of 10380 Old 10-01-2016, 05:15 AM
Quoted: 59 Post(s)
Liked: 26
My Xbox plays Netflix hdr, forza hdr but the 4k BluRay of deadpool won't toggle to hdr. Anyone knows what's happening?
post #8745 of 10380 Old 10-01-2016, 08:02 AM
O.E.'s Avatar
Quoted: 47 Post(s)
Ensure that the Xbox has all the check marks in the advanced options including HDR for movies!
O.E. is offline
post #8746 of 10380 Old 10-01-2016, 08:10 AM
Quoted: 59 Post(s)
Liked: 26
It has!
post #8747 of 10380 Old 10-01-2016, 09:47 AM
p5browne's Avatar
Liked: 3182
Can't hurt it. Plus, it's unplugged when you're not using it.
UN65KS9800 - Mine
p5browne is offline
post #8748 of 10380 Old 10-01-2016, 11:20 AM
Quoted: 40 Post(s)
Liked: 5
I have the JS Mod and since the last update I haven't been able to use Netflix. I tried resetting the smart hub and now I can't get past the T&S page to set it back up. I get an error that my internet connection is not stable (999). I tried changing the DNS but that didn't work. Unplugged it overnight and that didn't work either. Any ideas?
If I do a factory reset with the JS Mod in place, will it break anything? I know the mod will go away, but I don't care about that. I just want my smart hub back!
TV: Samsung UN65JU7100, TH01
AVR: Onkyo TX-NR717
BMoreLas is offline
post #8749 of 10380 Old 10-01-2016, 11:30 AM
Quoted: 59 Post(s)
Liked: 26
Anyone with BluRay hdr xbox one s issues?? Its not enabling hdr. Have green marks, netflix and gaming are good with hdr en have everything enabled. Game mode on or off doesn't change a thing.
post #8750 of 10380 Old 10-01-2016, 04:55 PM
p5browne's Avatar
Liked: 3182
Try changing your Auto Network to Manual 8.8.8.8 and see if that works.
UN65KS9800 - Mine
p5browne is offline
post #8751 of 10380 Old 10-01-2016, 08:44 PM
Quoted: 40 Post(s)
Liked: 5
No dice. Still getting the error.
AVR: Onkyo TX-NR717
BMoreLas is offline
post #8752 of 10380 Old 10-01-2016, 08:45 PM
Lionheart of AVS
King Richard's Avatar
Quoted: 1797 Post(s)
Liked: 4367
Did you try resetting everything? (Turn OFF, unplug, etc.)
Post all your settings for both TV and XBox and we'll see if it might be a setting you might be overlooking.
Richard
King Richard is offline
post #8753 of 10380 Old 10-01-2016, 09:46 PM
Quoted: 40 Post(s)
Liked: 5
Still getting the unstable internet error 999. I even tried using my phone as a hotspot on LTE. So it's not my internet. Guess I'll try changing my panel settings back to Non JS Mod and doing a factory reset.
AVR: Onkyo TX-NR717
BMoreLas is offline
post #8754 of 10380 Old 10-02-2016, 10:33 AM
biggggant's Avatar
Randomly my Sark's will look too dark and washed out. Sometimes restarting the TV or turning on UHD color mode on or off. Not sure what's the real cause but maybe that can help some of you guys.
biggggant is offline
post #8755 of 10380 Old 10-02-2016, 01:22 PM
Quoted: 22 Post(s)
Liked: 5
Is it safe to assume that Day/Night modes can be removed by changing D/N ADJ back to off in the service menu ?
I know it will reset all picture settings but I want to start fresh .
HWF
Samsung UN60JU7100, Sony STR-DN850, JBL (Movies 2) 7.1, Sony BDP X800, WD TV Live Hub, Raspberry Pi2/Kodi
harpanet13 is offline
post #8756 of 10380 Old 10-02-2016, 04:26 PM
Quoted: 40 Post(s)
Liked: 5
Reverted back to non JS Mod and everything worked right away. Smart Hub is working and Netflix and Amazon are both working. Also still able to play the Samsung HDR demos. I think I'll stick to normal for a while since there is some question of the benefits of the mod anyway. I think I'll read back through more threads and see what others are experiencing.
AVR: Onkyo TX-NR717
BMoreLas is offline
post #8757 of 10380 Old 10-02-2016, 08:55 PM
p5browne's Avatar
Liked: 3182
The Network Media in the SM has to be correct. Did you write down the original value before doing the JS Mod?
UN65KS9800 - Mine
p5browne is offline
post #8758 of 10380 Old 10-03-2016, 09:41 AM
Quoted: 12 Post(s)
Liked: 0
Have anyone good settings with Xbox One S HDR ?
Its to dark here and not bright and vivid
Mats Sturtewagen is offline
post #8759 of 10380 Old 10-03-2016, 11:37 AM
dilipb's Avatar
Quoted: 28 Post(s)
Sorry for this question (difficult to search this forum page by page)
I have the JU7100 75", I have been used CAL-DAY all these days.
What's this JS MOD that everyone is talking about in this forum?
Was there a special firmware OR some new setting that someone released?
How can I get that?
Will I get HDR functionality in Netflix and other apps ?
Hope someone helps me out.
dilipb is offline
post #8760 of 10380 Old 10-03-2016, 11:53 AM
atc98092's Avatar
Quoted: 1440 Post(s)
Liked: 644
How can I get that?
the JS mod makes the TV think it's a JS, not a JU model. This enables HDR for Amazon only, not Netflix. One or two new options appear in the video menu. It's debatable if there's an actual, measurable improvement in the video. However, because it's not an actual JS model, there is a limit to how well it can display HDR material. The TV will recognize HDR from outside sources (4K Blu Ray player for example) even without the mod, so it's not mandatory. With a handfull of new Roku players coming out shortly, there will be more HDR compatible players on the market, and the JS Mod becomes less necessary.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
Reply LCD Flat Panel Displays
4k tv , JU7100 , samsumg , Samsung , uhd
