**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 555 - AVS Forum | Home Theater Discussions And Reviews
 9791Likes
post #16621 of 24044 Old 03-03-2016, 12:34 PM
green666's Avatar
Quoted: 339 Post(s)
Liked: 126
Originally Posted by wrathloki View Post
Are you sure you didn't buy an OLED? Seriously though that's a nice looking set you may just want to keep it. Guess they have better manufacturing wherever yours was made (probably not Mexico like mine.)
Its made in Slovakia, and i am frankly surprised how it handles blacks ...it does it better then the 55 referent unit they had on Rtings...
Maybe coz i picked it in person and never let them (mis)handling it, so i never really touched the side frames to prevent the light bleed, only bottom and slight touch on top when getting it out of the box. Who knows.
Thnx for you though. I really appreciate.
1st 55js8002: Bad DSE - returned for replace
2nd 55js8002: Exactly the same thing - refund
55js9002: Panel R.I.P. (edge bleed after 1 year of use) - refund
55x900E: Great TV - hope it will last
green666 is offline
post #16622 of 24044 Old 03-03-2016, 12:36 PM
matrix123's Avatar
Quoted: 373 Post(s)
Liked: 142
Originally Posted by Sam S View Post
Originally Posted by matrix123 View Post
I know. I'm just used to it on CLEAR. Gonna try blur 10 and judder 0 and/or OFF to see what I like better. Just have to get used to it again.
Clear Motion OFF, AMP to Custom, Blur Reduction 10 and Judder Reduction 0 is the "correct" motion handling setting for 24p-based content.
Thanks. Gonna give it a try with mad max fury road HDR.
matrix123 is offline
post #16623 of 24044 Old 03-03-2016, 12:36 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
Originally Posted by prme19 View Post
So 45 is optimal then. What was your original question again?
You answered it, thanks.
Living Room
Samsung 65JS8500
Onkyo NR-737
Onkyo SKF-4800 Fronts w/ HTP-980 Surrounds & Center and Klipsch R-12SW
Bedroom
Samsung 55JS8500 w/ Yamaha YAS-105 Soundbar
wrathloki is offline
post #16624 of 24044 Old 03-03-2016, 12:37 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
I want a Slovakian set.
goksucats and buist like this.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #16625 of 24044 Old 03-03-2016, 12:50 PM
green666's Avatar
Quoted: 339 Post(s)
Liked: 126
I think all of electronics for my area and east Europe is assembled by them but its also considered as lower quality then for west EU.
Anyway, its a shame that they dont allow anymore of questions on Rtings, i would have asked them if my case is tolerable, being subjective or not, as i can imagine what Samsung would say.
green666 is offline
post #16626 of 24044 Old 03-03-2016, 12:53 PM
green666's Avatar
Quoted: 339 Post(s)
Liked: 126
My last question here ...is fast boot option need to be on or off? Read somewhere that its not good for a set. I find it pretty slow to boot up when i enable apps screen, so i disabled it...but kept fast boot on.
green666 is offline
post #16627 of 24044 Old 03-03-2016, 12:59 PM
Quoted: 31 Post(s)
Originally Posted by thegoldenone View Post
Just curious, but for someone like me who loves the SOE (my motion plus settings are maxed out), would any of the recommended settings from page one actually still improve PQ with the motion plus settings maxed out?
Originally Posted by trailryder42 View Post
I would say no. The calibrations found on the first page have to do with aspects that make up the picture. The motion settings have to do with frame interpolation of the picture. They don't adjust any of the pictures calibrated settings.
Did you mean to say yes? Based on your explanation, it seems that you're saying that using the suggested settings on page one would still make an improvement in PQ with the motion settings maxed out?!
thegoldenone is offline
post #16628 of 24044 Old 03-03-2016, 01:26 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
Motion settings are basically just a preference. If you like the soap opera effect then turn it on standard or smooth but if you just want to get rid of frame judder turn on clear.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #16629 of 24044 Old 03-03-2016, 01:27 PM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 139
That's a terrible example to try with MMFR has tons of intentionally "dropped frames" and sped-up action that will make motion processing artifacts hard to spot.
Recommend that you just start with a standard Blu-ray. Behavior for UHD should be the same, as both are 24p.
Sam S is offline
post #16630 of 24044 Old 03-03-2016, 01:31 PM
Quoted: 31 Post(s)
Thank you both for the input. Much appreciated.
post #16631 of 24044 Old 03-03-2016, 01:50 PM
matrix123's Avatar
Quoted: 373 Post(s)
Liked: 142
Your probably right! Ha! Didn't think of that. Set not the best one to try with. Thanks.
post #16632 of 24044 Old 03-03-2016, 02:13 PM
denpom's Avatar
Quoted: 1326 Post(s)
Liked: 1180
there's nothing "reference" about Rtings unit or their reviews and conclusions. they just buy their units like all of us here and pretend that one particular set represents the performance of the whole series. it's laughable.
denpom is offline
post #16633 of 24044 Old 03-03-2016, 02:22 PM
mc_avs's Avatar
Quoted: 307 Post(s)
Liked: 310
Originally Posted by goksucats View Post
Maybe Trump's wall will prevent them from shipping crappy TV's over here. Lol. Sorry, couldn't resist.
Hahahaha good one!
goksucats likes this.
Lounge - Sony 65" A8F OLED, Pioneer SC-LX59 9.2 Receiver, Oppo UDP-203 UHD Blu-Ray Player, JBL Studio 180 Speaker Series, ELAC Debut A4 Atmos Modules setup as 5.1.4, Sony PS4 Pro, Logitech Harmony Elite. Bedroom - Samsung UA55C8000 3D LED, Sony PS3.
mc_avs is offline
post #16634 of 24044 Old 03-03-2016, 03:37 PM
JCBiggs's Avatar
Quoted: 45 Post(s)
SO after seeing green666's set... im assuming that light bleed 12 inches away from the edge is totally unacceptable. it appears they CAN make good sets... why so much variation? I wouldn't even care about the light bleed if it was consistent and didnt move!!... but the whole screen lighting up for a white play icon in the bottom left corner bugs the absolute CRAP out of me.
JCBiggs is offline
post #16635 of 24044 Old 03-03-2016, 03:49 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
Because of crappy manufacturing in Mexico.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #16636 of 24044 Old 03-03-2016, 04:37 PM
kevinmscs's Avatar
Quoted: 493 Post(s)
Liked: 208
Which stared since El Chapo got busted.
blasterr and goksucats like this.
kevinmscs is offline
post #16637 of 24044 Old 03-03-2016, 05:08 PM
TinyRK's Avatar
Quoted: 223 Post(s)
Liked: 132
No, because of bad QC!
Don't blame the workers, they do what they're being told. But QC should filter and reject snafus, which they are not doing.
Or they're allowing a wider deviation from the quality standard they initially had to be able to offer it for half the msrp.
LG 65E6 | Denon x3200 | Klipsch RP-280F - RP-450C - RS-62II - R-115SW
TinyRK is offline
post #16638 of 24044 Old 03-03-2016, 05:18 PM
Quoted: 111 Post(s)
Liked: 42
Quick question guys. Will a 12.10' light strip make it all the way around our 65" tv?
Sent from my Nexus 6P using Tapatalk
Ajresendez is offline
post #16639 of 24044 Old 03-03-2016, 05:20 PM
Quoted: 111 Post(s)
Liked: 42
I thought this was normal? Because of how the localized dimming works on our tvs. If it's not I need to contact Samsung.
post #16640 of 24044 Old 03-03-2016, 05:48 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
I'm not blaming the workers, they get paid crap so it's not like they care how the TVs turn out. I blame Samsung and all these companies that send their products somewhere that has such cheap labor. I also blame the world market that allows this kind of stuff to happen.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #16641 of 24044 Old 03-03-2016, 05:57 PM
mc_avs's Avatar
Quoted: 307 Post(s)
Liked: 310
You're right.
Manufacturing here in Australia is less than 10%, everything is made overseas, especially in China. By next year we will have no car manufacturers left in Australia with all new Vehicles imported.
mc_avs is offline
post #16642 of 24044 Old 03-03-2016, 06:02 PM
kevinmscs's Avatar
Quoted: 493 Post(s)
Liked: 208
Why QC when people are buying? Apple is doing the same thing and noone's complaining...
post #16643 of 24044 Old 03-03-2016, 06:48 PM
eviljack's Avatar
Quoted: 59 Post(s)
Liked: 24
I ordered the longer OCM cable from Encompass ( https://www.encompassparts.com/item/...CBF_SIGNAL-OCM ) and it came today. It works perfectly. I'm pretty sure it is made by Samsung or whoever makes the original cable. The connectors are identical. The new cable is a little bit thicker though. See pics below.
ID:	1292529   Click image for larger version
ID:	1292537   Click image for larger version
eviljack is offline
post #16644 of 24044 Old 03-03-2016, 06:54 PM
70383roadrunner's Avatar
Quoted: 98 Post(s)
Liked: 46
$46 for a cable. Are you kidding me!
70383roadrunner is offline
post #16645 of 24044 Old 03-03-2016, 07:01 PM
Quoted: 111 Post(s)
Liked: 42
Have you ever bought a monster cable???
blasterr, goksucats and mc_avs like this.
post #16646 of 24044 Old 03-03-2016, 07:52 PM
Quoted: 98 Post(s)
Liked: 46
No. Why would I buy overpriced Monster cables. I buy Monoprice or cablesforless.
post #16647 of 24044 Old 03-03-2016, 08:01 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
Pointless waste of money.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #16648 of 24044 Old 03-03-2016, 08:08 PM
Quoted: 111 Post(s)
Liked: 42
Exactly buddy of mine used to work for bestbuy and the mark up on those things is insane.
post #16649 of 24044 Old 03-03-2016, 08:11 PM
Quoted: 79 Post(s)
Liked: 35
Nope hdmi cables are not all the same,I've tried several cheap ones,monster cables,and now I have some audioq est cables,big difference in clarity and smoothness..
camaro8500 is offline
post #16650 of 24044 Old 03-03-2016, 08:13 PM
wrathloki's Avatar
Quoted: 670 Post(s)
Liked: 313
goksucats and green666 like this.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
Reply LCD Flat Panel Displays
JS8500 , reflection , screen flashing black
