**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 642 - AVS Forum | Home Theater Discussions And Reviews
 9814Likes
post #19231 of 24074 Old 06-11-2016, 01:55 PM
Liked: 0
Originally Posted by 4K Tech View Post
The on/off faint clicking sound is normal behavior.
Great, thanks for the quick response and giving me peace of mind.
nightw1ng is offline
post #19232 of 24074 Old 06-11-2016, 03:53 PM
locob's Avatar
Quoted: 28 Post(s)
Originally Posted by gtgray View Post
Anyone here with 78JS8600?
My set seems to not have a power on led or it is not enabled. I don't find anything in the menu to enabled.
My other problem is how do I access the movies on the Western Digital My Passport Cinema?
Use the Fandangonow app to activate the tv and access the movies on the drive.
locob is offline
post #19233 of 24074 Old 06-11-2016, 04:21 PM
Quoted: 18 Post(s)
Liked: 1
About the UHD color, is this something that i should use while watching movies from my mediaplayer (Minix X8-H Plus) and what difference will it make?
Thanks so much again for the answers!
BUMP on this
Originally Posted by mc_avs View Post
Here are some pics of The Life Of Pi 4K HDR after Calibration. Taken with a Samsung S7 Edge & they honestly still don't do it justice.
I would love to try those settings out, if you have the time, PM those or post them in the thread. It will be much appreciated
Sjoegren is offline
post #19234 of 24074 Old 06-11-2016, 08:46 PM
Lionheart of AVS
King Richard's Avatar
Quoted: 1797 Post(s)
Liked: 4367
Originally Posted by Sjoegren View Post
I've only got my hands on one HDR clip and would like to try some more, so if someone can point me in the right direction to get some democlips i would appreciate that!
Here are a few links:
Master List of currently available 4k HDR titles
HDR UHD Demos
Here are some more excellent Demos from LG:
Note: You need to change the extension to .mkv after download.
MEGA 1
MEGA 2
MEGA 3
No.
Check out my "JS Series Picture Settings General Guide" (scroll down to HDMI UHD Color).
Richard
King Richard is offline
post #19235 of 24074 Old 06-11-2016, 10:04 PM
gtgray's Avatar
Quoted: 248 Post(s)
Liked: 162
gtgray is offline
post #19236 of 24074 Old 06-11-2016, 10:55 PM
gtgray's Avatar
Quoted: 248 Post(s)
Liked: 162
Thanks! Now I have to figure out why the two free movies aren't free.
gtgray is offline
post #19237 of 24074 Old 06-12-2016, 02:33 AM
Liked: 1
Originally Posted by Hyrax View Post
I had a similar problem until I stopped using the internal speakers. It drove me nuts ... I got so tired of it that I now use a 6x2 HDMI splitter to separate the video and audio going into the TV so that the audio goes through a receiver without being touched by the TV. In my setup everything connects to the splitter and one HDMI cable goes to the TV and another HDMI cable goes to the receiver. You could don't need a receiver but could a sound bar instead.
However, you may be able to do a few things to reduce the skipping problem.
  • Try changing what you cable box is sending to the TV. What I mean is that if the cable box is sending Bitstream, try sending PCM or vise-versa. Even try sending stereo instead of 5.1 if the audio skips bother you enough.
  • Reduce the audio delay as much as possible. I think that worked most of the time for me.
  • I seem to recall that unplugging the TV for a couple of minutes and then plugging it back in made the skipping stop for a while. If this does work, try remember if switching inputs brings the the problem back (or if using the TV's apps brings the problem back).
I use ATT uverse and have not had this problem. My cable box is plugged into a yamaha receiver which is then connected to the ARC HDMI output on the TV.
There is an issue with the TV ignoring ARC and outputting sound through the TV speakers - and its inconsistent (and thus maddening).
The anynet CEC functionality plays very poorly with a setup where all the input devices are first plugged into an AV receiver. Once I turned that functionality off - all my sound and control problems (except the ones in my head ) went away.
Niall Blehein is offline
post #19238 of 24074 Old 06-12-2016, 02:37 AM
Liked: 1
If you can stump up the cash, get it Professionally Calibrated, I can't recommend it enough.
Can you post your calibration settings ? Thanks
post #19239 of 24074 Old 06-12-2016, 07:55 AM
Richdog's Avatar
Guys I am having an issue where subtitles will not work for MKV's streamed over DLNA. The folder, MKV and SRT are all names exactly the same barring the extension, and I am sure last time I tried a month ago it worked fine. Any ideas? I tried it on two separate movies, no joy.
PS: I did a thread search but didn't find a solution.
Richdog is offline
post #19240 of 24074 Old 06-12-2016, 08:07 AM
TravisBean's Avatar
Quoted: 251 Post(s)
Liked: 301
Is there a way to turn off wi-fi and enter "airplane mode" on this TV ?
TravisBean is offline
post #19241 of 24074 Old 06-12-2016, 08:12 AM
Hyrax's Avatar
Quoted: 157 Post(s)
Liked: 71
It sounds as though your solution is very similar to mine except you're using your receiver as the HDMI splitter.
As to ARC being ignored ... I wonder if you even need to use the ARC channel except for the internal apps. I use the SP/DIF output from the TV to send the audio from the internal apps to the receiver. If you feel like puttering, you could try to see if that setup gives you more control over your audio.
Hyrax is offline
post #19242 of 24074 Old 06-12-2016, 09:53 AM
TravisBean's Avatar
Quoted: 251 Post(s)
Liked: 301
And does Samsung still extend the warranty if you register the TV with them ?
post #19243 of 24074 Old 06-12-2016, 11:51 AM
Quoted: 263 Post(s)
Liked: 249
Not that I'm aware of, I believe that perk may have been for certain computer monitors but not for the JS8500 series TVs. Here is the official warranty info for the 2015 JS Series 8 sets:
http://www.samsung.com/us/support/su...me=UN65JS8500F
4K Tech is offline
post #19244 of 24074 Old 06-12-2016, 12:12 PM
Quoted: 263 Post(s)
Liked: 249
There is no setting tantamount to "Airplane Mode."
4K Tech is offline
post #19245 of 24074 Old 06-12-2016, 01:52 PM
tmdorsey's Avatar
Quoted: 463 Post(s)
Liked: 425
Wanted to state I watched an episode of Daredevil (season 2 Ep 4 or 5) on Netflix last night with plenty of dark scenes and I experienced no blooming or flashlighting.
tmdorsey is offline
post #19246 of 24074 Old 06-12-2016, 01:54 PM
Michael Osadciw's Avatar
Quoted: 155 Post(s)
Liked: 131
Is the UN65JS8500 capable of receiving an HDR signal from an external source through it's HDMI input? (ex. a UHD Blu-ray) Was there a software upgrade that allowed that to happen with its OneConnect box that it came with or does the user need the SEK-3500?
Michael Osadciw is offline
post #19247 of 24074 Old 06-12-2016, 04:40 PM
tmdorsey's Avatar
Quoted: 463 Post(s)
Liked: 425
I believe it supports external HDR signals out of the box.
tmdorsey is offline
post #19248 of 24074 Old 06-12-2016, 05:01 PM
Quoted: 25 Post(s)
Liked: 8
Question Bose Sound Touch 130 soundbar
Anyone using a Bose sound touch 130 soundbar with their JS series tv?
Would like some feedback on what you experiences may be as I am planning to set this up for my 55'' JS
TIA
Vg247 is offline
post #19249 of 24074 Old 06-12-2016, 08:52 PM
mc_avs's Avatar
Quoted: 307 Post(s)
Liked: 310
Ok guys below is my Professional Calibrated settings using a UBD-K8500 UHD Blu-Ray Player set to Auto for 1080p Standard Blu-Ray's. For UHD HDR Discs, I change Brightness to 44 & set Colour Space to Native. It was Calibrated in a Dark Environment & the results are brilliant.
Picture Mode - MOVIE
Backlight - 10
Contrast - 92
Brightness - 43
Sharpness - 8
Colour - 48
Tint (G/R) - G50/R50
Picture Size - 16:9/Fit To screen
Dynamic Contrast - OFF
Black Tone - OFF
Flesh Tone - 0
RGB Only Mode - OFF
Colour Space - CUSTOM
Gamma - 0
Expert Pattern - OFF
Colour Tone - WARM2
Digital Clean View - OFF
MPEG Noise Filter - OFF
HDMI Black Level - NORMAL
HDMI UHD Colour - ON
Film Mode - OFF
Auto Motion Plus - CUSTOM
Smart LED - STANDARD
White Balance
R-OFFSET -2
G-OFFSET 0
B-OFFSET -8
R-GAIN -9
G-GAIN 0
B-GAIN 11
10pt White Balance
10% - Red 2, Green 0, Blue -50
20% - Red 7, Green 0, Blue -9
30% - Red 0, Green 0, Blue 0
40% - Red 0, Green 0, Blue 0
50% - Red 0, Green 0, Blue 0
60% - Red 0, Green 0, Blue 0
70% - Red 0, Green 0, Blue 0
80% - Red 0, Green 0, Blue 0
90% - Red 0, Green 0, Blue 0
100% - Red 0, Green 0, Blue 0
Custom Colour Space
RED - Red 43, Green 6, Blue 0
GREEN - Red 57, Green 48, Blue 7
BLUE - Red 0, Green 7, Blue 50
YELLOW - Red 52, Green 49, Blue 4
CYAN - Red 47, Green 6, Blue 0
MAGENTA - Red 30, Green 15, Blue 57
Daryl L and jer88 like this.
Lounge - Sony 65" A8F OLED, Pioneer SC-LX59 9.2 Receiver, Oppo UDP-203 UHD Blu-Ray Player, JBL Studio 180 Speaker Series, ELAC Debut A4 Atmos Modules setup as 5.1.4, Sony PS4 Pro, Logitech Harmony Elite. Bedroom - Samsung UA55C8000 3D LED, Sony PS3.
mc_avs is offline
post #19250 of 24074 Old 06-13-2016, 07:54 AM
TravisBean's Avatar
Quoted: 251 Post(s)
Liked: 301
So big brother Sammy is always watching ? Thankfully I don't have the JS9500 with a camera mounted on it.
post #19251 of 24074 Old 06-13-2016, 09:14 AM
neilometer's Avatar
Quoted: 14 Post(s)
I recall having a similar issue last year when I first got my TV. Also frustrating was not being able to choose which audio track it decided to play. I gave up on DLNA soon thereafter and bought an Nvidia Shield as my secondary HDMI 4k input. KODI isn't perfect, but it does alright.
neilometer is offline
post #19252 of 24074 Old 06-13-2016, 09:59 AM
bp787's Avatar
Quoted: 895 Post(s)
Liked: 620
you can just block the device at the router. or... don't enter the wifi information during setup.
Sony xbr65x850c Side Blooming test clips:
https://dl.dropboxusercontent.com/u/...br65x850c.xlsx
bp787 is online now
post #19253 of 24074 Old 06-13-2016, 10:04 AM
maddog510's Avatar
Quoted: 408 Post(s)
Liked: 90
My tv automatically updated to 1455 this morning. Anyone else receive the update yet?
maddog510 is offline
post #19254 of 24074 Old 06-13-2016, 10:07 AM
fmedrano1977's Avatar
Quoted: 410 Post(s)
Liked: 156
Been on that one for a few weeks now.
Sent from my HTC 10 using Tapatalk
fmedrano1977 is offline
post #19255 of 24074 Old 06-13-2016, 10:25 AM
TravisBean's Avatar
Quoted: 251 Post(s)
Liked: 301
Originally Posted by trailryder42 View Post
You misunderstand. Streamed content doesn't seem to work with the conversion. Only recorded material on USB, DVD and Blu Ray media in my experience.
Perhaps you misunderstood me. I have a Netflix enabled BL player plugged into HDMI 1 on the JS8500. When selecting HDMI 1 as the source, and Netflix is being output from the BL player, 3D is working just great while watching Netflix.
post #19256 of 24074 Old 06-13-2016, 12:21 PM
Quoted: 845 Post(s)
Liked: 364
You can get 4K HDR via the Samsung UHD Bluray Player K8500. The only app on the player that gives you HDR right now is Amazon. No updates or adapters are necessary. Just ensure that the HDMI cable is rated 2.0/18mbps. I hear the Amazon cables were fine.
65JS8500, P50-C1, K8500, SB3851 Soundbar
buju22 is offline
post #19257 of 24074 Old 06-13-2016, 12:50 PM
JGrana's Avatar
Quoted: 202 Post(s)
Liked: 123
I just checked. It was installed earlier today and said it wanted to restart the TV.
Did the power cycle - now on 1455 as well.
JGrana is offline
post #19258 of 24074 Old 06-13-2016, 02:18 PM
Quoted: 205 Post(s)
Liked: 269
Just updated now. Seeing anything noticeable? Only thing I noticed is I can fully control Amazon playback now!
Samsung 55" JS8500
7.1 Setup:
Onkyo TX-NR646, Chane A1.4 & A2.4 (LCR), Yamaha NS-IC600 surr, TDG Audio NFC-61 back surr, SVS SB-2000
Samsung K8500, Roku Premiere+ and Roku 2, Harmony 650
jfwilliams1 is offline
post #19259 of 24074 Old 06-13-2016, 02:27 PM
locob's Avatar
Quoted: 28 Post(s)
After numerous attempts to have "Auto Update - Update Now" to find and install the 1453 version (always told me there no updates), today it found and installed the 1455.
locob is offline
post #19260 of 24074 Old 06-13-2016, 05:28 PM
dlbsyst's Avatar
Quoted: 292 Post(s)
Liked: 176
It looks like a lot of us finally got our update today. I just got home from work, fired my set on and it said that an update(1455) was installed.
dlbsyst is offline
Reply LCD Flat Panel Displays
JS8500 , reflection , screen flashing black
