**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 648 - AVS Forum | Home Theater Discussions And Reviews
 9840Likes
post #19411 of 24128 Old 06-24-2016, 12:04 PM
JaytheDreamer's Avatar
Quoted: 237 Post(s)
Liked: 241
Originally Posted by tmdorsey View Post
Are you going to be viewing the set in a totally dark environment?
If not, I would say it wouldn't hurt to take a chance and see if you get a decent panel where 1-4 would be minimal issues.
As far as 5, my opinion is HDR10 is the standard so as long as that is supported you are ok. The margin of difference in PQ between the two is debatable. And if the 2015 sets get a firmware update for dynamic HDR10, the difference will probably be even that much smaller.
I know that's a big if but hopefully it would happen . No one is sure whether HDMI 2.1 needs a HW/Chip update or existing 2.0/2.0a ports cab be upgraded via firmware. But if it is possible our sets can be told as future-proof (I know nothing of that sort exists anymore) for at least few more years, especially with most of the content that would be coming out.
______________
Thanks, Jay
Spoiler!
JaytheDreamer is offline
post #19412 of 24128 Old 06-24-2016, 12:15 PM
turts85's Avatar
Quoted: 1028 Post(s)
Liked: 297
Originally Posted by turts85 View Post
Amazon has the 55" below 1200$ now...was thinking of swapping my 2016 Vizio P50 for this but am very worried about 1.) edge lit again 2.) blue light bleed 3.) light bleed in general. 4.) not fald 5.) not DV
well then that's a no go..thanks for the advice
turts85 is offline
post #19413 of 24128 Old 06-24-2016, 12:23 PM
tmdorsey's Avatar
Quoted: 471 Post(s)
Liked: 431
That seems strange to me that if dynamic HDR required hardware changes that the feature wouldn't be supported out of the box on the 2016 models.
tmdorsey is online now
post #19414 of 24128 Old 06-24-2016, 12:38 PM
Terry McLeod's Avatar
4K Blu ray player for this set
Will a 4K Blu ray player be a noticeable improvement in picture quality for this set? It's hard to imagine a better picture than my current player (3D Panasonic) after watching The Martian the other night?
Samsung UN65JS8500F
Samsung UBD-K8500 UHD Blu-Ray
HK 635 AVR
SVS PB10 sub, center channel, and 4 satellites
Terry McLeod is offline
post #19415 of 24128 Old 06-24-2016, 12:44 PM
tmdorsey's Avatar
Quoted: 471 Post(s)
Liked: 431
With HDR enabled, all signs point to yes. I don't have a 4K blu ray player as I've been getting away from buying and storing physical media, but that may change once the PS4 Neo is released.
King Richard likes this.
post #19416 of 24128 Old 06-24-2016, 01:18 PM
Quoted: 237 Post(s)
Liked: 241
Dynamic HDR
I also think it would be strange, but unfortunately the supposed HDMI 2.1 specs (which is required for the Dynamic HDR?) is still not clear about whether it needs a HW update or not. But there is a strong possibility that current HW would support it as Samsung seems to move in that direction already.
______________
Thanks, Jay
Spoiler!
post #19417 of 24128 Old 06-24-2016, 01:49 PM
Quoted: 237 Post(s)
Liked: 241
Rudy, that link is broken.
______________
Thanks, Jay
Spoiler!
post #19418 of 24128 Old 06-24-2016, 01:55 PM
Rudy1's Avatar
Quoted: 1971 Post(s)
Liked: 3274
Thanks, Jay...I'll try to find a better source.
JaytheDreamer likes this.
Definition of "Stupid": Knowing the truth, seeing the truth, but still believing the lies.
Rudy1 is offline
post #19419 of 24128 Old 06-24-2016, 06:41 PM
Lionheart of AVS
King Richard's Avatar
Quoted: 1797 Post(s)
Liked: 4368
Dynamic HDR
Everyone keeps regurgitating this "rumor" that Dynamic HDR10 will require an update/upgrade to HDMI 2.1
However, the truth is, we currently have no idea if Dynamic HDR10 will require an update to the HDMI ports, and if it does, we don't know yet if it will be in the form of a hardware upgrade or a simple firmware update. (Unless someone here knows something I don't.)
Furthermore, if it does require an HDMI port update/upgrade, we don't know what that will be (e.g. HDMI 2.0b; HDMI 2.1; HDMI 3.0) - although HDMI 2.1 does seem to be the most likely candidate from what I've been reading. However, it's mostly all speculation at this point.
All we know for sure is that it was said before (see video below) that Dynamic HDR10 would only require a firmware update on current Samsung TVs. How "credible"/"trustworthy" that info is, is anybody's guess.
Check out the video:
Richard
King Richard is offline
post #19420 of 24128 Old 06-24-2016, 06:53 PM
Lionheart of AVS
Liked: 4368
Just to add to this ^^^^^^^^^
A UHD/4K Blu-ray player (e.g. Samsung K8500) is a must to play UHD/HDR Blu-ray movies and videos since a regular Blu-ray player (including 4K upscaling ones) cannot play them. It can also stream UHD/HDR content as well.
That said, YES there is a noticeable quantifiable difference in picture quality between the two. Not only are you able to play native UHD/4K content, but, more importantly, you get HDR (High Dynamic Range), WCG (Wide Color Gamut), and Deep Color (10-bit) as well. All of which are far more noticeable than a simple resolution increase.
Richard
post #19421 of 24128 Old 06-24-2016, 09:58 PM
Liked: 0
Anyone knows if this TV (using HDMI 2.0) can support true 120hz input from a PC? Also at what resolution?
In theory it should, considering the panel can support 4K @120hz.
The HDMI 2.0 though can deliver 4K up to 60hz.
So the final question is can it do 1080p @120hz? Can someone confirm this?
stavari is offline
post #19422 of 24128 Old 06-24-2016, 10:15 PM
Lionheart of AVS
Liked: 4368
No, the JS8500 cannot do [email protected] It can only accept a 60Hz signal.
Richard
tmdorsey likes this.
post #19423 of 24128 Old 06-25-2016, 12:41 AM
TravisBean's Avatar
Quoted: 252 Post(s)
Liked: 303
Question:
My LN52B630 had a "safe remove USB/Hard drive" function under the tools option. Can't find it on the JS8500. Is there one ? One of my hard drives still remains on when turning off the JS8500. That same Hard drive will turn off when plugged into my LN52B630, if I select "safe remove Hard Drive" before I turn off the LN52B630.
TravisBean is offline
post #19424 of 24128 Old 06-25-2016, 05:19 AM
Quoted: 14 Post(s)
Liked: 4
Richard
Is it possibile to force [email protected] with Overlock? There are some program that force custom resolutions and custom hz
Drakas is offline
post #19425 of 24128 Old 06-25-2016, 07:54 AM
dlbsyst's Avatar
Quoted: 292 Post(s)
Liked: 176
Hit source on your remote, find your hard drive and hit down arrow. You have two options, information and remove USB device.
TravisBean and King Richard like this.
dlbsyst is offline
post #19426 of 24128 Old 06-25-2016, 08:09 AM
compnurd09's Avatar
Quoted: 188 Post(s)
Liked: 125
Originally Posted by Rudy1 View Post
I was told by Samsung engineers that they need to conduct extensive testing on the software packages from the streaming companies before they approve them for release to their devices. Things got complicated when they discovered issues with Netflix HDR titles and the 2016 TVs; those had to be resolved first, and now they're working on software for the 2015 models.
I wonder if we will see the new tizen at the same time
compnurd09 is offline
post #19427 of 24128 Old 06-25-2016, 08:34 AM
TravisBean's Avatar
Quoted: 252 Post(s)
Liked: 303
Works like a charm. Thanks alot.
post #19428 of 24128 Old 06-25-2016, 08:36 AM
Soccer1725's Avatar
Quoted: 77 Post(s)
Liked: 25
Originally Posted by mc_avs View Post
It is still a defect & would most definitely be ringing my extended warranty about it.
Well I'm glad I did something about it. I had Samsung come out and look at it. They ended up just replacing the panel. Wow, big difference. Not only did it fix the light bleed issue, the whole picture looks better. There was obviously more wrong with the panel than I could notice at the time. First time with Samsung customer service, thumbs up from me.
denpom, King Richard and mc_avs like this.
Denon AVR-X6200W w/5.2.4
Klipsch RP-260F, RP-440C, RP-250S, R-112SW, RP-140SA
LG OLED65C6P
Samsung UBD-K8500
Microsoft Xbox One
Apple iMac with Apple TV
Soccer1725 is offline
post #19429 of 24128 Old 06-25-2016, 10:42 AM
Liked: 0
I think HDR is the main discussion point now for JS8500, Some of the Android TV are getting HDR like Nvidia shield tv, Xiaomi Mi Box. If I play HDR content from these android TV like Netflix HDR will JS8500 support that HDR content?
Bourne51 is offline
post #19430 of 24128 Old 06-25-2016, 11:45 AM
Quoted: 845 Post(s)
Liked: 364
Simple answer, yes.
65JS8500, P50-C1, K8500, SB3851 Soundbar
Bourne51 likes this.
buju22 is offline
post #19431 of 24128 Old 06-25-2016, 12:04 PM
Quoted: 266 Post(s)
Liked: 249
Resetting TV following firmware update 1455.0
I have a quick question (for such a long-winded post) about resetting the TV since I've never had the need to do a factory reset in the 13 months I've owned my 65JS8500, but I may now have to do so following my latest firmware update. Question: Will unplugging the TV for a given length of time accomplish the same thing as going through the TV's factory reset menu option (MENU > SUPPORT > SELF-DIAGNOSIS > RESET)? The E-Manual states that the latter will reset everything to factory defaults except for network settings -- does simply unplugging the set from the wall outlet for X amount of time accomplish this too, or is it not as thorough of a reset (or not a reset at all)?
I hate like heck to go the factory reset route, but I think something might have gone awry during my latest firmware upgrade on June 14. I updated from an ancient year-old 1221.7 firmware version to the latest 1455.0 via USB (only reason for me wanting to perform this update was for the HDMI 2.0a capability Samsung released around November of last year to support the new K8500 player I'm thinking of buying), and following the update I immediately noticed that the picture was much darker with some black crush I'd never experienced before, and that some colors appear a bit overly saturated. With prior firmware updates, my set would reboot just once, but with this update it rebooted twice, with a 10-second or so delay between reboots. Just before the second reboot, the TV was fuzzy, reminded me of the good ol' days of rabbit ears and weak signals; I had a sickening feeling that the set was hosed, but just before the second reboot I saw that the activity light on my thumb drive was flashing, so I knew the TV was still accessing the drive and doing "something" with the firmware files on it. After the second reboot the PQ was greatly improved vs. the initial reboot, to my huge relief. All of my prior settings were retained except for my default audio delay of 0 -- the firmware reset it to 100 -- which was a simple fix. But the TV looks a lot darker overall now than before and some colors (especially red hues) are now on the over-saturated side, reminds me a bit of torch mode on store display models. Some cable channels are better than others, per usual, but I'm still not getting the overall PQ I'm used to (unfortunately I don't own a DVD player or gaming console to test other sources, just my Motorola QIP7232 DVR from Frontier Communications (formerly Verizon) which I rebooted to see if that would help, which it didn't; the cable is running directly from the OCM to the Motorola DVR, there is no intervening A/V receiver in the video mix since my old Pioneer receiver has no HDMI inputs and is strictly used for audio via a digital optical audio cable connection). As a matter of fact, when now viewed slightly off-axis (about 2'-3' from the left or right edge of the panel bezel), the TV looks like it did when viewed head-on prior to the update (weird!). But with this latest update, the head-on view is significantly darker and, for lack of a better description, has an "over-processed" appearance. I've fooled around with every conceivable picture setting the past 10 days, tried the Reset Picture option, and also searched for/found/tried the settings posted by forum members denpom, ERuiz, prme19, and King Richard (I prefer Standard mode, and feel that denpom's was the most suitable for my bright room), but things still look darker overall than before. I retained my backlight setting of 12 (tried 10 but it was too dark) and even though raising it beyond 12 does boost the overall brightness, the blacks in certain scenes still lack definition/detail, albeit they are now much blacker than before ("inky black" as denpom describes his). My initial contrast setting was at 100, but bringing it down to 90 still doesn't help provide definition to darker scenes.
I realize I'm in the minority when it comes to this latest 1455.0 update, everyone else has reported excellent PQ results from what I've read here, so I guess I'm the lucky one. As for what I plan to try next, I have a new HDMI 2.0 cable on order (I read that this one works good with the JS8500 and the K8500 player: http://www.amazon.com/HDMI-Cable-6ft.../dp/B00NQ9OQU2) since my current Belkin braided cable is at least 8 years old (http://www.belkin.com/IWCatProductPa...duct_Id=441602) and was rated at HDMI 1.3 at time of purchase. Moreover, the E-Manual recommends using a "High-Speed HDMI Cable" or "High-Speed HDMI Cable with Ethernet," so I'm hoping the newer cable might improve things when it arrives next week. I have not yet tried a different HDMI input on the OCM box since I thought I'd run this factory reset question by everyone first before crawling behind my AV furniture, plus the Sammy Set-Up Guide shows that set-top boxes should be connected to "HDMI In 1" on the OCM box.
Member "denpom" refers to those who see PQ improvements from firmware updates as experiencing the "placebo effect," but in my case I must be experiencing "reverse-placebo syndrome." Oh well, at least I planned ahead and wrote down all of my prior settings But those settings are no longer cutting it after this update, and I can't seem to get this thing dialed in to an acceptable level (the TV has looked freakin' OUTSTANDING for the past year), so I hope a factory reset -- or something less Draconian such as the new cable and/or HDMI input swap -- does the trick. Other than that, I guess I just have to wait for another firmware update and see if that helps things look closer to the way they did before.
4K Tech is offline
post #19432 of 24128 Old 06-25-2016, 12:32 PM
TravisBean's Avatar
Quoted: 252 Post(s)
Liked: 303
Speaking of HDMI cables, I thought they were all pretty much the same. I bought 2 decent quality ones back in 2010 for my pre-3d era LN52B630, which works great with my older Insignia BL player and the new JS8500. I'm planning on buying a Sony 3d BL player. Do I need new HDMI cables ?
post #19433 of 24128 Old 06-25-2016, 04:19 PM
Lionheart of AVS
Liked: 4368
As long as they are "High-speed" "Category 2" cables, you are good-to-go.
Richard
dlbsyst and porkchop999 like this.
post #19434 of 24128 Old 06-25-2016, 04:40 PM
Lionheart of AVS
Liked: 4368
Wow, that was quite the read
You can always try to reboot the TV first (even though I doubt it will do anything). Turn OFF the TV, unplug it from the wall, then with it still unplugged hold down the power button for 10+ sec, then plug it back in and reboot it.
If that doesn't help, you can try a "factory reset".
If that still doesn't help, you can try to adjust all your settings again from "scratch" (you can use my picture settings guide).
Sometimes (but not often) a new firmware update CAN make changes to picture/calibrated settings (and not always for the best unfortunately).
Good luck!
Richard
post #19435 of 24128 Old 06-26-2016, 12:24 AM
Quoted: 266 Post(s)
Liked: 249
Good luck!
Richard
Thanks for the reboot tip and other suggestions Richard, I'll give them a shot and keep my fingers crossed. I expect the new cable to arrive in a couple of days, so I'll probably hold off 'til then in order to have the replacement cable in hand to see if that makes a difference in PQ as well. Worst case scenario would be to just wait patiently for another firmware update (and hope for the best).
And yeah, that last post of mine puts "War and Peace" to shame as far as word count goes. Thanks for slogging through it to the bitter end!
4K Tech is offline
post #19436 of 24128 Old 06-26-2016, 01:33 AM
mc_avs's Avatar
Quoted: 307 Post(s)
Liked: 310
Good to hear that you got them out & they fixed your problem with no back & forth between Samsung. Hopefully you can start to enjoy your TV!
Theatre - Sony 65" A8F OLED, Pioneer SC-LX59 9.2 Receiver, Oppo UDP-203 UHD Blu-Ray Player, JBL Studio 180 Speaker Series, ELAC Debut A4 Atmos Modules setup as 5.1.4, Sony PS4 Pro, Logitech Harmony Elite.
mc_avs is offline
post #19437 of 24128 Old 06-26-2016, 01:35 AM
mc_avs's Avatar
Quoted: 307 Post(s)
Liked: 310
Definitely a long read bud but nothing wrong with that, that's we are all here for, to help.
Have you got any decent True 4K Demo's on a USB drive that you can test on the TV to see what the PQ looks like?
mc_avs is offline
post #19438 of 24128 Old 06-26-2016, 08:23 AM
JPHCCFC's Avatar
Quoted: 62 Post(s)
Has anybody experienced issues with YouTube not loading videos? I regularly have to reinstall the YouTube app to get it to play videos again. It's happening literally every day now. I'm running v3.00001
Sent from my SM-N910W8 using Tapatalk
JPHCCFC is offline
post #19439 of 24128 Old 06-26-2016, 11:53 AM
Quoted: 108 Post(s)
Liked: 55
Richard
I want to be sure I understand. A 4k Blu Ray is UHD. So is WCG and 10 bit color a part of the 4k standard and every 4k disc will have it?
Then you have HDR. Whether a 4k Blu Ray is also HDR or not depends on the content doesn't it? Whether it was shot in HDR or not?
With all the latest new movies also being released in 4k now, I'm trying to decide if I should start making any new purchases in the 4k format and buy a 4k player. From what I understand, both the Samsung and Panasonic players will also play regular Blu Rays, DVD and also Blu Ray 3D. Can anyone verify that they properly decode and display 3D content? I ask because I like 3D and buy movies in that format when I can and a new player would be replacing my current Panasonic 3D Blu Ray player.
I think I've also read that there will be no 4k 3D.
I saw a YT video a while back that explained why 1080P Blu Rays look so good up-scaled on a 4k tv. They really do look great on my 55"er. I've seen the short HDR clips referenced in the forum here and they look fantastic. Is that what you can expect from a 4k UHD HDR Blu Ray?
I guess I need to go see if Best Buy has a display playing 4k UHD HDR Blu Ray content.
trailryder42 is offline
post #19440 of 24128 Old 06-26-2016, 12:22 PM
denpom's Avatar
Quoted: 1326 Post(s)
Liked: 1180
no problems here. i also cast videos to the native YouTube app from my phone all the time without any troubles.
JPHCCFC likes this.
denpom is offline
Reply LCD Flat Panel Displays
JS8500 , reflection , screen flashing black
