**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 810 - AVS Forum | Home Theater Discussions And Reviews
 10053Likes
post #24271 of 24313 Old 05-24-2020, 06:54 PM
RYANtheTIGER's Avatar
Quoted: 312 Post(s)
Liked: 38
Originally Posted by mc_avs View Post
I thought that's what you were talking about. It's to get the full range/bandwidth of the HDMI input to be able to take the HDR signal, not all your HDMI inputs can do the full range from memory, think it's only 1 & 2.
By the way, here are the 4 inputs:
Sent from my iPhone using Tapatalk Pro
wraithrsw and mc_avs like this.
RYANtheTIGER is offline
post #24272 of 24313 Old 05-24-2020, 08:14 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
Cool, I couldn't quite remember, I only used 1 & 2 when I had that set.
Theatre - Sony 65" A8F OLED, Pioneer SC-LX59 9.2 Receiver, Oppo UDP-203 UHD Blu-Ray Player, Klipsch R820F Fronts, Klipsch R-52C Centre, Klipsch R-51 Surrounds, Klipsch R-100SW Sub x2, ELAC Debut A4 Atmos Modules setup as 5.2.4, Sony PS4 Pro, Logitech Harmony Elite.
mc_avs is offline
post #24273 of 24313 Old 05-29-2020, 01:35 PM
locob's Avatar
Quoted: 31 Post(s)
Originally Posted by locob View Post
I've been following this thread since it's inception and I don't remember any posts with the issue I am suddenly having with my JS8500. Until about a week ago I have had no problems with this TV. Now, whenever I turn the set on, the video and audio of the input displaying will shut off after about 30 seconds. It's not a backlight or similar issue because if I call up any of the setting menus, they display on the now black and silent screen as they always do. I first though it might be an issue with my cable box or connections as this is the usual input that is started on the TV. I swapped HDMI cords and inputs on the mini-box with no joy. I next set the TV up to use the over-the-air input at startup and this still happens. I would guess that eliminates the mini-box as the over-the-air antenna connects directly to the TV. I have found that after the initial input goes out, if I then change to a different input (antenna or different HDMI input), that input displays as normal and will have no more issues for the length of my viewing. If I switch back to the first input that went out, after changing to another, the first input now stays on for the rest of my viewing. But next time I turn the TV on from off the issue happens every time whether I shut off and turn back on immediately or wait until the next day. I have alway kept the fast start setting turned off. I have tried removing power from the set for awhile and still no joy. Any ideas?????
First, thanks for all the suggestions for a fix. While I replied that I would endeavor to try them all, I must admit I have been lazy and just not got around to any of them. I had to remove the set from power, etc. for a 24 hour period while carpet was being replaced in the room. Since hooking everything back up, the issue has gone away. I'll file those suggestions away in case it should return.
Thanks to all again!
TravisBean likes this.
locob is offline
post #24274 of 24313 Old 06-03-2020, 08:24 PM
TravisBean's Avatar
Quoted: 261 Post(s)
Liked: 328
Been watching the new Star Trek: Picard series in 2d to 3d mode on the JS8500. Simply stunning.
wraithrsw likes this.
TravisBean is offline
post #24275 of 24313 Old 06-03-2020, 08:28 PM
wraithrsw's Avatar
Quoted: 60 Post(s)
Liked: 74
Ooh man, I always wondered how it'd look in converted 3D. Now if only CBS will release it in 4K!
KDL40S2000 (still in use), UN55D7000 (10+ dead pixels, returned), TC-L32DT30 (still in use), KDL55HX820 (sold), 55JU7500 (cracked screen OOB, returned), 55JS8500 (light bleeding, returned after shady dealing by Samsung which involved BBB), OLED65C9PUA
Denon X1600H, Klipsch R-26FA x2, SVS PB-1000, Paradigm SE 2000C, Dayton B652-Air (surrounds).
wraithrsw is offline
post #24276 of 24313 Old 06-11-2020, 06:33 AM
ChoarBoy's Avatar
Has anyone hooked up the new Sonos Arc to the js8500 yet? Curious to see how its working with this exact tv with and without devices like apple tv/xbox one x
ChoarBoy is offline
post #24277 of 24313 Old 06-15-2020, 09:12 AM
Liked: 1
Contrast Issue?
Hi All. I have had this TV for 3 years now and haven't really had any issues (other than some light bleed from the edge) until now. Recently I noticed that the picture was way bright so I thought one of my kids messed with the settings I had. The settings were unchanged though and upon further review, it seemed like the contrast was way higher than it should be (maybe contrast/brightness combo) but it wasn't shown in the menu. Messing with these got me a decent picture but it was still not great. So I factory reset the TV and it all went back to how it was, even after I tweaked the settings again. But this now seems like a weekly or sometimes daily occurrence and sometimes even just turning the tv off and on will resolve it, but then again it may be only for a certain amount of time.
Has anyone seen anything similar to this with their TV or even another model? I am thinking I may need to have it repaired at this point. Maybe I am missing a setting that is causing this but I doubt any setting would make the picture look that bad. Thanks.
Justin Gross is offline
post #24278 of 24313 Old 06-15-2020, 01:42 PM
wraithrsw's Avatar
Quoted: 60 Post(s)
Liked: 74
It probably needs repairs if it keeps doing this. That you also have light bleed is also a big red flag. If you can get it repaired do it soon. If not, you may need to get a new TV because that light bleed will creep more and more towards the center of the screen (in which case you'll have to deal with either Samsung reps for a pro-rated refund aka their attempts to avoid a class-action suit or your extended warranty for money to put towards a new TV).
ChoarBoy, TravisBean and mc_avs like this.
post #24279 of 24313 Old 06-15-2020, 03:13 PM
Quoted: 40 Post(s)
Liked: 24
Prime Video and UHD since the 1550 firmware update
Over the past few weeks, maybe since the latest firmware update I am no longer able to play UHD or HDR with Prime Video on the JS8500. I have a 600 MBPs down connection and the tv is wired via ethernet. Netflix plays HDR and UHD perfectly fine. Prime video plays everything else quickly up to 1080p but never switches to HDR or UHD. I know how to find the sometimes hard to find UHD versions of tv shows and movies on Prime. For any other devices such as a 4k player (wired) and another 4k tv (wireless) play UHD/HDR fine and ok so it's not my network. I found on another Samsung forum that they had the same problem since the latest firmware update to 1550. I'm assuming it's either the firmware or the Prime video app
sven98 is offline
post #24280 of 24313 Old 06-16-2020, 02:57 PM
Quoted: 312 Post(s)
Liked: 38
Can all 4 HDMI ports receive 4K? Or is it just certain ones?
post #24281 of 24313 Old 06-16-2020, 03:16 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
All 4 HDMI Ports are 4K.
mc_avs is offline
post #24282 of 24313 Old 06-16-2020, 03:23 PM
Quoted: 312 Post(s)
Liked: 38
That’s what I thought but when setting up my XBOX, it tested for 4K UHD and said it didn’t work.
post #24283 of 24313 Old 06-16-2020, 03:27 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
You will need to go into the HDMI settings & change that HDMI to "UHD Colour" (I think that's what it's called), try that & it should work from memory.
mc_avs is offline
post #24284 of 24313 Old 06-16-2020, 03:48 PM
Quoted: 312 Post(s)
Liked: 38
By changing this:
MALICIOUS ONE and mc_avs like this.
post #24285 of 24313 Old 06-16-2020, 03:50 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
By changing this:
Yep that's the one.
mc_avs is offline
post #24286 of 24313 Old 06-16-2020, 04:56 PM
Quoted: 312 Post(s)
Liked: 38
Yep that's the one.
Still no luck. When I select “Info” from the “Menu”, It looks like HDR is working but the resolution is 1080P.
post #24287 of 24313 Old 06-16-2020, 05:00 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
Sounds more like an issue with the XBox & it's resolution settings. Are you playing a game or streaming media?
MALICIOUS ONE likes this.
mc_avs is offline
post #24288 of 24313 Old 06-17-2020, 11:15 AM
MALICIOUS ONE's Avatar
Quoted: 57 Post(s)
Liked: 65
Go to the Xbox "Settings" app. Under "General" tab select "TV & Display Options". See the "Display" tab & change "Resolution" to "4K UHD".
Then under "TV & Display Options" select "Advanced" tab that has "Video Modes" & select it. Put check marks beside the following selections: "Allow 50Hz, Allow 24Hz, Allow 3D, Allow 4K, Allow 4K HDR10".
Do NOT select "Allow YCC 4:2:2"! (It adds banding on our TV's & is only really for older TV's)
Next in the settings app, under "General" tab select "TV & Display Options" advanced tab select "Video fidelity & overscan". Make sure display is on "Auto-detect", have color depth at 24 bits per pixel (8bit), & color space at "Standard". (Yes, I know this TV is a 10bit TV. SDR games are 8bit & you are just adding processing by using 10bit setting on 8bit SDR games. If it is a 10bit game it will switch to HDR 10bit automatically.)
Here is a link to a good thread for any gamers. (XBOX/PS4/Switch Signal Analysis + Optimal XBOX Settings: Color Depth, Space, 4:2:2)
https://www.avsforum.com/forum/94-ho...l#post58084142
Samsung UN65JS8500/Samsung UBD-K8500/Outlaw 5000 amp/Onkyo TX-RX830 using 7.2.4/Xbox One X w/Kinect
XBL Gamertag: MALICIOUS ONE
MALICIOUS ONE is offline
post #24289 of 24313 Old 06-25-2020, 01:30 PM
jala12's Avatar
Quoted: 18 Post(s)
Wait, so if I have my UHD player set to HDMI 3 are you telling me that I'm still not getting full range even if UHD Color is on?
Also on a separate note, is it recommended that I keep sharpness at 0 for display settings?
jala12 is offline
post #24290 of 24313 Old 06-25-2020, 02:13 PM
Hyrax's Avatar
Quoted: 172 Post(s)
Liked: 79
I believe you need to turn on UHD color or something for each port. I've not looked at the settings for almost 5 years, so I forget where you do it.
Also, on another topic, I need a bigger TV so I am replacing my JS-85000 with a Q90R. The new TV is great, but I had to watch the 3D movies I own one last time. I hardly ever watched 3D movies (those glasses on top of my prescription glasses never were very comfortable), but it pisses me off that there are no new TVs that support it anymore. How could they do that to us?
Hyrax is offline
post #24291 of 24313 Old 06-25-2020, 04:52 PM
mc_avs's Avatar
Quoted: 337 Post(s)
Liked: 363
If you have UHD Colour on for the HDMI Input your 4K Player is connected too, you are fine & getting the full bandwidth.
mc_avs is offline
post #24292 of 24313 Old 06-25-2020, 06:38 PM
poppagene's Avatar
Quoted: 902 Post(s)
Liked: 836
All the HDMI ports are fine with UHD color
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #24293 of 24313 Old 06-26-2020, 04:49 AM
bp787's Avatar
Quoted: 948 Post(s)
Liked: 653
because there is one guy who watches 3d movies, and he's only in this thread. The market dictates features, and it's apparently not very popular.
Sony xbr65x850c Side Blooming test clips:
https://dl.dropboxusercontent.com/u/...br65x850c.xlsx
bp787 is offline
post #24294 of 24313 Old 06-26-2020, 10:46 AM
Quoted: 312 Post(s)
Liked: 38
OK so I couldn't get past Step 1 of ... Go to the Xbox "Settings" app. Under "General" tab select "TV & Display Options". See the "Display" tab & change "Resolution" to "4K UHD". When I selected 4k UHD for Resolution, the screen goes black for several seconds and then I receive this:
post #24295 of 24313 Old 06-26-2020, 12:27 PM
Quoted: 57 Post(s)
Liked: 65
"4K TV details" in that picture you provided will tell you what the TV can do or what your HDMI cables can do.
On the Xbox settings, I would make sure to go to advanced "Video fidelity & overscan" & make sure that display override is "Auto-detect" (Recommended) instead of HDMI or DVI. If you try to override it to HDMI it doesn't work right for some reason. At this point, I am thinking your using a HDMI cable that's 1.4 instead of an updated 2.0 that is needed for the Xbox One X 4K HDR or you are running it thru a 1.4 & not 2.0 receiver maybe? Everything should be have a green check mark except "Dolby Vision" if the chain is right & you turned on "HDMI Deep Color" on the HDMI port on that "4K TV details".
post #24296 of 24313 Old 06-26-2020, 08:15 PM
Quoted: 312 Post(s)
Liked: 38
When I clicked on "4K TV Details", everything was checked green except for "Your TV setup doesn't support Dolby Vision". I then went and double-checked to make sure that Overrides was set to "Auto-Detect" (and it was).
Any idea what might be wrong?
post #24297 of 24313 Old 06-26-2020, 09:03 PM
Quoted: 38 Post(s)
JS8500 does not support DV. It was made before DV was introduced
I now have an OLED TV. I honestly don’t think Dolby Vision is any better than standard HDR....at least to me
timkwong2 is offline
post #24298 of 24313 Old 06-26-2020, 09:10 PM
Quoted: 57 Post(s)
Liked: 65
When I clicked on "4K TV Details", everything was checked green except for "Your TV setup doesn't support Dolby Vision". I then went and double-checked to make sure that Overrides was set to "Auto-Detect" (and it was). Any idea what might be wrong?
Are you using 2.0 HDMI cable? What does it let you select or check mark under "advanced" then "video modes"? Also, just add me on Xbox Live. GT: MALICIOUS ONE (It's in my signature too) & we could just party chat thru Xbox instead of going back & forth here.
post #24299 of 24313 Old 06-27-2020, 09:04 AM
Quoted: 312 Post(s)
Liked: 38
These are the https://www.monoprice.com/product?c_...seq=1&format=2 I have.
And when I click on “Advanced” > “Video Modes”, this is what I see:
post #24300 of 24313 Old 06-27-2020, 09:49 AM
Quoted: 57 Post(s)
Liked: 65
It's just the dashboard UI then that is only 1080p & will not let you select 4K UHD resolution. Games & apps will do 4K HDR correctly since you have the check marks on the video modes screen & your 4K TV details are good. I don't know why you are not able to select 4K UHD for the dashboard resolution. I am able to select 4K UHD. Everything looks good & yet makes no sense why you are not able to select 4K UHD for the dashboard resolution.
Maybe do a hard restart of the Xbox or a total reset the console, if 1080p instead of 4K dashboard bothers you to see if that maybe fixes it. You can always press the TV info button to let you know the resolution you are getting at any time & even see if game mode is on/off or HDMI UHD color is on for that HDMI port.
Reply LCD Flat Panel Displays
JS8500 , reflection , screen flashing black
