2015 Samsung SEK-3500U/ZA Evolution Kit - Page 430 - AVS Forum | Home Theater Discussions And Reviews
 13397Likes
post #12871 of 23784 Old 12-27-2015, 01:00 PM
Martinuz's Avatar
Quoted: 59 Post(s)
Originally Posted by THXTEX1 View Post
Hallo
I have bought a SEK-3500 for my F9000. Do i need different picturesettings for the new box or can I use the same as for the old OCB.
BTW: Bought the SEK from Amazon.de and the F9000 was bought in Denmark where i'm from.
Same here, f9000 with sek3500. I started with the old one and then adjusted with settings from p5brown. It all about what you like. You also had the 2500?
Martinuz is offline
post #12872 of 23784 Old 12-27-2015, 02:38 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
Originally Posted by priuscat View Post
Probably because upsample is not the same as pure 4K. And it's not unique with the Roku 4, like I said earlier, My Tivo also exhibits the same phenomenon.
I have 30 days to return my Roku 4 and may do that if I can't get an answer this week. I believe it is a 60hz problem with the Samsung. The new 4K Fire TV is supposed to be getting Ultraflix and outputs 4k 30HZ so turning off or customizing Auto Motion should be possible with 4K Fire TV.
priuscat likes this.
Samsung UN65F9000, SEK-3500
Samsung UBD-K8500, Oppo BDP-105D
atodzia is offline
post #12873 of 23784 Old 12-27-2015, 03:26 PM
Liked: 0
Hi guys
For those with previous year model's, did the processor upgrade reduce your input lag?
PVRON is offline
post #12874 of 23784 Old 12-27-2015, 05:30 PM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
My AMP works with the Roku 4 on HDMI 2
korsjs and priuscat like this.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
post #12875 of 23784 Old 12-27-2015, 05:30 PM
dfran1's Avatar
Quoted: 68 Post(s)
Liked: 40
Originally Posted by PVRON View Post
Hi guys
If your talking about game lag = same or a tad better
If your talking about the voices not matching the mouths = perfect now using the ARC to receiver
If not one of them, please specify what lag you mean.
Samsung UN60HU8500FXZA With SEK-3500
dfran1 is offline
post #12876 of 23784 Old 12-27-2015, 05:38 PM
THXTEX1's Avatar
Quoted: 42 Post(s)
Liked: 25
@Martinuz . Thanks. No, I skipped the 2500. Could you point me to @p5browne settings. Can't seem to find it using search.
UE55F9005 - SEK-3500U/ZG
OPPO UDP-205EU
ROTEL RB980 + RB985 poweramps
Miller & Kreisel MP150 + S150T speakers + 2 V12 subs
THXTEX1 is offline
post #12877 of 23784 Old 12-27-2015, 05:41 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
Thanks for that info. Maybe it's just the first year (F9000) Samsung 4K TV's that don't. You have your Roku display setting at 4K? I will have to call Samsung in the morning.
atodzia is offline
post #12878 of 23784 Old 12-27-2015, 06:47 PM
ahro's Avatar
Liked: 4130
Roku 4 display setting at 4K 10 bit on my HU9000.
korsjs, atodzia and priuscat like this.
HENRY
ahro is offline
post #12879 of 23784 Old 12-27-2015, 06:55 PM
Rudy1's Avatar
Quoted: 1960 Post(s)
Liked: 3259
NEW VERSION OF VIMEO APP available...
with several new 4K titles, including the perfect video for many who wanted a red Corvette for Christmas but didn't get it: Kajira 4K
Rudy1 is offline
post #12880 of 23784 Old 12-27-2015, 07:32 PM
Liked: 0
I am talking about game lag. How much improvement, in ms, did you experience with the upgrade?
I am thinking of buying JS9000 but the SUHD have horrible lag in PC mode. I am just wondering if future upgrade would bring it down to a reasonable level. ATM, I guess the improvement from SEK3500 on previous model is the most reasonable estimate on potential improvement for JS9000.
PVRON is offline
post #12881 of 23784 Old 12-27-2015, 08:36 PM
Liked: 0
I'm having an issue since I got the SEK-3500 where most of the functions on my remote stop working (both egg remote and the one that comes with the SEK)
the touch sensitive part no longer works and I can't use any buttons except for source/menu etc.
Can't go up/down or choose any options. Have to power down the tv and remove the power cord for it to start working again. Possibly an bug with the Tizen OS? Anyone else had this issue.
Hayaeti is offline
post #12882 of 23784 Old 12-28-2015, 03:04 AM
dfran1's Avatar
Quoted: 68 Post(s)
Liked: 40
Sorry, I used my eyes (and feeling), not any testing equipment.
Though I think I read someone here did test for this.
Hopefully someone will chime in with some measured tests for you.
Copy all your settings now (if any, all picture, apps, etc....)
You need to factory default the unit. (at least it worked for me, when I was getting weird problems)
In this order
1 - Menu , Smart Hub, reset Smart Hub
2 - Support, Self Diagnosis, Reset
Now see if your problem goes away before you restore all your settings and stuff, If not I you do this again BUT now don't accept the terms and unplug the 3500, put your original back or if like mine (its built in my TV so no other connect) and reset that first (same as above), do a evolution kit backup, then put back your 3500, of course don't forget to power off the TV and unplug it waiting for the LED to go out on the TV before unplugging or inserting the 3500.
Let us know how goes.
dfran1 is offline
post #12883 of 23784 Old 12-28-2015, 07:13 AM
rlb
rlb's Avatar
Quoted: 2250 Post(s)
Liked: 1900
It's always questionable if any other set's calibration settings will be better on your set than default settings. There is no question about the fact that they will not be optimal (only optained by a metered calibration).
But, I believe you have the F9000 and p5browne has the HU9000. Therefore it's highly doubtful that his settings would be right for your set.
I used the CNET recommended settings for the F9000 and also found them excellent (vs the default) for use with the SEK2500. I did not install the SEK3500 on the F9000 because its strictly used now in the basement by visiting grandchildren; but I definitely would have started off trying the CNET settings with the SEK3500.
My recommendation would be to try the settings you have always used. Then try the "default" that came with movie mode on the set. See which of these two you prefer. I doubt that you will find recommended settings for the combination of the F9000 and SEK3500. If you do, you can always try/compare them (doesn't take more than 20 minutes) for their grayscale and colors. Of course, contrast, brightness and b/l should always be set specifically for your environment.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #12884 of 23784 Old 12-28-2015, 07:17 AM
p5browne's Avatar
Quoted: 3994 Post(s)
Liked: 3169
Dec 25, 2015: New August 2015 SEK-3500U installation - FW 1290.4 / 1440.4
Calibration Results: Samsung UN65HU9000 - November 2014 build. GFP9 Chipset US02 Panel
Calman 5.6.1 Beta Build # 2218 Meter: i1Display Pro profiled off i1Pro2
Radiance XE-3D Pattern Source
dE: CCT Avg dE Max Color dE Avg dE Max Room Temp: 62F
Mode: Movie
Backlight: 8
Contrast: 92
Brightness: 45
Sharpness: 0
Colour: 50
Tint: 50/50
Gamma: -1
Warm2
Smart LED: Standard
BDWise: Off
AMP: Off
UHD Colour: OFF HDMI 1, 2 and 4 ON: 3
Audio: HD On
Color Space: Custom Color
White Balance 2 Point: R / G / B Offsets: Gains
-7 / -6 / -8 : -2 / 0 / +3
Service Menu WBs: R / G / B Offsets : Gains
128 / 128 / 128 : 128 / 128 / 148
10 Point with Color Space on Native: R / G / B
10%: +7 / +20 / +4
20%: -6 / +3 / +3
30%: 0 / 0 / 0
40%: +4 / +2 / +8
50%: +12 / +7 / +14
60%: +5 / +3 / +12
70%: +7 / +5 / +8
80%: -2 / -5 / +1
90%: +6 / 0 / 0
100%: 0 / 0 / 0
Colour Space: Calibrated Custom Color R / G / B
Red: 48 / 0 / 2
Green: 4 / 47 / 3
Blue: 0 / 2 / 44
Yellow: 51 / 48 / 4
Cyan: 3 / 48 / 49
Magenta: 48 / 2 / 46
Dynamic Contrast: Off
Black Tone: Off
Flesh Tone: 0
RGB Only Mode: Off
Notes: Before changing any values in the Service Menu, write down the Original Values!
Use the MENU key to backout of any areas. DO NOT Use the Left or Right Key except to change values!!
Set to All Sources - Check your Inputs and Modes and change their settings if Samsung missed.
(This means the Apps, TV, USB, etc other Inputs and Modes)
Remember, my UN65HU9000, my room and lighting conditions. Calibrated in a darkened room.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #12885 of 23784 Old 12-28-2015, 07:18 AM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
Sounds more like a Sammy issue. I got the same results.
edit: Checked the same settings on my Tivo Bolt got the same results. so probably not a Roku 4 issue.
edit again: Checked Netflix on TV app with TV on the OTA source then on Tivo Source got Netflix Auto Motion to custom ok there, but when I went to my Tivo and played Netflix there Auto Motion was grayed out (Tivo on 2160P)
Spoke to Samsung support and they were of no help. 'If that's what it does then that's the way it is'. I also posted the same question to their FB support page which I have had better luck with in the past. At the moment it's looking like the Roku 4 will be returned. Except for the Auto Motion issue I really liked the Roku 4. I will try 4K Fire TV which will get Ultraflix sometime soon, or Nividia Shield, which has Ultraflix now. I think the Fire TV has a better search option across the different movie services. All this tech is changing and with that in mind perhaps spending $99 or Fire TV is better than $199 on Nividia Shield, especially since I am not a gamer.
atodzia is offline
post #12886 of 23784 Old 12-28-2015, 07:26 AM
Ted99's Avatar
Quoted: 969 Post(s)
Liked: 435
Roku 4 display setting at 4K 10 bit on my 8550 with SEK 3500
JVC RS600 Chad-callibrated, 120" 1.3g in Batcave HT, Denon X8500 Polk LSiM703 fronts,
RTi-12 rears, LSiM 706 center, Monitor 40 Heights, Monitor 60 FW, FXiA4 Bi-pole sides,
LSiC CH, Infinity 6" VOG. 4X 12" subs w/mini DSP on sub 1 and nearfield 18" from sub 2.
Ted99 is offline
post #12887 of 23784 Old 12-28-2015, 07:49 AM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
Can you check your Auto Motion Plus setting to see if you can change it, or is it locked at the Standard setting with the Roku 4 on.
atodzia is offline
post #12888 of 23784 Old 12-28-2015, 08:08 AM
Quoted: 12 Post(s)
Liked: 5
Upgraded UN65F9000 with SEK-3500 - Now all HDMI is green!
Hello,
I recently upgraded my UN65F9000 with the SEK-3500U. I was on the latest firmware (2112) on the original oneconnect. The upgrade appeared to complete successfully, however, now everything that is connected through HDMI is a bright green color. Any images that stream directly to the TV work correctly.
One strange thing is that any time I power on and off the TV, the picture mode shows as "Entertain", but when I look at the options, I only have Dynamic, Natural, Standard and Movie.
I am able to correct the bright green color by going in the picture mode menu choosing one of the other options (ie; natural) and then going into the HDMI black level menu. I dont even need to change anything in there. Just by going into the menu, the green color is corrected. This lasts until I power off the TV. Once I power back on, I need to redo these settings.
I have been through numerous Samsung remote support sessions, but so far no answers. Has anyone else heard of this issue? If so, any suggestions on how to fix it?
Any help would be greatly appreciated!
Dave
djhouck3 is offline
post #12889 of 23784 Old 12-28-2015, 08:20 AM
Sparty1020's Avatar
Quoted: 257 Post(s)
Liked: 51
To those who got the SEK3500 during the holiday season. What are your thoughts and impressions? Worth the upgrade?
It seems that with updates the old OCB is catching up in picture quality. Just trying to figure out if it's still worth the upgrade or not.
Sparty1020 is offline
post #12890 of 23784 Old 12-28-2015, 08:24 AM - Thread Starter
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
Originally Posted by djhouck3 View Post
Hello,
Dave
Yup, I had the same issue with my Roku or my networked media tank connected via HDMI. I was able to correct this issue by selecting Menu>Picture>Entertain>Dynamic>Picture reset.
Doing this caused my Tivo which worked normally to now exhibit a purple color. Turning the TV off then back on resulted in my Tivo reverting back to normal settings. I could also do the Menu>Picture>entertain>dynamic>Picture reset function but I'm to lazy, turning the TV off then back on is quicker.
Other than what I just suggested, sadly there is no fix for this issue.
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #12891 of 23784 Old 12-28-2015, 08:33 AM
Quoted: 12 Post(s)
Liked: 5
Thanks, Priuscat! If there is no long term fix, I may be forced to revert back to the original oneconnect. Any idea why this occurs on some TVs and not others? It does seem like some people have had success with the F series and the SEK-3500. It certainly seems like a software issue. Frustrating that it does not save the settings.
djhouck3 is offline
post #12892 of 23784 Old 12-28-2015, 11:58 AM
Quoted: 22 Post(s)
Liked: 2
Mode: Movie
Backlight: 8
Contrast: 92
Brightness: 45
Sharpness: 0
Colour: 50
Tint: 50/50
Gamma: -1
Warm2
Smart LED: Standard
BDWise: Off
AMP: Off
Audio: HD On
10%: +7 / +20 / +4
20%: -6 / +3 / +3
30%: 0 / 0 / 0
40%: +4 / +2 / +8
50%: +12 / +7 / +14
60%: +5 / +3 / +12
70%: +7 / +5 / +8
80%: -2 / -5 / +1
90%: +6 / 0 / 0
100%: 0 / 0 / 0
Red: 48 / 0 / 2
Green: 4 / 47 / 3
Blue: 0 / 2 / 44
Yellow: 51 / 48 / 4
Cyan: 3 / 48 / 49
Black Tone: Off
Flesh Tone: 0
RGB Only Mode: Off
The last sentence is fair - it is your unique display. Replication on another LCD display - as unique as yours - doesn't bring the same results in most cases.
celestica likes this.
Marco01 is offline
post #12893 of 23784 Old 12-28-2015, 12:48 PM
rx3
rx3's Avatar
Quoted: 95 Post(s)
Liked: 27
Yes! This has happened to me and it's annoying. I too have to unplug.
rx3 is offline
post #12894 of 23784 Old 12-28-2015, 12:48 PM
Quoted: 182 Post(s)
Liked: 37
Bad news for anyone using the iscan mini and a dtv 4k box. For some reason the 4k box does not recognize that the tv can support 4k and won't let you check mark that resolution. Took the mini out and recognizes it fine. Looks like I'll have to permanently get rid of the mini which sucks because I really enjoy the enhancements.
robjwilkins is offline
post #12895 of 23784 Old 12-28-2015, 01:16 PM
p5browne's Avatar
Liked: 3169
My settings work on my set in my room.
Some whom have tried them, found the results better than they had, others virtually no change and others, not so good.
To everyone who decides to try, WRITE DOWN your Original values first, or take a photo. This goes with trying anyone else's settings, whether they be mine, CNET's or other Member's or non Member's.
You Brick it, it's in your hands, not mine! (If you're married, it can be a double whammy!)
Marco01 likes this.
UN65KS9800 - Mine
p5browne is offline
post #12896 of 23784 Old 12-28-2015, 01:27 PM
dfran1's Avatar
Quoted: 68 Post(s)
Liked: 40
Hello,
Dave
All this stuff is a computer, and beings samsung's own OS, I would try a factory reset listed below and if that does not work then follow the 2nd option. (please read all before doing)
Copy all your settings now (if any, all picture, apps, etc...., or take pictures)
In this order
Now see if your problem goes away before you restore all your settings and stuff.
option 2 : If the problem is not fixed then do steps above again BUT now don't accept the terms and unplug the 3500, put your original back or if like mine (its built in my TV so no other connect) and reset that first (same as above), do a evolution kit backup, then put back your 3500, of course don't forget to power off the TV and unplug it waiting for the LED to go out on the TV before unplugging or inserting the 3500.
Just a suggestion, I am not sure anyone else tried.
dfran1 is offline
post #12897 of 23784 Old 12-28-2015, 02:38 PM
player002's Avatar
Quoted: 3933 Post(s)
Liked: 2939
Got my 4k cable box from Rogers today 4k channel is nice can't seem to find 4k tv shows on Shomi. My xbox one has no HDMI 2.0 so I have to put tv directly into tv.
ray0414 likes this.
My set up
LG 65B7 | Samsung KS8000 |Sony 55XBR 930D |Samsung 55Q7 Samsung 60F8500 |LG Oled 55C8
LG Oled 65C8 |Samsung 65 Q9FNSamsung 55 Q8FN | Sony 65 900F |Samsung 65 NU8000
Onkyo TX-NR545 + Dolby Atmos Speakers |Xbox One X |Ps4 Pro |PS VR |Oculus Rift
AMD Ryzen 1700 + Vega 64 + Mining Rigs Samsung Galaxy S8
player002 is offline
post #12898 of 23784 Old 12-28-2015, 02:43 PM
ray0414's Avatar
Quoted: 12558 Post(s)
Liked: 11736
how does the quality of hte 4k channel seem compared to other 4k stuff you have seen? does it look compressed or anything?
75Q9FN*55C8OLED*Galaxy S10+ *Ub820 fed into Oppo 203* XB1X* 4k Denon X4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is online now
post #12899 of 23784 Old 12-28-2015, 03:38 PM
p5browne's Avatar
Liked: 3169
Hello,
Dave
Have you tried the unplug trick overnight?
Check OCB cable is plugged in `ALL THE WAY' Should hear a click once it's in correctly.
HDMI cable contacts can become tarnished over time. Plug them in and out several times.
If nothing works, try to get a warranty replacement.
NOTE: Left hand end of the 3500 is ventilation - make sure it has plenty of room to circulate air.
UN65KS9800 - Mine
p5browne is offline
post #12900 of 23784 Old 12-28-2015, 05:00 PM - Thread Starter
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
I originally thought it had something to do with the infamous firmware update that occurred before the SEK3500U/ZA became available. What happened is some people that had this firmware installed experienced multiple power cycles of the TV and failure of the main board inside the panel.I was one of the "lucky one's" I simply unplugged my TV and re-connected my one connect, then swapped my one connect with the SEK2500U/ZA. the problem in my case disappeared with that swap. Edit: Except for the green screen.
priuscat is offline
Reply LCD Flat Panel Displays
SEK-3500U/ZA
