4K UHD TV 4:4:4 60Hz Capable Master List - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #151 of 163 Old 07-11-2016, 11:14 PM
oguignant's Avatar
Quoted: 29 Post(s)
Liked: 4
Hi, i need help...
I have an Alienware 17r3 notebook with Nvidia gtx 970m. When connected to a TV LG OLED 55EF9500 by HDMI and select YCbCr444 4k/60hz, YCbCr422 4k/60hz or RGB 4k/60hz mode on the Nvidia control panel, it looks good but after a while, it loses the connection for a second and back, and is repeated every few minutes.
If I select YCbCr420 mode this does not happen.
TV connection is HDMI 2.0a and HDMI cable (supposedly) is 2.0. Anyone know why this happens? is a cable HDMI problem?
supposedly nvidia gtx 970m and LG 55EF9500 support [email protected] RGB/YCbCr444...
thks!
oguignant is offline
post #152 of 163 Old 07-12-2016, 08:43 PM
Quoted: 59 Post(s)
Liked: 4
Yes, you will probably need to try a better HDMI cable.
narrn001 is offline
post #153 of 163 Old 07-13-2016, 05:21 PM
EJSLP's Avatar
Quoted: 87 Post(s)
Originally Posted by Lincoln Tanner View Post
Hi All, I just jumped on here for some help with my X900C 65" I just go a new GTX 1080 and have plugged it all in to my TV it's running really smooth but for some reason won't run at 60 hertz even though I have read at TV ratings that it can any help is appreciated this is the link that I read rtings.com/tv/reviews/sony/x900c I have turned on enhanced mode but to no avail at most i get 4k 30 hertz with my HDMI 2.0 cable and setup
I am having this same issue and with the same set but i have the 55".
I set my HDMI port #3 that i am using for the PC tower to ENHANCED but i still only get [email protected]? I cant even get [email protected], just [email protected]
is this cable related? the TV has the latest update
it was made in MAY 2016.
EJSLP is offline
post #154 of 163 Old 09-06-2016, 06:03 AM
Chuck666's Avatar
Quoted: 333 Post(s)
Liked: 90
My E43-D2 shows 444 in the nVidia display applet..........650Ti card @ 1080px60.... It also shows higher resolution choices; but, 1080p provides the best text readability for me. I have a GTX 950 card coming today, so I can test if the text will improve with a true 4K card and higher resolution. I am not a gamer; but have multiple apps open at the same time for genealogy.... I changed from a 3 monitor setup.....
Samsung UN82MU8000 4K UHD TV | Onkyo TN-NR787 9.2 AVR with Klipsch RP-600M L&R and R-34C front stage speakers | Klipsch G-12 surrounds | 4 Atrium 5 front & rear Tops | Dual BIC RtR EV-1200 Subs | 5.1.4 Atmos system | Samsung UBD M9500 BD Player | Logitech Harmony 700 | TIVO BOLT OTA 849000 | AppleTV 4K | HT PC |
Chuck666 is offline
post #155 of 163 Old 09-07-2016, 06:33 PM
sjchmura's Avatar
Quoted: 2455 Post(s)
Liked: 956
For your nvidia control panels, should I be outputting rgb full or switch to ycb4:4:4??
DocACE911 on Steam, XBOX, PS4
"Kill Cancer or Die"
Custom Z9 Game Settings For SDR and HDR
Sony 75" Z9, Denon X4200, Definitive Technologies BP7002 + 9.1 ATMOS, PSV 18" sub
Loving Wife and 4 year old Son who tolerate this expense!
sjchmura is offline
post #156 of 163 Old 09-08-2016, 08:21 AM
Chuck666's Avatar
Quoted: 333 Post(s)
Liked: 90
With my Vizio, I liked RBG much better.. As I am not a gamer on this PC......... Text was superior with RBG and creating a custom resolution: 3160 x 2132 @60 - Limited..
It's dynamic, in that, you can leave open a windowed version of your favorite app and try your choices and see almost instantly.
Can't speak to gaming..
Also, note, many say the Vizio's are NOT properly supporting 444. Which may be why I like RBG....... Which, I understand is the gaming default mode?
Chuck666 is offline
post #157 of 163 Old 01-05-2017, 06:56 PM
Liked: 0
I've been trying to get up to speed on this thread but I could use a little help.
I am hoping to use a Sony 55inch 850D as a wall mounted monitor for doing AutoCAD. We just purchased new DELL computers and I need a new video card as the ones we had installed do not support HDMI 2.0 as my partner planned on me using two 40" desk mounted monitors. So with that said it appears that the GeForce GTX 970 is the card to buy?
Please let me know if this would be the correct card or is there something else I should be looking at.
CC
spitracer is offline
post #158 of 163 Old 08-10-2017, 02:03 AM
crashnburn_in's Avatar
Originally Posted by broken7 View Post
tcl has also partnered with roku for 4k tv's
I don't know if they support chroma 4:4:4 or not but they will be available at amazon
http://www.tclusa.com/roku/
Dear Forum Veterans,
We plan to buy your models in US and India and have a few questions:
- How many of the HDMI ports are HDMI 2.0 and support 4k @ 60hz?
- Can you please check & specify whether screens support Croma 4:4:4 sub sampling -
https://www.google.com/search?client...UTF-8&oe=UTF-8
- Are the models in US and India the same? If not, what are the technical differences?
We are planning to buy in both places via Amazon Prime.
Please clarify. Thanks
crashnburn_in is offline
post #159 of 163 Old 12-22-2017, 02:52 AM
narasimhan's Avatar
4K UHD TV 4:4:4 60 Hz
If I buy a 4K UHD(3840×2160) 4:4:4 60Hz capable TV and want to use it as a monitor. And for some reason I want to reduce the resolution to say 1920x1080 60Hz. Will it still support 4:4:4? I only remember that for monitors 4:4:4 is a must or the text looks washed out. So want to make sure 4:4:4 still holds for lower resolution. Thanks in advance.
narasimhan is offline
post #160 of 163 Old 12-22-2017, 01:47 PM
etacarinae's Avatar
Liked: 0
Would love to know this too. Looking at LG B7.
etacarinae is offline
post #161 of 163 Old 12-31-2017, 10:12 AM - Thread Starter
GrandPixel's Avatar
Quoted: 302 Post(s)
Liked: 64
I can’t figure why a display would be 4:4:4 at 4k60 but not 1080. Should work fine.
GrandPixel is offline
post #162 of 163 Old 01-27-2018, 08:10 AM
relaxman's Avatar
Quoted: 60 Post(s)
where can i find the list for 2015 and 16 LG 4k tv-s? thx
relaxman is offline
post #163 of 163 Old 04-02-2018, 09:13 PM
narasimhan's Avatar
Anyone knows whether xiaomi mi 4s TV(55 inch 4K HDR) supports 4:4:4 at [email protected] or any other setting.
Reply LCD Flat Panel Displays
4:4:4 , chroma subsampling , uhd
