**Official** Sony X930C / X940C Owners Thread - Page 205 - AVS Forum | Home Theater Discussions And Reviews
 7034Likes
post #6121 of 14456 Old 12-21-2015, 05:04 AM
mt14942's Avatar
Quoted: 860 Post(s)
Liked: 246
Originally Posted by Ken Ross View Post
Mt, yes, I have the 940c.
I woke up this morning and low and behold Amazon 4K videos are now working. Also the 4K HDR videos are working but I still can't get the HDR to work. It doesn't automatically select it and when I manually select it, it doesn't stay, soon as I go back to the show it reverts back to the Picture Mode I had it set on before I manually selected HDR. Also I noticed that the picture looks a bit dark and not what I expected 4K to look like, so I am wondering if I am even watching 4K even though it shows that it is Ultra HD and HDR in the description. I tried hitting the display button to see if it would show me the resolution but the display button doesn't work. Maybe the display information doesn't work with streaming? Ken, could you please let me know if the display button works for you when you are watching Amazon shows when you get it working. To be honest the shows on Amazon that are HDR look the same as when I am watching a 1080i show on my DTV but a darker picture and maybe not even as good. This may have something to do with the fact that it is HDR and I am not able to watch it in that mode. When I watch a 4K show that is not HDR, like "Orphan Black" the picture is back to the brightness that I am use to seeing when I am watching my DTV, however it isn't as good as some of the 4K you tube videos I have viewed. At least I have Amazon working now and the non HDR 4K videos look good, just not as good as You Tube 4K videos. I hope that the HDR issue is a software issue and can be corrected with a firmware update, but since others have reported that there HDR is working as it should I wonder about that.
mt14942 is offline
post #6122 of 14456 Old 12-21-2015, 06:27 AM
CCsoftball7's Avatar
Quoted: 1704 Post(s)
Liked: 1304
I've had great luck with Amazon in the past, but was bitten by the bug as well. I'll check my UHD and HDR to confirm how it looks. I've had it working for quite some time, so I should have a good reference with which to start. Thanks for the update.
CCsoftball7 is offline
post #6123 of 14456 Old 12-21-2015, 07:17 AM
Quoted: 2996 Post(s)
Liked: 2846
Thanks for letting us know ,the videos in the 4k section are working.
TV: 65” Sony A9G TV:65” LG B6 HT: Revel Performa3 1 Sub:PSA 15” XS30 2 Sub:Dayton HO 15”
losservatore is offline
post #6124 of 14456 Old 12-21-2015, 07:33 AM
Ken Ross's Avatar
Quoted: 7459 Post(s)
Liked: 8346
Yup, mine too mt! That was a quicker resolution to this issue than I would have expected. Maybe it's my imagination, but the HDR looks better than ever to me.
Mt, when in Amazon, you won't get the resolution display by hitting the info button. That never worked. Not knowing your viewing distance, the best way to check 4K vs HD is to get close to the screen. With HD the picture breaks down as you approach closer to the screen. With 4K content, you can almost have your nose pressed against the screen and all you see is more detail. Of course with streaming content, quality can be very variable.
I'd suggest watching a show like Man in The High Castle. That's what I just used to check if the UHD was working. That show has some beautifully photographed scenes. Keep in mind that with HDR, you'll get brighter whites, but also darker shadows. With that said you should be able to see shadow detail if your settings are correct (whatever 'correct' is at this stage of the HDR curve ).
The other thing to keep in mind is that, at least in my case, as soon as I hit 'settings' for picture adjustments, the app exits as well as the HDR picture mode. It's easy to make the mistake of making PQ adjustments, not realizing you're making them for a different picture mode and not HDR. So in my case, just as the app exits, so does the HDR mode. That requires me to manually select HDR mode to begin making picture adjustments.
I believe this is how it should work as you wouldn't want the HDR mode retained as you exit the app.
Ken Ross is offline
post #6125 of 14456 Old 12-21-2015, 07:50 AM
Liked: 1304
If I can add one more thing to actually see it switch "out" of HDR mode:
Pause the HDR show
Press the "Action Menu" button
If you do that, you will see the menu itself switch color/brightness.
post #6126 of 14456 Old 12-21-2015, 09:20 AM
KidHorn's Avatar
Quoted: 1901 Post(s)
Liked: 1307
Glad the license_error issue appears to be fixed. I'll have to verify tonight. I spend about an hour chatting with Amazon on Saturday. They were clueless and concluded that Sony TVs aren't supported by Amazon UHD. It doesn't explain how everything was working a couple of weeks earlier.
The Amazon tech was very annoying. It was obvious after 10 minutes, he had no clue how to resolve the issue so I suggested he let the tech department know about my issue and end our chat. The guy kept insisting we try other options and kept making me wait. He also kept insisting the problem was my connection wasn't fast enough for UHD.
I have a separate problem where I can't change the display settings from the drop down menu. I have to go to the home page and go to settings to make changes. Not a huge deal since I don't change settings often. Just another in the list of things that don't work.
I've never owned a device as buggy as my 940c. I wonder if Sony has a QA/QC department that tests their software. More likely the developers do a quick check to see if their use case works and then they roll it out.
I used to manage some development groups in India and my guess is this software is developed there. I would spend my days fixing bugs introduced from the prior days changes and sending them emails pointing out all their mistakes. Many of the problems would be blatantly obvious. Every day I was assured we wouldn't repeat the same thing and every day we did.
KidHorn is offline
post #6127 of 14456 Old 12-21-2015, 10:31 AM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3038
It's most probable you are not getting an HDR signal to trigger the mode change to begin with.
Can your modem and/or router handle the load?
In my fooling around with things it looks to me Amazon and NF will send out the highest PQ a system can handle at the time and nothing more.
If your hardware can't deal with it, what you get is < what you want at the time.
I have seen streams where the rez is cycled thru on-screen before locking onto something.
I think 5PM came early at my house today...
oink is offline
post #6128 of 14456 Old 12-21-2015, 10:43 AM
jsessler's Avatar
Quoted: 139 Post(s)
Liked: 156
Originally Posted by loudog2 View Post
I would get a better one for 4K streaming especially if you have lots of devices connected. I'm running the netgear R8500. Look at the asus RT-AC3100 as well.
Instead of the big investments in wireless gear, build out a MOCA network using your existing coax. For 4K streaming, the consistency of the network is far more important than the maximum data rate, and there is more than enough consistent bandwidth in MOCA for 4K (270Mbps in v 1.1).
jsessler is offline
post #6129 of 14456 Old 12-21-2015, 11:50 AM
Liked: 2846
I noticed that the HDR season the man in the castle looks better on dci color space and the HDR red oaks look better on bt 2020 color space.
anyone have any idea why?
post #6130 of 14456 Old 12-21-2015, 11:59 AM
Quoted: 17 Post(s)
Liked: 1
Sony 930C and HDR
Hi Folks,
Can you tell me the software version that includes the HDR update? Also...do you know of any good HDR videos/clips out there to run on the TV?
Thanks and Merry Christmas.
sluiceman is offline
post #6131 of 14456 Old 12-21-2015, 12:21 PM
oink's Avatar
Liked: 3038
I have been using this for the last 6 months and it performs well:
TP-LINK TL-PA4010KIT AV500 Nano Powerline Adapter Starter Kit, up to 500Mbps
oink is offline
post #6132 of 14456 Old 12-21-2015, 12:25 PM
Ken Ross's Avatar
Liked: 8346
Nobody is doing 2020 at this point. You're better off leaving the position in "Auto".
Ken Ross is offline
post #6133 of 14456 Old 12-21-2015, 12:33 PM
mt14942's Avatar
Quoted: 860 Post(s)
Liked: 246
Pause the HDR show
I tried doing that, pausing the amazon show "The Man in the High Castle" but the picture went away but when I manually changed the Picture Mode to HDR the menu screen does get darker, I'm not sure if that is an indication of anything. When I think about it how would one know if it did or didn't automatically change the Picture Mode to HDR since the picture goes away when I press the Action Menu wouldn't also HDR go away since the show has also gone away and I have re-select it to watch it? How would one know they are truly seeing HDR except if they were impressed by the picture and can see a difference. The first episode of "The Man In The High Castle seems pretty dark, at least the first 30 minutes or so which is all I have watched. Maybe that's the way it is supposed to look and maybe the next 30 minutes have brighter scenes and I can get a better indication.
MY router/modem is reading Very Strong with a speed of 144Mbps when I swapped out the old modem/router for this new one that is 5Ghz capable it made a world of difference when watching 4K video on You Tube before I was seeing a lot of blurriness with the resolution coming in and out along with a lot of buffering. Now I don't get any buffering and stunning 4K resolution.
mt14942 is offline
post #6134 of 14456 Old 12-21-2015, 02:18 PM
jeffs777's Avatar
Quoted: 93 Post(s)
Liked: 90
We're really drifting off the thread topic, but if you're knowledge about MOCA I wouldn't mind discussing it offline (private message). I can see the benefits of bridging your internet signal onto your coax for reliable 4K. I know MOCA allows you to bring or run your Internet to your devices (TV, XBOX, etc) over the cable, then split it out to an RJ45 connector (hardwire Internet to TV without running CAT 5e/6). It eliminates latency, but it doesn't seem to be scaling up in speed as fast as the CAT 6 based equipment. This can be a problem as internet speeds increase and streamers Amazon, Netflix, Ultraflix, etc. start reducing compression - which I think they'll have to do to compete with UHD Blue Ray Players.
Right now, I increase my wireless speed with a modem/router upgrade. To increase the speed of a MOCA build I would have to upgrade the equipment in lockstep (it also currently lacks gigabit speed). I have a need to move large amounts of data wirelessly over my LAN (up to a TB) from computer to computer via AC wireless protocol. I also run IP cameras using POE injector switches. I don't see a MOCA solution alone meeting all my needs, but I'd like to learn more
This thread isn't the place for the discussion - PM me to discuss.
Sorry to everyone on the thread for getting so far off topic
jeffs777 is offline
post #6135 of 14456 Old 12-21-2015, 03:01 PM
jsessler's Avatar
Quoted: 139 Post(s)
Liked: 156
With MOCA v2 and a bonded adapter, you get up to 1Gbps. If you have the ability to run Cat 5e/6/6a (it's the same rate i.e. 1Gbps), then it's the way to go. If you don't have the ability to run wired ethernet, then MOCA is a far better option then WiFi. Leave the WiFi for all of the BYOD devices e.g. iPad, iPhone, and use MOCA to drive the 4K TV, XBOX, PS4, TiVO, etc.
I have FiOS 300/300 service, and I bridge one of the GigE ports on the router to coax via a MOCA gateway. At my entertainment center, I have another MOCA bridge, and the single ethernet port terminates into a 8-port Gig-E switch, and my TiVO, Sony 4K, PS4, AppleTV, etc. all connect to the Gig-E switch.
Technically, I can't hit Gig-E speeds over the MOCA bridge, but there is nothing in the setup, even if all of those devices were (could) stream 4K content at the same time, where the MOCA bandwidth would be a limiting factor. Oh, and it's going to be faster than the current crop of 801.11ac WiFi, especially if there is any distance between the WiFi client and the router - you see, 802.11ac performance drops off exceptionally fast as the distance between the client and router increase. Add in legacy 802.11n and g devices (in 5Ghz) and the performance suffers more.
jsessler is offline
post #6136 of 14456 Old 12-21-2015, 03:45 PM
pee
pee's Avatar
Quoted: 88 Post(s)
Liked: 53
Amazon 4K is now working for me as well. Hooray!
This is my 1st time watching an HDR program(The Man in the High Castle)...but I can definitely tell a difference with the images compared to using Cinemapro watching DTV. Especially switching from a dark scene to a bright scene. I noticed it more and more the longer I watched. Will be perfect once 5.1 audio is activated. (This looks like a good series, by the way).
pee is offline
post #6137 of 14456 Old 12-21-2015, 05:25 PM
Quoted: 67 Post(s)
Liked: 36
Of all the problems with the software of this Sony (and there are a million of 'em), there is ONE thing this TV does superbly well: 3D
I watched Avatar in 3D tonite and it was stunning.
Also watched Wolf Totem and it too dazzled.
After other comments about the 3D, I finally broke out the glasses and had to try it. The Hobbit on HBO Go is currently showing in 3D and was is incredible. Looking for Avatar now. One of my favorite 3D movies.
waja and frapso like this.
ATechGuy is offline
post #6138 of 14456 Old 12-22-2015, 12:24 AM
oink's Avatar
Liked: 3038
I really can't believe the quality of the 3D on this display.
As I understand it, the Samsung flagships (9500 series) also have this level of quality 3D.
Unfortunately, the format was rushed to market before manufacturers perfected it.
If they hadn't pushed it so quick, it could have caught on in a MUCH stronger way.
oink is offline
post #6139 of 14456 Old 12-22-2015, 04:16 AM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 746 Post(s)
Liked: 633
Though I can't include the Samsung, the 940C provides the best 3-D image out of many TV's I have seen. With Christmas just days away, there's a good opportunity to blow away your guests with Imax: Hubble (3D), Gravity (3D), any one of the three Lichtmonds, or the seasonal staple, Polar Express (3D).
jeffs777 likes this.
marcuslaw is offline
post #6140 of 14456 Old 12-22-2015, 05:22 AM
KChinn's Avatar
Quoted: 33 Post(s)
Liked: 30
I've never watched 3D at home and was looking to try it out on the 940C. Is 3D just as good from streaming it on netflix or should I buy/rent a 3D BR disc to get the best example for 3D on this TV?
Family Room: Sony XBR75X940C, Denon AVR-3312CI, DirecTv HR-44, Sony PS4, Sony BDP-S590, Monster Power HTS 3600 MKII, Def Tech BP 2002 towers, Def Tech CS-8080HD center channel, Def Tech UIW RCS II Reference In Ceiling Surrounds - Game Room: Sony XBR55850C, Sony KDL-46HX850 (on Golden Tee Live Home Edition) Arachnid Galaxy 3 Dart Machine - Bedroom: Sony KDL-55W900A - Living Room: Sony KDS-R60XBR1 - Patio: Def Tech AW6500
KChinn is offline
post #6141 of 14456 Old 12-22-2015, 06:27 AM
Crimsoncleaver's Avatar
Quoted: 72 Post(s)
Liked: 27
Does the 940c list 3D on the Netflix app?
Crimsoncleaver is offline
post #6142 of 14456 Old 12-22-2015, 08:16 AM
marcuslaw's Avatar
Quoted: 746 Post(s)
Liked: 633
I was told by a Sony tech a couple of months ago that the 940C did not support 3-D from apps. Has anyone found this not to be the case?
KChinn, I think you're almost always going to find that you'll get a superior or at least less artifact prone image from a 3-D BD than from steaming.
post #6143 of 14456 Old 12-22-2015, 08:52 AM
oink's Avatar
Liked: 3038
I would go with a disc.
All other things being equal, I prefer the AV quality of discs (DVD, BD, CD) to other delivery methods
Of course, YMMV.
I'm sure you can pick up a 3D BD player for a reasonable price somewhere.
I use an Oppo 95, which was high-end when I bought it.
With UHB BD players right around the corner you may want to wait and see what is available.
oink is offline
post #6144 of 14456 Old 12-22-2015, 09:21 AM
KChinn's Avatar
Quoted: 33 Post(s)
Liked: 30
Thanks for responding Marcuslaw and Oink. I have a 3d BR player and I think my PS4 will play them too. I just was wondering if I could get the 3D from Amazon Prime or Netflix ( I didn't know that 3D won't work over those apps) or I would need to stop and buy or rent a 3d BR disc. The only way I've been watching movies is over D* for a long while... I haven't rented a physical disc since Blockbuster went out.
KChinn is offline
post #6145 of 14456 Old 12-22-2015, 09:54 AM
Zexxion's Avatar
What is your source for these jsut regular Blue-Ray? or something else?
Zexxion is offline
post #6146 of 14456 Old 12-22-2015, 09:57 AM
Zexxion's Avatar
I can confirm 3D does NOT work on the 940c using:
KODI
ARCHOS VIDEO PLAYER
VLC PLAYER
GOOGLE VIDEO PLAYER (built in video app)
AMAZON (the listed 3D titles show up as 2D when I try).
It does work on youtube.
marcuslaw and KChinn like this.
Zexxion is offline
post #6147 of 14456 Old 12-22-2015, 10:36 AM
marcuslaw's Avatar
Quoted: 746 Post(s)
Liked: 633
All 3-D Blu-ray. Incidentally, the Lichtmonds are region free and offer spectacular fantasy space imagery with very good scores reminiscent of Enigma, Floyd and the like.
Zexxion likes this.
post #6148 of 14456 Old 12-22-2015, 02:14 PM
jsessler's Avatar
Quoted: 139 Post(s)
Liked: 156
About a month ago my x900a Sony 4K failed and Sony default is to exchange them. Since the 900a isn't made any longer they offered me the x930C - which I happily accepted. It's been an interesting experience so far with the x940c. Clearly, having native 4K support for Netflix and other apps is a huge plus, as is HDR, but I've noticed a few other items that seem to be a step back.
1. The viewing angle on the 930c seems worse than the 900a.
2. General poor remote response time e.g. volume is slow to respond, press power and there is a 3-6sec delay before the status light changes.
3. Android TV is so bug infested. This is my biggest complaint. I've had to reboot the TV more times then I can remember - remote input stops/slows to a crawl, video but no audio, apps like Netflix stop launching, etc. It's clear from the threads that this is a common "feature" of the Sony Android sets. To Sony's credit, each software update seems to improve more than it breaks, but it's clear that the software still isn't ready for prime time. My new bug is that when I wake up my AppleTV, the Sony switches to the wrong input.
The problems aside, it's still a great 4K set, and I'm happy to have joined the x930x club.
brickyardz likes this.
jsessler is offline
post #6149 of 14456 Old 12-22-2015, 03:10 PM
Quoted: 84 Post(s)
No Sound with Netflix, Amazon, VUDU since FW update
I just did the update to my 940c and I can confirm UHD videos on amazon gives the license error. My guess is that the firmware update changed the internal ID or hardware profile that Amazon checks to confirm this is the same authorized device as when it was originally paired. I've seen similar errors with software that takes a snapshot of the computer hardware it's installed on and deactivates if you change too much at once, or change a major component like a motherboard. Even windows used to have this problem in the past.
Ultraflix in the other hand is working fine. Watched all of the new terminator tonight without any problems. This is via wifi 2.4hz connection. It does test as 40-50mbit/s at the begining.
I just tried to go into streaming apps (Netflix, Amazon, VUDU) for the first time since the update processed on my set and I now have no sound through my surround setup; it was working fine. Everything seems to be set up OK - my Marantz 5010 switches to TV Audio and I get a picture, but no sound. Any ideas?
nobrien1 is offline
post #6150 of 14456 Old 12-22-2015, 04:27 PM
oink's Avatar
Liked: 3038
Clear the app's cache.
IF that doesn't work, do a "Factory Reset."
oink is offline
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
