**Official** Sony X930C / X940C Owners Thread - Page 278 - AVS Forum | Home Theater Discussions And Reviews
 7017Likes
post #8311 of 14433 Old 03-02-2016, 08:00 AM
CCsoftball7's Avatar
Quoted: 1704 Post(s)
Liked: 1304
Originally Posted by s2kro View Post
It's possible as I like for the colors to really pop but my issue is more with the brightness than colors. Yesterday I watched Finding Nemo in 3D on my PS4 and there was definitely a difference, im starting to suspect it's either the STB or the AVR thats causing the lack of brightness. When I go to settings the actual menu is twice as bright as the screen.
I will try your settings while watching a bluray and then using the STB directly connected to the TV and then going through the AVR and see if there is any difference. Right now im using the STB going through the denon x3200 and the screen is just too dim even with brightness/gamma raised to max.
If you are watching 3D, you need different settings. That's specifically why I stated that my calibration was for the Apps (Video) setting. With a PS4/gaming, you really need to crank up the settings and use one of the game modes on the TV (I don't use them so someone else will need to help there).
Are there any picture settings on the Denon that change the output video? Have you messed with the internal settings on the blu-ray player or the PS4? I try to leave components at the neutral defaults and change only the settings on the TV is possible. Each component hooked to the Denon probably needs to have calibration done separately. That makes it difficult to only use one input on the TV. Good luck.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #8312 of 14433 Old 03-02-2016, 08:07 AM
jbug's Avatar
Quoted: 282 Post(s)
Liked: 136
Originally Posted by JT78681 View Post
Thumping the screen.
Stop being and frightened and do a simple search like this one:
http://www.wikihow.com/Fix-a-Stuck-P...an-LCD-Monitor
It was about 4 years ago when I did that little trick so don't ask me where I saw it but there are other sites that use that method or something similar and again it does work if the pixel is alive and not dead.
jbug is offline
post #8313 of 14433 Old 03-02-2016, 08:14 AM
dkyork's Avatar
Quoted: 185 Post(s)
Liked: 103
What are you guys using for 3d? I'm happy with it overall, but wondering if there is a way to make it pop more. The depth is great.
dkyork is offline
post #8314 of 14433 Old 03-02-2016, 09:31 AM
bruceames's Avatar
Quoted: 538 Post(s)
Liked: 371
I'm using the posted HDR settings for HDR content (the one with color bumped to 65), but what about at night? Watching The Martian the black bars looked too gray so I lowered the Gamma to -2 and the brightness from 50 to 47. Is that about right, or is their a better setting?
bruceames is offline
post #8315 of 14433 Old 03-02-2016, 09:42 AM
Liked: 1304
Mine are black. Do you have a 940c?
post #8316 of 14433 Old 03-02-2016, 09:51 AM
bruceames's Avatar
Quoted: 538 Post(s)
Liked: 371
No I have the 930c.
post #8317 of 14433 Old 03-02-2016, 10:08 AM
Mengels7's Avatar
Quoted: 27 Post(s)
Liked: 25
I lowered my black level until the black bars jusssst became dark. The picture is still vibrant and the blacks are actually black now. Also on a 930c here. I want to say I went from 50 to 36 but I'm not home to check, maybe that's wildly inaccurate.
Mengels7 is offline
post #8318 of 14433 Old 03-02-2016, 10:11 AM
bruceames's Avatar
Quoted: 538 Post(s)
Liked: 371
Thanks. What about lowering the gamma a tad as well? That seemed to help but I don't know much about gamma so maybe it's best to only lower the black level?
post #8319 of 14433 Old 03-02-2016, 10:12 AM
Liked: 1304
Part of it may depend on the source. Ender's Game is way too bright. I had to lower gamma and black level. The Martian was spot on with my original settings.
post #8320 of 14433 Old 03-02-2016, 10:16 AM
Mengels7's Avatar
Quoted: 27 Post(s)
Liked: 25
Maybe? I'm quite an amateur at this stuff. I'll have to check it out.
I did that when Kingsman was too bright and never cranked it back up before watching The Martian. The Martian still looked spectacular I thought though.
papaleo likes this.
Mengels7 is offline
post #8321 of 14433 Old 03-02-2016, 10:22 AM
Liked: 1304
I'm finding the HDR settings are much more variable than SDR.
post #8322 of 14433 Old 03-02-2016, 10:22 AM
wrassie86's Avatar
Quoted: 23 Post(s)
I've not put much research into this, but have any of you guys noticed a blue half circle light emitting briefly from the bottom of the screen and about quarter way up the screen??? my X930C is doing this every so often and its becoming very annoying. its like pressing the home button on a android phone. same blue colored light.
wrassie86 is offline
post #8323 of 14433 Old 03-02-2016, 10:28 AM
Liked: 1304
The Last Witch Hunter
brickyardz and papaleo like this.
post #8324 of 14433 Old 03-02-2016, 10:56 AM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3037
Originally Posted by dkyork View Post
My sharpness for hdmi inputs was found to be 25ish when calibrated. I set that for all inputs and video modes I use.
That's about what I set it at.
With low-bit DirecTV HD, setting the Sharpness lower helps remove various artifacts...IOW, the better the source material, the higher the Sharpness can be set.
oink is offline
post #8325 of 14433 Old 03-02-2016, 11:37 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7274 Post(s)
Liked: 7305
This is frightening...
Pretty hard to even see a dead pixel, stuck can be seen easier in some cases. Dead/stuck pixels are pretty rare.
CCsoftball7 and C-Dub006 like this.
Cleveland Plasma is online now
post #8326 of 14433 Old 03-02-2016, 11:53 AM
a1usedcomp's Avatar
Quoted: 58 Post(s)
Liked: 33
Never Mind
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is offline
post #8327 of 14433 Old 03-02-2016, 11:59 AM
a1usedcomp's Avatar
Quoted: 58 Post(s)
Liked: 33
Found it
post #8328 of 14433 Old 03-02-2016, 12:17 PM
Quoted: 46 Post(s)
Liked: 6
Originally Posted by Danabw View Post
Thanks mate. Appreciate it. Will give that a test after work. I believe the other app that I had put on was designed for touch screens. No wonder it was horrid with the remote control.
chad321 is offline
post #8329 of 14433 Old 03-02-2016, 12:43 PM
JT78681's Avatar
Quoted: 1523 Post(s)
Liked: 1090
Has anyone tried the recommended settings from rtings.com for the 930C? I know someone said recently they did, but the picture was too dim afterwards. They state the below in regards to their settings and brightness.
"Here are the results of our calibration of the picture for our review of the Sony XBR65X930C. You can apply these settings for every usage (movies, TV shows, sports). You can increase 'Brightness' as much as you want, depending on the amount of light in your room. It won't mess with the calibration. It is the equivalent of the 'Backlight' setting on other TVs."
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #8330 of 14433 Old 03-02-2016, 12:46 PM
Danabw's Avatar
Quoted: 851 Post(s)
Liked: 419
NP...yup - you probably had the phone version of the app.
Good luck.
2015 Sony X850C FAQ: Recommended Picture settings, 3D FAQ, HDR FAQ, DirecTV 4K Ready FAQ, Troubleshooting & common problems; Dropbox Link || Alternate Google Drive FAQ Link. || My gear: TV - Sony XBR75X850C, BD - Sony BDP S350, AVR - Pioneer VSX-1020, Speakers - RBH MC-616C MKII Center Channel, RBH MC-6C MKII Bookshelf (fronts), RBH MC-615 In-ceiling surrounds, RBH TS-10AP 200W self-powered sub.
Danabw is offline
post #8331 of 14433 Old 03-02-2016, 01:03 PM
JT78681's Avatar
Liked: 1090
I'm almost contemplating getting a calibration done by Best Buy. Wait before you throw stones! I've used them before on my old LG Plasma and they actually did a pretty good job. Better than I could do anyways. I know it's nowhere near a calibration from the likes of Chad B, but it's also not that expensive. Trying all these picture settings is driving me a little crazy. What do you guys think?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #8332 of 14433 Old 03-02-2016, 01:04 PM
a1usedcomp's Avatar
Quoted: 58 Post(s)
Liked: 33
ChadB
post #8333 of 14433 Old 03-02-2016, 01:41 PM
brickyardz's Avatar
Quoted: 604 Post(s)
Liked: 605
Do yourself a favor and get a calibration done by someone who is certified, like Chad B. He did my HX929 and he will do my 940D when it gets here.
brickyardz is offline
post #8334 of 14433 Old 03-02-2016, 01:46 PM
sgtdisturbed47's Avatar
Quoted: 23 Post(s)
I started with the RTings settings but made a couple of changes. Colors looked perfect out of the box, so I didn't bother changing that much. I just set picture mode to Custom, set color to "sRGB/bt.709" and set color temperature to Expert 1.
I deviated slightly with the rest. Brightness at 25-30, Contrast at 88, Motionflow set to Custom with Smoothness at 1 and Clearness at 1 (Clearness cuts the light output down by a lot, hence my Brightness setting being so high). Gamma I leave at 0 but sometimes -1. I also turn on Auto Local Dimming to Low.
RTings tends to calibrate really dark, and that might be because they use a really dark room. I find that in my pretty dark living room, I like my brightness up a little because I use LED bias lights.
sgtdisturbed47 is offline
post #8335 of 14433 Old 03-02-2016, 01:56 PM
mt14942's Avatar
Quoted: 845 Post(s)
Liked: 241
Set it and leave it. The bluray discs are fine. The HDR definitely is an upgrade to UHD, probably a bigger change than the resolution...only because the 940c does a GREAT job upscaling.
Thanks, I will just leave it. I agree the TV's upscaling to near 4K to start with can sometimes make the difference between 1080P & 4K resolution
I run everything through one enhanced hdmi on my tv. Fios, roku, uhd player, and no issues.
Set it and forget it.
mt14942 is offline
post #8336 of 14433 Old 03-02-2016, 01:57 PM
Quoted: 23 Post(s)
Originally Posted by gutter24 View Post
I upgraded to the 940C. It's a no-brainer if you can swing it.
I was afraid of that. I've exchanged several televisions over the past few years because of dark scene uniformity issues, but the 930c is the most money I've ever put into a TV, about $2500. Every other thing about it is amazing, I just wish the x930c didn't have the weird edge light bleed during certain dark scenes. Funny thing though, The Martian looked fantastic and I didn't really notice it a whole lot. I'm still torn between exchanging it for a different set that has full-array backlight or just keeping it and learning to ignore it. Decisions, decisions.
jbug likes this.
post #8337 of 14433 Old 03-02-2016, 02:06 PM
Quoted: 18 Post(s)
Should i change x930c to x930d if the price is the same?
Hate the edge light during the dark scens.
Or do you guys think that the x930d will still have the same problem?
DavKaz is offline
post #8338 of 14433 Old 03-02-2016, 02:18 PM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 484 Post(s)
Liked: 397
The X930d is newer tech and has not yet been reviewed enough but if time is ticking away and same pricing then yes I would - just to have an HDR Mode Setting. If you are OCD about light bleed, then only a 940c/d FALD can help.
Sony 75Z9D, Denon 4300H, Sony 65Z9D, Denon X4311, OPPO UDP-203, ATV4K, X1X Scorpio
davehale is offline
post #8339 of 14433 Old 03-02-2016, 02:32 PM
C-Dub006's Avatar
Not promoting Best Buy in the slightest, but their calibrators are typically ISF certified. Another alternative to Chad B. is Jeff Meyer at AccuCal (His company). He has done two sets for me in the past with excellent results (My Sony 006 Qualia and a Pioneer plasma) as well as my HT audio system.
Jeff is based in Missouri, but makes trips to most any part of the U.S. Check out his website http://www.accucalhd.com/
Not an employee of Jeff's or anything of that nature, just a very satisfied customer.
brickyardz likes this.
C-Dub006
XBR75X940C, XBR60LX900, PDP5020FD, 3 other Sony LCD's
Polk, Infinity with Velodyne subs
3808ci, 3805
DP-UB420, BDT-101ci, HD-XA2
C-Dub006 is offline
post #8340 of 14433 Old 03-02-2016, 03:46 PM
Tim Glover's Avatar
Quoted: 148 Post(s)
Liked: 67
I posted this on another thread but this one has a lot more traffic and members with a larger experience with these TV's...
So here's my dilemma.
For those you have seen the 65x930c and the 65x950b..which do you prefer? I am leaning toward the 930c due to price (about $1000 less) ..
coming from a now DEAD Panasonic 65vt60 Plasma...
BUT I mostly watch movies and just a little of network TV. Not much actual network stuff. ESPN of course. College Football Nut.
Movies #1...Football #2.
The Blacklist is my favorite TV show.
I work 6 days a week so its mostly in the evening watching and at night.
My plan is to get a really great 65 inch TV for the liv room, then later on (probably this time next year) put this in my bedroom and get a 75" for the main liv room.
Who knows tho, those plans may never pan out. I may end up going smaller in the BR thus making this one be the main one for a few years.
Thats a lot of gibberish to say whats the best dang one? hehehehe. Oh I just ordered the Samsung UHD-BD player. But like most here, not much to choose from in movies just yet.
Thanks for any thoughts.
Tim Glover is offline
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
