**Official** Sony X930C / X940C Owners Thread - Page 449 - AVS Forum | Home Theater Discussions And Reviews
 7015Likes
post #13441 of 14409 Old 06-26-2017, 01:19 PM
Cyber Chulo's Avatar
Quoted: 122 Post(s)
Liked: 42
Originally Posted by bgrpph View Post
thought i read on here for one of sony sets to be sure that the motion flow was not turned to "off"- for some- Local dimming wasn't being turned on when motion flow was set to Off. try setting motion flow to one of settings besides Off- try custom with both set to Min & see if that helps at all.
Ok. I'll try that tonight. Mine is always off because I use this TV for gaming mostly. I'm going to assume that that if I turn it on and then HDR turns on automatically, I'll get more input lag. But let me try when I get home. Thanks guys!
PSN ID Cyber125
Cyber Chulo is offline
post #13442 of 14409 Old 06-27-2017, 04:54 AM
Quoted: 122 Post(s)
Liked: 42
Well that didn't work. In Uncharted 4, I turned off hdr first. Then I went into the settings of the TV and set motion to clear and then true cinema to test. Once I flipped HDR on in the game, the blacks turned slight gray. I could adjust the brightness setting but when it gets to the black levels that I like, the overall image suffers. I also have a Z9D which has no problems at all when HDR is on. I know it's a better set technically. Just thought since the 940c can achieve super inky blacks in regular mode, it would be able to maintain it in HDR as well. Oh well.
PSN ID Cyber125
post #13443 of 14409 Old 06-27-2017, 06:40 AM
GunmetalR56's Avatar
Quoted: 270 Post(s)
Liked: 415
Not sure if this will help but if you keep black level at 50 as many do... maybe try dropping it to 45 and set gamma to -2. That's what I did to resolve the "grey" issue.
daimler2015 likes this.
Ascend Sierra Towers w/RAAL, Ascend Horizon Center w/RAAL, Ascend Sierra 2 surrounds, PSB Imagine XA Atmos modules (x4), SVS PB13 Ultras (x2), SVS PB12+ (x2)
Denon X6500H / Emotiva Mini-X a-100
Panasonic DP-UB820 / PS4 Pro / XBOX 1X
Sony XBR75Z9D, LG OLED65B7A
GunmetalR56 is offline
post #13444 of 14409 Old 06-27-2017, 06:41 AM
Quoted: 122 Post(s)
Liked: 42
Ok. I'll try that and see how it works. Thanks for the tip!
PSN ID Cyber125
post #13445 of 14409 Old 06-27-2017, 12:42 PM
HDTV JJ's Avatar
Quoted: 21 Post(s)
Liked: 29
Originally Posted by nobrien1 View Post
I have 'TV Audio Switching' turned on in my AVR, but it isn't switching inputs when I go to and from streaming apps anymore. Anyone else run across this?
Sorry NoBrien but I haven't been on the forum too much recently (obviously)
I too have noticed that streaming apps flip my 940c to internal speakers rather than my Denon. Has happened since the PKG3.885.0136NAB MM update.
Sony XBR75X940E
Denon X4200W
OPPO UDP-203
HDTV JJ is offline
post #13446 of 14409 Old 06-27-2017, 07:13 PM
bschellva's Avatar
Quoted: 32 Post(s)
Originally Posted by Cyber Chulo View Post
Is there a way to get deeper black levels when HDR is on? Once it's on, black looks grey as if local dimming was turned off.
I struggled with the same problem. Turning motionflow to True cinema is what finally did the trick. There may be another way to get there, but this seemed to work for me.
bschellva is offline
post #13447 of 14409 Old 06-27-2017, 07:15 PM
bschellva's Avatar
Quoted: 32 Post(s)
With ever firmware update I think, "Surely this will be the one that fixes the horrible stuttering in the Amazon video app."
And every time I am woefully disappointed.
post #13448 of 14409 Old 06-28-2017, 10:34 AM
Quoted: 122 Post(s)
Liked: 42
Well True Cinema setting in the motion flow worked for me! Glorious difference. And the input lag is still the same (which is good). Still came in either 1st or 2nd place after 4 matches for Uncharted 4. I'm so happy. I guess when I was trying everything else other than the True Cinema setting after bgrpph suggested it. Local dimming definitely looks turned on now. Thanks for all your help guys!
PSN ID Cyber125
post #13449 of 14409 Old 06-28-2017, 07:34 PM
Ken Ross's Avatar
Quoted: 7370 Post(s)
Liked: 8247
Tried "software update" on TV but showed software was up to date. Went to sony 940c site, downloaded firmware update onto Mac then onto USB drive & updated TV. Update process took 30 min or so- at end it said pull out usb drive & click OK-
when i clicked ok it would do nothing at all- like it would not click. (same thing happened when i updated in April).
This time i used help button on remote to go into troubleshooting area- clicked many areas until finally found something that said "personal" under one of the settings- clicked this & it got into the home screen area- under apps found sony update app & deleted cache & file (or whatever other area was called). all is normal now. Very briefly turned on Amazon app on a HDR movie- the lip sync seemed normal & using the volume button did not seem to have the skipping it did previously- Only did this quickly- more later tonight.
Great post! I did the update and would have been lost without this procedure, since I got the same gray screen that a few others reported. As usual, this update did nothing for me, but it was the first time it created these issues.
I just despise this Android OS more and more.
Ken Ross is offline
post #13450 of 14409 Old 06-29-2017, 04:23 AM
mt14942's Avatar
Quoted: 757 Post(s)
Liked: 226
Ken, I feel your pain. I had my main board replaced a number of months ago and I am still having the TV do an auto re-boot when I am watching Direct TV, it has happened about 8 times since I had the main board replaced. Also I have had the TV volume go off for no explicable reason and had to force a reboot to get it back and also on a few occasions when I turn on the TV on along with the Direct TV HDDVR I get a pink screen and have to turn everything off and than back on to fix it. However the last two issues I mentioned have happened since I got the HR54 Genie so it might be related to that.
Sony 75xZ9D
Sony UBP-X800 4K player
Oppo UDP-205 4k player
Classe SSP-800 pre/pro
Parasound Halo 5 channel Amp
mt14942 is offline
post #13451 of 14409 Old 06-29-2017, 04:31 PM
Liked: 52
MT14942- sorry for your continued issues-totally frustrating with price of this TV. i don't have Direct TV-but have not had any of the reboot or volume off issues that u have. I've Oceanic TWC- (Spectrum)
After 6/20 update, i still have issue with Amazon streaming volume studdering/skipping when volume button used- but the lip sync on Amazon does seem to be a bit better and is not off as much as it was b4 the 6/20 update. I did not notice any other changes with the new update.
bgrpph is offline
post #13452 of 14409 Old 06-29-2017, 05:35 PM
Quoted: 47 Post(s)
Having my main board replaced next week. Once in a while my 940c has a flickering screen that persists until a reboot. Also my MotionFlow and Cinemotion seem messed up ever since I had a failed firmware update (2 updates ago...my power went out during flashing). I get a ton of pixelation/macroblocking when my MotionFlow is on Standard/Custom/Smooth with Cinemotion at Medium or High...this happens all the time when I have fast motion panning or watch something like animation due to the sharp edges and fast motion. Looks horrible unless I shut off MotionFlow and/or Cinemotion.
TotoyZ4 is offline
post #13453 of 14409 Old 06-30-2017, 04:51 AM
mt14942's Avatar
Quoted: 757 Post(s)
Liked: 226
I am still waiting for the latest update to make it to my TV. I switched to the 4K HR 54 Direct TV DVR and that could be the culprit for some of the issues I am experiencing like the pink screen and the loss of volume since those two issues I never experienced before I got the 4K Genie DVR
I had the main board replaced because when I streamed from the streaming apps that I was using the TVs' picture would freeze and than it would automatically go into a reboot and since the main board replacement I haven't had that issue. However I have had the TV do an auto re-boot a handful of times when just watching Direct TV so it is a lot better than it was. I have come to the realization that I am just going to have to live with these occasional bothersome glitches.
Sony 75xZ9D
mt14942 is offline
post #13454 of 14409 Old 06-30-2017, 07:11 AM
Quoted: 47 Post(s)
Sounds like we are/were experiencing different issues with our sets. Don't know if the X1 or motion processing occurs from the main board but hopefully some resolution will come from its replacement and that I never experience the flickering screen again. Set is almost 2 years old now so hopefully this overhaul does more good than bad.
TotoyZ4 is offline
post #13455 of 14409 Old 06-30-2017, 02:54 PM
mt14942's Avatar
Quoted: 757 Post(s)
Liked: 226
Yes I believe the X1 is part of the Main board, at least that is what I was told. I was concerned that the great picture that this TV produces would be affected but the picture was not affected and my streaming issues went away. Best of luck with your repair it should fix your problem.
Sony 75xZ9D
mt14942 is offline
post #13456 of 14409 Old 06-30-2017, 10:23 PM
Lionheart of AVS
King Richard's Avatar
Quoted: 1797 Post(s)
Liked: 4367
King Richard is offline
post #13457 of 14409 Old 07-02-2017, 10:55 AM
Quoted: 122 Post(s)
Liked: 42
Looks like the YouTube app for the 940c got updated. I no longer get the option to choose which resolution to stream to ensure I'm getting a 4k feed. I only have the stats for nerds option which only shows 1080p*2. I don't think that means 4k does it?
post #13458 of 14409 Old 07-02-2017, 02:02 PM
tuckers's Avatar
Quoted: 25 Post(s)
This is my favorite 4K test video on Youtube. It looks fantastic and has a full range of colors and blacks. Surely you will be able to tell if your YouTube app is showing 4K vs 1080p looking up close at the videos?
King Richard likes this.
tuckers is offline
post #13459 of 14409 Old 07-03-2017, 09:58 PM
Lionheart of AVS
Liked: 4367
post #13460 of 14409 Old 07-04-2017, 08:48 AM
Quoted: 59 Post(s)
Liked: 8
I apologize if this has been already been covered, but I wanted to share my experience. I have a 930C and have been watching HDR content from Netflix and Amazon for a while. Although usually better than 4K, I have never been really convinced that compressed HDR on the 930C is a significant step up. With that said, I recently purchased an Oppo UDP-205 4K/HDR blu ray player for my system and have been blown away. The difference is amazing. Even my wife is impressed (the real test). That is not to say that HDR10 and/or DolbyVision HDR on a newer TV isn't better, but I am really happy with my new set-up. The only negative is that movie rentals are not readily available and it is just too expensive to purchase movies that I may only watch a few times. So, I just watch out for sales. I have purchased several movies for $14.99, which to me is a good deal.
Tom Riddle likes this.
Stealth Vater is offline
post #13461 of 14409 Old 07-04-2017, 09:52 AM
Viper32's Avatar
Quoted: 1344 Post(s)
Liked: 1029
New update today, tv is updating now.
Sent from my SM-G925V using Tapatalk
iatacs19 likes this.
Current Sets: Sony XBR65A9F Master Series, Sony XBR75X940C, Sony XBR75X940D, Samsung UN65KS9800, TCL 65R617
Previous Sets: Samsung Q9FN, Sony XBR65X930D, XBR65X900B, XBR49X830C, Samsung KS8000, KU6500, UN55KS8500, UN49JS8500, JS9000, JU7090, JU6500, JU6400, HU9000, HU7250, PN64F8500, Vizio P65, LG 65EF9500, LG 55EC9300, Hisense 55H8C, TCL P-Series (55P607)
Viper32 is offline
post #13462 of 14409 Old 07-04-2017, 10:21 AM
iatacs19's Avatar
Quoted: 290 Post(s)
Liked: 174
Is this the update?
http://www.flatpanelshd.com/news.php...&id=1498724600
Firmware update (v. 3.885) features
Adds support for HLG (Hybrid Log Gamma) HDR format via HDMI input
Reduces input lag for 4K HDR gaming
Resolves issue where the right-hand side of the screen becomes bright when changing input from HDMI (4K signal input) to Terrestrial
Resolves sound skipping when using Sonos sound bar
Resolves stuttering playback on Amazon video when pressing ACTION MENU or VOL+/- buttons
Resolves poor video quality on BBC iPlayer when using “Watch from start” feature
https://esupport.sony.com/US/p/swu-d...os_group_id=18
This software update (version PKG3.885.0137NAB) provides the following benefits:
Improvements over version PKG3.865.0135NAB:
  • Improves general performance of the TV
  • Adds support for (Hybrid Log-Gamma) HDR content via HDMI input
  • Reduces input lag for 4K HDR gaming
Very nice!!!
OLED65C9PUA, AVR-X4200W, NVIDIA SHIELD TV, SVS SB12-NSD, RC-52 II, RB-41 II, KEF E301, BDI 8179
iatacs19 is offline
post #13463 of 14409 Old 07-04-2017, 10:28 AM
Viper32's Avatar
Liked: 1029
Originally Posted by iatacs19 View Post
Yes that is the one I just received OTA.
Viper32 is offline
post #13464 of 14409 Old 07-04-2017, 04:32 PM
Quoted: 398 Post(s)
Liked: 112
Amazon still stutters, even without touching the remote
dalek77 likes this.
daimler2015 is offline
post #13465 of 14409 Old 07-05-2017, 02:25 AM
mt14942's Avatar
Quoted: 757 Post(s)
Liked: 226
Is the stuttering that you are referring to only happen during the first 60 seconds more or less. I experience this and than the resolution along with the audio catches up with itself and after that it is fine. I think that is pretty much the norm and I am hardwired to the TV with max speed from Comcast and I get this.
Yesterday I also got the firmware notification on my TV and did it. Too early to be sure of any improvements but the remote control operation seems to be improved with less lag. I apologize for my ignorance but what exactly does support for Hybrid Log Gamma do? Does it allow for viewing HDR content on You Tube which there is actually a channel for now on You Tube with a considerable amount of videos?
Sony 75xZ9D
mt14942 is offline
post #13466 of 14409 Old 07-05-2017, 03:00 AM
Viper32's Avatar
Liked: 1029
https://www.whathifi.com/advice/hybr...oadcast-format
May explain a little, I am sure more information is out but quickest I could find right quick.
Viper32 is offline
post #13467 of 14409 Old 07-05-2017, 05:04 AM
HDTV JJ's Avatar
Quoted: 21 Post(s)
Liked: 29
Lightbulb
You might want to look at:
http://www.store-3d-blurayrental.com/default.asp
Their disk stock is sometimes limited on new issues so some wait time occurs but they are reasonably priced and there's nothing like watching 4K disks on your OPPO!
Stealth Vater likes this.
Sony XBR75X940E
Denon X4200W
OPPO UDP-203
HDTV JJ is offline
post #13468 of 14409 Old 07-05-2017, 05:27 AM
mt14942's Avatar
Quoted: 757 Post(s)
Liked: 226
Thanks Viper, an interesting article. So it sounds like it comes into play for live broadcast TV. I am still going to check out You Tube when I get a chance to see if those HDR videos on the HDR channel actually show HDR later today.
Sony 75xZ9D
mt14942 is offline
post #13469 of 14409 Old 07-05-2017, 07:11 AM
KidHorn's Avatar
Quoted: 1844 Post(s)
Liked: 1279
I did the update yesterday. Didn't notice anything different. I don't use the TV apps as the ones on my blu-ray player tend to work better.
KidHorn is offline
post #13470 of 14409 Old 07-05-2017, 07:35 AM
iatacs19's Avatar
Quoted: 290 Post(s)
Liked: 174
From everything I have read the SoC used in the 2015 models do not have the necessary codec support for YouTube HDR and will never be able to display it.
iatacs19 is offline
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
