**Official** Sony X930C / X940C Owners Thread - Page 464 - AVS Forum | Home Theater Discussions And Reviews
 7009Likes
post #13891 of 14301 Old 03-08-2018, 08:27 PM
spwill's Avatar
Quoted: 80 Post(s)
Liked: 70
Originally Posted by daimler2015 View Post
Thank you again. Changed all gains to MAX (had at MAX/MAX/-4) and added your 10 point settings. Looks great!!!!
No problem, glad it works well for you!
Sony 75x940c
spwill is offline
post #13892 of 14301 Old 03-09-2018, 05:18 AM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 735 Post(s)
Liked: 619
Originally Posted by vman83 View Post
Not sure if this will help but im sure i read somewhere that for HDR video you need to use some sort of motionflow to improve the black bars. I use TrueCinema myself for movies. Worth a try. I also notice some greyish blacks when viewing HDR content. I have ambient backlighting on my tv which helps a lot. I have the x930c.
Well, this did the trick. I set mine to "clear" and voilà, the bars went from grayish black to black (with HP: Philosophers Stone 4K). I didn't notice any pronounced changes to the image after activating it either so I might just keep it on. vman, according to Sony EU, TrueCinema is only active for "broadcast" sources?
Frequently Asked Questions related to the Motionflow feature on my TV
What is the "True Cinema" mode in the "Motionflow" menu?
True Cinema is a Motionflow mode which restores the original film motion in broadcast programs.
By the way, the XBR75Z9D looks terrific. However, I'd really miss the 940C's great sounding speakers that we use quite a bit when watching cable TV or with the apps such as Pandora (while turning the screen off!).
vman83 likes this.
marcuslaw is offline
post #13893 of 14301 Old 03-09-2018, 07:10 AM
CCsoftball7's Avatar
Quoted: 1692 Post(s)
Liked: 1285
"Clear" uses BFI, so in a dark room, it is probably fine. For a brighter room, it will cause the image to be pretty dark.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #13894 of 14301 Old 03-09-2018, 09:17 AM
marcuslaw's Avatar
Quoted: 735 Post(s)
Liked: 619
Well, this did the trick. I set mine to "clear" and voil?, the bars went from grayish black to black (with HP: Philosophers Stone 4K). I didn't notice any pronounced changes to the image after activating it either so I might just keep it on. vman, according to Sony EU, TrueCinema is only active for "broadcast" sources?
Which motionflow setting would have the least impact on other calibrated settings?
post #13895 of 14301 Old 03-09-2018, 09:20 AM
Liked: 1285
Anything other than:
Custom (unless Clearness is set to 0)
Clear
I prefer to leave it off. But I haven't had any issues with judder.
post #13896 of 14301 Old 03-10-2018, 07:31 AM
Quoted: 82 Post(s)
Liked: 49
I've been noticing more and more that there is a pretty heavy audio lip-sync issue on my 940c with my Marantz SR7010 hooked up over ARC.
On my Marantz I have the audio delay set to 0ms, and I have tried both "hdmi lip sync" both on and off (seems to make no difference). The audio is behind the video, so adjusting the setting on the Marantz would only increase the delay, and it's clear that the delay is coming from the TV.
In attempting to diagnose it, I used the Netflix test patterns a and my iPhone set to 240fps "Slow-Motion" to record, and found that my AppleTV4 has the audio 100% dead-on in sync (required 11ms of delay on the Marantz), but when using the Netflix player on the TV, even with all delays turned off, the audio is about 150ms behind the video.
I didn't really run into the problem before, because I used my AppleTV primarily for 1080p content, but lately I've been watching more 4K content on the TV, and the delay is driving me nuts.
It appears that audio the delay is actually happening inside the TV. Does anyone have an idea what can be done to fix this?
The only Audio setting I can see is ClearAudio, which I have tried set to both on and off, which has no obvious difference.
randompersonx is offline
post #13897 of 14301 Old 03-10-2018, 08:28 AM
Egghaus's Avatar
Quoted: 122 Post(s)
Liked: 71
I read about so many issues with ARC in these forums, I wonder why people don't just use the Toslink out from the TV to the AVR. I've used both my Sony's like this and never had an issue.
Tom Riddle likes this.
Egghaus is offline
post #13898 of 14301 Old 03-10-2018, 09:12 AM
waja's Avatar
Quoted: 39 Post(s)
Liked: 47
When I first bought my TV, I found Toslink to work better. The following year, my sister bought the XBR65X930C and a Denon receiver. She set up the TV to use ARC and was happy with it. I decided to see if ARC had improved and found that it worked much better than when I first tried it.
Favorite features (I don't know if these work with Toslink):
Changing TV volume controls the receiver volume including mute.
TV switches between internal and external speakers when receiver is turned off or on.
TV Audio selected on the receiver automatically when opening Netflix app.
Rick
Sony XBR-75X940C | Denon AVR-X4400H | TiVo Roamio Pro | Panasonic DMP-UB900 | Sewell Direct SW-30458
HSU
VTF-3 MK5 HP | EMOTIVA XPA-2 Gen3 | Snell Type C | Polk Audio 255C-LS + 265-LS + V80 + TL3
Sony KDL-48W600B
waja is offline
post #13899 of 14301 Old 03-10-2018, 09:53 AM
Quoted: 82 Post(s)
Liked: 49
Just tested with Toslink, audio seems to be about 200ms behind the video, so actually even worse than I was getting with ARC.
post #13900 of 14301 Old 03-11-2018, 02:44 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
I like Custom with Smoothness and Clearness set to Min. I find everything else to bother me, with the exception of off, but it somehow impacts HDR and the black bars on off. At least on my set.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #13901 of 14301 Old 03-12-2018, 05:40 AM
Liked: 1285
If both are set to min, doesn't that in effect turn it off?
post #13902 of 14301 Old 03-12-2018, 06:51 AM
Egghaus's Avatar
Quoted: 122 Post(s)
Liked: 71
I quickly played with Custom and both settings on minimum yesterday. I'm not sure if it affected the black level but it didn't seem to have any effect on peak brightness. You can directly switch from "Custom" to "Off" and it looked the same to me.
Sony XBR75X940C, UBP-X800, PS4 Pro 5.1.2 System Yamaha RX-V1081 Paradigm Studio 60 V5, Monitor Center 3 V7, Titan V2 Klipsch RP-140SA DIY 15" Sub w/Inuke1000DSP
Egghaus is offline
post #13903 of 14301 Old 03-12-2018, 01:36 PM
ultrasilent's Avatar
Quoted: 263 Post(s)
Originally Posted by King Richard View Post
The Sony 940c has a higher max nits level than the JS9500 (1200+ vs. 900+).
Richard
Can anybody provide link to some test or review where we can see that 9405C got 1000+ nits of peak level?
Zidoo X9S (1.4.16.), Vertex FW 1.36.1.41,
Himedia Q10 Pro (2.0.4) > 6ft copper > Vertex > 6ft copper > SONY X9405C HDR TV (HDMI 4)
Nvidia Shield Android TV (7.1.0.) 2015 16Gb+ 1TB HDD>6ft copper >----> 6ft copper > Yamaha RX-A2020 HDMI 1.4 > SONY X9405C HDR TV (HDMI 1)
ultrasilent is offline
post #13904 of 14301 Old 03-12-2018, 03:32 PM
Liked: 1285
http://forum.blu-ray.com/showthread....280279&page=10
The 940C is #9 in the graph.
post #13905 of 14301 Old 03-12-2018, 03:59 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
Yes, it does exactly that. For some reason turning it completely off interferes with the local dimming, but turning it to min and min on custom solves the problem.
post #13906 of 14301 Old 03-12-2018, 04:25 PM
Quoted: 263 Post(s)
Can you give a list of Tvs and which graph related to every one?
post #13907 of 14301 Old 03-14-2018, 02:58 AM
stjefrey's Avatar
New Update! I have not downloaded yet.
Release Date 3/13/2018 Version PKG5.381.0167NAB File Size 1.52 GB
The section below provides a list of benefits provided by previous updates and included in the latest System Software Update.
  • Adds support for (Hybrid Log-Gamma) HDR content via HDMI input (does not apply to the XBR43X830C, XBR49X800C, XBR49X830C, XBR55X810C, XBR65X800C and XBR65X810C models)
  • Reduces input lag for 4K HDR gaming (does not apply to the XBR43X830C, XBR49X800C, XBR49X830C, XBR55X810C, XBR65X800C and XBR65X810C models)
  • Improves the general performance of the television
  • Adds support for 4K Live/NeuLion® Sports digital video technology
  • Improves general software quality of the TV
  • Improves RVU support
  • Adds Twin Picture (PAP function) support
  • Resolves a condition where a black picture may occur after performing a remote Off/On (KDL-75W850C)
  • Supports PlayMemories Online service
  • Supports PlayStation™ Now service
  • Improves Wi-Fi connectivity of the TV
  • Improves picture quality (dynamic range, noise reduction, sharpness)
  • Supports Netflix® streaming service (4K Models)
  • Improves Lip Sync for HDMI input
  • Improves performance and stability of the USB video playback features
  • Resolves a condition where a black screen and no sound may occur when an input changes from YouTube® to another input
  • Resolves a condition where a black screen may occur during USB video playback
  • Supports Internet based EPG (Electronic program guide)
  • Supports Netflix streaming service (2K Models)
  • Supports Amazon®, Pandora®, and Crackle™ applications
  • Supports Force Reboot by holding down the Power key on the BT or IR remote controller
  • Improves performance and stability of overall UI operation
  • Improves performance and stability of the Action Menu
iatacs19 and vman83 like this.
Sony XRB-930C
Sony Playstation 4
Mitsubishi 1100 DVHS
stjefrey is offline
post #13908 of 14301 Old 03-14-2018, 02:49 PM
Liked: 1285
I downloaded and installed. TV looks great and is very snappy.
post #13909 of 14301 Old 03-15-2018, 08:16 AM
charles0424's Avatar
Quoted: 55 Post(s)
Liked: 44
I always hold off on updates in the beginning (930c owner) this update however does sound more promising than the previous updates. Would love to hear more members take on it!
charles0424 is offline
post #13910 of 14301 Old 03-15-2018, 09:00 AM
Egghaus's Avatar
Quoted: 122 Post(s)
Liked: 71
I did some more testing with Motionflow on HDR material and will now say it absolutely alters the black level when set to Custom and Min/Min. A good scene to test this with is Stranger Things S2 E5, about halfway through there is a scene with the characters against a pitch black background. The drop in black level is very apparent when switching from Off to Custom. If there is any drop in peak brightness by doing this it is not noticeable to me.
Egghaus is offline
post #13911 of 14301 Old 03-15-2018, 01:49 PM
Quoted: 396 Post(s)
Liked: 112
940c after update
Noticed after the latest update under External inputs>HDMI Signal Format
once an HDMI input is selected the caption under Enhanced Format says “Displays High-Quality signals on HDMI inputs 2 & 3....”
I assuming this is a templated caption that doesn’t apply to the 940c???
daimler2015 is offline
post #13912 of 14301 Old 03-15-2018, 04:49 PM
NoBodyH0mE's Avatar
Quoted: 41 Post(s)
Liked: 26
Need some help.... if anyone got their 930c professionally calibrated can u please pm your picture settings THANKS
stjefrey likes this.
NoBodyH0mE is offline
post #13913 of 14301 Old 03-16-2018, 06:26 AM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
A new firmware update and I never got notification of the last update nor this new one? Oh well I really didn't want to do another factory reset, which from what I have read is highly recommended to do after a new firmware update.
Sony 75xZ9D
Sony UBP-X800 4K player
Oppo UDP-205 4k player
Classe SSP-800 pre/pro
Parasound Halo 5 channel Amp
mt14942 is offline
post #13914 of 14301 Old 03-16-2018, 06:37 AM
Liked: 1285
I've found no reason to do a factory reset. I did the USB update and am very happy with the results.
post #13915 of 14301 Old 03-16-2018, 06:58 AM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
I have my TV settings set to let me know of any updates, but for some reason never notified and I check in the tools menu to confirm that I am still on the old firmware. I guess I can always go the USB route. I was curious CC, when you did the new firmware update did that have an affect on your picture settings?
Sony 75xZ9D
mt14942 is offline
post #13916 of 14301 Old 03-16-2018, 08:11 AM
Liked: 1285
It did not effect the picture settings. I would highly recommend this latest update as the performance of the TV OS seems to be much better.
post #13917 of 14301 Old 03-16-2018, 09:42 AM
TheMusicMaestro's Avatar
Quoted: 23 Post(s)
Liked: 5
You and me both!😍 Does anyone know, why? Does anyone know why some are notified and some of us are not? I go into the menu daily to check if I have a new update available, and the message I am given is 'Your software is up to date' My software version is PKG3.915.0139NAB
____
SONY XBR-75X940C * OPPO UDP-203 DIY Project Converted to Region Free * Apple TV 4K* SONY FMP-X10 * PANAMAX M5400-PM
TheMusicMaestro is offline
post #13918 of 14301 Old 03-16-2018, 11:02 AM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
I'm sure they do the updates in waves.
Just go to Sony.com and download to usb - mine is updating right now while I watch basketball on my computer - best of both worlds! Happy Spring Break to me!
CCsoftball7 likes this.
post #13919 of 14301 Old 03-16-2018, 12:29 PM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
Thanks CC,I haven't read to much positive comments regarding the new firmware update. I do experience some OS instability from time to time so I will do the update if I don't get a notification on my TV I will download it from there web-site and go the USB route.
Sony 75xZ9D
mt14942 is offline
post #13920 of 14301 Old 03-16-2018, 12:37 PM
Liked: 1285
Since it's only been out a couple of days, I really haven't heard anything positive or negative.
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
