**Official** Sony X930C / X940C Owners Thread - Page 465 - AVS Forum | Home Theater Discussions And Reviews
 7009Likes
post #13921 of 14302 Old 03-16-2018, 08:06 PM
Liked: 0
It's been more then 2 months since the last firmware update and I never got the push. The waves never lasted that long. I wouldn't be surprised if they saw a lot of complaints on the last firmware they stopped pushing it. That's the reason they push it out in waves in the first place.
fade_ is offline
post #13922 of 14302 Old 03-17-2018, 05:22 AM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
Maybe.... but who knows. I've never received the push notifications that I have new firmware either. The process to install via USB is so simple, I've never found it to be problem.
As @CCsoftball7 noted, the picture quality remains the same from the update, but the system seems to operate at a better pace. I too found no reason to do a soft reset, and everything operated smoothly upon initial boot up.
One awesome thing - my sound issues are completely gone! On DirecTV, we were getting a screeching sound when fast-forwarding on the DVR (sounded like nails on a chalkboard). It came with the previous update and left with the new one. Highly recommended!
Stephen Terry and CCsoftball7 like this.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #13923 of 14302 Old 03-17-2018, 05:34 AM
peterlee's Avatar
Quoted: 97 Post(s)
Liked: 59
The new update didn't fix my sound problem with my 930c. I didn't have the screeching problem - the issue introduced with the last update is that there's no sound for a couple seconds after coming out of a fast forward or fast reverse when watching recordings on my Tivo HD. Put me down as one owner as not pleased with Sony. Two months waiting for an update to fix a problem caused by Sony and I'm still waiting.
peterlee is offline
post #13924 of 14302 Old 03-17-2018, 06:24 AM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
What amazes me is the amount of different types of issues this TV has been reported to have by different owners (I certainly have had my share) but than again the a/v combinations that people have I guess maybe it's to be expected. I called Sony yesterday about why I wasn't getting a notification on the last two updates and the customer service person intimated that it may have to do with my TV being almost 2 years old, but that I could still download it via the web-site.
Sony 75xZ9D
Sony UBP-X800 4K player
Oppo UDP-205 4k player
Classe SSP-800 pre/pro
Parasound Halo 5 channel Amp
mt14942 is offline
post #13925 of 14302 Old 03-17-2018, 07:45 AM
TheMusicMaestro's Avatar
Quoted: 23 Post(s)
Liked: 5
I'm sure they do the updates in waves.
Just go to Sony.com and download to usb - mine is updating right now while I watch basketball on my computer - best of both worlds! Happy Spring Break to me!
Originally Posted by daimler2015 View Post
Noticed after the latest update under External inputs>HDMI Signal Format
once an HDMI input is selected the caption under Enhanced Format says “Displays High-Quality signals on HDMI inputs 2 & 3....”
I assuming this is a templated caption that doesn’t apply to the 940c???
I decided on yesterday to update my 940C via usb drive, because I hadn't received notification for the last 2 updates. Afterwards, I see 'Displays High-Quality signals on HDMI inputs 2 & 3...' , which was originally pointed out by daimler2015. Does anyone have an explanation for this? I thought on the 940C all 4 inputs were able to handle 'High-Quality signals'.
daimler2015 likes this.
____
SONY XBR-75X940C * OPPO UDP-203 DIY Project Converted to Region Free * Apple TV 4K* SONY FMP-X10 * PANAMAX M5400-PM
TheMusicMaestro is offline
post #13926 of 14302 Old 03-17-2018, 09:58 AM
jsessler's Avatar
Quoted: 128 Post(s)
Liked: 153
The TiVo HD is a 10-year-old piece of technology that is no longer supported by the manufacture. TiVo had a killer deal for upgrading the old hardware to a TiVo Bolt/Pro/VoX. It's hard to blame Sony for a problem with a discontinued product - no matter how frustrating. My TiVo bolts aren't having a problem with no sound out of FF FR, so perhaps this is a bug in the TiVo HD?
Do you have the TiVo HD outputting PCM or Dolby Digital? Maybe try switching audio between PCM/Dolby or Dolby/PCM?
jsessler is offline
post #13927 of 14302 Old 03-17-2018, 09:45 PM
Liked: 0
Think it was mentioned that the 940d is only on input 2 and 3. They probably just forgot to change the caption for the 940c. Can you still set the other inputs to enhanced in the settings?
fade_ is offline
post #13928 of 14302 Old 03-18-2018, 05:47 AM
Quoted: 23 Post(s)
Liked: 5
Yes, inputs 1,2,3 and 4 are STILL, 'Enhanced format' abled.
Tom Riddle and daimler2015 like this.
____
post #13929 of 14302 Old 03-19-2018, 05:39 PM
Egghaus's Avatar
Quoted: 122 Post(s)
Liked: 71
Does anyone know exactly what the "True Cinema" Motionflow setting does? I've now noticed that the Custom setting is shared between SDR and HDR. I like to use Custom with Clearness 2 for SDR to lower the brightness, but also want Min/Min settings in HDR to lower black level. I tried the "Clear" preset but found it introduces SOE. So I would like to set True Cinema for HDR but I don't know if it would affect my HDR gaming with additional lag or something. I don't want to be changing these settings every time. I suppose I could run dual HDMI out from the AVR and have separate inputs for SDR/HDR worst case.
Egghaus is offline
post #13930 of 14302 Old 03-19-2018, 06:18 PM
Quoted: 396 Post(s)
Liked: 112
Isn't turning motionflow off recommended for HDR?
daimler2015 is offline
post #13931 of 14302 Old 03-21-2018, 05:02 PM
Quoted: 67 Post(s)
Liked: 36
Unhappy What happened to my sound via external inputs?
I took the update and I can't say when I can remember that I had problems after an update with my 930C. However this time, non of my HDMI inputs are providing audio. The internal Netflix app is fine with sound, and if I enable them, I can get system sounds. If anyone has an idea on how to resolve this, please let me know!
I did reboot the tv, but I think I'm going to power cycle it as well and see. Until you hear back from me on how to resolve, consider one 930C owner without audio after the latest update...
Sony XBR65X930C
ATechGuy is offline
post #13932 of 14302 Old 03-21-2018, 05:17 PM
Quoted: 67 Post(s)
Liked: 36
OK, after full power cycle, I started getting audio again. All were fine then, except for my set top box from Spectrum, which decided to change the digital audio output to "other", (whatever that means!) Switching it back to HDMI did the trick.
phew
Sony XBR65X930C
ATechGuy is offline
post #13933 of 14302 Old 03-22-2018, 01:01 PM
Stephen Terry's Avatar
Quoted: 74 Post(s)
Liked: 41
Best update in a long time.
This one fixed 95% of my issues ( maybe 100% but need to give it more time to see if anything resurfaces).
Stephen Terry is offline
post #13934 of 14302 Old 03-22-2018, 07:10 PM
charles0424's Avatar
Quoted: 55 Post(s)
Liked: 44
Can you please elaborate on the issues it fixed? I’m still weary of updating as I don’t want to mess with anything only because I’m loving that this tv has been providing without any updates to this point. Thanks! Updates sometime scare the crap out of me
charles0424 is offline
post #13935 of 14302 Old 03-22-2018, 11:22 PM
Quoted: 74 Post(s)
Liked: 41
TV hasn’t reset itself once since this update vs every 1 or 2 days max
TV use to squeal sometimes when pausing or changing channels (6-8 times daily) but is now stable/silent
Color seems a bit more vibrant (deeper?)
Apps seem a bit snappier
No negatives that I have seen or heard so far.
post #13936 of 14302 Old 03-23-2018, 11:37 AM
CCsoftball7's Avatar
Quoted: 1692 Post(s)
Liked: 1286
Also, I think the HDR is a bit better as well. I'm not sure, but maybe they tweaked the local dimming???
Stephen Terry and Tom Riddle like this.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #13937 of 14302 Old 03-23-2018, 11:44 AM
Quoted: 74 Post(s)
Liked: 41
YES! I thought that also but it was subtle so I wasn't sure if I was just imagining it (looking for more improvements).
post #13938 of 14302 Old 03-24-2018, 02:18 PM
Egghaus's Avatar
Quoted: 122 Post(s)
Liked: 71
I installed the new firmware today and await the results. Unlike most, I purchased this set a month ago brand new, a January 2016 built set. I upgraded it to Android 7.0 and have been getting a reboot on startup about once a week. Hopefully this fixes it. Funny that I have never had any firmware issues with my 850C that I've owned since December 2015.
Egghaus is offline
post #13939 of 14302 Old 03-27-2018, 06:33 AM
bobbino421's Avatar
Quoted: 1154 Post(s)
Liked: 724
Anybody have any idea on what a used 65 X930C might be worth in excellent condition with about 2700-3000 hrs all accessories included?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Samsung HW-K950 Dolby Atmos sound bar
bobbino421 is offline
post #13940 of 14302 Old 03-27-2018, 07:00 AM
waja's Avatar
Quoted: 39 Post(s)
Liked: 47
I usually use eBay's recently sold search to see what people have paid, but no 65X930C were listed. There were quite a few 65X930D sets. In general, these went between US$500 and US$1300.
Rick
Sony XBR-75X940C | Denon AVR-X4400H | TiVo Roamio Pro | Panasonic DMP-UB900 | Sewell Direct SW-30458
HSU
VTF-3 MK5 HP | EMOTIVA XPA-2 Gen3 | Snell Type C | Polk Audio 255C-LS + 265-LS + V80 + TL3
Sony KDL-48W600B
waja is offline
post #13941 of 14302 Old 03-27-2018, 07:04 AM
bobbino421's Avatar
Liked: 724
Yes I checked there too but the C models are supposed to be sought after more than the D with the exception of a Z9D and are supposedly better sets from what I’ve read on here.
CCsoftball7 likes this.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #13942 of 14302 Old 03-27-2018, 03:14 PM
Quoted: 55 Post(s)
Liked: 44
Is there anyone else out there that updated their sets to find any improvements? I’m still weary about updating due to problems newer firmwares caused in the past.
Thanks everyone!
post #13943 of 14302 Old 03-27-2018, 07:17 PM
pee
pee's Avatar
Quoted: 88 Post(s)
Liked: 53
Thanks everyone!
I updated my 930C to the latest software.
I think everything does feel just a little bit faster. But I never had any issues before.
I still love this TV!
pee is offline
post #13944 of 14302 Old 03-27-2018, 08:46 PM
Quoted: 55 Post(s)
Liked: 44
Yes! I love this TV as well. Maybe its my anxiety but updating firmware always has me weary. The more positive comments the more comfortable I feel proceeding. It sucks this TV is a few years old now, which brings in less traffic, these sets are fantastic! My jaw still drops every night I pop in a 4K disc!
Thanks again all!
post #13945 of 14302 Old 03-28-2018, 05:34 AM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
Thanks everyone!
Over the weekend I decided to buy a USB drive to do the latest firmware update this week, since my TV wasn't alerting me about the new update. So naturally Monday morning when I turned on the TV the notification of a new firmware update appeared. Anyway I did the update and based on the past couple of days the TV does seem to be more responsive. Also when watching an Amazon Prime Video show that's 4K HDR the TV is now much quicker to reach the 4K resolution where previously it took almost a minute for the resolution to get up to speed and the audio stutter is quicker to correct itself so that is also a plus. As far as seeing any changes in the picture quality I can't confirm that it is any different (might be a bit more vibrant) but at least it is still as good as it was. Previously I had read you should do a factory reset after doing a new firmware update. I haven't yet done that and prefer not to since it is a bit of a hassle to have redo all my settings so I don't plan on doing one.
Sony 75xZ9D
mt14942 is offline
post #13946 of 14302 Old 03-28-2018, 01:49 PM
iatacs19's Avatar
Quoted: 269 Post(s)
Liked: 162
I only do the factory reset when it's a major version. Like going from 6.x to 7.x otherwise I don't bother.
Sent from my SM-T820 using Tapatalk
OLED65C9PUA, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #13947 of 14302 Old 03-28-2018, 03:56 PM
bdrozda's Avatar
I have a 940c and never got the January Naugat alert / update and no longer see that file on the support site.
I see that the recent pkg 5 update also includes Naugat 7. (I better download it in case I don’t get the alert)
Do you think if/when I get the alert it will be ok to update?
I hate to do a factory reset because I have Google dual factor authentication and it was a pain to get YouTube
Reconnected properly to obtain all the previous features (subscriptions, etc) instead of the web version.
bdrozda is offline
post #13948 of 14302 Old 03-28-2018, 04:56 PM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
Good to Know as I really would like to avoid having to redo all my settings info and what not.
I would do the update when you get it. I have always done it from the TV, but had to be patient as it didn't always come right away as it seems Sony does not send out the firmware all at once. Of course if you get inpatient you can go the USB route via there web-site and as I said I almost wound up doing.
Sony 75xZ9D
mt14942 is offline
post #13949 of 14302 Old 03-28-2018, 06:22 PM
bdrozda's Avatar
I would do the update when you get it. I have always done it from the TV, but had to be patient as it didn't always come right away as it seems Sony does not send out the firmware all at once. Of course if you get inpatient you can go the USB route via there web-site and as I said I almost wound up almost doing.
Ironically right after posting no update alerts for the last two upgrades I received the alert when I turned on the TV.
Updated to Naugat plus latest fixes with no issues.
bdrozda is offline
post #13950 of 14302 Old 03-30-2018, 05:37 AM
mt14942's Avatar
Quoted: 750 Post(s)
Liked: 225
It's been 4 or 5 days since I did the upset and no issues so far. I like the way they changed the OSD to be on one side and smaller so when you are making picture setting changes it's easier to see the results.
goksucats likes this.
Sony 75xZ9D
mt14942 is offline
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
