**Official** Sony X930C / X940C Owners Thread - Page 476 - AVS Forum | Home Theater Discussions And Reviews
 7034Likes
post #14251 of 14456 Old 01-22-2019, 01:03 PM
tuckers's Avatar
Quoted: 33 Post(s)
Thanks for your answer. I will update to newer firmware. I did look at the Shield HDMI settings which are the only video settings it has. I was using the recommended 4K mode of Rec. 2020 10-bit. I was surprised that there was also a 12-bit version showing and even more surprised that the 940C works on this mode. I thought the 940C only supported 10-bit. Going to 12-bit really brightened up the picture, whites pop more, subjectively feels like max brightness has been raised 10-20%, and the blacks look much blacker. Even on non-HDR material. Darker HDR material is almost viewable when the sun is shining in my room too. So thanks for suggesting I look there, I thought the recommended settings would be the best.
I'll try the firmware update and re-calibration sometime soon.
Originally Posted by CCsoftball7 View Post
Your settings are very odd. Contrast should be set to max (for sure, partly why your picture is dark). The newer firmware definitely has improved HDR. You should probably upgrade and try the settings below to see if it helps. Also, are there settings on the player that can be adjusted? That could cause issues as well.
Brightness:
Brightness: Max
Contrast: Max
Gamma: 0
Black Level: 50
Black Adjust: Off
Adv. Contrast Enhancer: Off
Auto Local Dimming: Medium
X-tendend Dynamic Range: High
Color:
Color: 50
Hue: 0
Color Temperature: Expert 1
- Adv Color Temperature
- R-Gain: Max
- G-Gain: Max
- B-Gain: Max
Color Space: Auto
Live Color: Off
Clarity:
Sharpness: 50
Reality Creation: Manual
- Resolution: 20
Mastered in 4K: Off
Random Noise Reduction: Off
Digital Noise Reduction: Off
Motion:
Motionflow: True Cinema
CineMotion: Off
tuckers is offline
post #14252 of 14456 Old 01-22-2019, 02:51 PM
CCsoftball7's Avatar
Quoted: 1704 Post(s)
Liked: 1304
I'm happy this helped. If you don't mind, follow up with what you find and maybe others can find it useful as well.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #14253 of 14456 Old 01-23-2019, 01:44 AM
eXeraZoR's Avatar
Quoted: 23 Post(s)
Liked: 25
Hi
Anyone knows if this update will also work with our model x940c?
Maybe our one gets this at a later date or will never get a new update again
https://www.sony.com/electronics/support/downloads/00015771
eXeraZoR is offline
post #14254 of 14456 Old 01-23-2019, 07:50 AM
iatacs19's Avatar
Quoted: 320 Post(s)
Liked: 192
Originally Posted by eXeraZoR View Post
Hi
https://www.sony.com/electronics/sup...loads/00015771
No, it won't work. Even if you try it, the TV will tell you it's not valid for your specific model.
OLED65C9PUA, NVIDIA SHIELD TV Pro, Xbox One X, B&O Beosound Stage, BDI 8179
iatacs19 is offline
post #14255 of 14456 Old 01-23-2019, 10:12 AM
Quoted: 48 Post(s)
Does changing it to a 12-bit output on the Shield really help brighten or increase the contrast of your HDR picture mode? I am curious to see if you are experiencing the same thing after you update your 940C to the latest available firmware and if your Shield is on the latest firmware (7.2.2) as well. Very curious to see your results and thanks for sharing this.
TotoyZ4 is offline
post #14256 of 14456 Old 01-23-2019, 04:40 PM
x21inc's Avatar
Quoted: 109 Post(s)
Liked: 70
Hello all
Can anyone who's owned both the 940c and the z9d give any insight on both TV's performance when it comes to controlling blooming and black bar handling? I've read up on a few z9d posts stating the presence of bad blooming regardless of its backlight master drive.
Does the z9d have any significant improvement over the 940c when it comes to the above mentioned issues?
x21inc is offline
post #14257 of 14456 Old 01-23-2019, 05:04 PM
Egghaus's Avatar
Quoted: 134 Post(s)
Liked: 74
Originally Posted by x21inc View Post
Hello all
That sounds more like comments about the Z9F than Z9D. I do not have experience with the Z9D but everything I have read points to its excellent cinema bar bloom control. The 75" Z9D has over 800 zones vs only 128 in the 940C. The only negative I have read about Backlight Master Drive is it creates a very narrow viewing angle even for LCD standards. To me the 940C has pretty good viewing angle for a FALD VA panel.
Egghaus is offline
post #14258 of 14456 Old 01-23-2019, 05:41 PM
x21inc's Avatar
Quoted: 109 Post(s)
Liked: 70
This is good info. 'much appreciated sir
x21inc is offline
post #14259 of 14456 Old 01-23-2019, 11:59 PM
tuckers's Avatar
Quoted: 33 Post(s)
I've had it set on 10bit for over a year, changing to 12bit was pretty noticeable. Why? That I don't know.
tuckers is offline
post #14260 of 14456 Old 01-24-2019, 08:50 AM
Quoted: 48 Post(s)
I tried it for a short bit last night. Have a Shield TV on 7.2.2 connected to my Pioneer Elite SC-97 that goes to my 940C on latest firmware. Setting is 422 Rec.2020 12-bit at 59.xx HZ on my Shield instead of the Shield Recommended 10-bit 420 Rec. 2020...I didn't notice any issues but will need to see if anything shows a visible difference. Both modes look amazing in HDR. I left the Shield beta setting of automatic colorimetry to off...Shield with 940c never had issues to me with remapping SDR to HDR color spaces...turning on colorimetry beta option actually makes my Netflix app crash to black screen 100% of the time for some odd reason. Beta for a reason...
Will test some stuff later to see if anything pops out. Can't hurt to leave it at this setting as I haven't seen any issues yet so why not be at 12-bit. 422 if anything can possibly means more detail in luminance than the 420 so more is better right?
EDIT: Found this site with some comparisons of 422 to 420. Source media is a factor but something interesting nonetheless.
https://www.ntt-electronics.com/en/i...d-video-codec/
TotoyZ4 is offline
post #14261 of 14456 Old 01-24-2019, 07:20 PM
Quoted: 14 Post(s)
[QUOTE=kronan;57012286]I have a xbr75x940c, the picture flashes black randomly (sound stays on and TV is on) sometimes 5 or more in a row, (the flashes to black are 1 to 2 seconds long)sometime it will stay on for a few min. occasionally it will turn off and I get 4 red flashes on the led indicator, any idea what I can do, my local repair shop says 850.00 to "possibly" fix it...I am fairly savy and could possibly replace some parts if need be, sony was no help..
thank you...I did just order a85" 900F so I can take my time with the repair on the 940c[/QUOTE
I found a LED driver board in china... took 3 weeks to get it... anyway its up and running for 309.00
kronan is offline
post #14262 of 14456 Old 01-28-2019, 07:18 AM
GunmetalR56's Avatar
Quoted: 272 Post(s)
Liked: 425
My experience so far is that the 940c has a better viewing angle than the Z.
Blooming in cinema bars on the Z definitely exists but it has noticibly better blooming control overall.
Ascend Sierra Towers w/RAAL, Ascend Horizon Center w/RAAL, Ascend Sierra 2 surrounds, PSB Imagine XA Atmos modules (x4), SVS PB13 Ultras (x2), SVS PB12+ (x2)
Denon X6500H / Emotiva Mini-X a-100
Panasonic DP-UB820 / PS4 Pro / XBOX 1X
Sony XBR75Z9D, LG OLED65B7A
GunmetalR56 is offline
post #14263 of 14456 Old 01-29-2019, 08:24 AM
jarroldharrell1's Avatar
Quoted: 28 Post(s)
Liked: 6
I want to hang my 940c on the wall. Anyone know if there is a special bracket for it, or will any general bracket do?
jarroldharrell1 is offline
post #14264 of 14456 Old 01-29-2019, 10:30 PM
dalto's Avatar
Quoted: 1292 Post(s)
Liked: 658
Any wall mount that matches the vesa pattern and that can hold the weight should work.
It is heavy. I decided to use an articulating mount so that I could access the back easily. It has come in handy.
Tom Riddle likes this.
dalto is offline
post #14265 of 14456 Old 01-30-2019, 06:16 AM
Quoted: 28 Post(s)
Liked: 6
"Vesa Pattern"? Do I search for that phrase specifically?
post #14266 of 14456 Old 01-30-2019, 06:34 AM
Quoted: 28 Post(s)
Liked: 6
Originally Posted by Fazzz View Post
I've had my 930C for about 2 years on this mount with no problems whatsoever. It's pretty easy to set up, sturdy and is full motion
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My 940c is the 75". I need a good mount for it. Any recommendations?
post #14267 of 14456 Old 01-30-2019, 11:36 AM
dalto's Avatar
Liked: 658
If you look in the specification sheet or the manual it should be listed. It will be something like VESA 400x300. It basically defines the distance between the mounting holes on the back of the TV. The specifications for any wall mount should also list the sizes they support.
Also, if you search this thread for mount you should find specific models listed that people are using. This question comes up somewhat frequently.
EDIT: I am using this one: https://www.monoprice.com/Product?p_id=12280
dalto is offline
post #14268 of 14456 Old 01-31-2019, 04:58 PM
Tom Riddle's Avatar
Quoted: 1101 Post(s)
Liked: 1353
I have mine on this one - works great and the articulating arm is awesome.
Routh Family Theater - My Dedicated Home Theater Build - 7.2.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I & TV3612 Subwoofers
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #14269 of 14456 Old 02-13-2019, 11:30 AM
yubakram's Avatar
late reply - but I used the Omnimount ULPC-X - low profile holds up to 250lbs.. great mount if you can locate one.. we pull out our 75" 940c all the time and rotate. The unit is a tank!
https://www.amazon.com/d/TV-Wall-Cei...ion/B002Q9LW5K
yubakram
My DIY Screen Endeavor!
yubakram is offline
post #14270 of 14456 Old 02-19-2019, 02:46 AM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 746 Post(s)
Liked: 633
marcuslaw is offline
post #14271 of 14456 Old 03-24-2019, 05:34 AM
marcuslaw's Avatar
Quoted: 746 Post(s)
Liked: 633
Over the past year, I'm not sure exactly when it began or after which FW update, my panel has developed a flicker across the top 1/3 of the screen during initial 3-D playback from an Oppo 203 via a Marantz 8802A into the 940C's ARC HDMI port. I say "initial" because I have found a remedy for it that includes rebooting the Sony and restarting all 3 components. Incidentally, we use Panasonic VIERA TY-ER3D4MU Active Shutter 3D glasses. Anyone else have this issue or are aware of a thread discussing it somewhere?
post #14272 of 14456 Old 03-24-2019, 06:12 AM
Tom Riddle's Avatar
Liked: 1353
I haven’t, but have you tried isolating the guilty party? I would suggest trying thr Oppo direct and even a different 3D player to make sure it is the 940c that is the culprit.
post #14273 of 14456 Old 04-02-2019, 02:47 AM
Liked: 0
Same here with 3D files over AppleTV 4K (Infuse / MrMC) on HDMI 3. It's not only flickering in the upper third of the screen, the 3D is also not working correctly. Rebooting the TV helps, but it is nevertheless very annoying. Haven't yet tried another HDMI port or direct play via a TV app – will do so and report back.
icanboogie is offline
post #14274 of 14456 Old 04-10-2019, 12:54 PM
charles0424's Avatar
Quoted: 57 Post(s)
Liked: 57
New update released yesterday. Anyone try it out yet?
charles0424 is offline
post #14275 of 14456 Old 04-10-2019, 01:12 PM
Balthazar2k4's Avatar
Quoted: 720 Post(s)
Liked: 834
Appears to be an Android security update. I installed it today on my 940C and nothing readily apparent seems to have changed.
Sony 77A9G / Sony STR-ZA5000ES / Martin Logan Motion 40i w/AFX (Front), Motion 50XTi, Motion 40i w/AFX (Rear) / REL HT/1508 / Bluesound Node2i / AppleTV 4K / ShieldTV Pro (2020) / 170TB Media Server
Balthazar2k4 is offline
post #14276 of 14456 Old 04-10-2019, 06:30 PM
pee
pee's Avatar
Quoted: 88 Post(s)
Liked: 53
Same here. No change. All settings seem fine as well.
pee is offline
post #14277 of 14456 Old 04-11-2019, 04:56 PM
Liked: 2
Upgrading now. So basically it will still be slow and apps run like garbage. Check. Love my LG oled way more than this big ass brick.
Sent from my SM-G950U using Tapatalk
dalek77 is offline
post #14278 of 14456 Old 04-15-2019, 04:04 PM
iatacs19's Avatar
Quoted: 320 Post(s)
Liked: 192
Benefits and improvements from the latest update
Provides the latest Android security updates
Improves the user experience (UX) of the "Enhanced format - HDMI signal format" setting
Installing now...
Sent from my SM-T820 using Tapatalk
iatacs19 is offline
post #14279 of 14456 Old 05-03-2019, 04:56 PM
ultrasilent's Avatar
Quoted: 286 Post(s)
Can anybody be more specific about HDR picture improvements? Did you made any calibration measurements about this? I`m really don`t believe in sony engineers (after I did saw what they did with good Android TV idea) and do afraid that they can broke HDR experience with newer FW...
Zidoo X9S (1.4.16.), Vertex FW 1.36.1.42, GUI 1.34
Himedia Q10 Pro (2.0.9 and 2.1.4) > 6ft copper > Vertex > 6ft copper > SONY X9405C HDR TV (HDMI 4)
Nvidia Shield Android TV (7.1.0.) 2015 16Gb+ 1TB HDD or ZIDOO X9S (2.1.22) >6ft copper >----> 6ft copper > Yamaha RX-A2020 HDMI 1.4 > SONY X9405C HDR TV (HDMI 1)
ultrasilent is offline
post #14280 of 14456 Old 05-05-2019, 03:20 AM
Quoted: 33 Post(s)
Liked: 6
loll they broke HDR again, hdmi dynamic range has to be set limited when in HDR video mode, else picture goes dim n fuzzy(whitewash), when set to limited colours are nice n bright and sharp
litlnicky is online now
Reply LCD Flat Panel Displays
940C , hdr , Sony , X930C , X940C
