"Official" Samsung JU6700/6600 (4K) 2015 model owners thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #91 of 126 Old 01-24-2016, 10:00 AM
kb11's Avatar
I am thinking of buying the UN65JU6700 and I know it has a VA panel but can anyone tell me is the curve panel made by Samsung or someone else?
kb11 is offline
post #92 of 126 Old 02-03-2016, 11:28 AM
J_alma's Avatar
Liked: 0
Just bought this TV and have serious problems with "White Clouds" over any black part of the image, also "judder" is very VERY bad when watching movies. I was able to calm the jutter problem down in menu system, but the white spots over the tv basically leaves my picture unwatchable.
J_alma is offline
post #93 of 126 Old 02-05-2016, 10:12 AM
boxer0987's Avatar
ive been using 4K videos on YouTube but how do I know if it's actually being received in 4K? On my last tv there was an info button that told me.
boxer0987 is offline
post #94 of 126 Old 02-09-2016, 01:13 PM
joe81's Avatar
I pulled the trigger on the 6700. Got it for 1499.00 at walmart. I calibrated using the rtings settings. Very bright and colorful picture. So far so good.
ID:	1241817   Click image for larger version
joe81 is offline
post #95 of 126 Old 02-09-2016, 02:51 PM
tripod39's Avatar
Quoted: 28 Post(s)
Never had a "judder" problem.
UN65JU6700FXZA TD01 3/15
PN51D6500
BD-D6500
Sony CT-100
USN Ret.
tripod39 is offline
post #96 of 126 Old 02-15-2016, 12:46 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
Any idea if the new Samsung k8500 uhd player would be ok with this model?
Bodyslide is offline
post #97 of 126 Old 02-15-2016, 01:43 PM
joe81's Avatar
My audio is on film mode, and sounds nice and loud. But it's never level. It usually gets noticeably lower. It comes and goes. Does anyone know how to fix this problem?
joe81 is offline
post #98 of 126 Old 02-16-2016, 06:02 PM
Liked: 0
Just updated to 1443 firmware via auto update when I got home today and turned on the TV. I got 1440.3 back in early January. There aren't any release notes on samsungs site and the latest release according to the site was released back in December. Anyone else seeing this?
endlezzdrifter is offline
post #99 of 126 Old 03-20-2016, 08:22 PM
Teisco's Avatar
Quoted: 36 Post(s)
Thinking of getting the 65" model but hate going from 70" to 65" so has anyone done this and what are your feelings?
Also about the 60hz - how will that effect gaming with this tv? Also how much does the 4k effect your frame rates?
Teisco is offline
post #100 of 126 Old 03-21-2016, 03:03 PM
Teisco's Avatar
Quoted: 36 Post(s)
Looks like no one comes here anymore?
I just got the 65" and need to know some things that are a mystery so far. One is with my old Sharpe I could have one hdmi cable come from my Denon and switch inputs between the pc, tv, cable, blu ray. But this tv won't let that happen. If I try to use one cable from Denon it will only provide cable tv and if I try to switch cable tv to pc on the Denon all I get is a black screen. So only way I can run pc is from a seperat hdmi cable and input so now sound is a problem.
How do you have your Reciever/TV setup and hooked up?
Teisco is offline
post #101 of 126 Old 04-12-2016, 12:26 AM
Peepo's Avatar
I just ordered this set using my Aeroplan points. I did some research and although this is not their top of the line set, I am basically getting it for "nothing". Otherwise I would not spend several thousand on a newer 2016 model anyways and this set seems like a good deal even if I bought it. I am upgrading from a 48" Vizio I got in 2011.
I don't really care about HDR... I have read enough about it and I'll leave that "fun" for the early adopters to waste their lives on - making sure the picture is good (and they have to watch in a dark room else it supposedly doesn't look very good). Supposedly there is HDR update for this TV but I don't believe it supports what the higher end sets will do. Unless I have HDR set right beside mine to compare, I won't really know (or care) what I am missing.
I also am not too concerned with 4K (I am just getting it mainly for the bigger size 65") since most of what I will watch is broadcast HDTV, AppleTV, Plex, Kodi, and playing a bit of Xbox One. Of course I may try out Netflix and some other services and one day get a 4K BluRay, but I really watch most of my content streaming and I think that would be a step backwards using those physical discs.
Can't wait till it gets here... they say 3-5 weeks but hoping it is closer to the 3 weeks.
A few questions:
Do I have to download update and flash or will it flash the updates automatically once I connect to the internet?
I have a Harmony Ultimate and have read it has issues with discrete HDMI 4 input IR code that doesn't work. They have a workaround now using macro and sounds like they do by setting it to HDMI 3 and doing an input up to HDMI 4. Does anyone have any more information on this?
Is there a Plex app?
Peepo is offline
post #102 of 126 Old 04-16-2016, 02:58 AM
Peepo's Avatar
I had this also on my new set. I had read somewhere else before I got it that by taking a soft cloth and gently wiping the screen with a small amount of force in the area of the clouds solves. Surprisingly it worked for me and I greatly minimized these clouds. There are still a couple areas but they are barely noticeable. Seems like there are reflectors or something in between the lcd and backlight that may loosen or form a gap and lightly pressing on screen fixes.
Peepo is offline
post #103 of 126 Old 04-16-2016, 03:06 AM
Peepo's Avatar
I received my set earlier than I thought. It is a huge upgrade in screen size from my 48" Vizio!
I did experience the white clouds on black screen that someone else mentioned but I responded already with what fixed for me.
To answer some of my own questions briefly...
Updates automatically (was already on latest version)
Didn't have issue with HDMI 4 yet and didn't see in detail how harmony handles it since I don't have 4 devices currently plugged in.
Plex app is available for download - works good (now I have 3 ways to view Plex on my TV instead of 2 LOL)
I cannot get it to output DD 5.1 to my Sonos Playbar. Still working on this.
Tried a 4K x265 file I downloaded, played via USB and looks pretty nice.
Watching some 1080p BluRay rips look amazingly good and I sorta agree what I read in lots of places - that 4K/UHD may not be as big of a deal at viewing distance I am at.
Don't notice any judder.
Peepo is offline
post #104 of 126 Old 04-16-2016, 04:03 AM
Viper32's Avatar
Quoted: 1344 Post(s)
Liked: 1029
Great to hear, enjoy your set.
Current Sets: Sony XBR65A9F Master Series, Sony XBR75X940C, Sony XBR75X940D, Samsung UN65KS9800, TCL 65R617
Previous Sets: Samsung Q9FN, Sony XBR65X930D, XBR65X900B, XBR49X830C, Samsung KS8000, KU6500, UN55KS8500, UN49JS8500, JS9000, JU7090, JU6500, JU6400, HU9000, HU7250, PN64F8500, Vizio P65, LG 65EF9500, LG 55EC9300, Hisense 55H8C, TCL P-Series (55P607)
Viper32 is offline
post #105 of 126 Old 04-16-2016, 11:12 AM
Peepo's Avatar
Ok, I got DD 5.1 working. I also got DTS transcoding from my AppleTV using MrMC (Kodi port). This is required because Sonos Playbar does not support DTS.
The issue was getting Dolby Digital selected
Seems that the option to select Dolby Digital was grayed out and only PCM was selectable (well, and a DTS Neo 2:5 which I didn't know what that is)...
Menu, Sound, Additional Settings, Audio Format.
What I had to do is play back a video with Dolby Digital and while it was playing I could go into this same Sound settings and select Dolby Digital. Once I did that the TV knows the setting and will seem to flip between PCM and Dolby Digital depending on the source.
For my AppleTV, I set Settings, Surround Sound to Dolby Digital 5.1
How to get DTS from MrMC...
The instructions I follow online did not work and I would get silence when playing back DTS:
Set "number of channels" to 2.0.
"Output configuration" to optimised.
"Enable Passthrough" on
"AC3 capable receiver" on
" - Enable Dolby Digital transcoding" on
"DTS capable receiver" off
After experimenting I changed the number of channels from 2.0 to 5.1 and now it works perfect and transcodes DTS to Dolby Digital 5.1 on the fly. Can verify in Sonos App it sees Dolby Digital 5.1 (Sonos, About Sonos System)
Plex on AppleTV also is transcoding to Dolby Digital 5.1 (believe it picks up AppleTV settings).
However, Plex App on Samsung TV outputs Dolby 5.1 but won't transcode DTS to Dolby Digital 5.1 and therefore defaults to PCM. Here is strange thing - I find that after playing a DTS movie in this TV Plex app then I have to go back and manually select Dolby Digital again for subsequently DD 5.1 videos afterwards (eg. playing back from AppleTV) or it defaults to PCM/Stereo in the TV. Not sure if other TV apps have same affect.
Hope this helps someone...
Peepo is offline
post #106 of 126 Old 04-17-2016, 05:05 PM
Quoted: 438 Post(s)
Liked: 192
The white clouds on the screen are very annoying lots of flash lighting going on. I will deal with it at $1500 price point. If I paid any more I would take it back. Besides that I absolutely love the TV and it is only noticeable on a black background while anything is being displayed on the screen I don't notice it. No issues with judder for me and I have all the motion crap off cause I'm using this 65" as a PC monitor in Chroma 4.4.4 and game mode. Movies and everything look wonderful. Gaming at 4k is breathtaking. The entry price into OLED is just too steep for all the features I want. MY next move is OLED or a 4k projector this guy will hold me off until prices get a little better. Overall I'm happy with the TV for the price.
David Varner is offline
post #107 of 126 Old 07-05-2016, 09:21 AM
Liked: 0
muy tv didnt came with the screws
muy tv didnt came with the screws:crying : please help can anyone id the screws or measure em?
thanks,
Rob
Rj Chópite is offline
post #108 of 126 Old 07-20-2016, 07:07 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
Firmware 1460 is out. No Idea what it did...
post #109 of 126 Old 07-21-2016, 05:55 AM
tripod39's Avatar
Quoted: 28 Post(s)
After a year I found UHD on my menu (pic options) and turned it on.Is it my imagination or is pic really sharper and the colors more brilliant?
PN51D6500
BD-D6500
Sony CT-100
USN Ret.
tripod39 is offline
post #110 of 126 Old 09-08-2016, 01:08 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
I found this set on sale this weekend for 699.00. Is that a good deal?
basshead81 is offline
post #111 of 126 Old 09-12-2016, 06:39 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
So I went ahead and purchased this TV and I am very impressed. Scored big time at the 699.00 price, hell I would of been happy paying more. Fantastic picture and the off axis viewing is fine. I love the remote control with the pointer feature.
post #112 of 126 Old 10-26-2016, 09:09 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
anybody know what the latest firmware update changed?
post #113 of 126 Old 11-25-2016, 03:28 AM
talon95's Avatar
Quoted: 337 Post(s)
Liked: 186
Anybody know what the new 1464 firmware changed? I just got it on my 6700 yesterday.
talon95 is offline
post #114 of 126 Old 11-26-2016, 05:31 AM
tripod39's Avatar
Quoted: 28 Post(s)
Me too.No idea.
PN51D6500
BD-D6500
Sony CT-100
USN Ret.
tripod39 is offline
post #115 of 126 Old 11-26-2016, 06:49 AM
talon95's Avatar
Quoted: 337 Post(s)
Liked: 186
Did we have Amazon HDR before?? I tried it the other day, but it wasn't working. Now it is. Although I tried The Grand Tour before which was partially messed up in the Amazon listings and didn't always offer HDR depending on how you selected it. So I'm not sure if it changed or not.
talon95 is offline
post #116 of 126 Old 11-30-2016, 08:30 PM
Peepo's Avatar
I just upgraded my Xbox One to an Xbox One S. I had my Xbox on HDMI 3. Xbox One S gives detailed HDMI information but showed that all of the HDR10 settings were unavailable with warnings indicating was disabled. I remember reading that this TV does support HDR but only on HDMI 1. I swapped inputs and enabled UHD Color on HDMI 1, and sure enough - now all the HDR settings are enabled in Xbox One S showing nice green checks for everything. I realize that this TV is not as capable as a real HDR one, but it makes be feel better
Peepo is offline
post #117 of 126 Old 12-17-2016, 03:49 PM
Liked: 0
Sports Mode
What are the best settings for watching sports besides the sports mode. I just got the TV and would like to figure out best settings. I also had a blurr judder problem but figured it out. The TV upgraded to 4K 30hz when I ran Directv HDMI through my Onkyo receiver. Ran it straight to TV no blurr or judder and displays actual HD 1920X1080 60i. I probably need to fix setting on my receiver unless someone knows about a setting on the TV. I am trying to like this TV but my Samsung 50" 1080p seemed to have a better picture. Any suggestions on the different settings would help especially in Dynamic or Standard mode.
Ddurh is offline
post #118 of 126 Old 03-12-2017, 03:28 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9205
I watched Secret life of Pets in 4k HDR with the Sammy K8500 player and the picture was Amazing! It showed HDR under the info tab.
post #119 of 126 Old 04-03-2017, 05:10 PM
Liked: 0
Hi.
I bought a UN65JU6700.-
1- I can´t find a way to control the volume of the headphones.-
2- I only can turn off the screen and play only audio through the speakers if the source is HDMI. Does not work when a video is playing from a hard drive connected via usb.-
Thank you very much for your help.
fogmancito is offline
post #120 of 126 Old 04-04-2017, 06:08 AM
whizkid39's Avatar
Quoted: 24 Post(s)
Liked: 30
Last week received update #1469 for my JU6700.Any one know what it addresses?
USN Ret.
TCL55P607
Westy,WD48FB100
Polk Signa
4 Vizios,2 RCA,2 Sony, 2 Toshiba,1Panasonic,2 Samsung-Gone.
whizkid39 is offline
Reply LCD Flat Panel Displays
