Fandango (Formerly MGo) 4K download troubleshooting thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 792Likes
post #1231 of 2338 Old 08-19-2015, 09:39 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
Originally Posted by sytech View Post
You should be able to fit roughly 14 UHD/HDR full length movies on the hard drive.
I only have 8, but it insists it's full unless I delete something. The movie(s) I deleted I would never watch anyway, but just another of those 'known issues' that M-GO is always touting.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
post #1232 of 2338 Old 08-19-2015, 09:45 AM
grizzledbiker's Avatar
Quoted: 2886 Post(s)
Liked: 1331
If Vidity is indeed chip embedded than I would assume one could re-format the drive and have plenty of room available.
I personally think HDR is over hyped and $30/80+g for one movie is just a waste of money and drive space. Yes it may look better. But IMHO not that significant of a difference to justify.
grizzledbiker is offline
post #1233 of 2338 Old 08-19-2015, 09:56 AM
ahro's Avatar
Liked: 4130
I had enough difficulty getting the drive to work with M-GO -- how on Earth would you reformat the drive?
HENRY
ahro is offline
post #1234 of 2338 Old 08-19-2015, 10:20 AM
Liked: 1331
It's done on your PC. Basically wipes it clean. But in this case it's windows based NTFS and so you couldn't do it on Apple anyway.
post #1235 of 2338 Old 08-19-2015, 10:27 PM
ray0414's Avatar
Quoted: 12407 Post(s)
Liked: 11583
Thought i would put this out there for everyone that does the MGO HDR. but i was playing with the new JS9500 tonight with the HDR, and it seems that some of our suspicions were correct about Dynamic Contrast with HDR. With dynamic contrast turned off, the picture is dark and alot of detail is lost that should be there. When you turn it on, it brightens up all the dark areas and brings out detail and more color all over the place and DOES NOT CRUSH. if anything, the picture is crushed with dynamic contrast turned off. the key to HDR with samsung sets its dynamic contrast, no doubt about it.
ID:	897178   Click image for larger version
75Q9FN*55C8OLED*Galaxy S10+ *Ub820 fed into Oppo 203* XB1X* 4k Denon X4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is offline
post #1236 of 2338 Old 08-20-2015, 02:59 AM
Liked: 1331
Ray - I've had DC on high from day 1 back in Sept. Picture looks blah without it. No arguement here.
ray0414 likes this.
post #1237 of 2338 Old 08-20-2015, 09:23 AM
GregLee's Avatar
Quoted: 1092 Post(s)
Liked: 382
I still don't believe this theory that HDR requires Dynamic Contrast turned on. I do believe that sometimes turning on Dynamic Contrast improves the picture by making some picture detail visible, but that may be because other settings were not set optimally, like Contrast and Brightness. It doesn't prove anything.
ahro likes this.
Greg Lee
GregLee is offline
post #1238 of 2338 Old 08-20-2015, 09:54 AM
ray0414's Avatar
Liked: 11583
Greg, I can take pictures all day showing that with dynamic contrast off, the picture is crushed. I have the backlight and contrast at max here on the JS9500 which is a 1000 nit tv, and the picture is completely crushed with it turned OFF.
Hdr is supposed to fill the picture with detail and color, which doesn't happen with it turned off. I really hate arguing about this, but to me and alot others the difference is extremely obvious.
ray0414 is offline
post #1239 of 2338 Old 08-20-2015, 11:11 AM
GregLee's Avatar
Liked: 382
I don't doubt it. I'm not questioning your observations. Did you read the part of my comment where I mentioned Brightness? The first remedy you should try for crushed blacks is to turn up Brightness. Put on a scene with shadows, turn off Dynamic Contrast, then turn up Brightness until shadow detail becomes visible. I'm not saying this is a sure cure for crushed blacks, but it is something you should try before coming to the conclusion that you need Dynamic Contrast. It is not necessarily best for blacks to have Backlight and Contrast maxed out. (Also, make sure Black Tone is Off, and check the Gamma setting.)
Greg Lee
GregLee is offline
post #1240 of 2338 Old 08-20-2015, 01:49 PM
ahro's Avatar
Liked: 4130
Stange thing going on with my M-GO HDR movies. Sometimes I can control DC and black tone and gamma. Other times I can't. It looks so much better when I CAN'T control them, as though the M-GO HDR wants particular settings to look its best.
When this occurs, I can only control BL, contrast, color, sharpness and tint.
HENRY
ahro is offline
post #1241 of 2338 Old 08-20-2015, 01:56 PM
GregLee's Avatar
Liked: 382
... as though the M-GO HDR wants particular settings to look its best.
And those settings it wants are ... ?
Greg Lee
GregLee is offline
post #1242 of 2338 Old 08-20-2015, 03:16 PM
ahro's Avatar
Liked: 4130
It seems that DC is HIGH, black tone Dark, Gamma O
If I leave M-GO and re-enter, I can gain control again. Go figure, but it looks good when I have no control over those settings, Of course either way, I get snap back of BL and contrast.
When I do have control. I can't seem to dial it in to my satisfaction.Believe it or not, that's what happens when I load M-GO from the Tizen strip on my STB.
HENRY
ahro is offline
post #1243 of 2338 Old 08-20-2015, 03:28 PM
ray0414's Avatar
Liked: 11583
I will check it out later. I have a feeling i have to turn brightness up to 60 or 65 to bring out the same detail out which imassuming would hurt overall black levels.
ray0414 is offline
post #1244 of 2338 Old 08-20-2015, 03:33 PM
ahro's Avatar
Liked: 4130
@GregLee -- I don't know if this has anything to do with it, but I load the movies from the Vidity movie strip on the movies page and not from my library page.
HENRY
ahro is offline
post #1245 of 2338 Old 08-20-2015, 06:08 PM
ray0414's Avatar
Liked: 11583
HDR clip on the JS9500. Playing again with dynamic contrast, decided to take more pix. which picture do you think has the most "crush"? which picture shows the most detail/ the least detail?
ID:	899066   Click image for larger version
ID:	899074   Click image for larger version
ray0414 is offline
post #1246 of 2338 Old 08-20-2015, 08:08 PM
GregLee's Avatar
Liked: 382
I can't tell anything from that. To see if shadow detail is crushed, I'd need to see a scene with shadows.
Greg Lee
GregLee is offline
post #1247 of 2338 Old 08-20-2015, 08:28 PM
prme19's Avatar
Quoted: 447 Post(s)
Liked: 393
At a calibration standpoint, I'll have to agree with Greg Lee. Dynamic Contrast on High in regular content will crush blacks, but will show more light or colored details. I'm guessing this will also apply on UHD/HDR. But, I'm not against using Dynamic Contrast because I do have mine set to High for HDR content, but for other content/sources, I turn it off for the above mentioned reason.
my JS8500 movie calibration settings as of 8/8/15 https://www.avsforum.com/forum/166-lc...l#post34495410
my JS8500 standard calibration settings as of 6/18/15 https://www.avsforum.com/forum/166-lc...l#post35124130
prme19 is offline
post #1248 of 2338 Old 08-20-2015, 08:46 PM
prme19's Avatar
Quoted: 447 Post(s)
Liked: 393
Here's some pics to show how Dynamic Contrast causes Blacks to crush (sorry for the poor quality of the images, i took them with an iPhone 6), I used the brightness panel in the Disney WoW disc, I know the stars flash back and forth, each pic was taken exactly at the same time a few seconds after the stars flashed:
PIC 1: Dynamic Contrast Off
PIC 2: Dynamic Contrast Low
PIC 3: Dynamic Contrast Medium
PIC 4: Dynamic Contrast High
ID:	899226   Click image for larger version
ID:	899234   Click image for larger version
ID:	899242   Click image for larger version
prme19 is offline
post #1249 of 2338 Old 08-20-2015, 09:38 PM
ray0414's Avatar
Liked: 11583
yes, it crushes with regular content, with HDR, it works completely differently. its so obvious that i think you guys are just denying it. its even more obvious in person.
Troy LaMont likes this.
ray0414 is offline
post #1250 of 2338 Old 08-20-2015, 10:12 PM
chunon's Avatar
Quoted: 3733 Post(s)
Liked: 3553
Ive watched some hdr on my 9500 have never seen anything even remotely "dull" or lacking detail never used dynamic contrast. sounds more like a preference that not everyone will like. You can't force a personal preference on someone imo.
chunon is online now
post #1251 of 2338 Old 08-20-2015, 10:21 PM
ray0414's Avatar
Liked: 11583
I got the JS9500 and HU9000 set up side by side tonight.
with dynamic contrast OFF, the pictures are actually pretty close. With dynamic contrast engaged on both sets, peak illuminator cranks up big time, more so on the JS9500. peak illuminator is what drives the HDR, so without it, it wont have its "it" factor.
ID:	899314   Click image for larger version
ray0414 is offline
post #1252 of 2338 Old 08-20-2015, 10:28 PM
prme19's Avatar
Quoted: 447 Post(s)
Liked: 393
I'm not denying anything. I'm simply stating what I know and see, that Dynamic Contrast on High crushes blacks while increasing pop on lighter details. Here's another example: cage/elevator scene from Maze Runner HDR, first few scenes of the movie. First Pic is Dynamic Contrast Off then Low then Medium then High. Just look at the sleeves on his right shoulder, his bottom teeth, or the background. See how these seems to disappear in the shadows?
ID:	899330   Click image for larger version
ID:	899338   Click image for larger version
ID:	899346   Click image for larger version
prme19 is offline
post #1253 of 2338 Old 08-20-2015, 10:30 PM
ray0414's Avatar
Liked: 11583
heres another interesting picture.
I decided to keep dynamic contrast OFF the JS9500, and turn it ON for the HU9000. with the exception of a tiny bit of shadow detail (from the fald), the pictures now look almost exactly the same. the js9500 is being held back despite both tvs having backlights at 20.
Name:	dynamic contrast on HU9000.jpg
ray0414 is offline
post #1254 of 2338 Old 08-20-2015, 10:37 PM
ray0414's Avatar
Liked: 11583
whatever is going on with your camera is screwing with the picture, the picture shouldnt be more cloudy with dynamic contrast turned on, it should be darker if anything. were you playing with the exposure or something?
ray0414 is offline
post #1255 of 2338 Old 08-20-2015, 10:54 PM
player002's Avatar
Quoted: 3928 Post(s)
Liked: 2934
I have to say those HDR pics look horrible your blacks look grey entire picture is washed out..
My set up
LG 65B7 | Samsung KS8000 |Sony 55XBR 930D |Samsung 55Q7 Samsung 60F8500 |LG Oled 55C8
LG Oled 65C8 |Samsung 65 Q9FNSamsung 55 Q8FN | Sony 65 900F |Samsung 65 NU8000
Onkyo TX-NR545 + Dolby Atmos Speakers |Xbox One X |Ps4 Pro |PS VR |Oculus Rift
AMD Ryzen 1700 + Vega 64 + Mining Rigs Samsung Galaxy S8
player002 is offline
post #1256 of 2338 Old 08-20-2015, 11:08 PM
ray0414's Avatar
Liked: 11583
here is a VERY dark scene in exodus HDR. with dynamic contrast OFF, the picture is very dark. you really cant make out any details, despite both backlights being at 20. when i turn on DC to high, the entire picture lights up, and nothing is crushed at all, it brings out all the details you couldnt see before. and if you see the blu ray, this scene is not supposed to be totally dark like this, the HDR grading process darkened the picture, and the tv needs to "relight" it back up. i mean seriously, what exactly is being crushed in the DC on picture?? The HU definitely has a hard time luminating the picture, though in person you can actually see alot more than whats in the picture.
the JS9500 has peak illuminator ULTIMATE. dynamic contrast helps turn that on. thats why when i turn DC on, the js9500 zooms past the 9000 which is lacking the juice and has a lower version of peak illuminator. with SDR dynamic contrast crushes big time, but not with HDR. havent seen it at all yet.
ID:	899434   Click image for larger version
ray0414 is offline
post #1257 of 2338 Old 08-20-2015, 11:09 PM
player002's Avatar
Liked: 2934
Looks like last Fw changed dynamic contrast a little in HDR mode. The director probably does not intend that dynamic contrast to be on if this is the case Metadata would adjust the set accordingly. Dynamic contrast behaves differently in HDR mode. Dynamic contrast up until medium offers little to no perceivable black crush and it actually brightens up highlights and some darker details. Dynamic contrast high in HDR mode with current FW does crush some details and over brightens others. Example life of pi sunset with tiger in boat with dynamic contrast set to high you can't see the details of the sun it is clipping or over brightening the sun so you can't see the detail. also look at the reflection in water of sun its just a yellow blob you can't see the ripples in the water they are washed out. My personal opinion dynamic contrast can help the picture look brighter and have more specular highlights up until med with little to no crush. High does look bright and punchy but it is actually crushing some dark and bright detail.
We are very early in HDR phase and as fall approaches and netflix along with bluray ramp up for 4k hdr release we are bound to see some improvements. Expect quite a few HDR FW updates from now until christmas it will only get better. Try some hdr clips and toggle Dynamic through the levels and report what you see.
prme19 likes this.
My set up
post #1258 of 2338 Old 08-20-2015, 11:19 PM
GregLee's Avatar
Liked: 382
If you have an HDR capable set, it is going to be able to deliver high peak brightness levels for small areas on the screen regardless of whether the source is HD, UHD, or HDR. What would prevent the TV from producing very bright areas with a non-HDR source? So far as I know, nothing would prevent it, provided you set the user controls to allow high peak brightness.
Consequently, when you compare HDR with non-HDR sources and expect the HDR sources to give you more brightness, you're going to be disappointed. Unless, of course, you turn up user controls that affect brightness whenever you're watching a source that was branded HDR -- then you'll see more brightness, but it will have nothing to do with HDR in the source.
This is my theory of why the HDR branded sources from MGO sometimes set Contrast and Backlight to the maximum. Someone stuck in metacommands to do that with the idea of minimizing complaints from users that the HDR movies weren't any brighter than regular UHD movies. It's not that they should be brighter because they're HDR; it's because people expect them to be brighter.
The difference we ought to be seeing between UHD and UHD-HDR should be the extra color shading information in 10 bit sources, not more brightness.
Greg Lee
GregLee is offline
post #1259 of 2338 Old 08-20-2015, 11:20 PM
player002's Avatar
Liked: 2934
I really think we are going to have to calibrate a HDR mode for our sets and await more FW for HDR playback. HDR is not just about a bright picture it is about accurate colours and specular highlights it's about tricking the brain with light output to think the image is real so the tiniest details should not be lost. The js9500 is super bright so if on my Hu its crushing on dynamic high it is definitely crushing and blowing out highlights on JS9500.
Dynamic low to med is acceptable for what I have seen so far on HDR like I stated it does bring out some dark details and improves highlights but on high I can't honestly say you will get a refrence PQ it will be bright and have crazy highlights but @ the expense of overblown highlights and some black crush..
prme19 likes this.
My set up
post #1260 of 2338 Old 08-20-2015, 11:26 PM
ray0414's Avatar
Liked: 11583
tried the c lips earlier with the tvs side by side, it acts the same. even with the js9500, the picture is on the dark side with it on medium. i dont think any directors intended their movies being redone in HDR, so that point is moot. the question, is what did the production company intend when they were doing their grading. I dont think there will ever be exact calibration settings for HDR because every movie or tv show will be graded with a different purpose which could require the viewer to set his settings differently each time.
people say they arent seeing a big difference with HDR, well i just showed you that with DC turned off, the js9500 and HU9000 have almost the same picture. its not until you activate peak illuminator via DC that you really see a huge difference. if you dont use at least medium DC, you will not see a difference over last years tvs.
ID:	899450   Click image for larger version
ray0414 is offline
Reply LCD Flat Panel Displays
fandangonow , hdr , js9000
