you tip a flat panel LCD HDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-11-2015, 04:51 PM - Thread Starter
Liked: 0
This may the dumbest question ever asked, but, is it going to affect operation of my TV to tip it slightly up so the screen is better directed to the viewer? I see them angled down from walls in offices all over, but mine is on a low stand, on it's feet, and I want to put something under the front feet and tip it up a little. Any long term ramifications to the panel (bending) or technical components inside? Only about 10 degrees. Thanks!
SKTillman is offline
post #2 of 3 Old 12-11-2015, 05:01 PM
asarose247's Avatar
Quoted: 1265 Post(s)
Liked: 1109
you want your line of sight to hit the screen in the horizontal middle
that slight a tilt should be no issue wrt "bending" or interanl components
you may experience more issues with unintended light reflection depending on how much you can control the "darkness' and incidental light.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 3 Old 04-26-2016, 11:43 AM
Liked: 0
Should make no difference - does it make one when you buy a titled wall mount?
speakertester is offline
Reply LCD Flat Panel Displays
