Official LG 55/60/65/75 UH8500 Thread - Page 78 - AVS Forum | Home Theater Discussions And Reviews
 1404Likes
post #2311 of 3624 Old 01-12-2017, 08:39 AM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
As an alternative, purchase (if not already) an XB1 S which will let you play 4K Blu-Ray in HDR10. Naturally a dedicated player would be the best, but if you want a gaming system and a great introductory level to jump into 4K Content you cant do much better than a Xbox One S for the value.
Datagg is offline
post #2312 of 3624 Old 01-12-2017, 08:46 AM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
On a side note speaking of HDR. You may have heard the Nvidia Shield has a new Model. I think it is important to know that the original model will get all new features via firmware update. Here is a post I made on a YouTube page when I was asked if the need to run out and buy one was necessary if already own the first.
The original shield to get HDR support via firmware update. http://www.theverge.com/ces/2017/1/4...stant-ces-2017 - In short "Nvidia says that existing Shield TV devices will get the new features through a software update delivered sometime in January."
Anyways, this is important IMO (why posted here) to anyone who is already in or thinking on jumping into HDR via the shield.
Thunder18 likes this.
Datagg is offline
post #2313 of 3624 Old 01-12-2017, 08:48 AM
Johnny Angell's Avatar
Quoted: 68 Post(s)
Originally Posted by bobtbobt View Post
I wanted 4 HDMI inputs. I use a Tivo, Bluray, Fire TV and a Chromcast. However, it seems that this tv is capable of screen casting from my Android and Windows laptops after downloading some free software, so I won't need the Chromcast. I haven't bought this tv yet but it is my current first choice. I'll wait another month before pulling the trigger.
Excuse my lack of knowledge on this but wouldn't an AVR with several inputs alleviate this problem? Couldn't all the things you want to input go into the AVR, or least some of them so that not having 4 HDMI is not a deal breaker?
Johnny Angell is offline
post #2314 of 3624 Old 01-12-2017, 08:52 AM
Quoted: 68 Post(s)
Originally Posted by irnmdnkristo View Post
The UH8500 has a 8bit panel with 10bit dithering and the UH9500 has a true 10bit panel. So the specs on the UH8500 is kind misleading that its not a true 10 bit panel. I got the info from hdguru.com
Is this a big deal? Is it worth the extra $1000 that the 9500 currently costs on Amazon?
post #2315 of 3624 Old 01-12-2017, 09:04 AM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
Absolutely. yet the AVR MUST support HDR 10, Dolby Vision, 4K and 3D if you wish to go that route or you wont get those features to your TV.
Johnny Angell and Thunder18 like this.
Datagg is offline
post #2316 of 3624 Old 01-12-2017, 09:05 AM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
IMO no. The UH8500 has dithering that ends up making it 10bit output anyways. Save your money is my opinion.
Datagg is offline
post #2317 of 3624 Old 01-12-2017, 09:13 AM
Thunder18's Avatar
Quoted: 121 Post(s)
Liked: 63
Especially since Rtings found the picture quality of the 8500 to match and in some cases exceed that of the 9500, FWIW.
"The peak brightness is below average. These measurements are consistently lower than the lower end UH8500, which is a bit surprising. Although the whole screen can get quite bright, the local dimming significantly reduces the peak brightness of smaller windows. This test is performed with a HDR10 signal."
"When viewed at an angle, the contrast decreases a little bit but the colors remain quite accurate. This is about the same result as the LG UH8500 which is good for an LED TV."
"The higher end UH9500 has a slightly more glossy screen than the UH8500, but it is still semi-gloss. It should be fine for a room with a few windows."
"Although the motion blur is better than average, fast movement isn't as clear as some other TVs. The LG UH8500 which is the model below actually has a shorter trail following moving objects, but this still shouldn't be an issue for most people."
"The motion blur is better than average, but noticeable worse than the slightly lower model LG UH8500."
"The LG UH9500 is a good all-round TV, but can be hard to recommend for those looking at the 65" variant due to its similar performance to the cheaper LG UH8500. In some cases, the LG UH8500 actually performs better due to the lower response time and higher peak brightness. For those interested in the 86" variant there is very little competition and it could be a good choice depending on your usage."
Sent from my LG-LS997 using Tapatalk
Johnny Angell likes this.
Thunder18 is offline
post #2318 of 3624 Old 01-12-2017, 09:58 AM
mercennarius's Avatar
Quoted: 273 Post(s)
Liked: 133
For 99% of users and content available the simple answer is no, it's not worth it. The UH8500 does a fine job with 10 bit content. If you could get the UH9500 for $200-$400 more then it would be worth considering. But at a $1,000 more and the fact that you most likely wouldn't even notice a difference your money is better spent else where.
mercennarius is offline
post #2319 of 3624 Old 01-12-2017, 10:15 AM
Liked: 2
I purchased the 65UH8500 at Frys last Sunday after monitoring the price for the past 4 days months. I was hoping the price of this TV would drop. But after the news that LG is not going to make 3D TVs in 2017, I went ahead and made the purchase. So far I'm impressed. It's not the best, it it has/does most of what I was looking for. Kind of a jack of all trades, master if none kinda Tv. The 2D to 3D conversion is cool! Can't wait to actually watch 3D content when I get a UHD player.
Sent from my LG-H901 using Tapatalk
bladerunner0427 is offline
post #2320 of 3624 Old 01-12-2017, 10:43 AM
Thunder18's Avatar
Quoted: 121 Post(s)
Liked: 63
While you are waiting to purchase a 3D player, check out 3D videos on YouTube.
bladerunner0427 likes this.
post #2321 of 3624 Old 01-12-2017, 11:09 AM
NorthJersey's Avatar
Quoted: 574 Post(s)
Liked: 246
nevermind that rtings.com rated the 8500 >9500 series, but if you look at the thread for the 9500 series, you will see a LOT of complaints from people.
NorthJersey is offline
post #2322 of 3624 Old 01-12-2017, 11:22 AM
Quoted: 14 Post(s)
Liked: 6
Any good 3d videos in youtube to test this tv?
bisip is offline
post #2323 of 3624 Old 01-12-2017, 12:14 PM
Thunder18's Avatar
Quoted: 121 Post(s)
Liked: 63
Search for "G NA Top Girl 3D". It is ridiculously immersive. Almost too much so. I'm not one of those people that get sick from 3D or experiences vertigo, but this one almost does it to me. . If this one bothers you, don't blame the TV, it's just very intense.
Let us know what you think?
raif71 and bisip like this.
post #2324 of 3624 Old 01-12-2017, 03:55 PM
Ddarkonline's Avatar
So i again called lg support on the whole 10 bit thing and their reply was and i quote
regard your tv the lguh850v, the tv is a true 10 bit panel with 400 cd.
It is not 8 bit panel with dithering.
The information you read on third party websites is wrong.
greetings
micheal ryan
LG electronics
So what do you guys think lg is specifically denying that the
lguh8500 8 bit panel.
Ddarkonline is offline
post #2325 of 3624 Old 01-12-2017, 04:16 PM
Wesley Hester's Avatar
Quoted: 190 Post(s)
Liked: 146
greetings
micheal ryan
LG electronics
See my post 2111 with a PDF of the entire 2016 LG TV lineup. It's been out there for awhile. I'm not claiming I discovered it or anything, easy to get to. I believe LG had to update it too and just didn't correct a copy and paste error on their site.
Datagg likes this.
Display: Optoma UHD51A Projector > Elite Screens R135WH1 ezFrame | 7.2.4 Audio: Onkyo TX-RZ920 9.2ch Network A/V Receiver, M-5010 2ch Amplifier; Definitive Technology ProCenter 2000, ProMonitor 1000(x10), SuperCube I & 4000 | Sources: PC, DirecTV, Apple 4K, Fire Stick 4K, Oppo UDP-203, Chromecast & Roku Ultras, Xbox One X, PlayStation 4 Pro & Nintendo Switch | Remote: Harmony Elite | HDMI: 40' Monoprice DynamicView+4x1 Switch
Wesley Hester is offline
post #2326 of 3624 Old 01-12-2017, 04:35 PM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
This will always go down as a point of confusion for the consumer. I had contacted LG and was told it was 8 Bit With Dithering also, then moments later got another answer. Guess we will never know the true answer as long as you believe the LG staff who act like they all took different training classes. There own tech sheet now says "8 Bit", so that's gospel in my book. Either way, for those who got the set (I was one of them) thinking otherwise to find out it wasn't, no worries the output after dithering is 10 bit.
Datagg is offline
post #2327 of 3624 Old 01-12-2017, 04:41 PM
Quoted: 190 Post(s)
Liked: 146
On the line up sheet, the marketing department would never leave off a "with 10-bit panel" tagline of a 10-bit panel display unless it was in error.
All show "Billions of Colors" so to accomplish this it has to be 10-bit panel models and 8-bit with dithering models.
P.S. when I was reading up on this TV, the LG site didn't make it clear if the Magic Remote was included or not. In fact, it appeared to say it didn't even though I knew from other sites and this forum that it did.
Datagg likes this.
post #2328 of 3624 Old 01-12-2017, 05:18 PM
raif71's Avatar
Quoted: 142 Post(s)
Liked: 58
I'm all for 8500 having an 8 bit panel but I'm gonna throw a monkey wrench here...what do you think will happen to 9500 sales if LG openly declares that 8500 do have a 10 bit panel? Especially since 8500 seems to perform better in PQ than 9500
Thunder18 and Datagg like this.
raif71 is offline
post #2329 of 3624 Old 01-12-2017, 05:47 PM
Thunder18's Avatar
Quoted: 121 Post(s)
Liked: 63
It's an interesting quandary to be sure. How do you justify the existence of a model that is supposed to be better, costs more, but is actually worse. The only advantage to it in my eyes is double the wattage for the audio and I don't even use mu TV speakers so that's a dubious advantage at best. I suppose design wise it does have a slimmer bezel at the bottom, but who cares?
post #2330 of 3624 Old 01-12-2017, 06:00 PM
wel the lg employee was very specific saying sites such as this and rting.com are wrong
note they did not just say that the panel is native 10 bit. they also said specially that its not 8 bit with dithering
also 400 cd is that 400 nts ?
btw doesent dolby vision require native 10 bit ?
post #2331 of 3624 Old 01-12-2017, 06:48 PM
Liked: 1
I bought the 65UH8500 as well. So far I've been impressed. I know people will **** on it but the built-in audio is pretty good. I want to get a soundbar for it but not sure if I should hold out for Dolby Atmos sets coming later this year.
dgambino1 is offline
post #2332 of 3624 Old 01-12-2017, 07:42 PM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
No they require a 10 Bit output display. how it gets there doesn't matter.
Datagg is offline
post #2333 of 3624 Old 01-12-2017, 07:44 PM
Datagg's Avatar
Quoted: 289 Post(s)
Liked: 262
No the sound was really good. Until i figured out to run an optical to my non 4K AVR I used it for quite some time and enjoyed it.
Datagg is offline
post #2334 of 3624 Old 01-12-2017, 08:59 PM
Liked: 2
I forgot my PS4 plays 3D discs so I popped in Prometheus...WOW! My next purchase is a soundbar. Waiting for my wallet to recover
post #2335 of 3624 Old 01-13-2017, 06:17 AM
3DBob's Avatar
Quoted: 1077 Post(s)
Liked: 577
LG 60UH8500 issue
Having an issue with my 60UH8500 for several days. About once every ten minutes or so, the screen goes black, then comes back on 1 or 2 seconds later. I thought it might be the cable, but other TVs in the house don't show the same issue. Has anyone on this board suffered the same issue??? I haven't tested whether the same thing happens watching a bluray--will do that later today. Very frustrating. Looks like a service call is in order.
3DBob is offline
post #2336 of 3624 Old 01-13-2017, 06:33 AM
Thunder18's Avatar
Quoted: 121 Post(s)
Liked: 63
Is this when watching OTA, or some other input source?
post #2337 of 3624 Old 01-13-2017, 06:46 AM
Quoted: 273 Post(s)
Liked: 133
I have not experienced this. My first suggestion would be to see if the TV does this on its own built in apps like Netflix/Amazon. If it does then you can rule out any external device or HDMI problem.
post #2338 of 3624 Old 01-13-2017, 07:26 AM
Quoted: 574 Post(s)
Liked: 246
you need to specify the source, is it a cable box? what cable are you using?
I'm in NJ, use Cablevision/Optimum, have an SA 8300HD cable box with a "regular" HD cable. From time to time the hdmi signal gets out of whack from this older cable box, and it requires me to reboot the cable box to fix, as unplugging and re-plugging in the hdmi cable, on the tv end and cable box end, doesn't resolve it
post #2339 of 3624 Old 01-13-2017, 08:50 AM
Quoted: 68 Post(s)
Optimum's newer Samsung boxes work much better.
Sent from my SD4930UR using Tapatalk
Jay Stone is offline
post #2340 of 3624 Old 01-13-2017, 10:03 AM
3DBob's Avatar
Liked: 577
I'm using a cable box, and yes, I realize it could be a bad box and am just now going to watch something internal to the set...thanks for all the responses so far.
3DBob is offline
Reply LCD Flat Panel Displays
55uh8500 , 60uh8500 , 65uh8500 , 75UH8500 , lg led
