Samsung popping and clicking sounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-17-2016, 08:15 AM - Thread Starter
fasttimes's Avatar
I have a new UN65JS850DFXZA from Costco. I've been unable to get ARC to work for the built in Netflix to send sound back to my AV. I've spent hours on the phone with Samsung to no avail. They are sending me a new one connect box to see if that fixes the issue.
In the meantime I've been using an optical cable for the sound, but I am getting a lot of popping and clicking noise, especially when I use my STB which is plugged into the TV directly. Yes, I know I can use the pass through on the AV and avoid this, but I shouldn't have too.
My receiver is an RXV473 from Yamaha. Is there anything I can do to try identify/solve the problem of the popping and clicking?
fasttimes is offline
Reply LCD Flat Panel Displays
