Proscan PLED6515 65ìnch 4K led - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By audiman
post #1 of 7 Old 03-05-2016, 01:10 AM - Thread Starter
aravs's Avatar
http://www.visions.ca/catalogue/cate...4&sku=PLED6515
Just wondering if anyone has any experience with owning this tv?
Its onsale in Canada for $996. This is the cheapest price for a non smart $4k display but is it any good
Response Time (Televisions)6 msScreen Size (Televisions)65 inchesDisplay Resolution 3840 x 2160 (4K UHD; 16:9)Smart TVNoPanel Type (Televisions)Information Not Available3D CapableNoDual View Multiplayer GamingNoGame Mode (Televisions)Information Not AvailableDimming TechnologyInformation Not AvailableVideo Upscalingto 4k Digital Cinema + 1080p UpscalingContrast Ratio5,000:1Refresh Rate (Televisions)120HzViewing Angle (Televisions)178° (H) 178° (V)Tuner (Televisions)Digital: ATSC // Analogue: NTSCPicture Modes (Televisions)Information Not AvailableSpeakers (Televisions)Information Not AvailableSpeaker Power Output (Televisions)Information Not AvailableAudio Enhancement (Televisions)Information Not AvailableHDMI Input(s)3MHL® CompatibleInformation Not AvailableComponent Video Input(s)1Composite Video Input(s)1RF Inputs (Televisions)1VGA Input(s)1Headphone / Line Output(s)1RS-232C (Control/Service)Information Not AvailableOptical Digital Audio Output1USB Ports1IR Extender PortInformation Not AvailableEthernet Port(s)NoWi-Fi CapabilityNoWireless ConnectivityNoCamera/Webcam (Front Facing)NoSmart TV FeaturesNoBezel Colour (Televisions)BlackPedestal Stand (Televisions)Feet (Included)VESA Mounting CompliantInformation Not AvailableHDMI-CECInformation Not AvailableManufacturer's Parts Warranty1 Year LimitedManufacturer's Labour Warranty1 Year LimitedDLNA CertifiedInformation Not AvailableEnergy EfficientInformation Not AvailableHDCP (Home Theatre)Information Not Available
aravs is offline
post #2 of 7 Old 03-26-2016, 05:28 PM
audiman's Avatar
Quoted: 35 Post(s)
Liked: 34
i'm looking for some support on this tv. Cant find the user manual.
Is it hdcp 2.2 compatible ?
audiman is offline
post #3 of 7 Old 03-27-2016, 06:40 AM
audiman's Avatar
Quoted: 35 Post(s)
Liked: 34
just installed the pled6515 uhd yesterday.
overall, not bad at all for the price. the menus are limited, not much you can do for calibration. must find the hidden menus, if any.
the rcu is a pos, but i dont use it much.
it is hdcp 2.2 compatible on some hdmi inputs. i was able to watch some cable 4k content from my local provider and it was very nice.
hope this can help you. ask me any questions if you need info.
audiman is offline
post #4 of 7 Old 03-28-2016, 11:41 AM - Thread Starter
aravs's Avatar
thanks for posting
do you console game? notice any input lag?
How is lower def material on it? In the Visions showroom they had it hooked up to standard definition cable feed which looked awful. Does the set upscale well or do you have a receiver that does a better job of upscalling? how do blurays look?
aravs is offline
post #5 of 7 Old 03-28-2016, 02:50 PM
audiman's Avatar
Quoted: 35 Post(s)
Liked: 34
thanks for posting
may i suggest this thread. looks pretty accurate based on my limited experience with this tv.
watched some hockey and i dndt see any motion lags or flickering. will watch the chicago toronto nba game on march 30th in 4k and report back.
http://forums.redflagdeals.com/visions-proscan-65-led-4k-tv-998-a-1895325/
audiman is offline
post #6 of 7 Old 03-28-2016, 04:40 PM
audiman's Avatar
Quoted: 35 Post(s)
Liked: 34
service menu
tv on
press menu
enter 1147
madmadworld likes this.
audiman is offline
post #7 of 7 Old 11-28-2018, 10:45 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
the WB can be set in the service menu, but most other settings I've change don't stick after powering off.
anyone have better luck for example with the Gamma setting? changing it to linear gets the set close, but it will revert to default after a power off.
vega509 is offline
Reply LCD Flat Panel Displays
4k ultra hd , led , proscan
