Vizio 2016 P-Series UHD/HDR TVs no price talk please - Page 107 - AVS Forum | Home Theater Discussions And Reviews
 2448Likes
post #3181 of 3197 Old 08-11-2017, 08:14 AM
Liked: 0
TV Arrived!!!
Hello again,
My P65-C1 arrived today . What are some of the 1st things that should be done to the TV as soon as I connect it? or better yet, where can I find out a breakdown of the menu settings (for calibration) and which HDMI ports to use for certain devices (Ex. low input lag for xbox s, HDR, etc...)
Thanks in advance!
esteef is offline
post #3182 of 3197 Old 08-11-2017, 08:20 AM
Quoted: 1137 Post(s)
Liked: 982
You should start by going over the first post in this thread:
https://www.avsforum.com/forum/166-lc...lk-please.html
Ph8te and shoman94 like this.
LG 65B7 | Odroid N2 with CoreELEC | LG SK10Y+SPK8-S | Calibration + Settings (TBD)
Vizio M60-D1 | T95M with LibreELEC | Calibration + Settings
Dell UP2516D | Le Potato with CoreELEC (Development/testing platform)
Vizio M55-C2 (Ex) | Calibration + Settings
The Coolest is offline
post #3183 of 3197 Old 08-27-2017, 08:45 PM
StrykerSTI's Avatar
Question Oppo UDP-203 Menus not showing
I bought an Oppo UDP-203 for my P65-C1. I connected everything but it didn’t show any signal on the tv. I check the cables and switch cables with the PS4 Pro thinking that it might be the HDMI without luck. I thought that I received a non working unit when I remember the sub sampling or full uhd colors settings on the Vizio. When I disabled the option I was able to see the menus on the Oppo but it broke the 4k HDR capabilities for the PS4 Pro and XBox One S. Is there any way the Oppo interface work with sub sampling on?
RJ_Reda likes this.
StrykerSTI is offline
post #3184 of 3197 Old 10-15-2017, 04:52 AM
rontalley's Avatar
Quoted: 839 Post(s)
Liked: 433
I used 3 different meters to measure how much power my P-65-C1 is drawing and on average it uses 25 watts in standby mode! This number seems crazy high for a modern piece of equipment. Sometimes it has random power spikes in standby as well. I finally put a smart switch on it and have it turn off power to the TV when not in use but this should not be necessary...
The Vizio's site suggest that it should be using about 0.5 watts in standby mode. Vizio's site also state that it consumes around 122 watts in use but my display consumes around 255 on average while in use.
Any thoughts? I have contacted Vizio Support...
Meters used:
P3 P4400
Iris Smart Plug
Aeon Labs DSC11 Smart Power Strip
The Screen Shots are from the Aeon Labs Power Strips but all three meters told the same story.
ID:	2298634   Click image for larger version
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP, Sub 2-Klipsch RW12D
Projector-BenQ 3550 4K, Screen-110" Silver Ticket STR-169110, TV-Vizio P-65 4K
rontalley is offline
post #3185 of 3197 Old 10-15-2017, 08:50 AM
shoman94's Avatar
Quoted: 5751 Post(s)
Liked: 3845
Meters used:
P3 P4400
Iris Smart Plug
They updated the wattages for the 2017 model which is actually the correct numbers.
Are you using eco mode or quick start mode?
Sent from my ZTE A2017U using Tapatalk
2018 Sony LCD Master Series Calibration Thread
Sony XBR-75Z9F, Vizio M50-E1, Pioneer Kuro 5020, Marantz SR6013, AppleTV-4K, XBox One & (X), NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #3186 of 3197 Old 10-15-2017, 09:53 AM
rontalley's Avatar
Quoted: 839 Post(s)
Liked: 433
I am using Eco mode...Don't know where quick start mode is located...
However, is 25 watts normal?
My Media Room
post #3187 of 3197 Old 10-15-2017, 09:55 AM
shoman94's Avatar
Liked: 3845
It's under power mode in the system settings. I know quick start is suppose to use more power. Maybe CEC. Being on does as well. I'm not sure.
shoman94 is offline
post #3188 of 3197 Old 10-15-2017, 12:16 PM
rontalley's Avatar
Quoted: 839 Post(s)
Liked: 433
Yep, that was it. Quick Start uses 25 watts in standby mode which in my case = a little over $3 a month. Don't seem like much but I am on a quest to reduce my energy usage and this TV has accounted to a good portion of my electric bill considering it is watched almost 12 hours a day by different family members.
shoman94 likes this.
My Media Room
post #3189 of 3197 Old 12-02-2017, 05:35 AM
Zaxdad's Avatar
Quoted: 44 Post(s)
I need some input. I have a 3 1/2-year-old sony kdl65w850a. I'm trying to find a reasonable entry into 4K. I'm looking at a refurbished P65-C1. I watch mainly sports and news.Is that my best bang for the buck in the $1000 area? Any thoughts or input would be greatly appreciated.
Howard
Zaxdad is offline
post #3190 of 3197 Old 12-02-2017, 06:39 AM
CleCakYngMfd's Avatar
Quoted: 2073 Post(s)
Liked: 730
Originally Posted by Zaxdad View Post
I have a 3 1/2-year-old Sony kdl65w850a. I'm trying to find a reasonable entry into 4K. I'm looking at a refurbished P65-C1. I watch mainly sports and news.
Sports and News? I would think the P-Series is overkill. Movie/show watchers dive into the P-Series. You could start at the entry Level D-Series. Next up is the E-Series. Then the M-Series. The flagship Vizio is the P-Series.
- Pj
DaverJ likes this.
- PjThis is The End-Age GenerationTime is Running OutQuakes, Sinkholes, Meteors
EvilutionMankind Was CreatedWe Didn't Come From ApesThere Was a Worldwide Flood!
The End of This Age is Near!I'm Ready For The Rapture!Are You Ready?The Time is Now!
CleCakYngMfd is offline
post #3191 of 3197 Old 12-02-2017, 11:32 AM
Zaxdad's Avatar
Quoted: 44 Post(s)
- Pj
I'd rather over buy. I'm one of those people that easily has buyers remorse. If I buy higher up the line than I need I generally feel better about my purchase.
Zaxdad is offline
post #3192 of 3197 Old 12-02-2017, 01:05 PM
Liked: 730
Are you the only viewer for this Display you're looking to purchase? If so, then the VA panel (P65) requires eye-level, dead-center for maximum PQ. If you have other viewers at off-axis that is important to them also, then an IPS panel (P55) should be considered:
"In-Plane Switching displays (IPS and S-IPS) offer wider viewing angles and better color reproduction, but are more difficult to construct and have slightly slower response times. Vertical Alignment (VA, S-PVA and MVA) offer higher contrast ratios and good response times, but suffer from color shifting when viewed from the side.
- WikiPedia.org
- Pj
post #3193 of 3197 Old 12-02-2017, 03:36 PM
Zaxdad's Avatar
Quoted: 44 Post(s)
I'm maybe a foot off center horizontally and 6" off center vertically. I'm really the only viewer. My wife and son really don't care.
Zaxdad is offline
post #3194 of 3197 Old 12-02-2017, 04:14 PM
Liked: 730
Well, then. You are hereby approved to purchase a Refurbished P65-C1.
- Pj
post #3195 of 3197 Old 12-02-2017, 06:25 PM
Zaxdad's Avatar
Quoted: 44 Post(s)
- Pj
Great. Now if you could call my wife.
Zaxdad is offline
post #3196 of 3197 Old 12-10-2017, 08:30 AM
Zaxdad's Avatar
Quoted: 44 Post(s)
Still haven't bought. Is a refurbished P65-c1 a better choice than a new M65-E0 given they are the same price?
Thanks for any input.
Howard
Zaxdad is offline
post #3197 of 3197 Old 12-10-2017, 08:41 AM
Liked: 730
Since the P-Series is the top-of-line and the M-Series is below that, then if the price is the same, then your Refurbished P65-C1 would be the better buy. The P-Series have more Dimming Zones and more features than any of the other Series: M, E, and the D. I believe your Refurb P65-C1 (2016) comes with a Tablet. If so, You'll have the option to get a newer remote to have access to the Web-based Apps, also.
You said you'd like to 'overbuy', so jump on it, I say, if it's not too late already.
- Pj
Reply LCD Flat Panel Displays
p-series , Vizio
