Vizio 2016 P-Series UHD/HDR TVs no price talk please - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 2448Likes
post #1171 of 3197 Old 03-24-2016, 11:15 AM
roaf85's Avatar
Quoted: 33 Post(s)
Originally Posted by thomasfxlt View Post
Active LED Zones: Off
Hey I know you answered my question about 1080p content but I meant to follow up.
Is there any settings that "don't work" as expected. Meaning like does "reduce judder/motion blur" actually do what it is supposed to do or are we gonna need firmware fixes like the M series.
Also I don't know if you are much of a gamer or anything but aside from the contrasts levels in your Mad Max shot you mentioned that normal Xfinity TV had better color tones, but you wouldn't recommend this as an upgrade for 1080p sources? Is that due to the upconversion engine? Thanks.
roaf85 is offline
post #1172 of 3197 Old 03-24-2016, 11:15 AM
pearsco's Avatar
Quoted: 305 Post(s)
Liked: 309
Originally Posted by accord 4 me View Post
Vizio app crashes and is basically useless on the tablet. Had to install and use on my phone. Although I think they may be related to the constant "connecting.." screen I see on the cast screen that I took a picture of. I had a heck of a time actually getting the phone and TV to connect to each other. Netflix app is giving me issues too. Plays for about 5 seconds and then freezes and says an error occurred..try again later. Haven't had any trouble streaming any other services though.
Plan on hitting up Best Buy later to get mad max in 4k to try out vudu hdr
edit: and to anyone saying not to worry about the dead/stuck pixels. I'm not actually too concerned there, was just mentioning it. My real issue is getting the TV to connect
Out of curiosity is your TV connected via WiFi or ethernet? I have had some real issues getting Google Casting to work well over Wifi in the past on my Nvidia Shield.
pearsco is offline
post #1173 of 3197 Old 03-24-2016, 11:18 AM
thomasfxlt's Avatar
Quoted: 3332 Post(s)
Liked: 6192
I only say it's not a good 1080p upgrade if you have NO intention of going UHD/4k. Otherwise, it's outstanding and a no brainer if you can afford one in the size you're after.
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #1174 of 3197 Old 03-24-2016, 11:18 AM
accord 4 me's Avatar
Quoted: 54 Post(s)
Liked: 38
Do you have a timestamp for the frame?
I'm curious. What build number do you have?
Go to settings > system > system information > system information
Under cast version I have 1.17.46921
I thought it was interesting you mentioned firmware updates. I've yet to run into any reboots
Heck, if somebody can help me figure out my connection problems I'll live with the minor dead pixel problem
I have ethernet connected. I also set it up to connect to wifi. The weird part is, if i factory reset the TV and leave the ethernet unplugged, I can't get the app to see the TV at all. It's pretty frustrating for something that should be dead simple
accord 4 me is offline
post #1175 of 3197 Old 03-24-2016, 11:18 AM
EvilRonin_'s Avatar
Quoted: 131 Post(s)
Liked: 175
Sigh... Could not resist and ordered the TV - will be here on Saturday.
SiGGy, reanimator and AVmanic like this.
EvilRonin_ is offline
post #1176 of 3197 Old 03-24-2016, 11:19 AM
Johnnyice426's Avatar
Quoted: 85 Post(s)
Liked: 33
Originally Posted by SiGGy View Post
yes, correct 2 pictures. I was only addressing the one with the local dimming enabled.
Outside of the pause icon; you can see some blooming around the text too if you look for it.
I haven't seen a FALD which this doesn't happen on (credits). I was only commenting it's really subjective to make any decisions on it from a photo. And if the photo depicts what you see in person then it's outstanding!
Wow, I think I need new glasses! Lol!
LG 65 B6P
Vizio 2014 P 702ui-3B
Samsung K8500, Apple 4K TV
Pioneer Elite VSX-72TXV THX
Atlantic technology speakers 5.1 THX
Johnnyice426 is offline
post #1177 of 3197 Old 03-24-2016, 11:20 AM
thomasfxlt's Avatar
Liked: 6192
1.18.60081. It could be the VUDU app.
What's your connection issue? I must have missed that question.
post #1178 of 3197 Old 03-24-2016, 11:25 AM
DSF767's Avatar
Quoted: 32 Post(s)
I want to order this so bad must resist paying full price until there is a sale!
DSF767 is offline
post #1179 of 3197 Old 03-24-2016, 11:30 AM
blynott's Avatar
Quoted: 86 Post(s)
Liked: 55
Originally Posted by jtvarisco View Post
I'm considering getting the 50", not so much because of 4K but for the FALD. Any reason NOT to if I plan to stick to 1080p for while?
I believe the 50" is a 60Hz native panel while the others are 120Hz. That's the reason I don't want the 50". Then the 55" is an IPS panel and I don't want that and the 65" is too big for me! I'm waiting to see what they do to the new M series.
s44 likes this.
Bob
65" TCL-Roku R613, Philips 7302 UHD Blu ray, Yamaha TSR-5830, Wavecrest speakers, Speedwoofer 10s, DEf Tech BP6B
blynott is offline
post #1180 of 3197 Old 03-24-2016, 11:32 AM
SiGGy's Avatar
Quoted: 576 Post(s)
Liked: 450
lol; if your brightness isn't adjusted right on your monitor it'll be difficult to see the blooming. (that's a good thing! and yes it's subtle)
Also, it's easier to see around "Tom Hardy" than it is over "Charlize Theron"
Johnnyice426 likes this.
SiGGy is offline
post #1181 of 3197 Old 03-24-2016, 11:33 AM
pbc
pbc's Avatar
Quoted: 501 Post(s)
Liked: 223
I wonder what the record is for the number of posts on a new thread in a 48 hour time frame. I think this one may break it. lol
JudgeSmails likes this.
My DIY Subs ... https://www.avsforum.com/forum/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #1182 of 3197 Old 03-24-2016, 11:34 AM
bluemoon737's Avatar
Quoted: 2209 Post(s)
Liked: 2710
Curious why you say that...is it poor upscaling or something else?
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #1183 of 3197 Old 03-24-2016, 11:35 AM
Steve Goff's Avatar
Quoted: 457 Post(s)
Liked: 282
Originally Posted by Mattopotamus View Post
The TV itself has no apps. All of the apps are stored on the tablet it comes with and must be "casted" to the TV. If you do not have at least 30mbps internet speeds, you may not want this set. Otherwise, you would be missing a lot of 4K streaming opportunities.
All streaming, including that on sets with built-in apps, depends on internet speed. Casting is no different.
Steve Goff
Steve Goff is offline
post #1184 of 3197 Old 03-24-2016, 11:41 AM
thomasfxlt's Avatar
Liked: 6192
Originally Posted by ray0414 View Post
Its right about when the war boys 1st start their chase of furiousa toward the beginning of the movie. Sometime around 20mins
Flare on the left is almost a fire engine red/orange and the right one is a saturated yellow/orange.
post #1185 of 3197 Old 03-24-2016, 11:43 AM
Quoted: 303 Post(s)
Liked: 102
@thomasfxlt
i see you upgraded from a 2015 M. how's the motion on this years P-Series? i find with the 2015 M, fast action scenes are hard to concentrate on.
jasyn is offline
post #1186 of 3197 Old 03-24-2016, 11:44 AM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 485 Post(s)
Liked: 397
Originally Posted by denpom View Post
do you really have to post this every other page?
Personal evaluations come from many factors and from many different threads and most can come to a personal decision. But I do agree if these panels are the same as Sony panels then that leaves the processing, me thinks. The reports here so far show at the moment on par results. Motion and if upscaling DVD's is important then the results are not yet in. A tablet to cast applications is a novel but not family friendly unless you know a lot about Google casting, (I certainly don't). Motion needs evaluated so hopefully rtings.com will be swift. I am very interested in this Utilitarian Display.
Sony 75Z9D, Denon 4300H, Sony 65Z9D, Denon X4311, OPPO UDP-203, ATV4K, X1X Scorpio
davehale is offline
post #1187 of 3197 Old 03-24-2016, 11:44 AM
hernanu's Avatar
Quoted: 1391 Post(s)
Liked: 2278
Originally Posted by k124 View Post
So currently available for 4k HDR on this set: Netflix + VUDU?
I'd like to line up some content for when my TV arrives next week
It would be awesome if some of the initial owners could compile a short list of 'reference' content to show this bad boy off.
I think you start on Mad Max...
thomasfxlt likes this.
hernanu is offline
post #1188 of 3197 Old 03-24-2016, 11:46 AM
Spine Guy's Avatar
Quoted: 140 Post(s)
Liked: 93
Originally Posted by Kadath View Post
Bruce, I've got a much longer thread over at home base, but the long and the short of it is I'm buying a 50" P for my office to upgrade a 5 year old 32". Should be a massive difference.
I've still got a 940D on order but I am VERY nervous about that. I'm going to evaluate my 50" very closely before deciding if the 75" P or the 940 will get the final nod. If I had to guess right now I don't think I can justify the cost difference but time will tell.
You should start a seperate thread comparing the 940d and the P. This would be an interesting show down. I'm basically buying the 940d or this Vizio P. If the P shows no real flaws, I'm in.
Curious, I'm wondering if we can get screen shots of whites and color saturation.
Also, how is motion during sports? Any ghosting?
Vizio P75-C1
Yamaha RX-A1040
5.1- Def-Tech STS towers, mythos 10 center, mythos gem rears, super cube sub
PS3
Roku 4k
Xfinity X1
Spine Guy is offline
post #1189 of 3197 Old 03-24-2016, 11:52 AM
dingly's Avatar
Liked: 26
So for the owners how is the tablet, does it seem durable? And is there any way to charge it outside the dock? Can it just be plugged in USB. Also do the physical volume buttons change the TV volume or only the tablet volume?
dingly is offline
post #1190 of 3197 Old 03-24-2016, 11:53 AM
AVmanic's Avatar
Quoted: 472 Post(s)
Liked: 533
Is the USB port 3.0 would like to know if my WD passport cinema drive will work on it with Mgo app. Do you have the Mgo app.
Ready to pull the trigger on the P75.
Thanks..
AVmanic is offline
post #1191 of 3197 Old 03-24-2016, 11:53 AM
EvilRonin_'s Avatar
Quoted: 131 Post(s)
Liked: 175
So is there an app that will let one watch Amazon 4K even if it doesn't support HDR? Or is another device required (Firestick, UHD BluRay, etc.)?
post #1192 of 3197 Old 03-24-2016, 11:53 AM
Quoted: 845 Post(s)
Liked: 364
Originally Posted by Dannychico View Post
Nobody gets to complain about missing Amazon content if I can't complain about missing the OTA tuner. I can just pick up an external tuner for $40 on Amazon? You can just pick up an Amazon Fire for about the same.
What external device will give you Amazon with HDR?
Sent from my SM-G900P using Tapatalk
buju22 is offline
post #1193 of 3197 Old 03-24-2016, 11:55 AM
Quoted: 845 Post(s)
Liked: 364
Originally Posted by drock2k1 View Post
The whole Amazon thing is still puzzling to me. Is this not a big deal to anyone else? Amazon has some great HDR content (visually speaking) that is pretty much blocked at this point.
I agree, Amazon has great shows. I enjoyed Mad Dogs and Mozart Jungle. Currently watching season 2 of Bosch.
buju22 is offline
post #1194 of 3197 Old 03-24-2016, 12:00 PM
dvdchance's Avatar
Quoted: 113 Post(s)
Liked: 56
Has anyone used Plex with this set yet? Are the menus only on the tablet or can they also be onscreen?
dvdchance is offline
post #1195 of 3197 Old 03-24-2016, 12:00 PM
Mattopotamus's Avatar
Quoted: 2149 Post(s)
Liked: 2259
My guess, and I hope I am right, is that you could use any device that supports google casting. That would mean an iOS device could cast the amazon app in 1080p.
Mattopotamus is online now
post #1196 of 3197 Old 03-24-2016, 12:00 PM
Quoted: 28 Post(s)
You'll have to wait either for new Blu-Ray models with Dolby Vision later this year, or when the Samsung UHD Blu-Ray player is updated to play HDR.
Ninhalem is offline
post #1197 of 3197 Old 03-24-2016, 12:02 PM
Quoted: 28 Post(s)
Amazon doesn't have a 4K streaming app for iOS. They've specifically left Apple out of that.
You can get a Roku 4 that will play the Amazon 4K library at 60 fps, but it will not be HDR.
Ninhalem is offline
post #1198 of 3197 Old 03-24-2016, 12:05 PM
RetiredNow's Avatar
Quoted: 47 Post(s)
Liked: 26
Do any of the 2016 Vizio's have an onboard Digital Tuner on board....the web site says no...that's a deal breaker for me.
RetiredNow is offline
post #1199 of 3197 Old 03-24-2016, 12:07 PM
pearsco's Avatar
Quoted: 305 Post(s)
Liked: 309
Its not the device but the App that needs to support casting and to the best of my knowledge Amazon doesnt even support 1080p (much less 4k) casting in any iOS or Android App.
pearsco is offline
post #1200 of 3197 Old 03-24-2016, 12:07 PM
thomasfxlt's Avatar
Liked: 6192
There are many cheaper sets that will look great without paying for 4k/HDR/DV .
Reply LCD Flat Panel Displays
p-series , Vizio
