Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 1655 - AVS Forum | Home Theater Discussions And Reviews
 288467Likes
post #49621 of 63935 Old 07-18-2017, 10:54 AM
ffactoryxx's Avatar
Quoted: 543 Post(s)
Liked: 91
Do any live TV streaming services broadcast in 1080p?
Have PS Vue but its 720p.
ffactoryxx is offline
post #49622 of 63935 Old 07-18-2017, 11:32 AM
Timenow's Avatar
Originally Posted by Matt McRae View Post
We are enabling 3.3.18.1 for AVS Forum testers... The updates include:
1. Ethernet connectivity fixes
2. Improved CEC/ARC behavior
3. UHD support on Amazon Video
4. Improvements to MEMC
5. New info for different Dolby audio standards
6. Long folder/filename support in USB player
7. Final fixes to retain color tuner settings for all resolutions/inputs
Many of these were pointed out or suggested by testers here on the forum. VIZIO truly appreciates your testing and feedback! This is a candidate release to the wider audience and we are rolling up additional fixes into a minor release in the coming weeks (this will inlaced blue shift using Xbox, Google play blinking/flickering, 25/50/100 EDID support, and other minor items).
I am on a flight right now... but will also be scrubbing my private messages for serials to get the added to the group later today.
Thank you again!
Matt
@Matt McRae
Please add me to the AVS Forum Testers, please and thanks for all your help.
LTMATKAS2850001
Timenow is offline
post #49623 of 63935 Old 07-18-2017, 11:36 AM
kclfoxtrot's Avatar
Quoted: 39 Post(s)
Liked: 33
Originally Posted by shoman94 View Post
Try sending an email to [email protected]
Sent from my ZTE A2017U using Tapatalk
Yes....thanks. Have tried that as well. I somehow get the feeling my serial number(s) have been blacklisted
Sony 65A1E
Vizio P65
LG 55EA9800
kclfoxtrot is offline
post #49624 of 63935 Old 07-18-2017, 11:39 AM
DirkBelig's Avatar
Quoted: 386 Post(s)
Liked: 345
Originally Posted by tondeezy99 View Post
I get blackouts with YouTube hdr also on the x800. I'm running monoprice ultra high speed certified cables too. I turn off full uhd color and it stops. You will still get hdr on Netflix and discs, but the flickering is so annoying. I haven't found a fix yet.
I'm sorry to be unclear; in my brief testing, YouTube HDR seemed OK after perhaps a bit of flicker when initially starting, but the serious blackout problems was with looking at Transformers 4 on BD and The Fifth Element on UHD BD with the latter blacking out about five times in two minutes. Between the flakiness with the FW and the question mark about the player, I'm trying to rule out the latter since I can't do anything about the former.
PimpVision® Quantum: Vizio PQ65-F1 | Denon AVR-X4400H | Def Tech ProCinema 600 + ProCenter 1000 + Monoprice Caliber #4104 (Atmos) + Monolith 10" THX Select (5.1.4) | Nvidia SHIELD (2015) | Apple TV 4K | Sony UBP-X800 | XBOX Project Scorpio | Xbox 360 | PS4 Pro | PS3 | Toshiba HD-A30 | Chromecast Ultra | Harmony 650 | Monoprice 8-Port gigabit switch
My DVD Profiler List | DirkFlix: My Movie Viewing Diary and Reviews
DirkBelig is offline
post #49625 of 63935 Old 07-18-2017, 11:52 AM
Dodge DeBoulet's Avatar
Quoted: 131 Post(s)
Liked: 103
@Matt McRae
Has the Hulu streaming support changed significantly with the switch from cast-from-device to the beta "internal cast/web app" mechanism? Since I installed the previous beta (3.3.16.1), Hulu appears to be seeing a markedly degraded bit rate, resulting in significantly more blurring/pixelation than I'd seen previously.
I suppose it could be a temporary Hulu issue, but it's happened multiple times over the last 2 weeks and didn't occur at all before that.
Dodge DeBoulet is offline
post #49626 of 63935 Old 07-18-2017, 12:01 PM
Quoted: 218 Post(s)
Liked: 189
Updating now, it's available if you're a beta tester by way of the "update" feature in the main menu.
Karnis2 is offline
post #49627 of 63935 Old 07-18-2017, 12:10 PM
cmg2006's Avatar
Quoted: 60 Post(s)
Liked: 52
Originally Posted by RCIII View Post
Originally Posted by cmg2006 View Post
have the same problem no much difference with hdr gaming i also have the Xbox One X
Xbox One X? Are you a special person or something? If so I'm a little jealous
Lol Xbox S sorry i am waiting for the Xbox One X
SamuraiXSendai and Skunka like this.
cmg2006 is offline
post #49628 of 63935 Old 07-18-2017, 12:16 PM
Liked: 1
@Matt McRae
Please add me to the Beta testers group. Thank you!
LTMATLCT0350787
ecf1969 is online now
post #49629 of 63935 Old 07-18-2017, 12:46 PM
lujan's Avatar
Quoted: 4346 Post(s)
Liked: 2443
Thank you again!
Matt
Any idea if you'll eventually have the FandangoNow app available with 4k/HDR capability?
shoman94, dsertedsun and Daemon11 like this.
lujan
513 Ultra HD
723 HD
4 SD
lujan is online now
post #49630 of 63935 Old 07-18-2017, 12:49 PM
bobkat007's Avatar
Quoted: 403 Post(s)
Liked: 70
Rather simple question on my P50-C1. Does changing the audio equalizer settings affect only the TV speaker and/or soundbar? Or does it also change the return HDMI audio out?
bobkat007 is offline
post #49631 of 63935 Old 07-18-2017, 01:00 PM
skschatzman's Avatar
Quoted: 2635 Post(s)
Liked: 1573
Wouldn't it be simpler just to test it yourself and listen for the effect?
Sent from my SM-G955U using Tapatalk
skschatzman is offline
post #49632 of 63935 Old 07-18-2017, 01:03 PM
Quoted: 109 Post(s)
Liked: 107
Thank you again!
Matt
What a badass
Daemon11 is offline
post #49633 of 63935 Old 07-18-2017, 01:06 PM
Ph8te's Avatar
Quoted: 6276 Post(s)
Liked: 5920
Isn't this still limited to Samsung devices? Until that opens up, I don't see them getting it.
https://www.fandangonow.com/help/4k-uhd
Also, HDR is limited to Vidity capable hardware that allow downloads (HDD).
It would be great if they offered it, I just know Samsung has a stranglehold on that company (at least they used to).
Ph8te is offline
post #49634 of 63935 Old 07-18-2017, 01:18 PM
CleCakYngMfd's Avatar
Quoted: 2020 Post(s)
Liked: 721
At least with my simple 2.1 sound bar, there's
no affect. The EQ only affects the internal Display
speakers.
Tip: Best overall sound from the Display's speakers
is to have EQ on 'Bass' and then turn Surround Sound On.
DOCT0R likes this.
- PjThis is The End-Age GenerationTime is Running OutQuakes, Sinkholes, Meteors
EvilutionMankind Was CreatedWe Didn't Come From ApesThere Was a Worldwide Flood!
The End of This Age is Near!I'm Ready For The Rapture!Are You Ready?The Time is Now!
CleCakYngMfd is offline
post #49635 of 63935 Old 07-18-2017, 01:27 PM
shoman94's Avatar
Quoted: 5048 Post(s)
Liked: 3574
I thought I read somewhere that certain TVs or devices are now streaming HDR..... Maybe I'm mistaken.
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #49636 of 63935 Old 07-18-2017, 01:27 PM
kensingtonwick's Avatar
Quoted: 358 Post(s)
Liked: 70
Originally Posted by CleCakYngMfd View Post
I watched, "Salt and Fire" last night.
The pic was ok enough with the EggzScream Black-Hole Turbo Engine left
On and Gamma at 2.2. I had long forgotten whether I had 'ALZ' On or Off
as I was 'involved' into the movie.
Then it happened.
In one scene where a view of the white salt-flats switches immediately
to a night view of the stars. Ouch. The 'ALZ' couldn't handle it properly.
For a split micro second, the star-field was bright and quickly dropped way down
in brightness. I rewound to watch the scene transition again with 'A-El-Zee'
Off, and that worked fine. I watched the rest of the movie with 'A-El-Zee' Off and
the Brightness turned down a bit under 50. Better dynamic balance.
Bee-Yoot-Eee-Ful scenery, especially the back-half of this movie on my P50.
Here's a good NetFlix movie (a rarity) to get lost into: "Lion".
Caution:
Spoiler!
I've noticed that happening a lot with my p65 too since beta firmware. Although I forgot to reset to default settings. We'll see if it persists tonight on Netflix. Also, what is the soft power cycle?
kensingtonwick is online now
post #49637 of 63935 Old 07-18-2017, 01:35 PM
cmg2006's Avatar
Quoted: 60 Post(s)
Liked: 52
@MattMcRae
Hi Matt with the new update 3.3.18.1 it say Smartcast is not available in your region can i know why is not avalible when Chromecast is?
cmg2006 is offline
post #49638 of 63935 Old 07-18-2017, 01:44 PM
Ph8te's Avatar
Liked: 5920
Looks like maybe they have limited offerings via Roku? I guess once it becomes more common it would be easier to add. From the few posts I got hits on m, seems like a crapshoot if you don't do vidity (via WD drive) or have a Samsung TV.
shoman94 likes this.
Ph8te is offline
post #49639 of 63935 Old 07-18-2017, 01:57 PM
lujan's Avatar
Liked: 2443
No, you can view FandangoNow UHD/HDR with the Roku 4k devices now such as certain Universal titles. Only the 20th Century Fox UHD/HDR titles are limited to Vidity.
mpgxsvcd and shoman94 like this.
lujan
513 Ultra HD
723 HD
4 SD
lujan is online now
post #49640 of 63935 Old 07-18-2017, 01:59 PM
ccolbert's Avatar
I've had a P75-C1 since 4/25/17 and have loved it, but as of 2 weeks ago saw a dark spot on the screen, today I turned it on and saw about 5 dark spots. I called Vizio support, and described the issue, the person immediately said "Oh it sounds like the backlight is failing", I replied "Ah that sounds expensive, and of course it happened not even 3 months after the warranty ran out", he replied "oh no, you can't replace the back light on that unit, would you like help placing an order for a replacement unit?". I'm assuming you can see where it went from there, spending almost $4,000 on a tv that apparently will just get more messed up until I give up on it.
Has this happened to anyone else? Has anyone had any success on it?
Also posting this as a clear warning of what can happen with these units.
ccolbert is offline
post #49641 of 63935 Old 07-18-2017, 02:07 PM
rockaway1836's Avatar
Quoted: 224 Post(s)
Liked: 228
@Matt McRae
Yesterday I was able to watch Meridian, and Sparks in HDR10 from Netflix. (even though they are DB titles) Following the update both are showing as "Normal".
rockaway1836 is offline
post #49642 of 63935 Old 07-18-2017, 02:13 PM
stikle's Avatar
Quoted: 946 Post(s)
Liked: 1110
Originally Posted by ccolbert View Post
Also posting this as a clear warning of what can happen with any electronics at any point in time.
Here, I fixed that for you.
Good thing you paid for the extended Square Trade warranty for a measly $100, right? RIGHT?
mpgxsvcd, kemac, Ph8te and 6 others like this.
stikle is offline
post #49643 of 63935 Old 07-18-2017, 02:30 PM
Quoted: 66 Post(s)
Liked: 69
Thank you again!
Matt
@Matt McRae
Please add me to the Beta testers group. I don't have enough posts to PM you. Thank you!
36LTMATLBS50136
Tremaine Wright is offline
post #49644 of 63935 Old 07-18-2017, 02:49 PM
quaff2001's Avatar
Quoted: 113 Post(s)
Liked: 83
Just got the latest update and there was a code on the screen for the new remote I assume. The code is gone from the screen, any way to get it back?
mpgxsvcd likes this.
quaff2001 is offline
post #49645 of 63935 Old 07-18-2017, 02:52 PM
Liked: 1573
Nope. Not until full release
post #49646 of 63935 Old 07-18-2017, 02:58 PM
fletchmath's Avatar
Quoted: 22 Post(s)
Originally Posted by rockaway1836 View Post
@Matt McRae
I can confirm this. I didn't have 3.3.16.1, but with the latest version, I cannot view anything in HDR, whether I view it through the smartcast apps, or if I cast from a tablet to the Vizio. None of the DV-enabled shows on netflix come up in DV mode. I haven't checked if vudu works, so this could be a weirdly timed netflix issue, but that seems unlikely.
BTW, casting from the tablet seems a bit twitchy -- Do I have to click on the cast button in the upper-right first, before I can cast? Even if I do that, I'm having difficulty getting apps to connect to the tv; it often takes several tries. That hasn't happened to me over the last several firmware versions.
fletchmath is offline
post #49647 of 63935 Old 07-18-2017, 03:04 PM
quaff2001's Avatar
Quoted: 113 Post(s)
Liked: 83
Vudu shows DV for me and looks great. I am having the same issue with Netflix and DV. It just shows Normal.
post #49648 of 63935 Old 07-18-2017, 03:05 PM
Liked: 721
Originally Posted by kensingtonwick View Post
What is the soft power cycle?
Hard Power-Cycle a Vizio TV/Display
I guess the Soft Cycle can be used first to see if it can 'clean up' some problems.
Otherwise, there's the Hard Power Cycle and a Factory Reset (the 'Master' of all resets).
post #49649 of 63935 Old 07-18-2017, 03:24 PM
fletchmath's Avatar
Quoted: 22 Post(s)
How about if you cast from your tablet. Do you get DV from netflix then?
post #49650 of 63935 Old 07-18-2017, 03:26 PM
kevin82485's Avatar
Liked: 0
Oh, a sale. I may have to get me some cables, too.
I suppose the 10-footers would work for you,
but some time back, there was talk that HDMI
ports were designed/tuned for 6-foot lengths,
optimally. Just something to keep in mind.
Perhaps, but I think one of added benefits of a Certified Premium cable is that it is also guaranteed to perform to spec for its given length.
Sales over unfortunately.
kevin82485 is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
