Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 1661 - AVS Forum | Home Theater Discussions And Reviews
 288589Likes
post #49801 of 64411 Old 07-20-2017, 11:21 AM
Athlon646464's Avatar
Quoted: 63 Post(s)
Liked: 31
Originally Posted by rjsmith2007 View Post
What do they stream in 4k? Certainly not broadcast channels?
See Post #49791 above.
LG OLED65C7 | Denon S930H | Klipsch 5.1 setup - 2 Forte - 1 R-25C - 2 R-14S
BA Sub w/Bosch amp | Sony BDP S570
Tablo Dual LITE | Antennas Direct ClearStream 2V TV Antenna | RCA Preamp (TVPRAMP1R)
Athlon646464 is offline
post #49802 of 64411 Old 07-20-2017, 11:35 AM
Sbuchanan813's Avatar
Quoted: 474 Post(s)
Liked: 312
I wish this was true. My gaming PC (not kaby lake) can't play 4k/hdr netflix but my tiny slow android box can.
Yea guy doesn't know what he's talking about .
Sbuchanan813 is offline
post #49803 of 64411 Old 07-20-2017, 11:59 AM
CleCakYngMfd's Avatar
Quoted: 2054 Post(s)
Liked: 726
Originally Posted by skschatzman View Post
I have monitored this forum for almost a year
and I never once heard Matt advise not to do
a factory reset unless things act up.
I guess you missed the July 1st, 2017 post from Matt:
"It is not necessary, but sometimes it can clean up issues after a major update."
Name:	Matt McRae's FR Post.PNG
- PjThis is The End-Age GenerationTime is Running OutQuakes, Sinkholes, Meteors
EvilutionMankind Was CreatedWe Didn't Come From ApesThere Was a Worldwide Flood!
The End of This Age is Near!I'm Ready For The Rapture!Are You Ready?The Time is Now!
Last edited by CleCakYngMfd; 07-20-2017 at 01:18 PM. Reason: Cleared for Clarity, Clarence. :D
CleCakYngMfd is offline
post #49804 of 64411 Old 07-20-2017, 12:00 PM
Quoted: 170 Post(s)
Liked: 93
Matt.
Matt stated it is NOT necessary unless there
are some issues after a MAJOR Update.
He still didn't advise against it.
rjsmith2007 is offline
post #49805 of 64411 Old 07-20-2017, 12:10 PM
Liked: 726
Originally Posted by Ph8te View Post
There has never been a promise to increase peak brightness.
It's a "wish" of some, but I don't see it happening, otherwise
they might compromise other PQ aspects...
I don't think it 'needs' to be. It's freaking SUPER-BRIGHT as it is!
I got my welder's glass nearby when needed!
Good grief. Any brighter and I'll go blind and the screen will melt.
blatz8 and Oldways7 like this.
post #49806 of 64411 Old 07-20-2017, 12:15 PM
Liked: 726
No, he didn't. However, the point is, it is normally NOT necessary.
If it were necessary, it would be in the User Manual.
rjspring, pos1121, blatz8 and 1 others like this.
post #49807 of 64411 Old 07-20-2017, 12:21 PM
Quoted: 41 Post(s)
Liked: 49
If it were necessary, they'd bake it into the firmware update process! I've never had issues after FW updates....maybe I'm just lucky.
Vizio P55-C1 | Marantz SR6011 | Oppo UDP-203 | PS4 Pro | PS3
JBL ES Series Speakers | Dayton Audio ME650C Ceiling Speakers
dlkuhn1974 is offline
post #49808 of 64411 Old 07-20-2017, 12:37 PM
Liked: 726
Originally Posted by DAB View Post
NF stated I need ~25.
I can tell you that 20Mbps works at off-peak local hours. Plus, the modem I have is multi-bonded.
Off-peak, I get 4K 99.9% of the time. I've seen it drop under 4K during peak-demand hours.
post #49809 of 64411 Old 07-20-2017, 12:45 PM
Quoted: 474 Post(s)
Liked: 312
I've never had issues much either but I have found after doing a factory reset the picture is better where as before reset it seemed the picture never changed. It literally takes 2 min so who cares either way
shoman94 likes this.
post #49810 of 64411 Old 07-20-2017, 12:51 PM
Liked: 726
issues after FW updates... maybe I'm just lucky.
Nah, not luck. Problems after a Firmware Update are not the norm.
So, any problems after a Firmware Update are like what
they say in some infomercials:
Problems "Not Typical".
If I were always Meter-Calibrating my Display, perhaps I would
always do a FR to make sure it's 'all clean'. Why waste hours
of Meter-Calibrating and some bug-a-boo is still there when a
Factory Reset would have cleared it up in the first place.
post #49811 of 64411 Old 07-20-2017, 12:53 PM
Quoted: 170 Post(s)
Liked: 93
Maybe if I reset enough times I'll unlock a secret code to a golden remote with even more buttons.
CleCakYngMfd and Jill Moore like this.
post #49812 of 64411 Old 07-20-2017, 12:58 PM
skschatzman's Avatar
Quoted: 2858 Post(s)
Liked: 1664
Matt.
I didn't miss anything. You and the other guy misunderstood, misread, and reworded what he said.
Originally Posted by Matt McRae View Post
It is not necessary but sometimes it can clean up issues after a major update.
He said "It is not necessary". Which is correct. I, nor anyone else said it was. I have stated numerous times that it shouldn't be necessary, but I and many others do recommend it as a preventative measure.
He never specified "unless" as you quoted. When you reword a quote that way, it changes the context like he is saying you shouldn't. It also makes it sound like there is a risk involved, which there isn't. If you are going to paraphrase, then please make sure you aren't rewording it and/or changing the context.
Again. It shouldn't be necessary to factory reset after a firmware update, but us more experienced ones here do recommend it as a preventative measure. This does not mean you have to, but it is merely a recommendation.
Sent from my SM-G955U using Tapatalk
shoman94 and blatz8 like this.
skschatzman is offline
post #49813 of 64411 Old 07-20-2017, 01:18 PM
mpgxsvcd's Avatar
Quoted: 2958 Post(s)
Liked: 2618
Red face
There has never been a promise to increase peak brightness. It's a "wish" of some, but I don't see it happening, otherwise they might compromise other PQ aspects. Shoman has been keeping an eye and pushing for higher peaks, but nothing that I am aware of yet.
At one point early on they pushed a new version of Vudu along with a firmware update. It drastically changed the way Dolby Vision looked. At that point eyes of characters would glow like headlights. It gave an interesting effect but wasn’t really beneficial.
Subsequent updates corrected this behavior and made the picture much more uniform. I think it is much better now.
I have been testing creating my own “True” HDR content for my P75 lately and it is actually quite hard to grade it so everything looks right. There is so much more latitude available with HDR than with SDR. It is easy to over do it just because the TV can handle it.
We are no longer under the limitations of REC.709. However, we have to be careful not to push things to the extreme so that they look unnatural now.
mpgxsvcd is offline
post #49814 of 64411 Old 07-20-2017, 01:22 PM
mpgxsvcd's Avatar
Liked: 2618
Red face
Originally Posted by Sandman65 View Post
I have 4k DirecTV and honestly it sucks. Audio on normal hd channels will disappear very briefly every couple of minutes, which has forced me to leave Closed captioning on nearly all the time. Takes nearly a minute to tune to a 4k channel of which you only have three, one is pay per view, one is a 4k documentary channel (like planet Earth 2 and foreign language snowboarding stuff), and the other channel has Garth Brooks concerts and 4k baseball (but you can't watch your home team)
Hopefully they will have 4k NFL games this year. I think the fights will be in 4K as well. That is better than nothing. The 4K streams I have seen aren't really much better than 1080p but that is SOOOO much better than 1080i or 720p.
mpgxsvcd is offline
post #49815 of 64411 Old 07-20-2017, 01:23 PM
DAB
DAB's Avatar
Quoted: 172 Post(s)
Liked: 88
Last night watch a NF show.. Then calibrated the AVR w/Audyssey Muti EQ[ have done this a couple of time but not with p65}. turn off when to bed. Turn the system on this morning- just to hear the results. CAN NOT get vizio to play NF thru the AVR[did last night].
I have hard powered OFF AVR> vizio. factory reset both and the tablet . reset all setting...
Unplugged all HDMI and plugged back in..
Spend a good hour + on this Vizio--- and I am PS%$**%$. I can not recommend this display to anyone................
PQ is good thu..
DAB is offline
post #49816 of 64411 Old 07-20-2017, 01:26 PM
Liked: 726
...It changes the context like he is saying you shouldn't.
which there isn't...
I read it again. It reads the same to me, however, I edited my post for extra-crisp clarity.
post #49817 of 64411 Old 07-20-2017, 01:28 PM
DAB
DAB's Avatar
Quoted: 172 Post(s)
Liked: 88
FWIW-- "factory reset after a firmware update", I agree with SK--- it doesn't hurt- but could remove a clitch or two
DAB is offline
post #49818 of 64411 Old 07-20-2017, 01:31 PM
Liked: 1664
The problem was I quoted a guy telling people not to factory reset as advised from Matt. If you read his post. Not necessary isn't the same as not advised. It's all about context.
Remember the telephone game when you were a kid? Did the message ever come back to you as you first said it?
post #49819 of 64411 Old 07-20-2017, 01:46 PM
Liked: 726
it doesn't hurt- but could remove a glitch or two.
That's implying 'glitches' are high enough of a chance to be there, so
'we here on the Forum recommend it' whereas with Matt and Vizio,
they have not recommend this as a 'preventative' procedure.
I'd be doing this myself after every Firmware Update if Matt and Team
Vizio said/recommended so.
I just want other members here to see 'the other side of this' from
Matt/Vizio's standpoint. Let each owner do as they wish with their Display,
with the understanding what Vizio is saying, also.
post #49820 of 64411 Old 07-20-2017, 02:13 PM
Liked: 1664
Glitches are a common issue after firmware updates. This thread is bombarded after each update. I would say the chances are pretty fair.
Matt hasn't made a statement condoning it, but he hasn't condemned it either. If it was an issue, he would have voiced it already. This whole issue aroused from someone telling others that "Matt advised not to". That just simply is not true. It didn't need to spin off into this whole fiasco.
post #49821 of 64411 Old 07-20-2017, 02:42 PM
shoman94's Avatar
Quoted: 5307 Post(s)
Liked: 3675
I can tell you for a fact (meter read) that I have seen Vizio Calibrated changes not take effect even after resetting the color tuner. After a factory reset they took. Do what you want with those facts. They can help and they don't hurt. We don't need another 10 arguing posts on factory resets.
I did one yesterday before calibrating and it took all of 15 minutes to reset and reset all my personal settings prior to calibrating.
Sent from my ZTE A2017U using Tapatalk
promike and Ph8te like this.
2018 Sony LCD Master Series Calibration Thread
Sony XBR-75Z9F, Vizio M50-E1, Pioneer Kuro 5020, Marantz SR6013, AppleTV-4K, XBox One & (X), NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #49822 of 64411 Old 07-20-2017, 02:57 PM
Liked: 726
No arguing. Just if the 'changes don't take effect' after a Firmware
Update was a common issue, then Vizio would address it or change
their stance on Firmware Updates.
Like I said in my other post, if I were Meter-Calibrating, I'd do regular
FR, also.
I 'regularly' have not seen issues after a number of these Firmware Updates.
This latest one from what I can tell is fine and dandy, except for the bugs
we all know about, here.
post #49823 of 64411 Old 07-20-2017, 02:58 PM
Mustang66's Avatar
Quoted: 77 Post(s)
Liked: 59
Don't you have to enter all the different app's login info again after a factory reset? I know I can't do that in "literally 2 minutes"
Sent from my Nexus 6P using Tapatalk
Mustang66 is offline
post #49824 of 64411 Old 07-20-2017, 03:02 PM
shoman94's Avatar
Liked: 3675
15 minutes with reset and redoing settings for 4 inputs for two pic modes. It also included logging into 4 apps in SmartCast.
shoman94 is offline
post #49825 of 64411 Old 07-20-2017, 03:04 PM
shoman94's Avatar
Liked: 3675
Yea sure they would, just like it took 3 months of complaining and 2 videos showing the CMS problem.
Ph8te likes this.
shoman94 is offline
post #49826 of 64411 Old 07-20-2017, 03:04 PM
quantumparticle's Avatar
Liked: 0
Originally Posted by slippery44 View Post
Hello, I've been experiencing the picture freezes/vertical blinds freezes for several months now. I've called Vizio support a few times but it's hard to reproduce on demand. We always seem to do a reset and it goes away and then comes back in a month or so. Has anyone came across a definitive fix for this, at what point will they replace the TV? It's a 2016 P series so I do worry about it being out of warranty now, but I have been trying to work with customer support since April on this but I'm almost at the end of my rope.
My P55-C1 was doing this since I bought it in January. Maybe every couple weeks/months, couldn't reproduce on-demand. I opened a support case to document in early June, and when it happened again in late June followed up. They sent me a "new" set a few weeks ago. So far, no problems.
Better to report and document early, so that you can get it swapped out before the warranty goes.
quantumparticle is offline
post #49827 of 64411 Old 07-20-2017, 03:12 PM
Liked: 726
Not that I'm aware of. It holds. Unless you Factory Reset
the Tablet. Don't know about the Web-based Apps.
If a lot of owners are in default mode only, then maybe
'2-Minutes'. If all goes ok.
Myself, I have 6 Custom Picture Modes. If I touched up
the 11-Point, more time needed. If there's a fussy problem
with connection of the Tablet and/or to my router, more
time on top of that.
If I suspect something fishy going on, I'd first do the other
two Cycling methods before a FR. I know. Some problems
require the FR.
(At least these recent postings is a change in pace from the
'remote' postings.)
post #49828 of 64411 Old 07-20-2017, 03:23 PM
DAB
DAB's Avatar
Quoted: 172 Post(s)
Liked: 88
Going back to my original> to reset or not to reset <. Being a Beta tester where we are working on bugs/fails etc...
It came to the conclusion that it would be a "helpful asset''. However, maybe a - public FW update- has all the glitches out. so reset is a mot point..... YMMV
DAB is offline
post #49829 of 64411 Old 07-20-2017, 03:30 PM
sgondek's Avatar
Quoted: 27 Post(s)
Liked: 40
Originally Posted by Athlon646464 View Post
Got to thinking about part of your answer. DirecTV's channel 106 plays 4k content - am I still okay running it through my DVR if I will be watching that channel??
I also have the DirecTV 4K genie and agree that the channel program content is nothing special.
Now, as to the hookup, I have to connect via HDMI from the 4K genie directly to the TV.
The reason I cannot connect the 4K genie to the AVR and then to the Vizio is because my old Denon (2310CI) is not HDCP compliant. New AVR's will not have this limitation.
Vizio P65, Denon X1400H AVR, DirecTV 4K, Sony UHD BlueRay UBP-X800, Apple TV 4K, Cambridge PSW-1 sub, Cambridge center channel, ELAC B4 fronts, Klipsch rears;
sgondek is offline
post #49830 of 64411 Old 07-20-2017, 03:45 PM
tondeezy99's Avatar
Quoted: 128 Post(s)
Liked: 101
Has anyone ever recieved a support ticket from Vizio without ever filing a claim? I just recieved an email from Vizio with a support ticket...but I never contacted Vizio...?
tondeezy99 is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
