Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 1692 - AVS Forum | Home Theater Discussions And Reviews
 288495Likes
post #50731 of 64064 Old 08-06-2017, 08:20 AM
fletchmath's Avatar
Quoted: 22 Post(s)
Originally Posted by rightintel View Post
Those of you who are using a Logitech Harmony One and are using the RS120-B3 model no. for "cast", what input are you assigning it to? There's Netflix, Vudu, Media, and Vizio Internet Apps. No "cast" input is available...
The "Vizio Internet Apps" input puts the TV into SmartCast mode.
fletchmath is offline
post #50732 of 64064 Old 08-06-2017, 08:31 AM
rightintel's Avatar
Quoted: 914 Post(s)
Liked: 350
Tried that. It definitely switched to cast, but the Logitech screen was blank, and no controls on the remote worked. I had that situation already w/ "cast" programmed to my P75. What am I missing?
Xbox Live: General PATT0N
rightintel is offline
post #50733 of 64064 Old 08-06-2017, 09:21 AM
Kabobi's Avatar
Quoted: 54 Post(s)
Question
has anyone here managed to setup Plex to directplay HEVC (in mkv container) to a Vizio P series display?
I can't get HEVC to work for 720p, 1080p, or 4K; Plex just defaults to transcoding, and after messing with the chromecast.xml file, I got it to Direct Stream, but still no directplay.
I have been searching these and the Plex forums for hours and still have not found a clear answer as to what the source of the problem is.
Kabobi is offline
post #50734 of 64064 Old 08-06-2017, 09:46 AM
puddy77's Avatar
Quoted: 1064 Post(s)
Liked: 1997
Nope. Matt says it's something wrong with Plex. Until they fix it, turn on DLNA in the Plex server and use a different app to cast. I'm using Localcast. It casts HEVC HDR MKVs easily with no transcoding.
Kabobi likes this.
puddy77 is offline
post #50735 of 64064 Old 08-06-2017, 09:59 AM
shoman94's Avatar
Quoted: 5069 Post(s)
Liked: 3581
You're not missing anything. There just isn't any on screen buttons for that. Nothing is stopping you from programming your own on screen buttons.
Sent from my ZTE A2017U using Tapatalk
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #50736 of 64064 Old 08-06-2017, 10:24 AM
rightintel's Avatar
Quoted: 914 Post(s)
Liked: 350
Obviously, but I already could've programmed my own buttons w/ my P75 model no. I thought the point of using the other model numbers was the cast function w/ those allowed you to use the One's buttons to control casting(and w/o programming buttons).
post #50737 of 64064 Old 08-06-2017, 10:28 AM
DAB
DAB's Avatar
Quoted: 168 Post(s)
Liked: 86
On the P65-E1- with current tiles on screen
how does one add back the slide show.
Just received the new remote- like it.....
DAB is offline
post #50738 of 64064 Old 08-06-2017, 11:09 AM
shoman94's Avatar
Liked: 3581
That's Harmony fault for not adding on screen buttons by default. A blank slate is nice so you can program exactly what you want.
shoman94 is offline
post #50739 of 64064 Old 08-06-2017, 11:11 AM
shoman94's Avatar
Liked: 3581
Press up then right to highlight the display name and select that.
shoman94 is offline
post #50740 of 64064 Old 08-06-2017, 11:13 AM
rightintel's Avatar
Quoted: 914 Post(s)
Liked: 350
I get that, so is there no advantage to using the other model numbers then? Why are people doing in the first place then?
post #50741 of 64064 Old 08-06-2017, 11:15 AM
fletchmath's Avatar
Quoted: 22 Post(s)
Are you setting up a Harmony Activity? The one I set up uses my AVR to control volume and the TV to do everything else; the harmony buttons are fine, and I then added buttons to the screen to do what I wanted.
shoman94 likes this.
post #50742 of 64064 Old 08-06-2017, 11:20 AM
shoman94's Avatar
Liked: 3581
Could depend on the remote? I'm using a Harmony hub now and retires my One.
Maybe it depends on what you set as the main device in the activity?
shoman94 is offline
post #50743 of 64064 Old 08-06-2017, 11:24 AM
rightintel's Avatar
Quoted: 914 Post(s)
Liked: 350
Yeah, I set it up as cast, and cast is pre-labeled as an input in the harmony menu. It switches back n forth between inputs/powers on & off fine, but no button controls like directional, FF, etc.
post #50744 of 64064 Old 08-06-2017, 11:24 AM
playadel2001's Avatar
Quoted: 100 Post(s)
Liked: 117
If you are casting from your phone, the FF, REW etc buttons are not going to work. You can only use the Harmony to control the onscreen apps with the most recent firmware.
Sent from my SM-G920V using Tapatalk
playadel2001 is offline
post #50745 of 64064 Old 08-06-2017, 11:26 AM
fletchmath's Avatar
Quoted: 22 Post(s)
I used R120-B3 because it gave d-pad, menu, and the netflix, etc., buttons. I haven't checked the Harmony entry for the P65-E1, but at the time, the entry for my TV had none of those. So, using this model gave me every control I wanted except for a Hulu launcher, which I was able to learn from the X136 as soon as I received that. I simply had to go in the setup and add buttons to my screen for the 4 streaming services, and I was set.
post #50746 of 64064 Old 08-06-2017, 01:00 PM
movix13's Avatar
Liked: 0
Blurry patches
Originally Posted by Y2BNE1 View Post
Hi All,
I recently got P65-C1 and am really enjoying the TV. One thing I noticed is that when using it with my Xbox One S, the picture and text sometimes become blurry.
Has anyone figured this out? I have been having this same issue on my P50-C1 on two different inputs from an Oppo UDP-205 and PS4 (inputs 1 and 2 respectively). At first I was talking to Oppo about it since I only noticed it on their menu, but recently I noticed the PS4 input having this issue and now I know I'm not the only one. The only workaround is to soft restart and all is well for a little while. I believe this started with the last firmware, along with random restarts, which is a whole other matter.
movix13 is offline
post #50747 of 64064 Old 08-06-2017, 01:09 PM
sonoftumble's Avatar
Quoted: 2714 Post(s)
Liked: 2472
Keep in mind that the IR codes for accessing and controlling the older Vizio's Smart TV interface and apps are exactly the same as with the new Smartcast. That includes the transport, navigation and app launch short cuts. Get from the database a 2014 Vizio model such as an M702i-B3 and you should be good. You'll even have the on-screen handset buttons.
LG OLED65C7P 4-20-19 Calibration SDR/HDR/DV FW 05.80.15: https://www.avsforum.com/forum/40-ol...l#post57928994
VIZIO M70-D3 Calibration SDR/HDR FW 3.4.8.15: https://www.avsforum.com/forum/166-l...l#post55595700
sonoftumble is offline
post #50748 of 64064 Old 08-06-2017, 01:30 PM
rightintel's Avatar
Quoted: 914 Post(s)
Liked: 350
Thanks for the help, guys. I finally figured it out. It told me that there was an "update for this device", and it asked me to replace my P75-C1 w/ "Vizio TV". I deleted the P75-C1 from devices/activities, and added the "Vizio TV". I think it must've updated the Vizio database recently, or "CAST" wouldn't have ben in there. Now I've got it on input CAST, and it controls everything as it should w/ the Harmony One on CAST as well. The troubleshooting directs you to replace your model number to a universal "Vizio TV" since the update.
post #50749 of 64064 Old 08-06-2017, 01:42 PM
Pgcmoore's Avatar
Liked: 1
Originally Posted by jsutton2871 View Post
Does anyone know when the P55 series will get the updates? Looks like all I see is P65's getting the new firmware.
My P55-E1 updated this morning to 3.3.18.1
Pgcmoore is offline
post #50750 of 64064 Old 08-06-2017, 02:15 PM
eJeremye's Avatar
Quoted: 167 Post(s)
Liked: 32
My P65-C1 still has firmware 3.2.13.3
eJeremye is offline
post #50751 of 64064 Old 08-06-2017, 04:25 PM
Quoted: 27 Post(s)
Liked: 6
Originally Posted by hachima View Post
and they also said they are a bit slow in processing requests right now due to the holiday. In the meantime I am able to use an XRT510 remote from another set with the new SmartCast app.
Curious, how are you making it so you're able to use your XRT510 remote? I have a 2016 P Series that doesn't seem to be responding to my XRT510.
TheIndieArmy is offline
post #50752 of 64064 Old 08-06-2017, 05:39 PM
hachima's Avatar
Quoted: 53 Post(s)
Liked: 39
Are you on the upgraded firmware? I didn't have to do anything at all to get it to work with the P75. My new XRT136 remote was also delivered yesterday which I ordered by entering in the codes that poped up on my screen a week ago. So now I have the XRT135 and XRT136 plus the original remote that came with the TV.
hachima is offline
post #50753 of 64064 Old 08-06-2017, 05:54 PM
Quoted: 193 Post(s)
Liked: 223
Yea my 135 also worked right out of the package
AirborneMaikai is offline
post #50754 of 64064 Old 08-06-2017, 06:30 PM
Quoted: 27 Post(s)
Liked: 6
Yes I am upgraded. My XRT500 from my 2015 M works fine, but the XRT510 from my 2013 M has no response. I still need the XRT500 for my 2015, but since my 2016 P is replacing the 2013 M, that XRT510 remote is available for use. Unfortunately doesn't seem to be working though.
post #50755 of 64064 Old 08-06-2017, 06:40 PM
Dodge DeBoulet's Avatar
Quoted: 142 Post(s)
Liked: 107
Has anyone else noticed sub-par performance from the "built-in" (you know what I mean) SmartCast Hulu "app?" I've watched a couple of shows recently where it kept switching between 480p and 720p, but never went higher. When I switched to Google-casting from the Hulu app on my smartphone, I locked in at 1080p immediately and the image quality was rock solid.
I know it's not a bandwidth issue; I don't have any problem with the "built-in" Netflix and 4K/HDR, or the Amazon "app."
I saw similar (poor) Hulu performance on my TiVo Bolt+, so have been mostly using Google Cast to watch it on the P75. A bit disappointing to see that the included Hulu functionality doesn't measure up to casting.
@Matt McRae , is this something Vizio can fix? I'm in the beta, running 3.3.18.1.
Dodge DeBoulet is offline
post #50756 of 64064 Old 08-06-2017, 07:01 PM
skschatzman's Avatar
Quoted: 2724 Post(s)
Liked: 1611
@Dodge DeBoulet
No Vizio does not create the non-built-in interfaces for any of the services. It is up to the service to update and troubleshoot
Sent from my SM-G955U using Tapatalk
skschatzman is offline
post #50757 of 64064 Old 08-06-2017, 07:49 PM
Pgcmoore's Avatar
Liked: 1
I noticed the same when using the "smartcast" app from my iphone, I un-installed it completely and just ran the apps (youtube, netfilx, etc) directly from them, noticed an immediate improvement, but this was before the latest firmware update that added them to the screen, have gotten used to just running them from my phone. have not tried the on screen menu yet
Vizio P55-E1
Oppo UDP-203
Pgcmoore is offline
post #50758 of 64064 Old 08-06-2017, 08:00 PM
Pgcmoore's Avatar
Liked: 1
i find it much more convenient to run them all from there
blatz8 likes this.
Vizio P55-E1
Oppo UDP-203
Pgcmoore is offline
post #50759 of 64064 Old 08-07-2017, 04:32 AM
Quoted: 142 Post(s)
Liked: 107
I do like the single-button convenience the new remote offers, and prefer the UI the SmartCast-presented app provides (Hulu's recent redesign of their Android app is horrifyingly awful). But I'll gladly take an unpleasant UX over severely degraded picture quality. I spend only a few minutes in the app, but hours viewing what it streams
naustin and blatz8 like this.
post #50760 of 64064 Old 08-07-2017, 08:42 AM
JimLely's Avatar
Quoted: 209 Post(s)
Liked: 66
O.K., I know it's off topic but I didn't think you could cast (only mirror) MAXGO.
JimLely is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
