Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 1699 - AVS Forum | Home Theater Discussions And Reviews
 288684Likes
post #50941 of 64619 Old 08-11-2017, 12:30 PM
DAB
DAB's Avatar
Quoted: 176 Post(s)
Liked: 89
"[First step -- ensure that you've connected an HDMI 1.4 or later compliant cable between the ARC HDMI port on the Vizio TV (its labeled as ARC) and the ARC enabled monitor port on the Denon Receiver (its is also labeled as ARC). None of the other ports on either the TV or the Denon receiver will support ARC. Also -- ARC technology was not implemented in the HDMI standard until version 1.4 -- so just to be safe, make sure you have a more recent cable.
Set up your Vizio TV -- Go to the Menu on the Vizio TV, and into the Audio settings. Turn your TV Speakers to "Off", and "Digital Audio Out" to Bitstream". The other settings here can be set to whatever you'd like. Then, go to the Main Menu again, and select "Devices". What you should see if the Denon receiver is turned on, is HDMI-1 labeled as "AVR-X1100W". If you see that, it means the TV has discovered the Denon receiver properly. if not... don't worry, we'll fix that next. Finally, go back to the Main Menu, select "System", then select "CEC". Make sure "CEC" is set to "Enabled".
Set up your Denon Receiver -- Bring up the onscreen menu for the Denon Receiver ("Setup" on your remote). Select "Video" and then "HDMI Setup".
Turn "HDMI Control" to "On" and here is the key.... turn "TV Audio Switching" to "Off". (That last setting is not the most intuitive and tripped me up for a long time....) The other settings in this menu can be changed as you see fit.
Back out of the setup menu, and you should be good to go at this point.
Note -- when you use the Vizio TV as your source for audio (either the tuner or the imbedded apps), make sure you select "TV Audio" as your source on your Denon receiver. This tells the receiver to listen to the ARC information from the TV on the Denon HDMI port for audio."
***** Nope didn't work - even printed it out- to fallow stepXstep.. didn't give me NF into AVR
DAB is offline
post #50942 of 64619 Old 08-11-2017, 12:54 PM
DJ Lushious's Avatar
Quoted: 328 Post(s)
Liked: 117
Originally Posted by sonoftumble View Post
I'm ARC'ing to my heart's content with my Pioneer AVR. Good audio sync as well. I use ARC for Smartcast, but until recently I did the same with the TOSLink port. For casting sourced audio there is a zero sum gain whether you go with ARC or TOSLink because you won't find any uncompressed audio hiding in a HEVC stream.
There are several members with Denon's who have reported zero problems with ARC. Maybe one of them will chime in. My experience in getting it to work with my setup is that I discovered that you need both ends of the chain to be set to ARC ONLY. Apparently you can't have ARC + Control as the audio won't work if you do.
Do you get DD+ when using Vizio Cast Netflix? I have a Pioneer SC-95 and I cannot get a DD+ signal through ARC to save my life.
DJ Lushious is offline
post #50943 of 64619 Old 08-11-2017, 12:58 PM
Quoted: 39 Post(s)
Liked: 8
When will be the Youtube App added to the smartcast screen, its very basic app where usage is greater but still missing on the onscreen
ssarava9 is offline
post #50944 of 64619 Old 08-11-2017, 01:05 PM
sonoftumble's Avatar
Quoted: 2729 Post(s)
Liked: 2488
I didn't get DD+ with Netflix, but I did with Vudu. Also, I get it with the DirecTV 4K channels. So I'm thinking it's a Netflix server thing or the app needs some tweaking. This is beta FW, so there's some things that are not all there yet.
LG OLED65C7P 4-20-19 Calibration SDR/HDR/DV FW 05.80.15: https://www.avsforum.com/forum/40-ol...l#post57928994
VIZIO M70-D3 Calibration SDR/HDR FW 3.4.8.15: https://www.avsforum.com/forum/166-l...l#post55595700
sonoftumble is offline
post #50945 of 64619 Old 08-11-2017, 01:06 PM
Quoted: 1876 Post(s)
Liked: 1135
Originally Posted by shoman94 View Post
I've never noticed that. I do know the calibration changes some.
Sent from my ZTE A2017U using Tapatalk
I noticed this while watching, Fate of the Furious DV Vudu.
Sent from my SM-G360T1 using Tapatalk
DisplayCalNoob is offline
post #50946 of 64619 Old 08-11-2017, 01:09 PM
Liked: 2488
The gain is DD+ and Atmos with Arc.
You're right. I forgot about Vudu!
post #50947 of 64619 Old 08-11-2017, 01:43 PM
txdude's Avatar
Quoted: 12 Post(s)
Originally Posted by Jasonn B View Post
Is there anything I can stream for FREE on this tv to see what HDR looks like? I've never tried ir or tested it. Just wondering if there's a way to see it somehow with all the thousands of chrome cast apps without paying a fee to try it. I don't have any add on items like a firestock, etc. Can I?
p75-C1, Version 3.3.18.1, cast version 1.22.78594.
So yes I think you are correct. Not sure about this so someone correct me where I'm wrong.
Using the cast visio app on TV: no HDR for Hulu, Vudu, Amazon, NexFlix...is that correct?
4K for Vudu, Amazon, NetFlix, no for Hulu...is that correct?
So bottom line the fantastic picture I'm getting now is only going to get better as content providers catch up to the technology in my display...I can live with that.
Correct me where I'm wrong. Also when I cast, from the table or phone, I did not get HDR from the VUDU free HDR examples. But now that I think of it how would I know that HDR is working. It was 480P and look fantastic.
hope this made sense
P75 -C1
txdude is offline
post #50948 of 64619 Old 08-11-2017, 01:53 PM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
Originally Posted by Sbuchanan813 View Post
Can you guys really see the difference with Dolby vision and hdr10 on Netflix ? I have been experimenting and I hate how slow the SmartCast is to load initially, the Roku ultra is so snappy and easy. Idk I can't see a difference at all.
Originally Posted by DisplayCalNoob View Post
You will have to do a side by side in order to see a difference. What you can look for though, is detail, highlights that lack blooming. Primary colors pop more.
1) Is there some type of clip or movie that demonstrates Doubly Vision or HDR10 and switches it on/off on the same scene as a test to see what it does? There has to be a video loop out there or something that shows this as a test?
2) I noticed this with the Amazon app and Vudo I just tried both for 4k movies. When you first start the 4k movie and hit info it's sometimes at 1080P, then will ramp up to 4k and stay there. I guess this is normal?
Originally Posted by cgpublic View Post
I'm experiencing a lack of consistent responsiveness when casting, wondering if the set is confused by which connection to select and related speed issues.
Any thoughts if the set is more stable with Ethernet or WiFi?
I think it's slower to load so it 4k from the start.... Which I prefer.
I've it hook up ethernet and Wifi and there's no difference.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #50949 of 64619 Old 08-11-2017, 01:59 PM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
There is free HDR on Vudu. Here's how.
Originally Posted by puddy77 View Post
Vizio sponsored some short films that are available for free on Vudu. You need a Vudu account to add them to your collection and watch them, but they are free.
https://filmchallenge.vizio.com
Otherwise, as others have mentioned, there are some free demos you can download and play via USB. Check the first post of this thread to find a few: https://www.avsforum.com/forum/465-hi...ted-often.html
Yep. Just be sure to play/add the UHD versions. And if you use the Chrome browser on your PC, you can cast directly from that if you don't want to install the app on your phone.
The movie SHUN and THE FLESH OF MY LOVERS seems to look the best out of all 5. But, I've seen stuff on youtube look much better that isn't HDR.
Harmony 890 Remote
Jasonn B is offline
post #50950 of 64619 Old 08-11-2017, 02:11 PM
playadel2001's Avatar
Quoted: 100 Post(s)
Liked: 117
For your question #2 , yes it's normal to start at 1080p then go to 4k, it reduces the buffer time and complaints from people who think it takes too long to start a program
Sent from my SM-G920V using Tapatalk
playadel2001 is offline
post #50951 of 64619 Old 08-11-2017, 02:14 PM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
Cool, so even if hardwired to ethernet it's the same scenario?
playadel2001 likes this.
Harmony 890 Remote
Jasonn B is offline
post #50952 of 64619 Old 08-11-2017, 02:16 PM
Quoted: 100 Post(s)
Liked: 117
Yup. It's intentional behavior
post #50953 of 64619 Old 08-11-2017, 02:29 PM
fletchmath's Avatar
Quoted: 22 Post(s)
No, that's not correct. HDR is available on NetFlix and Vudu (if you pay for it). As others have noted, there is some (limited) free HDR content available on Vudu.
It does not matter whether you use the on-screen interface or cast from the tablet; NF and Vudu offer 4K/HDR.
Amazon (on-screen) offers 4k but no HDR at the moment. We are promised that HDR will be turned on soon.
Hulu does not offer 4k on any device except the game consoles ATM.
I found that if I just tried to play the demos on Vudu, i did not get 4k/HDR. If instead I clicked "Own", and chose to purchase the UHD versions (for $0), then I could play the Dolby Vision versions.
Christian Reyes likes this.
fletchmath is offline
post #50954 of 64619 Old 08-11-2017, 02:31 PM
-griffy-'s Avatar
Quoted: 159 Post(s)
Liked: 124
Now that I've got the latest firmware with the on-screen apps, I was looking forward to finishing up American Gods in 4K on Amazon, but I can't seem to find the UHD version. Does anyone know if the UHD version isn't available in the US or I'm missing something? I can see other UHD titles available via the app.
-griffy- is offline
post #50955 of 64619 Old 08-11-2017, 02:42 PM
abouttreefitty's Avatar
Quoted: 196 Post(s)
Liked: 380
Anyone else seeing lip sync issues on the latest firmware? Before the update, I was using Calibrated Dark with GLL on and Auto Lip Sync turned off on my Onkyo TX NR646 and lip sync was perfect. After the firmware update, I have to have Auto Lip Sync turned on in my receiver for Blu Ray and casting, and off for DIRECTV to have proper lip sync.
abouttreefitty is offline
post #50956 of 64619 Old 08-11-2017, 03:05 PM
ironmikey12's Avatar
Quoted: 216 Post(s)
Liked: 107
Poor grey uniformity/Dirty screen effect -- How much is "too much"
I know all LEDs have some degree of dirty side effect and also some issues with gray uniformity. But today I was watching the Arsenal game and could see good deal dirty screen effect right in the area where I see this giant like a blob pictured below. Is it just normal and to be expected? Or is this a little beyond what one should tolerate?
Obviously, it's very difficult to capture the dirty screen effect in a photo because you can only see it when when the image is panning
ID:	2266436   Click image for larger version
ID:	2266438   Click image for larger version
ironmikey12 is offline
post #50957 of 64619 Old 08-11-2017, 03:10 PM
DirkBelig's Avatar
Quoted: 397 Post(s)
Liked: 346
1. Kudos for the Spinal Tap reference. I've used it in this context myself.
B. As for toggling HDR10/DV on and off mid-clip, I don't think that's possible because (I believe) whenever HD content is plays, it sends a meta flag to the display to shift the transfer case into 4WD/HDR mode and it can't (again, I believe) be switched on and off mid-stream and would cause the screen to blank out in between modes.
I suppose a clip could be graded in HDR space to simulate Rec. 709 the way those demo loops which simulate the difference HDR makes in SDR, but actually mode switching, not really. (If I'm wrong, the Internet will swiftly arrive to correct all of this.)
reallynotnick likes this.
PimpVision® Quantum: Vizio PQ65-F1 | Denon AVR-X4400H | Def Tech ProCinema 600 + ProCenter 1000 + Monoprice Caliber #4104 (Atmos) + Monolith 10" THX Select (5.2.4) | Nvidia SHIELD (2015) | Apple TV 4K | Sony UBP-X700 | XBOX Project Scorpio | Xbox 360 | PS4 Pro | PS3 | Toshiba HD-A30 | Harmony 650 | Monoprice 8-Port gigabit switch
My DVD Profiler List | DirkFlix: My Movie Viewing Diary and Reviews
DirkBelig is offline
post #50958 of 64619 Old 08-11-2017, 03:43 PM
Liked: 1135
I don't have a link, but there are some downloads in the "master list" thread for current and upcoming HDR titles.
There are some demos for download there, DV and HDR10.
post #50959 of 64619 Old 08-11-2017, 03:49 PM
Sbuchanan813's Avatar
Quoted: 474 Post(s)
Liked: 312
Official Vizio 2016/2017 P Series Owners Thread UHD/HDR/DV No Price Talk Please
What I mean by liking the Roku better was about the SmartCast interface. When I input into SmartCast on screen menu it takes at least 10 sec to load up.. its slow and reminds me a lot of my 2014 e series apps... when I use the Roku it's incredibly fast and just works perfectly. I'm hoping they can make the menu interface faster because right now it just seems thrown together. I know it's beta so I'm hoping there is a way to add casting apps (I know you farts will say they aren't apps ) I want to be able to sort my apps I use and get rid of the ones I don't. That's all. Really not asking for much.i feel this tv simply cannot handle a faster system due to it being made without the notion of having a built in system.
Sbuchanan813 is offline
post #50960 of 64619 Old 08-11-2017, 03:53 PM
pwishart's Avatar
Quoted: 475 Post(s)
Liked: 468
Any fellow Vizio P Series owners have Ethernet connected and WiFi active and find that the system switches from one to the other on a continual basis? Typically, past HW connected to both will select the primary or strongest networking option. Should I disable WiFi?
On a related note, with 100mbs service from Verizon FiOS, the speed fluctuates from 25mbs to 60mbs for Ethernet. What is the experience of others?
I have a 150Mbs fiber internet connection and my P75 is connected by an Ethernet cable through an intelligent gig switch to the fiber router. It never switches to WiFi, the ethernet connection is always stable.
If you are loosing connection on Ethernet it has to be your router, cabling or a switch you have in the signal chain that is intermittent.
shoman94 and reallynotnick like this.
pwishart is offline
post #50961 of 64619 Old 08-11-2017, 04:00 PM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
It's because it's a cloud based system and the apps need to load, they aren't on the circuit board like the 2014 m for example. I hope some of it is due to it being a beta but yea, loading and exiting out of apps takes just as long. Longer than my 2014 m series. At least they could have the app load in the screen first and then show an actual progress bar to make it seem shorter
Harmony 890 Remote
Jasonn B is offline
post #50962 of 64619 Old 08-11-2017, 04:01 PM
Quoted: 474 Post(s)
Liked: 312
Agreed , honestly it's just not good enough for me. This is their premium tier tv and I expect it to feel like it when navigating .
post #50963 of 64619 Old 08-11-2017, 04:09 PM
txdude's Avatar
Quoted: 12 Post(s)
Thank you this was great feedback.
dirtydansv likes this.
P75 -C1
txdude is offline
post #50964 of 64619 Old 08-11-2017, 04:32 PM
Quoted: 12 Post(s)
Liked: 2
I have the x2300w and I have mine set up exactly like these instructions and it's works for me. Sometimes I do lose connection and have to unplug everything for a few minutes and I'm ok again.
Sent from my SM-G955U using Tapatalk
gwilly7 is offline
post #50965 of 64619 Old 08-11-2017, 04:48 PM
puddy77's Avatar
Quoted: 1189 Post(s)
Liked: 2493
No, the 4k version of American Gods is not available on Amazon in the US. Hopefully we'll get it eventually. But it's a distribution rights thing. It's a Starz show and only available on Starz in the US, which can only do HD. But since Starz doesn't distribute elsewhere, they released it via Amazon, which can do 4k.
puddy77 is offline
post #50966 of 64619 Old 08-11-2017, 05:27 PM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
Agree. I think if it preloaded the apps when you turned the tv on, BUT, BUT then it would take a lot longer for the tv to boot up, and things like google home turning on your TV and playing things would super slow down. Maybe instead of a global change there couldbe an option in settings to have apps preloaded or not preloaded when the tv turns on, for those that still want their tv to turn on almost instantly. Just thinking out loud, and maybe that can't even be done. I love that my tv can start displaying a picture in about 4 seconds!
Also, we are lucky to have the both options of casting with smart cast, and then having them add the menus without having to upgrade. Nothing everything is ever going to be perfect. I just don't want my tv boot up time to slow down. It blows away most other tv's in start-up time and that's important to me.
Harmony 890 Remote
Jasonn B is offline
post #50967 of 64619 Old 08-11-2017, 06:02 PM
Quoted: 196 Post(s)
Liked: 380
I think I figured this out. Previous firmware allowed Game Low Latency and Pure Cinema to both be on. Now it's one or another. Weak.
post #50968 of 64619 Old 08-11-2017, 07:32 PM
DirkBelig's Avatar
Quoted: 397 Post(s)
Liked: 346
I was noticing I was having lip sync issues last night where I'd never before and this reminded me that (IIRC) shoman had suggested turning GLL on to deal with motion issues and I'd said that I'd tried that before, but noticed lipsyc issues (had to dial in 16 ms in the Denon for some stuff, 30 ms on the X800 for others) and that I couldn't toggle PC on and judder/blur sliders were locked out. Go now and see GLL is on, so I flip it off, zero out the Denon adjustment and everything's fine. Pfft.
As for the ARC mystery, I'm looking at the instructions I'd posted (and others have seen) and my setup is rather different and ARC is working flawlessly for me. Let's look:
My Digital Audio Out is set to Auto. I'd set it to Bitstreaming before, but must've forgetten after the last factory reset and since I didn't have issues, never looked.
It's called Input Settings, not Devices, but I'm seeing the AVR name.
Mine is set to ARC only.
TV Audio Switching on mine is set to On.
post #50969 of 64619 Old 08-12-2017, 08:27 AM
Quoted: 144 Post(s)
Liked: 71
mattmcrae Im having the same problem as others with no connection detected. Using pc as input and game as pic mode.pc to receiver. Receiver to tv. Firmware 3.3.18 tv.
Sent from my SM-G935P using Tapatalk
jopat is offline
post #50970 of 64619 Old 08-12-2017, 12:56 PM
Quoted: 65 Post(s)
Liked: 8
Originally Posted by The Coolest View Post
The latest SmartCast firmware supports 50Hz and 100Hz, but these modes are not exposed via EDID. One of the upcoming FW updates will include these modes in the EDID too, so that devices querying the display capabilities (such as consoles and PCs) will have 50Hz as an option too.
Thanks for the info! I upgraded from the Vizio 2015 M-series to the 2016 Vizio P-series last year to enable all of these great features and that one yellow information bubble is just bugging me.
Jacob Prezbindowski is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
