Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 288589Likes
post #31 of 64411 Old 03-25-2016, 08:23 AM - Thread Starter
thomasfxlt's Avatar
Quoted: 3331 Post(s)
Liked: 6192
HDMI 1 is for ARC back to the AVR. ALL HDMI ports will route audio out HDMI 1.
Sent from my XR6P10 using Tapatalk
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #32 of 64411 Old 03-25-2016, 08:25 AM
alexanderg823's Avatar
Quoted: 3128 Post(s)
Liked: 2545
Originally Posted by B0000rt View Post
Thanks, not sure how I would test/show this. I'm coming from a Sharp LC-XXLE820UN which has terrible bleeding issues, and a Samsung HL-T5687S where the light engine was dying so white spots everywhere.
I do not have any HDR or 4k content or devices to test, other than probably my PC (AMD 290). Got any test images you'd want me to try?
I don't think that's correct, the Snapdragon 615 actually does have 8 cores, 4 of which are clocked lower for better power consumption, and the other 4 clocked higher for better performance.
http://www.anandtech.com/show/7784/s...ex-a53-designs
Refreshed CPU-Z and the CPU 3 is active again, I guess it was off for power savings?
You can just use your eyes for black levels and blooming
On black images like credits at the end of a movie does it get very black for you or a shade of dark gray? etc.
And about the cores... Looks like I'm indeed wrong. Maybe I should keep up more on the mobile CPU front... Or nah, moves too fast anyways lol.
alexanderg823 is offline
post #33 of 64411 Old 03-25-2016, 08:28 AM
Liked: 2545
Originally Posted by SiGGy View Post
Which cores are you talking about when you say this ARM or GPU?
GPU is programmable; so I suppose it's possible to do this if one wanted too.
ARM cores; no. Outside of power savings this isn't correct.
I believe Android will reserve 1 core for really low level functioning to indeed save power. Been a while since I've dabbled in android though so could have changed.
post #34 of 64411 Old 03-25-2016, 08:28 AM
thrashmagazine's Avatar
Quoted: 123 Post(s)
Liked: 63
Follow up even dumber question, can this be by-directional? As in, should I use 2 HDMI cords to my denon x2200w or can i just use HDMI 1 as my sender and receiver for signal?
Vizio P65-C1 (2016 - Dolby Vision/HDR10)
Denon AVR-X2200W
Klipsch Quintet III's + Klipsch R-12SW 5.1
Apple TV 4K | XBox One S | HDHomeRun Prime w/ FiOS
Silverback S6 HDMI Cables
thrashmagazine is offline
post #35 of 64411 Old 03-25-2016, 08:31 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
It's bidirectional. 1 cable is all you need unless you need to use HDMI 5.
post #36 of 64411 Old 03-25-2016, 08:32 AM
Quoted: 123 Post(s)
Liked: 63
you and your fancy spelling of bidirectional
thanks again!
thomasfxlt likes this.
Denon AVR-X2200W
post #37 of 64411 Old 03-25-2016, 08:34 AM
Quoted: 123 Post(s)
Liked: 63
one more Q, I need to extend my power cord, is this a polarized (square/circle) or non-polarized (circle/circle) cord in the back of the TV?
Denon AVR-X2200W
post #38 of 64411 Old 03-25-2016, 08:35 AM
SiGGy's Avatar
Quoted: 567 Post(s)
Liked: 445
Originally Posted by alexanderg823 View Post
If it fnctions anything like nvidias tegra, which that anandtech article implied, it'll reserve 1 core for really low level functioning to indeed save power.
It has 8 ARM cores.
4 High performance; higher power usage.
4 Lower performance; less power usage
Android (linux) kernel power savings (and scheduler) can remap interrupts to whatever CPU it wants and shutdown individual ones as it sees need based on load. This is a function of power saving done by manufacturer.
What you said is incorrect. It does use all of the ARM cores. Power saving/cpu scaling kernel modules do not take all of the CPU cycles of one core; not even close.
SiGGy is offline
post #39 of 64411 Old 03-25-2016, 08:39 AM
Liked: 2545
It has 8 ARM cores.
alright, yup appears i'm pretty ignorant on android these days, I won't try to discuss it anymore since i'm out of my element.
htwaits likes this.
post #40 of 64411 Old 03-25-2016, 08:41 AM
SiGGy's Avatar
Quoted: 567 Post(s)
Liked: 445
I doubt many people know this stuff; everyone is guilty of being ignorant. You just happened to speak of something I work on day to day
SiGGy is offline
post #41 of 64411 Old 03-25-2016, 08:44 AM
Liked: 3
B0000rt - Did you watch any college basketball on it last night? ( if you are into that sort of stuff )
cloudsblade is offline
post #42 of 64411 Old 03-25-2016, 08:46 AM
videoguy60467's Avatar
Quoted: 175 Post(s)
Liked: 203
Ha! I never gave it that long. Perhaps that's what's happening with the brief audio dropouts I've had with this set when using display audio out back to the AVR when set to DD. I had the same with the M series. I gave up and used PCM.
If they fix that, I'll move my audio score way up.
Where did you see the info posted on the Atmos audio?
Interesting.... I have a M55-C2, and I had developed the audio/video dropout bug when using bit-stream as an output. IIRC, it started during one of the firmware updates perhaps 1.3.15-UHD. Setting audio to PCM fixed it.
I have been expecting to see a later firmware update, but I'm still on 1.3.15-UHD. What's weird is that I put my audio back to bit-stream a few weeks back, and the problem seems to have magically fixed itself. I have read that sometimes Vizio pushes incremental minor updates that don't show a new version number. In any case, that bug seems to be killed on my TV for now.
videoguy60467 is offline
post #43 of 64411 Old 03-25-2016, 08:54 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I think that's probably true about the little updates. My M80 has some new behavior with colorspace and my TV hasn't updated beyond 1.13.15b.
The HDMI specs of the P series has me rethinking my AVR integration. It appears ports 1-4 are very powerful so I'll probably switch my main line into the TV to HDMI1 so I can prepare for ARC audio w Atmos back to the Pioneer SC-95. HDMI 5 on the P75 syncs with the Samsung K8500 routed through the Pio at 4k/60 4:4:4 but HDMI 2 did not. I had to set the Pio to 4:2:0 to get it to work. When the P75 gets the HDR update, I'll see whether I need a discreet port with 4:4:4 at that time. I've got 2 HDMI lines in the wall.
tigerfan33 likes this.
post #44 of 64411 Old 03-25-2016, 08:54 AM
GardenVariety's Avatar
Quoted: 725 Post(s)
Liked: 951
Mine's out for delivery. The suspense is killing me.
GardenVariety is offline
post #45 of 64411 Old 03-25-2016, 08:55 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
Which one did you get?
Tommy H likes this.
post #46 of 64411 Old 03-25-2016, 08:55 AM
Neceo's Avatar
Quoted: 41 Post(s)
I will have to see this in real life .. but how is the motion on here? If you turn off that "smooth effect" or whatever they call it, I really hate that soap opera effect, how is it? I love my plasma but 4k and HDR at this price looks interesting. Though I hate most LCDs due to motion.
Neceo is offline
post #47 of 64411 Old 03-25-2016, 08:57 AM
B0000rt's Avatar
Quoted: 33 Post(s)
I'm not sure, check the picture below
No, only got it this morning. I haven't touched any settings at all.
B0000rt is offline
post #48 of 64411 Old 03-25-2016, 09:01 AM
Quoted: 123 Post(s)
Liked: 63
Thank you, its polarized. If you dont mind could you send me the numbers on the power cord? I assume 120v/25 or something like that. Just wnt this on order before I pick my TV up today so I can get this TV mounted ASAP (infants, cats, hazard zone haha).
Denon AVR-X2200W
post #49 of 64411 Old 03-25-2016, 09:02 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I've got it off and so far no complaints. I am playing with the Reduce Judder and Reduce Motion Blur settings. Right now I've got RD at 1 and RM off. I'll adjust in real time viewing as needed and post feedback as it's relevant.
tazz3 and Patrick Randall like this.
post #50 of 64411 Old 03-25-2016, 09:03 AM
csrini1's Avatar
Quoted: 240 Post(s)
Liked: 80
Do we know what SOC is used in this set?
can the owners post the system screen shots using this app please?
https://play.google.com/store/apps/d...nalwire.aida64
csrini1 is offline
post #51 of 64411 Old 03-25-2016, 09:04 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
You got me with that acronym?
post #52 of 64411 Old 03-25-2016, 09:04 AM
B0000rt's Avatar
Quoted: 33 Post(s)
Hope this helps
B0000rt is offline
post #53 of 64411 Old 03-25-2016, 09:06 AM
B0000rt's Avatar
Quoted: 33 Post(s)
On the tablet or the TV? I posted the tablet above. Snapdragon 615.
Edit: Probably should stop calling it a TV
SOC - System On (a) Chip The processor.
B0000rt is offline
post #54 of 64411 Old 03-25-2016, 09:08 AM
Neceo's Avatar
Quoted: 41 Post(s)
cool thanks, though I will have to play with it in real life. I have my eye on an LG OLED but this will be oh 3k or so cheaper for the 65 inch and is tempting
tigerfan33 and cloudsblade like this.
Neceo is offline
post #55 of 64411 Old 03-25-2016, 09:12 AM
csrini1's Avatar
Quoted: 240 Post(s)
Liked: 80
SOC- System on Chip. I am looking for the tv system info.
csrini1 is offline
post #56 of 64411 Old 03-25-2016, 09:12 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
No experience with the LG OLED but I'm guessing your decision just became very difficult.
post #57 of 64411 Old 03-25-2016, 09:13 AM
Quoted: 123 Post(s)
Liked: 63
Hope this helps
to confirm, it looks like this? as in square circle, not circle and circle. i think your first picture answered it, but I got an hour to confirm before I can't get it tomorrow.
Denon AVR-X2200W
post #58 of 64411 Old 03-25-2016, 09:18 AM
B0000rt's Avatar
Quoted: 33 Post(s)
Square circle
ID:	1336874   Click image for larger version
B0000rt is offline
post #59 of 64411 Old 03-25-2016, 09:20 AM
B0000rt's Avatar
Quoted: 33 Post(s)
How would one go about getting this on the TV? It literally is just a "casting" device that shows up on the casting dropdown menu in applications.
B0000rt is offline
post #60 of 64411 Old 03-25-2016, 09:22 AM
pearsco's Avatar
Quoted: 305 Post(s)
Liked: 309
I'm right there with you. I was looking to replace my Kuro with an LG OLED B6 but the Vizio might be hard to pass up for the price. That and who knows when the B6 will become available.
dnoonie likes this.
pearsco is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
