Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 2085 - AVS Forum | Home Theater Discussions And Reviews
 288457Likes
post #62521 of 63893 Old 09-22-2018, 03:35 PM
fsrenduro's Avatar
Quoted: 45 Post(s)
P75-C1 turns itself off randomly
I bought this around March 2016 and haven't made changes to any settings on the display in a LONG time. In fact I haven't changed anything in my system at all except maybe firmware updates to my Apple TV.
I have verified that CEC settings on the display and my Marantz 7702mkii are off (not even ARC).
I did do a soft reset and that didn't help. I know there will be suggestions to do a factory reset but in my experience that won't solve this problem.
Just wondering if anyone else had had this issue. There's no way to make it happen but it happens probably once every 90-120 minutes. Happen whether we're watching TV, Wii or Apple TV.
don't insult my intelligents
fsrenduro is offline
post #62522 of 63893 Old 09-22-2018, 03:40 PM
Quoted: 202 Post(s)
Liked: 97
You made no mention of what the issue or problem is. Please tell and elaborate
Sent from my SM-G965W using Tapatalk
brownknuckles is offline
post #62523 of 63893 Old 09-22-2018, 04:14 PM
fsrenduro's Avatar
Quoted: 45 Post(s)
The title of the posting.
P75-C1 randomly turns itself off
post #62524 of 63893 Old 09-22-2018, 04:33 PM
Quoted: 202 Post(s)
Liked: 97
My friend you merely replied to an existing thread. There is no posting title since you didn't start a new thread.
If you've checked all your devices and disabled cec on them all. I'd recommend reseating all the HDMI cables.
Although you imply you don't want a do this, a factory reset is usually recommended after firmware updates to rule out any bugs left from old firmwares. It would be a good thing to rule out because otherwise my guess would be either a failing Main board or Power supply.
Cheers
post #62525 of 63893 Old 09-22-2018, 04:48 PM
pwishart's Avatar
Quoted: 474 Post(s)
Liked: 468
Cheers
If you read his first post (#62521) carefully it does have a title in bold letters that states the problem he is having:
blatz8 likes this.
pwishart is offline
post #62526 of 63893 Old 09-22-2018, 04:51 PM
bobby94928's Avatar
Liked: 786
Cheers
This is what I see from his post and it definitely has a title that explains what he is asking:
blatz8 likes this.
Bobby
bobby94928 is offline
post #62527 of 63893 Old 09-22-2018, 04:55 PM
Quoted: 202 Post(s)
Liked: 97
Guess I'm blind? Or Tapatalk has a glitch lol
post #62528 of 63893 Old 09-22-2018, 05:02 PM
pwishart's Avatar
Quoted: 474 Post(s)
Liked: 468
Crapatalk tends to leave out stuff randomly, to make room for their commercial Ads.
fireman325 and CleCakYngMfd like this.
pwishart is offline
post #62529 of 63893 Old 09-22-2018, 05:24 PM
Quoted: 202 Post(s)
Liked: 97
Ahhh. My bad then guys. We went off topic so back to tryna help the guy lol
post #62530 of 63893 Old 09-23-2018, 01:15 AM
7-Year Tribulation Soon?
CleCakYngMfd's Avatar
Quoted: 2020 Post(s)
Liked: 720
_________________________
...it happens probably once every 90-120 minutes. Happen whether we're watching TV, Wii or Apple TV.
Try testing the Display this way: Make sure you're in 'Economy' mode instead of 'Quick Start'. Remove all devices. Factory Reset. Confirm ARC/CEC are Off.
Watch the Display this way for a while and see if it still turns itself Off. If it does, it's probably a failing capacitor. Maybe in the Power Supply. Have there been any unusual changes how the Indicator Light and/or the Vizio onscreen logo behaves in the way it powers-up and/or takes longer to power-up?
- Pj
blatz8 likes this.
CleCakYngMfd is offline
post #62531 of 63893 Old 09-23-2018, 06:48 AM
fsrenduro's Avatar
Quoted: 45 Post(s)
- Pj
Interesting idea. I have had a few times where the display won’t turn on with my universal remote sequence. I have to pull out the original remote to power it on and when I do that it does this thing where it turns off and then on. Hard to describe but just different than normal.
post #62532 of 63893 Old 09-23-2018, 10:59 AM
stikle's Avatar
Quoted: 943 Post(s)
Liked: 1109
Originally Posted by lujan View Post
Very true, as I've almost reached my 1000GB cap on Comcast twice this summer including this month.
Consider switching to Business Class. No data caps. Dedicated bandwidth. I had Comcast Business for the better part of 10 years until I moved earlier this year. Now I'm on Spectrum Business (Charter) with no contract or data cap.
stikle is offline
post #62533 of 63893 Old 09-23-2018, 11:01 AM
lujan's Avatar
Quoted: 4279 Post(s)
Liked: 2414
Thanks, I may check into this?
lujan
506 Ultra HD
721 HD
4 SD
lujan is online now
post #62534 of 63893 Old 09-24-2018, 07:16 AM
Liked: 1
From my understanding Atmos will only work over arc if:
1) The tv has built in Dolby Atmos decoding and outputs DD+ with Atmos metadata (converting from lossless source to lossy DD+)
2) The Source Format is DD+ with Atmos metadata and the soundbar/receiver can handshake + decode with metadata.
In most cases you need to connect the Atmos source directly to the soundbar via HDMI.
This is why I'm holding off from buying Atmos soundbars until HDMI 2.1 and eARC go mainstream.
I was able to spend some more time with this over the weekend, and confirmed the following:
- Under no circumstance was I able to get Atmos to work "from" the TV, lossy or otherwise. After reset of TV and soundbar, different cables and sources, under no circumstances will it output Atmos from the ARC port. It looks like it tries (the green light pops on for a second, sometimes there is stuttery sound, then it is silent again.)
- If I change the settings on the TV to PCM, audio works over ARC but no Atmos. This makes me thing the ARC port isn't defective, which I initially considered.
- As mentioned before, the Chromecast Ultra and Xbox One X, connected to the HDMI In in the soundbar, then from HDMI OUT ARC on soundbar to back of TV will output HDR (including DV for Chromecast) and Atmos to the speaker. But as their is only one port, they can't both be hooked up. I watched Jurassic World Fallen Kingdom through the Chromecast and it looked and sounded incredible, with the display indicating DV was active and the SmartCast app indicating the soundbar was running Atmos. The fact this worked without incident makes me feel like there is nothing "wrong" with the soundbar.
My guess would be that there is some sort of... software issue (if that is right way to say it) with the HDMI ARC on the TV passing through Atmos to the soundbar, maybe just to this soundbar since others indicated it worked for them.
The big question for me now is if anyone with this soundbar has it working since that would indicate that there is something wrong my setup.
Mike Hitchcock is offline
post #62535 of 63893 Old 09-24-2018, 07:19 AM
Liked: 1
Just saw this - https://www.avsforum.com/forum/195-s...os-update.html - so nevermind! Looks like it will be fixed soon enough! Yay!
a61688 likes this.
post #62536 of 63893 Old 09-24-2018, 12:21 PM
brewtownska's Avatar
Quoted: 14 Post(s)
No audio on Vizio P65-C1 from 1byOne ATSC tuner
I'm hoping to get some feedback on whether my issue seems like a Vizio problem or a 1byOne ATSC tuner problem. Based on timing, I think my problems started with one of the last 2 or 3 Vizio firmware updates.
I bought the 1byOne ATSC tuner from Amazon back in January, mostly because my Mediasonic Homeworx ATSC DVR was giving me hassle where it wouldn't play nice with my Xbox One X and PS4 (had to shut down the TV and back on if I switched between devices, else had blinking video or subpar video). The 1byOne worked well for a few months (even after getting a firmware update to v1.1.2), then when the primetime shows went away for the summer, I really had no use for it. Seems like somewhere between May and August, I no longer get sound (video still works fine).
I tried so many things the past few days trying to get sound on the Vizio - changing the 1byOne to use PCM vs Bitstream, adjusting the volume on the 1byOne, tried connecting it to each of the 5 Vizio inputs over 2 different HDMI cables (that were known working for other devices). I verified the same cables produce sound to a small 32" Toshiba TV, so I know the 1byOne box is at least outputting sound.
I already reached out to 1byOne and had them send the most recent firmware, v1.1.3 (from April 2018), and while it updated fine, I still don't get sound on the Vizio.
I suspect either the 1byOne is not outputting the same standard audio that the Vizio expects to see, therefore ignoring the audio completely. Or possibly, one of the Vizio firmware updates causes the TV to no longer recognize the audio from the 1byOne tuner.
Anyone else have the 1byOne and a Vizio P-series to confirm working settings? Have you had any odd effects over the past few Vizio firmware releases? Any other suggestions I should try? I will reach out to 1byOne to explain the problem there to see if they have any ideas for me to try.
Mike
brewtownska is offline
post #62537 of 63893 Old 09-24-2018, 12:45 PM
lujan's Avatar
Liked: 2414
I got some information on the Comcast Business and it would cost $40.00 more pre month and the speed would go from 250Mbps to 75Mbps. Since I don't reach the caps every month (mostly in the summer), I decided to keep the one I have but thanks for the recommendation.
a61688 likes this.
lujan
506 Ultra HD
721 HD
4 SD
lujan is online now
post #62538 of 63893 Old 09-24-2018, 03:23 PM
pwishart's Avatar
Quoted: 474 Post(s)
Liked: 468
HDMI ARC has always been unreliable ever since it's inception with HDMI Ver1.4, just because you got it to work once does not mean it will work the next day or ever again with any type of equipment.
Ph8te likes this.
pwishart is offline
post #62539 of 63893 Old 09-24-2018, 04:07 PM
Liked: 720
Originally Posted by brewtownska View Post
My issue seems like a Vizio problem or a 1byOne ATSC tuner problem...
Did you check the Vizio Audio settings in combo with the tuner settings? Did you reset the tuner and start over setting it up? Does the Vizio remote cause the volume to go down or mute with the tuner? Does the tuner's remote change something with the Vizio? This can happen. I have interference problems with my Channel Master Tuner and my P50-C1.
- Pj
post #62540 of 63893 Old 09-25-2018, 07:15 AM
DAB
DAB's Avatar
Quoted: 162 Post(s)
Liked: 82
P65 E-1
I just noticed this> On a full white screen back ground is all white. I am getting flickering on screen. [ maybe call ?blooming?
It is a white flicker on a white back ground. Does anyone know what this is?
On a normal screen shot< with colors >. I don't see any issues and PQ is excellent. Self calibrated and use some forum members setting as well. - Game/noise are >OFF
DAB is offline
post #62541 of 63893 Old 09-25-2018, 07:36 PM
Liked: 720
Originally Posted by DAB View Post
P65 E-1. I just noticed this: On a full white screen back ground is all white. I am getting flickering on screen...
Is Clear Action On?
- Pj
post #62542 of 63893 Old 09-26-2018, 08:01 AM
DAB
DAB's Avatar
Quoted: 162 Post(s)
Liked: 82
Is Clear Action On?
- Pj
No- Clear Action is - OFF
DAB is offline
post #62543 of 63893 Old 09-26-2018, 03:22 PM
shoman94's Avatar
Quoted: 5016 Post(s)
Liked: 3562
The software on this TV is so glitchy. I wish I could go back to FW 2.2.7.4.
Sent from my LG-H932 using Tapatalk
zer0cool2007 likes this.
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is online now
post #62544 of 63893 Old 09-26-2018, 04:07 PM
lujan's Avatar
Liked: 2414
What specifically is "glitchy" as this one has been the most stable for me?
lujan
506 Ultra HD
721 HD
4 SD
lujan is online now
post #62545 of 63893 Old 09-26-2018, 04:54 PM
shoman94's Avatar
Liked: 3562
What specifically is "glitchy" as this one has been the most stable one for me?
Bottom half of the screen being glitchy at times.... Self muting and then rebooting at times, tonight switched inputs and it locked with the info bar stuck down for 30 seconds and then rebooted.......
Backlights pulsing is annoying too.
post #62546 of 63893 Old 09-26-2018, 04:56 PM
Quoted: 202 Post(s)
Liked: 97
For starters when pressing the smartcast button it defaults to the support page rather than the home screen. This is an issue with the models sold in Canada as I have the problem with both the P50-C1 and P55-C1. CEC control for my PS4 and switch on the p55-c1 also broke after the last update (although it's usually a hit or miss with devices). I'd even be okay with the 4.0.2.3 update since most things worked fine then lol
post #62547 of 63893 Old 09-26-2018, 05:28 PM
pwishart's Avatar
Quoted: 474 Post(s)
Liked: 468
My P75 was bought from Costco in Canada in August of 2016, when pressing the Smartcast button it always goes to the Smartcast home screen, it has never ever gone to the support page.
CEC and HDMI ARC has always been unreliable on all equipment, every time you attempt to use either it is a coin toss if it is going to work, both always will be until the newer version eARC comes out with HDMI 2.1 but that will not help any current equipment.
pwishart is offline
post #62548 of 63893 Old 09-26-2018, 07:56 PM
naustin's Avatar
Quoted: 1636 Post(s)
Liked: 1018
I agree with you, on my P65-C1 the latest firmware has been very stable and the picture once calibrated is outstanding. IMHO. Maybe @shoman94 is experiencing hardware problems
a61688 and Oldways7 like this.
naustin is offline
post #62549 of 63893 Old 09-26-2018, 08:09 PM
bobby94928's Avatar
Liked: 786
In the last few days, on my P75-C1, I have had a screen freeze and then a window blinds issue. I hadn’t done a reset to factory since the last download so I did one. All is good so far...
Bobby
post #62550 of 63893 Old 09-26-2018, 09:49 PM
lujan's Avatar
Liked: 2414
Sorry to hear.
lujan
506 Ultra HD
721 HD
4 SD
lujan is online now
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
