Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 2137 - AVS Forum | Home Theater Discussions And Reviews
 288720Likes
post #64081 of 64736 Old 10-05-2019, 09:50 AM
Quoted: 258 Post(s)
Liked: 119
Originally Posted by KristopherSteel View Post
Not sure what changed but it’s something with the TV. I can turn the tv on with CEC but for the past couple of months, it won’t turn off via CEC. This was never an issue before. Tried all the ricks. Have not done a factory reset as it’s Calibrated and don’t feel like losing that. What did Vizio break? I have to use the remote to turn it off. FWP I know. It’s really annoying. All firmware is up to date.
Cec control continues to be further broken with each firmware update. I've long changed cec to "arc only" and been using a harmony remote.
A factory reset may work but probably not.
Sent from my SM-G965W using Tapatalk
naustin likes this.
brownknuckles is offline
post #64082 of 64736 Old 10-06-2019, 04:10 AM
bigxboss's Avatar
Quoted: 125 Post(s)
Liked: 62
How is clear action STILL broke? What is going on?
@VizioService @VizioService @VizioService
Can we get an update on CLEAR ACTION getting fixed?
You guys broke it with a firmware update months ago.
blatz8, rhelliott2 and Sanctine like this.
bigxboss is offline
post #64083 of 64736 Old 10-10-2019, 10:52 AM
DaveFi's Avatar
Quoted: 1037 Post(s)
Liked: 399
I can't even get ARC alone to work.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #64084 of 64736 Old 10-10-2019, 11:01 AM
Quoted: 258 Post(s)
Liked: 119
Try with a new 6ft HDMI premium certified cable. Monoprice one. Also ensure arc is enabled on both devices. Toggle if needed.
If it still doesn't work factory reset.
post #64085 of 64736 Old 10-10-2019, 01:28 PM
naustin's Avatar
Quoted: 2023 Post(s)
Liked: 1369
Also try toggling Audio from Auto to bitstream or visa versa.
naustin is offline
post #64086 of 64736 Old 10-10-2019, 05:36 PM
DaveFi's Avatar
Liked: 399
Yeah, have the monoprice premium cable, toggle multiple times, nada. It seems to have a problem with my Onkyo TX-NR676. I got it back briefly after factory resetting my P65-E1 but after turning it off it refuses to see the receiver any longer (sees my Shield just fine). I tried turning off CEC/ARC completely and just using an optical cable, but the TV is only outputting standard DD. With CEC/ARC on it also will only output standard DD unless the TV sees the receiver (which it doesn't).
Very, very, frustrating. I'd reset the TV again but I'm getting tired of it.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64087 of 64736 Old 10-10-2019, 07:38 PM
naustin's Avatar
Liked: 1369
One last option, that I had to do for ARC to my Samsung 7.1.4 system....
Turn off Enhanced option on my P series ARC HDMI port. That will limit HDR to 30Hz or less input to the P display. Output from the other P series HDMI ports won't be affected.
naustin is offline
post #64088 of 64736 Old 10-10-2019, 08:09 PM
DaveFi's Avatar
Liked: 399
Won't work because my receiver needs to be connected to the ARC port to get DD+/Atmos, I'll just be limiting all my other devices connected to my receiver.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64089 of 64736 Old 10-10-2019, 11:29 PM
naustin's Avatar
Liked: 1369
Yes it is a pretty limiting kludge. Luckily I only have my Oppo player and AppleTV4K going thru the ARC port with the rest of my devices switched into the P65. Hope you find a fix.
naustin is offline
post #64090 of 64736 Old 10-11-2019, 08:00 AM
Dodge DeBoulet's Avatar
Quoted: 168 Post(s)
Liked: 127
I have an Onkyo TX-NR787 and CEC/ARC is (at the moment) working fine. I had an issue before the recent 7.x.x.x update where it wasn't, though, and posted here about it. Unplugging the power from the receiver and plugging it back in again resolved the problem.
Dodge DeBoulet is offline
post #64091 of 64736 Old 10-11-2019, 08:08 AM
Quoted: 168 Post(s)
Liked: 127
Since post editing appears to be broken, I'll just have to quote myself ...
I should also mention that I'm using the Amazon Basics 10' HDMI cables, not them fancy-dancy Monoprice ones.
post #64092 of 64736 Old 10-11-2019, 07:50 PM
DaveFi's Avatar
Liked: 399
That "fancy" monoprice cable costs like $8.
I tried unplugging both my TV and receiver for hours, and no go. I'll reset both devices one last time and if that doesn't help I give up.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64093 of 64736 Old 10-12-2019, 04:33 AM
Quoted: 168 Post(s)
Liked: 127
Yikes. In my case I'd only unplugged for maybe 15 seconds, so I'm not optimistic that it'll fix your issue. I hope resetting fixes it ...
post #64094 of 64736 Old 10-12-2019, 05:17 AM
DaveFi's Avatar
Liked: 399
I have an Apple TV 4k as well, I don't really use it, I tend to like the TV's smart-apps mainly because it scales all the output properly (and offers true DD+/Atmos audio, instead of putting a "layer" on the system sounds like the ATV4k does. I suppose if I have to use it I will.
I suppose I can use my Shield too, but then I sacrifice DV support.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64095 of 64736 Old 10-12-2019, 08:14 AM
lujan's Avatar
Quoted: 5205 Post(s)
Liked: 3217
Except the Smartcast apps are so very slooooow. That's mostly the reason I use them the least.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #64096 of 64736 Old 10-12-2019, 05:37 PM
DaveFi's Avatar
Liked: 399
They are, it’s because they’re HTML5 based. Poor planning on Vizio’s part. You can always cast from your phone.
The ATV 4k does have some pretty cool integration with the TV app. When I tell it to play something on my iPad it starts immediately.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64097 of 64736 Old 10-14-2019, 12:03 PM
I have exactly this same issue. It was introduced after the v6 to v7 firmware.
Denon AVR‑X3400H; Pioneer SP-C22 (C), Pioneer SP-FS52-LR (F/LR), Pioneer SP-BS22-LR (R/LR & FH), BIC America V-1220 (SB)
Vizio P55-C1, Apple TV 4K, TiVo Bolt OTA, Sony UBP-X700, NAP TS-253 Pro w/ Plex, URC MX-700Q, Sevenhugs Smart Remote
callworth is offline
post #64098 of 64736 Old 10-14-2019, 12:53 PM
Quoted: 258 Post(s)
Liked: 119
Do a factory reset. P55-c1 and p50-c1 turn on and off via cec just fine if connected device supports feature (e.g. apple tv).
post #64099 of 64736 Old 10-14-2019, 02:59 PM
KristopherSteel's Avatar
Quoted: 89 Post(s)
Liked: 55
Not sure what changed but it’️s something with the TV. I can turn the tv on with CEC but for the past couple of months, it won’️t turn off via CEC. This was never an issue before. Tried all the ricks. Have not done a factory reset as it’️s Calibrated and don’️t feel like losing that. What did Vizio break? I have to use the remote to turn it off. FWP I know. It’️s really annoying. All firmware is up to date.
So I had a feeling this wouldn’t work. It did not. Not only did I lose my calibration, I can no longer do Dolby Vision. Before I was able to set my Apple TV to use DV but now, if refuses. It will only use 4K HDR. Literally nothing changed except resetting the tv.
KristopherSteel is offline
post #64100 of 64736 Old 10-14-2019, 03:22 PM
lujan's Avatar
Liked: 3217
Did you try resetting the ATV as well? Maybe it's that device rather than the display?
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #64101 of 64736 Old 10-14-2019, 03:36 PM
Quoted: 89 Post(s)
Liked: 55
It’s not the ATV. So I plugged the ATV directly into the display. It picked up Dolby Vision fine. It also turned the display off when I put the ATV to sleep. However, when I connect it back to the Onkyo, no Dolby Vision and it doesn’t turn it off. Again, I have no clue as all this was working previously?
post #64102 of 64736 Old 10-14-2019, 04:50 PM
Quoted: 258 Post(s)
Liked: 119
Make sure Onkyo receiver is running latest firmware.
Also try unplugging all 3 devices. Reseat the HDMI cables, then try again. Also you could try running the HDMI cable test on the apple tv. Perhaps one of the links isn't passing DV properly.
post #64103 of 64736 Old 10-14-2019, 04:54 PM
Quoted: 89 Post(s)
Liked: 55
Did all that. Spent an hour wasting my time with this crap. Not doing it anymore. Guess it’s just HDR now.
post #64104 of 64736 Old 10-14-2019, 06:38 PM
Quoted: 168 Post(s)
Liked: 127
So this probably won't have a positive effect, but it's worth trying. Documentation here:
https://www.onkyo.com/manual/sup/upd/hdmi_4k_onk.pdf
It's a feature on my TX-NR787 with one of the recent firmware upgrades; maybe it's on yours too. If it's on, turn it off. If it's off, turn it on. See what happens ...
If the link scares you due to its broken certificate, here's what it says:
While pressing BD/DVD (*1) on the main unit, press ON/STANDBY to display the current setting on the display.
While this is being displayed, hold down BD/DVD on the main unit and repeatedly press ON/STANDBY to switch the setting.
post #64105 of 64736 Old 10-14-2019, 07:00 PM
DaveFi's Avatar
Liked: 399
Always have to remember to turn that back on when I reset my TX-NR676.
It's the Onkyo receivers that cause a lot of problems. I have to keep resetting it to get CEC/ARC back. Initially I had to reset it a few times to get Dolby Vision working- it's very picky about the cable you use. I found the Monoprice premium cables (not that expensive) to work best for DV. They really need to update the firmware.
As far as the Vizio's firmware goes, I've pretty much given up hope.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64106 of 64736 Old 10-14-2019, 07:08 PM
Quoted: 258 Post(s)
Liked: 119
Rip Onkyo, not even D&M holdings purchasing the company will save em lol
post #64107 of 64736 Old 10-16-2019, 04:02 AM
DaveFi's Avatar
Liked: 399
Eh, they're Pioneer receivers now anyways. Never much liked Pioneers, and the new Onkyos have similar problems. I only bought one because it's cheap. Next time I'll buy a Yamaha or something.
Is it too much to expect Vizio to fix Clear Action? It hasn't worked since last Dec. Geez.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #64108 of 64736 Old 10-16-2019, 09:08 AM
Quoted: 258 Post(s)
Liked: 119
Technically they're Denon now lol.
I've PM'd @VizioService about clear action so we don't sound like broken records in the forum.
post #64109 of 64736 Old 10-16-2019, 09:54 AM
lujan's Avatar
Liked: 3217
Denon is another one of those companies that are getting too big now.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #64110 of 64736 Old 10-18-2019, 03:36 PM
CleCakYngMfd's Avatar
Quoted: 2073 Post(s)
Liked: 730
Any with a P-50C1 notice the Film mode stays OFF and can't be toggled?
Also, streaming content with 25 VF still has motion issues.
- Pj
CleCakYngMfd is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
