Official Vizio 2016/2017 P Series Owners ONLY Thread UHD/HDR/DV No Price Talk Please - Page 533 - AVS Forum | Home Theater Discussions And Reviews
 288502Likes
post #15961 of 64096 Old 06-09-2016, 09:26 AM
lujan's Avatar
Quoted: 4582 Post(s)
Liked: 2659
Originally Posted by lujan View Post
Great, my P75 is supposed to be in Monday and a big reason I bought it is for the Vudu UHD streaming which now doesn't seem to be working?
Just had a thought! If the P75 comes with earlier firmware should I just NOT update it? It seems Vudu 4k streaming was working prior to the latest firmware, right?
lujan
559 Ultra HD
721 HD
4 SD
lujan is online now
post #15962 of 64096 Old 06-09-2016, 09:34 AM
zer0cool2007's Avatar
Quoted: 189 Post(s)
Liked: 205
I just tested "In The Heart Of The Sea", and it appears to be streaming UHD/DV just fine on my P75 (with the latest FW).
zer0cool2007 is offline
post #15963 of 64096 Old 06-09-2016, 09:37 AM
whizzer4113's Avatar
Quoted: 84 Post(s)
Liked: 29
So, I'll admit I'm a little slow, but could someone please explain HDR capabilities with the P65. I just got the Samsung k8500 UHD bluray player and noticed in the P65 system info screen that HDR was listed as "No" while playing a new UHD disk. The disk even popped up a choice to play HDR content. So is HDR only available via casting now, until the HDR10 firmware update comes out? I also have a Denon x3200. Current path is as follows; k8500 -> X3200 -> P65. All BJC HDMI cables.
If this is the case, what quality I'm I currently getting with the K8500 and a UHD disk? Standard 4k?
Thanks in advance.
whizzer4113 is offline
post #15964 of 64096 Old 06-09-2016, 09:43 AM
Quoted: 189 Post(s)
Liked: 205
Originally Posted by whizzer4113 View Post
So, I'll admit I'm a little slow, but could someone please explain HDR capabilities with the P65. I just got the Samsung k8500 UHD bluray player and noticed in the P65 system info screen that HDR was listed as "No" while playing a new UHD disk. The disk even popped up a choice to play HDR content. So is HDR only available via casting now, until the HDR10 firmware update comes out? I also have a Denon x3200. Current path is as follows; k8500 -> X3200 -> P54. All BJC HDMI cables.
Thanks in advance.
Not that slow, you answered your own questions.
you will not get HDR10 from the K8500 (or anywhere) until the update. You are getting 4K resolution though.
You can get Dolby Vision HDR from some UHD titles on VUDU, and Marco Polo from Netflix (with DV coming to some other titles "soon")
post #15965 of 64096 Old 06-09-2016, 09:51 AM
Mattopotamus's Avatar
Quoted: 2104 Post(s)
Liked: 2117
Just to piggyback on this to help.
There are two types of HDR: HDR10 and Dolby Vision.
-All UHD disk must include HDR10 and Dolby Vision is optional. Currently there are no Dolby Vision UHD players on the market.
-VUDU and Netflix currently stream in Dolby Vision and that works just fine with the P series
-HDR10 will be rolled out into 2 phases, first so it works over HDMI and then with streaming content. The HDR10 update should hit our TVs at the latest in the next 45 days.
Mattopotamus is offline
post #15966 of 64096 Old 06-09-2016, 09:53 AM
shortyg83's Avatar
Quoted: 1066 Post(s)
Liked: 955
Thanks in advance.
You are actually not getting standard 4k. Sadly UHD discs do not have a standard 4k format.
UHD discs are graded to be very dark. This does not change when your tv doesn't have HDR. Which means some scenes will be too dark unless you calibrate the picture to be brighter. Normally the HDR metadata would change this but without the metadata the picture will be dark.
You will not likely notice in brightly lit scenes. But scenes that are suppose to be very dark, get so dark you can't even see what is happening.
shortyg83 is offline
post #15967 of 64096 Old 06-09-2016, 09:56 AM - Thread Starter
thomasfxlt's Avatar
Quoted: 3322 Post(s)
Liked: 6165
This is somewhat true. Not all of the UHD disks have dark grading but many do. You can accommodate by boosting backlight and lowering gamma. Until we have the HDR10 update, you need to customize the setup for each disk but usually by just using those 2 settings.
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #15968 of 64096 Old 06-09-2016, 09:58 AM
Quoted: 84 Post(s)
Liked: 29
Perfect. Thanks for the explanation. Just curious, is there a way to verify which HDR signal is being received? HDR or DV? Maybe that will come with the HDR10 update?
post #15969 of 64096 Old 06-09-2016, 09:58 AM
Liked: 2
Such sadness. I had this happen 3 times since I got my P75 a little over a month ago. When it happens on mine the right half of the screen is a bunch of crazy lines and barely any picture. It happened this morning but went away after 10 seconds. The other 2 times I had to power cycle.
Did it look anything like this? This happens on my TV every few hours or so. I called Vizio and got it replaced; getting my new set today!
Marshall Simmons is offline
post #15970 of 64096 Old 06-09-2016, 10:00 AM
shortyg83's Avatar
Liked: 955
Yea I normally have my set at 2.4 gamma. Dropping it to 2.1 helps quite a bit when watching movies that are dark.
thomasfxlt likes this.
post #15971 of 64096 Old 06-09-2016, 10:01 AM
shortyg83's Avatar
Liked: 955
Similar to that. But at this point it only happened 3 times in last month. If it starts occurring more or if the next firmware doesn't fix it I will call vizio.
post #15972 of 64096 Old 06-09-2016, 10:02 AM
Quoted: 143 Post(s)
Liked: 80
Originally Posted by Fascinate View Post
Eh ive only owned vizio tv's starting with a 32" from about 2007 (flat panels that is, before that was a ton of random tube tv's lol). I was brand loyal and i regret it, this TV simply does not offer the WoW factor i was looking for. I will say it does better with dark scenes on netflix compared to my 40" from last year, but aside from that i dont see appreciable differences. I am a vizio fanboy if anything, but i think its time i try some other brands.
You posted nothing about your settings and you come here to rant. If you don't like it get another TV. Only you can decide not us.
Live intentionally, not habitually
Sent from my XT1254 using Tapatalk
toonj64 likes this.
Bootnylee is offline
post #15973 of 64096 Old 06-09-2016, 10:03 AM
weeber24's Avatar
Quoted: 71 Post(s)
Liked: 57
Originally Posted by turts85 View Post
How is your P55 holding up? Any issues for you after the update...if you got it
I did get the update, and haven't seen any problems. But you're the second person to ask about any issues after the update. Is there an issue out there I'm not aware of? I haven't been keeping up with this thread.
Actually, if there is an issue, maybe I'm better off not knowing... ignorance is bliss after all
weeber24 is offline
post #15974 of 64096 Old 06-09-2016, 10:05 AM
Liked: 2117
In the settings it just says HDR: Yes or No. If a movie contains HDR10 and Dolby Vision, Dolby Vision will take over. The general consensus is that Dolby Vision is the better of the two b.c it is dynamic and contains metadata to make changes scene by scene. HDR10 is static it the current state.
Dolby owns Dolby Vision and they license HDR10. If you think about it, it makes sense to keep the best for yourself.
post #15975 of 64096 Old 06-09-2016, 10:08 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
All, the VUDU problem (specifically with casting UHD titles) has been replicated by Vizio and is being analyzed. Stay tuned.
htwaits, bferr1, Kadath and 7 others like this.
post #15976 of 64096 Old 06-09-2016, 10:11 AM
lujan's Avatar
Liked: 2659
One thing that is consistent on these forums is the lack of consistency.
shoman94, zer0cool2007 and toonj64 like this.
lujan
559 Ultra HD
721 HD
4 SD
lujan is online now
post #15977 of 64096 Old 06-09-2016, 10:17 AM
toonj64's Avatar
Quoted: 863 Post(s)
Liked: 556
If you are THAT disapointed with it, there is without a doubt something wrong either with your settings on the set or somewhere in your chain of devices or you simply have a deffective set.
These are not OLED wow but pretty damn close so saying it looks like crap just says something isnt right....
shoman94 and Furyus like this.
toonj64 is offline
post #15978 of 64096 Old 06-09-2016, 10:20 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Try scrubbing to other locations after you start playing. Make sure you are in UHD. HDX is fine.
post #15979 of 64096 Old 06-09-2016, 10:21 AM
Ph8te's Avatar
Quoted: 6510 Post(s)
Liked: 6225
Well it's about time someone called Vizio
Sent from nowhere
Ph8te is online now
post #15980 of 64096 Old 06-09-2016, 10:21 AM
friendlysmith's Avatar
Quoted: 40 Post(s)
exactly how I have it. While the TV can be set to ARC only, the AVR needs Control Mode (CEC) and ARC on
Yea, I finally gave up on ARC and installed optical cable. Now receive DD and DD+. Have CEC off on both ends and auto for 2112 with bitstream on p65...
friendlysmith is offline
post #15981 of 64096 Old 06-09-2016, 10:23 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
You are getting DD+ over optical to your AVR? Do you have ATMOS? If so and it works, you might be the first guy on planet earth to play ATMOS over optical via DD+.
shoman94 and a61688 like this.
post #15982 of 64096 Old 06-09-2016, 10:24 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Sent from nowhere
Somebody told me to read Page 1....
htwaits, Ph8te, shoman94 and 8 others like this.
post #15983 of 64096 Old 06-09-2016, 10:33 AM
Quoted: 40 Post(s)
So i finally got my P55 setup, ive watched a few netflix series 4k youtube vids cable tv and i gotta say....im not very impressed. I guess i was expecting more coming from a 300 dollar 1080p vizio from last year, but i dont think its as big of an upgrade as id hoped. First off the viewing angles are not impressive at all, colors shift almost instantly but get slightly better the farther you go which is odd. 4k youtube vids looks good i guess, but they also did on my last tv at 1080. Cable looks ATROCIOUS with my charter spectrum box, with a 1080i signal (highest my box can output) there is so much artifacting, good thing i dont watch much cable but it looks way better on my 40" e series from last year. Last the sound.....holy hell i didnt think it was possible but it honestly sounds worse than my 40". Obviously i was going to upgrade audio either way so not a huge deal, but how can speakers inside a 55" tv sound worse than a 40? If you dont turn on "volume leveling" the dialogue gets completely drowned out by whatever music/background noises are going on. I have two seating positions in my bedroom, im at my PC right now and the colors are so muted watching one of the most vibrant netflix series (kimmy schmidt) its quite disappointing.
Needless to say its going back, guess ill try a samsung out. On plus side i am having no issues with casting at all, which i knew i wouldnt cause i was very used to using a chromecast. Getting full 4k youtube etc. Guess ill have to get used to other brands smart interface until google releases a 4k chromecast. Real shame i was hoping to like this tv and i snagged it for 1099.00. Admittedly i havent watched any HDR on the set, but given how little of it is out there and how much normal netflix viewing i do HDR wont save this set for me.
I have a p65 but I have noticed every once in awhile if I change brightness or other options back and forth on tablet, the picture looks TERRIBLE. So, I just reset the input(calibrated) this morning and WHAM!! The tv went from looking like garbage to a thing of beauty. I hope this isn't something that will be an ongoing issue moving forward.. BTW on a different subject even after resetting tablet, the options button(picture,ect.) is blanked out. I downloaded vizio app on my phone and it works perfectly. This tv is used in my basement for myself and teenagers. If my wife spent anytime down there, I would have returned this set weeks ago...
post #15984 of 64096 Old 06-09-2016, 10:45 AM
scarylarry's Avatar
Quoted: 51 Post(s)
Liked: 47
@scarylarry what happenened bud? What did you get?
Sorry not to update sooner--I've been slammed at work. I ended up sticking with the P50. I'm not thrilled with the viewing angle, but I've been pretty happy with everything else, firmware quirks aside.
I think I would have exchanged it if the Best Buy sale were still going on. I got the P50 during the Memorial Day sale, and the difference between the sale price on the P50 and the non-sale price on the P55 is too steep. I kept checking with the hope that there would be a flash sale on the P55 yesterday, but it stayed firm. In the end, I could not justify what amounts to a $500 price difference, PLUS shipping/cab charges for the P50 return.
I don't love the fact that the colors start washing out whenever I'm not literally sitting in front of the very center of the screen, but I will learn to live with it! It's a great display otherwise.
scarylarry is offline
post #15985 of 64096 Old 06-09-2016, 10:52 AM
Liked: 2117
DD+ cannot pass over optical. The person you quoted is mistaken
post #15986 of 64096 Old 06-09-2016, 10:53 AM
Liked: 2117
I actually use the app on my iPhone over the tablet b.c it works that much better. I do not think I have touched the tablet in close to a month.
post #15987 of 64096 Old 06-09-2016, 10:54 AM
Quoted: 189 Post(s)
Liked: 205
Has it been confirmed that HDR10 is definitely rolling in two waves (not to start up another rumor mill...), or just that they are strongly considering that plan?
post #15988 of 64096 Old 06-09-2016, 10:55 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
It was a bit of a challenge. I will say there are some that have said it could, but I've yet to see it.
shoman94 likes this.
post #15989 of 64096 Old 06-09-2016, 10:57 AM
Coyote Waits
htwaits's Avatar
Quoted: 1332 Post(s)
Liked: 2364
Originally Posted by Vader182 View Post
To be honest my personal read of the situation is that by the time Vizio would ship it to you you'll likely be able to get it from Best Buy.
-Vader
At the moment that seems to depend on where you live. Regardless, Vizio is an option.
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #15990 of 64096 Old 06-09-2016, 11:02 AM
Quoted: 382 Post(s)
Liked: 139
Tablet is still in the case actually, still sealed. TV does not look terrible on most content just the cable box, and sorry i am using calibrated preset calibrated dark is too dim for my liking. I am simply just not wow'ed by the set as i hoped, the colors dont pop out at me and i think that has to do with vizios matte coating tbh, thats why i said i wanna try different brands. Glass makes more of a difference imho than panel quality when talking in same price bracket. I bought 55 because of the IPS, blacks are still amazing but the colors really look odd at an angle....almost subdued.
ataneruo likes this.
Fascinate is offline
Reply LCD Flat Panel Displays
2016/2017 vizio p-series - nice pic(k)! / netflix , best value , D7000 , dolby vision , latest firmware - 6.0.18.1 - previous 5.0.16.1 , Vizio , Vudu
