Official Samsung KS8000/KS8500 Owners Thread - Page 601 - AVS Forum | Home Theater Discussions And Reviews
 180065Likes
post #18001 of 36870 Old 12-24-2016, 12:44 PM
mrtickleuk's Avatar
Quoted: 5360 Post(s)
Liked: 7745
Originally Posted by Riptide_NVN View Post
Question regarding 10bit content. If you play 10bit content while the screen is in 4:4:4 8bit 60hz then what is the result? I am assuming it looks off?
The TV changes mode as soon as you press "play" on the 10bit clip, out of 4:4:4 8bit 60hz into something else. We can't see precisely which mode it's in because the TV's info screen doesn't tell you. The TV's info screen only gives you resolution and frame rate.
Samsung thinks that we don't want to know the bit-depth OR the chroma information of the incoming signal, but they are wrong, wrong, wrong. We want to know both of those two secret pieces of technical information.
But by a process of elimination, it's probably 4K60 10bit 4:2:0.
The 10bit 60Hz modes that the TV supports are in the first link in my sig. Click it to see why I said 4:2:0.
If that is correct then if you take the file and play it off a thumbdrive directly from the TV itself.
Well remember you can't get 4:4:4 8bit 60Hz outside of "PC mode", and "PC mode" means a HDMI input ONLY. It never gives you 4:4:4 from the USB drive playback.
Originally Posted by justpassedu View Post
I don't have any solid settings to post I have tried every setting reccomended here as well as ratings settings which produced a dark picture and when I played with those a bit to brighten it up everything looked washed out.
Just post what you have now, anything. It's just a starting point. We can't help otherwise.
joe75xp and King Richard like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #18002 of 36870 Old 12-24-2016, 12:51 PM
The_Donster's Avatar
Quoted: 597 Post(s)
Liked: 884
Originally Posted by berniez View Post
Do you have the Xbox One S configured for 4k and 10 bit. The default in the Xbox setup is for 8 bit. But the tv requires 10 bit. It is in the Xbox set up screen. Just checking. If it is set to 8 bit and 4K, the screen will go black with the HDMI UHD set ON. I did not use the hdmi cable shipped with the Xbox. I am using a different one latest greatest.
So are there any fellow Xbox One, not Xb1S owners here? I'm curious if it will support 10 bit too? It shows it as an option in the video settings but is defaulted to 8 bit.
Originally Posted by mrtickleuk View Post
Make sure you have "fit to screen: ON" in all modes. From what you're saying, you haven't yet turned it on in the other modes. So you are choosing to zoom and crop the screen in your other modes. It sounds like Movie is the only mode you have set correct so far. Now it's up to you to fix the others to match it.
(It's nothing special about the Movie picture settings out of the box),
Nope. It's probably just xmas eve, no-one is at work, everyone's watching Youtube.
Unfortunately you can't set it to On in the streaming apps or at least the last time I checked. Kind of bums me out that I'm at the mercy of the apps settings. Although none have disappointed me too much.
Well at least post what you have at the moment. That way folks can help you better.
Official Samsung KS8000/8500 Owners Information PDF
Living Room: LG 55LE5500 Sony BDP‑BX510 XBox 360 w/Kinect
Bedroom: VIZIO E470VL VIZIO VSB200 Sound Bar Sony BDP‑BX510 XBox 360
Inner Sanctum: Samsung 65KS8000, Halo XBox One, GoW Xbox 360, Onkyo HT-S5300
The_Donster is offline
post #18003 of 36870 Old 12-24-2016, 12:58 PM
hdtv00's Avatar
Quoted: 277 Post(s)
Liked: 154
Having problem lately where the damn Netflix app when you go back into and it asks to pick profile it freezes up any controls after that, have to pull cord on tv and reset it.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/470's/2200 Sub
hdtv00 is offline
post #18004 of 36870 Old 12-24-2016, 01:00 PM
mrtickleuk's Avatar
Liked: 7745
Ah yes. I didn't like that either. I played a test clip which was a testcard in the USB player, and that didn't crop anything. So in the USB media playback at least, it's not overscanning.
All we'd need is a 4K testcard video to do the same check in the YouTube app. The BBC is good for this sort of thing
Try this - complete with muzak!
_______________
post #18005 of 36870 Old 12-24-2016, 01:08 PM
Tario70's Avatar
Question Pixels stuck White...
I attached a picture but it isn't good. Couldn't get it to focus. Just setup a return exchange for a string of stuck pixels along the top of my screen. Some are white, one is green, another is orange. All are on the same line. About 6-8 pixels.
Anyone have this happen?
Otherwise I've loved the TV. Thank goodness I'm in the return exchange window & got the 5 year warranty.
Tario70 is offline
post #18006 of 36870 Old 12-24-2016, 01:09 PM
justpassedu's Avatar
Quoted: 63 Post(s)
For set All default settings , movie mode and color tone set to cool as all these others provided to dark of a image. Same with hdr , movie mode , cool , back light at max , led on high , messed with dynamic contrast a bit and prefer low , med, or high for the brighter image. Also tried both judder and blur to zero not touching led with custom and tried it in auto and off .
justpassedu is offline
post #18007 of 36870 Old 12-24-2016, 01:15 PM
Eric V's Avatar
Originally Posted by EddyKnights View Post
You tube app is running slow today does this happen here n there i have great connection speeds but it's stating other wise n it's lowering my resolution to 2k speeds.. Does you tube app run slow sometimes on certain days on this set
At Least Youtube comes on for you. Mine just shows a blank screen and doesn't load up. I'm on 1154. No new updates being pushed to the tv.
Eric V is offline
post #18008 of 36870 Old 12-24-2016, 01:24 PM
Quoted: 33 Post(s)
I must be the only stupid person on this thread. I've searched for a list of voice commands, searched the web, and read the e-manual and downloaded and read the manual. No such luck. I don't even find a suggestion as to what voice commands are. I've experimented and found a few commands, such as Settings, Netflix, etc. I would appreciate a quick primer from one who is much brighter than me.
oldbob38 is offline
post #18009 of 36870 Old 12-24-2016, 01:31 PM
SunPowered's Avatar
Quoted: 25 Post(s)
Liked: 40
Originally Posted by dante`afk View Post
Prevoiusly: http://imgur.com/a/YbV0w
This has been fixed now with a complete new panel, however they did a terrible fitting job: http://imgur.com/a/ysdVq
You're scaring me! Mine is supposed to be replaced next week. Thinking maybe I should live with the three small spots (which I can't see from my viewing position).
SunPowered is offline
post #18010 of 36870 Old 12-24-2016, 02:43 PM
ketamine's Avatar
Quoted: 55 Post(s)
Liked: 64
Originally Posted by oxbrown View Post
Thankfully, the second panel doesn't have any light bleed. The uniformity looks good and the picture was pretty easy to get dialed in.
You have a 60" set that has no light bleed??
Terminader and jeremie like this.
ketamine is offline
post #18011 of 36870 Old 12-24-2016, 03:01 PM
Riptide_NVN's Avatar
Quoted: 79 Post(s)
Liked: 40
Understood. However playing a H.265 encoded 10bit media file from a PC software player such as MPC-HD is possible. The TV won't switch out of 8 bit mode when you attempt playback under such a condition. Hence my query about what that scenario creates as far as output quality goes. Does the file display with muted color or some other deficiency?
I have yet to try a 10bit H.265 encoded file from a thumbdrive or over Windows 10 via MPC.
Riptide_NVN is offline
post #18012 of 36870 Old 12-24-2016, 03:15 PM
mrtickleuk's Avatar
Liked: 7745
But how do you know that's how the TV behaves? You're saying that the MPC-HD player is faulty I think? It should know it's trying to play a 10bit file in an 8bit video mode, and it should know not to do that.
If the PC is controlling the display, then the PC dictates which screen mode to switch the TV into. The PC can't say "give me a 4K60 10-bit 4:4:4 mode", because no such mode is available via HDMI2.0a.
It's down to the PC end what it does.
That would be down to whatever the PC is sending. It can't be sending 4K60 10-bit 4:4:4, as above. If it trashes the colours and chooses to send 10bit video in an 8-bit mode, it's the PC that's doing that, not the TV.
_______________
post #18013 of 36870 Old 12-24-2016, 03:18 PM
bargervais's Avatar
Quoted: 1755 Post(s)
Liked: 1090
your not alone that should comfort you. Merry Christmas
Living Room Sam. UN65KS8000 / 2017 Roku Ultra / Onkyo TX-RZ920 7.2.4 / M-5010 Amp. /Sam. UBD-M8500 Blu-Ray Player.
DEN TCL 65R617 65-Inch 4K Ultra / Onkyo TX-RZ730 5.2.4 / Philips 4K UHD Dolby Vision Player (P7502) BEDROOM Sam. 55JS8500 / 2016 Roku Ultra / LG UP870 3D Ultra High Definition Blu-Ray 4K Player
bargervais is offline
post #18014 of 36870 Old 12-24-2016, 03:21 PM
kevinf1990's Avatar
Quoted: 28 Post(s)
I believe your tv must be connected to the internet for that to work. Something similar happened to me when I tried the voice command. It didn't recognize any command and then realized that it wasn't connected to internet. Once connected, voice commands worked again.
kevinf1990 is offline
post #18015 of 36870 Old 12-24-2016, 03:38 PM
camd5pt0's Avatar
Quoted: 311 Post(s)
Liked: 204
Originally Posted by WarpSpeed2013 View Post
What are you using to watch movies? DVD, Blu-ray, streaming services? I've also noticed a few movies do not pass 5.1 through properly. I also had audio sync issues and ended up just routing my PS4 audio directly to the receiver.
Blu-ray movies with ps4. Even though the movies show the sound profiles, they can't passthrough, that's a bummer. Crazy that all games passthrough flawless at least.
Sent from my SM-N930P using Tapatalk
Home theatre: 65" Sony X950G / LG UBKM9 / Sony UBD-X800 / Xbox One X Project Scorpio / PS4 Pro
Denon AVR-X4400H 7.1.4 config. / Plantronics Dolby Atmos RIG 600LX
Pioneer Andrew Jones L,R,C,SL,SR,SBL,SBR / (4) Polk Atrium 5 series TF,TR
SVS PB-2000 w/ SVS SoundPath Subwoofer Isolation System
camd5pt0 is offline
post #18016 of 36870 Old 12-24-2016, 03:39 PM
Quoted: 79 Post(s)
Liked: 40
Perhaps that is the question then. Does it have the logic necessary to differentiate between an 8 and 10 bit file. And to switch the TV into an alternate setting to output the file as intended.
mrtickleuk likes this.
post #18017 of 36870 Old 12-24-2016, 03:56 PM
emmons's Avatar
Quoted: 267 Post(s)
Liked: 184
try warm 1. I think its the best. dynamic contrast i set to low. but all panels are differnt. if you think movie is too dark try natural. its brighter and lots of places like it in a light room. also see auto being used more in settings for color.
Terminader likes this.
emmons is offline
post #18018 of 36870 Old 12-24-2016, 04:36 PM
EddyKnights's Avatar
Quoted: 176 Post(s)
Liked: 63
Mine has light bleed galore lol n uniformity issues
EddyKnights is offline
post #18019 of 36870 Old 12-24-2016, 04:38 PM
Quoted: 176 Post(s)
Liked: 63
I think native color for hdr+ setting fits the bill and for hdr auto.. Any one try to compare standard with movie any difference
post #18020 of 36870 Old 12-24-2016, 04:40 PM
Quoted: 79 Post(s)
Liked: 40
Noticed mine has a bit of bleed in the upper left and right corners. Some small amount of clouding overall. Nothing that makes me inclined to ditch it. The vast majority of the time these flaws aren't going to be real visible.
post #18021 of 36870 Old 12-24-2016, 05:58 PM
mechx's Avatar
Quoted: 41 Post(s)
Liked: 42
^^this...driving me crazy as well, can't believe more people aren't having the same issue...
mechx is offline
post #18022 of 36870 Old 12-24-2016, 06:00 PM
blenky's Avatar
Quoted: 993 Post(s)
Liked: 914
Just wanted to wish all users of this forum a very Merry Christmas!.
600 pages and 18,000 posts and still going strong
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #18023 of 36870 Old 12-24-2016, 06:25 PM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
Anyone with an Xbox One S had any luck splitting the signal to separate HDMI inputs on the 8000? (Sick of swapping between game/movie settings with it on one input).
I've tried one splitter with marginal results so I'm hoping someone else with an 8000 has had better results and can share them before I end up buying 5 or 6 different splitters.
~Bill
BillKen is offline
post #18024 of 36870 Old 12-24-2016, 07:27 PM
LReyes66's Avatar
Quoted: 57 Post(s)
Went to best buy. Ks8000 back to bf prices.
Sent from my Nexus 6P
LReyes66 is offline
post #18025 of 36870 Old 12-24-2016, 08:20 PM
oxbrown's Avatar
The photo on the left is the first TV, picture on the right is the second. I tried to get the exposures close, ignore the Christmas lights reflecting in the second shot, there is almost no light bleed along the bottom edge.
ID:	1852217   Click image for larger version
Name:	2016-12-24 22.12.29.jpg
ketamine and tjsilva like this.
oxbrown is offline
post #18026 of 36870 Old 12-24-2016, 08:30 PM
Quoted: 63 Post(s)
Ty I'll give anything a shot at this point , will natural also work if feeding it hdr or is that only possible in movie mode. Kinda bummed after coming back from a holiday party while seeing the football game look beautiful on a 6 yr old Lcd they had on. I just hope I can't get this set looking nice , I'm not picky and I really don't want to go through the hassle of returning it.
post #18027 of 36870 Old 12-24-2016, 10:20 PM
Quoted: 44 Post(s)
Liked: 39
Ok here is mine. Movie mode Backlight is 8 brightness is 45 contrast is 95 gamma at 1 sharpness is 5 AMP is off smart LED low dynamic contrast off- this can kill blacks if on, color tone warm 1 sometimes standard and auto instead of native as it keeps colors realistic
JohnnyD83 is offline
post #18028 of 36870 Old 12-24-2016, 10:59 PM
Quoted: 58 Post(s)
Liked: 8
Ok I got my Xbox One S to work thanks to some advice on here, now I am looking for some ideas to get the PS4 Pro to work.
As soon as I switch it to UHD on the screen goes black, I checked the PS4 Pro settings and it says UHD is not supported. So I tried bypassing my receiver, which is a Denon AVR X1200 which does support 4k, and then the PS4 recognized my TV as UHD and I could turn UHD on. I however would like to use my receiver for my surround setup and since the Xbox one S goes through it and is recognized the PS4 should as well. I did check and the PS4 pro is setup for 10bit and not 8 bit so that is not the problem this time. I checked the faq and did a search but I did not find anything on here. Some other sites talked about changing HDMI cords but since mine worked if I hooked it up through the one connect bypassing my receiver that is not the issue.
Thank you in advance for any support I can get.
Mishtar is offline
post #18029 of 36870 Old 12-25-2016, 03:10 AM
tylerSC's Avatar
Quoted: 1390 Post(s)
Liked: 263
Looks like they have eliminated the black level adjustments in the Picture Settings menu for the K Series. In previous series, there was a subcategory where you could select Black, Blacker, and Blackest. Is there another way to adjust the black levels on the KS8000?
tylerSC is online now
post #18030 of 36870 Old 12-25-2016, 03:12 AM
tylerSC's Avatar
Liked: 263
And as much as I may like the KS8000, I do not understand why they eliminated the Information category of apps in the Smart Hub. I miss the live streaming news apps and other channels. The overall selection of apps is too limited and I am going to add a Roku box.
Reply LCD Flat Panel Displays
denon s740h , extra , hdmi input , KS8000/KS8500 , no picture , one connect fail , xbox one s
