Official Samsung KS8000/KS8500 Owners Thread - Page 670 - AVS Forum | Home Theater Discussions And Reviews
 180162Likes
post #20071 of 36964 Old 01-14-2017, 07:35 AM
blenky's Avatar
Quoted: 1006 Post(s)
Liked: 931
Originally Posted by caviefreak View Post
That's a simple one. Not every component is created equal. There are brand new computers that through Ethernet they can only get 30 megs. Samsung decided that the TV does not need any faster then 10megs.
Huh? I get about 65 megs on mine.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #20072 of 36964 Old 01-14-2017, 07:41 AM
almost too old's Avatar
Quoted: 84 Post(s)
Liked: 122
Originally Posted by Elisha View Post
- have you noticed the the volume levels have changed since the past few fw updates?
- I swear that when I first got the KS8000, I could leave it at 10-12 and 15 if it was noisy in the living room and it was enough volume.
- Now it seems like I have to use at least 20 and even up to 35 sometimes higher if the kids are being noisy!
Not so much on regular TV but definitely watching BD / UHD movies. Also get serious volume changes in scenes that require adjusting the volume drastically + / -
Can be even more pronounced when running audio through my AVR. Always did have to use higher volume using the AVR but recently even higher settings. This wasn't as severe when I got the TV last June but then again I have played with audio settings on all in the last week w/o testing after each change which made things worse volume wise (I should know better being a technician, lol).
UN60HU8550FXZC / UHD w/ SEK-3500U, Arris VIP5662W Whole Home PVR, ONKYO TX-SR353, 4K Apple TV and UBD-K8500 /ZC
UN65KS8000FXZC /SUHD w/Arris VIP5662W Whole Home PVR, Denon AVR-S720W 5.1.2 and UBD-K8500 /ZC
almost too old is offline
post #20073 of 36964 Old 01-14-2017, 07:53 AM
Elisha's Avatar
Quoted: 632 Post(s)
Liked: 609
On Blu-Ray that is normal because there is a higher Dynamic Range for volume. You can Normalize it in your AVR or the Blu-Ray player if the option exists.
The KS has that option too. I leave it at Auto. Turning it Off gives you the full Dynamic Range and you pretty much need to watch with high volume. Night mode is supposed to Normalize it more so the Higs and Lows don't vary much but on the TV is sounds crappy.
I think they have been tweaking Auto in the firmware updates and that's why it's not the same as it used to.
Kind of like HDR+. Now I find no difference turning on HDR+ with the exact same settings as my Movie mode.
almost too old likes this.
Elisha is offline
post #20074 of 36964 Old 01-14-2017, 08:05 AM
Quoted: 44 Post(s)
Liked: 31
Originally Posted by druidflame View Post
I purchased a 65KS8000 directly from Samsung over Christmas during their special pricing. My TV has a permanent distortion along the bottom edge of the screen. Originally they agreed to have a tech replace the screen in home but Samsung then decided I would need to ship it back. I was wondering if anyone could tell me what would cause a defect like this, the rippled distortion right above the Samsung logo.
I'm curious to know if it left Samsung this way or if perhaps it was damaged during shipping, the box was in perfect shape, looked like it was right off the stores shelf.
does it get any better when you turn off the horrible glowing logo?
BennoDXB is offline
post #20075 of 36964 Old 01-14-2017, 08:25 AM
joe75xp's Avatar
Quoted: 225 Post(s)
Liked: 340
Ive noticed the same thing with HDR+. I don't use HDR+ often enough to know for sure but Im thinking this happened just recently with the first 115* builds. I keep my Color at 52 and personally don't like Native color space for anything. With Auto color on HDR+ I have almost identical screens to a 53/54 color setting on regular Movie or CAL settings.
Terminader likes this.
___________________
:49KS8000 :TX-NR757
joe75xp is offline
post #20076 of 36964 Old 01-14-2017, 08:49 AM
Elisha's Avatar
Quoted: 632 Post(s)
Liked: 609
Movie and HDR+ is identical for me with 2 Point WB and Custom colour space. The only exception is that with HDR+, DC is Off and with Movie it is on Low.
Elisha is offline
post #20077 of 36964 Old 01-14-2017, 09:04 AM
Quoted: 39 Post(s)
uhd movie and the hdr sample. you get the same hdr effect on movies like the sample? or is it a totally different thing?
DaiKami is offline
post #20078 of 36964 Old 01-14-2017, 09:04 AM
joe75xp's Avatar
Quoted: 225 Post(s)
Liked: 340
I have DC off and find thats the only way to combat elevated whites and highlights regardless of the backlight and brightness settings. The differences in DC is the main reason I can't use HDR+ because even with it off its still a little too powering.
___________________
:49KS8000 :TX-NR757
joe75xp is offline
post #20079 of 36964 Old 01-14-2017, 09:07 AM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
Originally Posted by BennoDXB View Post
Not true at all. The TV has a 10/100 network interface, 100Mbps capable if your internet connection was that fast. Also theres no such thing as a 30Mbps network interface.
I assume you are using the crappy ookla beta speed test? It doesnt work properly.
use fast.com Its pretty good, will give you an accurate result.
I get ~44Mbps from my 50Mbps connection.
I think you will get about the same, which is why you 4K stuff works fine. 10 wouldnt cut it.
Bingo! Fast.com works MUCH better than ookla. Tried that and it is reporting 47Mbps on the TV. Thank you for the suggestion! I was all ready to go get a new switch and start reconfiguring my network.
King Richard and mrtickleuk like this.
~Bill
BillKen is offline
post #20080 of 36964 Old 01-14-2017, 09:28 AM
Liked: 2
USB port
Sorry for the silly question. I just got one of those backlight kits. I love it so far. It's slightly messing with my clean wall mount setup though, since I see the white cable reaching down to the connection box. Is there, by chance, a USB port on the back of the unit? I couldn't find any info in the manual, and couldn't feel one reaching around the back of the unit. Cheers
OmsieG is offline
post #20081 of 36964 Old 01-14-2017, 09:32 AM
Liked: 0
Refered from reddit to come here. Please check out the video and give my some advice. https://youtu.be/kq7mKXorZt0
TheCrow13 is offline
post #20082 of 36964 Old 01-14-2017, 09:34 AM
The_Donster's Avatar
Quoted: 597 Post(s)
Liked: 884
Yes, it is in the same location as where the One Connect Box Cord plugs into in the back of the KS.
Official Samsung KS8000/8500 Owners Information PDF
Living Room: LG 55LE5500 Sony BDP‑BX510 XBox 360 w/Kinect
Bedroom: VIZIO E470VL VIZIO VSB200 Sound Bar Sony BDP‑BX510 XBox 360
Inner Sanctum: Samsung 65KS8000, Halo XBox One, GoW Xbox 360, Onkyo HT-S5300
The_Donster is offline
post #20083 of 36964 Old 01-14-2017, 09:45 AM
VivaItalia's Avatar
Hi All, I have a 65in KS8000 and a Samsung HW-J550 soundbar. I cannot get the TV to pair with the soundbar using bluetooth. Does the KS8000 support soundconnect?
I used to have this soundbar paired to my UN60F7500 and that always worked without issue.
VivaItalia is offline
post #20084 of 36964 Old 01-14-2017, 09:46 AM
Liked: 2
Got it, thanks much!
The_Donster and mrtickleuk like this.
OmsieG is offline
post #20085 of 36964 Old 01-14-2017, 10:14 AM
VivaItalia's Avatar
I figured this out.
For anyone who was having the same issue as me, the steps are as followed:
Turn on your KS8000.
Turn on your soundbar.
On your soundbar or the remote, select the source button until you reach TV.
While in TV mode, press and hold the play/pause button for 5 seconds then let go.
In a few seconds you should see a message pop up on your TV asking whether you accept to connect with your soundbar.
Select Yes.
It is now connected.
post #20086 of 36964 Old 01-14-2017, 10:35 AM
mrtickleuk's Avatar
Quoted: 5519 Post(s)
Liked: 7992
Very interesting! I know that @aron7awol did extensive testing in the past to determine that all that it used to do was expand the colour gamut. I wonder if he's noticed these changes to HDR+ in recent firmwares?
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #20087 of 36964 Old 01-14-2017, 11:27 AM
dunno's Avatar
Quoted: 45 Post(s)
Liked: 24
NFL Football Today
Hey, just received a KS8000 and so far so good. Currently used rtings for basic set up and also looking at the dedicated ks8000 calibration forum as well. I am going to be messing around with it today watching the NFL playoffs and I am wonder what other users have found worked best for them regarding motion, judder or any other sports settings. I am fully aware your settings may look like @#[email protected] on mine but that is what I want to find out. Will be using OTA antennae but will look at other set ups as well. Any help is appreciated. Thanks
dunno is offline
post #20088 of 36964 Old 01-14-2017, 11:33 AM
druidflame's Avatar
I got excited reading your suggestions, it would save all the return and refund hassle but sadly the defect is still there even with the logo turned off. Thanks anyway.
druidflame is offline
post #20089 of 36964 Old 01-14-2017, 11:33 AM
Quoted: 3147 Post(s)
Liked: 13448
They are using Color Space Auto with HDR+, which defeats the purpose of using HDR+. If someone isn't using Color Space Native with HDR+, they might as well just go back to Movie mode.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #20090 of 36964 Old 01-14-2017, 11:39 AM
Quoted: 597 Post(s)
Liked: 884
Hey, apologies for the OT post, but wondering if the Onkyo owners (@acefr, @maximuslcd ?) can give me some feedback on how my HT-S5300 is currently set up. Right now I'm just using the two front and center speakers. I also have it and my components connected through the OCB and using Bitstream and Dolby on my KS. All's good there, but I'm wondering if I need to change any of the following default settings? I don't want to sideline the thread too much. So if you feel more comfortable pm'ing me that's cool too.
Set Up Menu->Audio Adjust:
Input Ch(Mux)-> Main/Sub
Input Ch(Mono)-> Left+Right
Panorama-> Off
Dimensions-> 0
Center Width-> 3
Height Gain->Mid(Greyed Out)
Dolby EX-> Auto
Center-> Image-> 2
Audyssey-> Off
Dynamic EQ-> Off
Reference Level-> 0dB(Greyed Out)
Dynamic Volume-> Off
Listening Angel-> Wide
Set Up Menu->HDMI Setup:
Audio Out-> Auto
LipSync-> Off
HDMI Control-> On
Audio Return Ch-> Auto
Power Control-> On
TV Control-> On
post #20091 of 36964 Old 01-14-2017, 12:33 PM
Liked: 1
Hi everyone,
I recently purchased the 65KS8000 and am running into a bit of a dilemma. The conduit that was run behind my fireplace is only about 1.25" wide (long story), so it does not fit the One Connect cable into it. Unfortunately, the conduit is also too small to run every single cable up to the device (4 HDMI, Ethernet, Coax). This leaves me with a few options that I'm hoping the group can help me make the best decision about:
  1. Attempt to file down the plastic sides of the One Connect cable head to get it closer to the input's width and have it fit into the conduit. This seems like a bad idea, but might actually work if it's all plastic in the surrounding area.
  2. Purchase some sort of HDMI switch/receiver so I can simply run one HDMI cable through the conduit, then mount the One Connect box behind the TV. I imagine this means I'll miss out on some of the smart TV features and would also have to use a separate remote to switch inputs, but let me know if I'm wrong about that.
  3. Find slimmer HDMI cables that may allow me to fit all of the wiring necessary into the conduit. I'll still have to mount the One Connect box behind the TV in this scenario.
  4. Find a way to detach the head of the One Connect cable, run it, and reattach it afterwards. From what I have researched, it doesn't seem that this is possible.
Ideally I'm looking for a solution that will prevent me from having to run additional cables in the future and also be able to use a single remote (I'm still investigating IR options).
If the group has any thoughts or suggestions I'd greatly appreciate it. Thanks!
brandofaction is offline
post #20092 of 36964 Old 01-14-2017, 12:36 PM
camd5pt0's Avatar
Quoted: 313 Post(s)
Liked: 204
Most times people confuse bandwidth with throughput. But we also don't know what kind of adapter is part of the TV. It could be artificially capped via fw as well to reduce overhead and processing load!
Yes I suspect it's purposely limited. Via wifi or wired, I get 160 mbps of 160 Mbps of my bandwidth on my phones, Xbox one S, Ps4. I know I get my full internet speed. That'S why I can use the two terms, bandwidth and thoroughput, synonymously.
Sent from my LGLS990 using Tapatalk
Home theatre: 65" Sony X950G / LG UBKM9 / Sony UBD-X800 / Xbox One X Project Scorpio / PS4 Pro
Denon AVR-X4400H 7.1.4 config. / Plantronics Dolby Atmos RIG 600LX
Pioneer Andrew Jones L,R,C,SL,SR,SBL,SBR / (4) Polk Atrium 5 series TF,TR
SVS PB-2000 w/ SVS SoundPath Subwoofer Isolation System
camd5pt0 is offline
post #20093 of 36964 Old 01-14-2017, 12:43 PM
Quoted: 386 Post(s)
Liked: 277
Originally Posted by dunno View Post
NFL Football Today
I completely turn off AMP for everything I watch (make sure you set it 'off' not just turn the sliders to 0) including sports. Sports mode is off as well. NFL games look fantastic on this TV.
bargervais likes this.
TB4XSBC is offline
post #20094 of 36964 Old 01-14-2017, 01:18 PM
Quoted: 84 Post(s)
Liked: 122
Originally Posted by brandofaction View Post
Hi everyone,
I am no TV expert by any means (see my post count, lol) but am an electronics technician so I'd say that 1 and 4 are a bad idea. 2 may work for you but just about any sort of cheaper HDMI switches can introduce PQ, audio, and HDCP issues. High end ones can handle that but then there is your TV settings to consider for your individual input devices. Someone else may be better able to answer that though. IMO 3 is your best bet just make sure the cables meet the latest specs. I really can't offer any advise concerning slim cables as I haven't used them (but they would clean up my cable management) and I also use individual remotes (old school or too lazy to figure it out) so no help there I'm afraid. I am sure you will get some good ideas from the more senior members here.
King Richard likes this.
post #20095 of 36964 Old 01-14-2017, 01:26 PM
lmartinijr1's Avatar
Quoted: 299 Post(s)
Liked: 254
NFL Football Today
Set all processing to OFF. I have time warner cable and football is great. No motion blur either. Watch when football is in air....should be a natural spinning football with no blur,lag or tail. Both my Samsungs look great with all the motion stufF OFF. Same thing with hockey.....any processing on makes the puck blur and tail......with it off the moving puck is natural and clear. Hope this helps. Enjoy the games.
bargervais and King Richard like this.
lmartinijr1 is online now
post #20096 of 36964 Old 01-14-2017, 01:28 PM
Quoted: 299 Post(s)
Liked: 254
Agree!
post #20097 of 36964 Old 01-14-2017, 01:36 PM
Quoted: 299 Post(s)
Liked: 254
Did you try and lightly massage the area? Sometimes this works. Give it a shot before u return it.
post #20098 of 36964 Old 01-14-2017, 01:43 PM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Hi guys.... How does the KS7000/KS8000 work with soundbars connected by optical only? I've read a few horror stories online and debating whether to get one or not. I'm looking at a Dali Kubik One.
So since the TV has no headphone or RCA out I'm going to have to rely on optical (the Kubik One has no HDMI).
Can the Smart Remote be configured the control the volume on an external, non Samsung, soundbar for the HDMI inputs and inbuilt apps (Netflix, Plex etc)? Another option might be Bluetooth but audio might be better with optical. So can the Smart Control blast IR codes or does the TV have an IR blaster somewhere?
__________________________________________
DIY Sound Group 893 & Volt 8's Build Thread
sjackson is offline
post #20099 of 36964 Old 01-14-2017, 02:04 PM
Quoted: 597 Post(s)
Liked: 884
Here's what I found using the search function that is located at the upper right hand corner of each thread using the key words soundbar optical. 6 pages might be easier to read than 670. Hope this gets you some answers
Name:	AVS Search.JPG
post #20100 of 36964 Old 01-14-2017, 02:59 PM
jconjason's Avatar
Quoted: 1378 Post(s)
Liked: 2301
I recall someone else having the same issue in the same area. If I remember correctly, it was due to some type of impact to the TV. Best to just exchange it.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
Reply LCD Flat Panel Displays
denon s740h , extra , hdmi input , KS8000/KS8500 , no picture , one connect fail , xbox one s
