Official Samsung KS9000 4K UHD Owners Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 455Likes
post #1621 of 1845 Old 06-14-2017, 04:35 AM
dunkle's Avatar
Quoted: 18 Post(s)
Can anyone please help, I still can not get arc to work
I'm using a uk hu8500 with sek3500 connecting to a yamaha ysp2500
Now I have had arc working ages back but now, try as I might I can't seem to find the magic and elusive combination of settings between the TV and the sound bar that will allow sound to go to sound bar
It no longer shows under the sound options and trying all combos if options I can think of nothing works.
dunkle is offline
post #1622 of 1845 Old 06-14-2017, 06:15 AM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 832
Wrong forum. You will want to post over here https://www.avsforum.com/forum/166-lc...l#post53626601 and maybe in your soundbar thread to get help with your specific to your equipment.
Basically you want to make sure your HDMI is connected to the ARC port on SEK, turn on Anynet +(HDMI-CEC) in Samsung Menu, turn on HDMI-CEC in soundbar (not sure where that is in your particular bar), turn everything off, then turn TV on and then soundbar. Once everything is on you may have to go into samsung menu and choose the soundbar from speaker list.
dunkle and King Richard like this.
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #1623 of 1845 Old 06-14-2017, 09:00 AM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 365
Originally Posted by adampj4 View Post
Had the 65ks9000 for a couple of days and noticed the light bleed across the bottom of the screen. Have changed picture settings using Avforums "best picture" settings and have since tweaked, but light bleed is always there regardless.
Can anyone advise if they have similar, is this a bad example or acceptable?
Try turning the Samsung light logo Off at the bottom of the tv to start with.
Go to Settings>System>ExpertSettings> Light effect> OFF
Nothing's Impossible if you don't have to do it yourself ! Glenee
Glenee is offline
post #1624 of 1845 Old 06-14-2017, 02:12 PM
Liked: 0
Just tried it tonight and absolutely no difference! Are they all like this?
adampj4 is offline
post #1625 of 1845 Old 06-14-2017, 05:06 PM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 365
Is it on all sources and videos in the dark frames ? Look and see if you are starting to have panel seperation at the bottom.
Let's try some things before we decide there is a problem.
Glenee is offline
post #1626 of 1845 Old 06-17-2017, 09:27 AM
FQs19's Avatar
Quoted: 71 Post(s)
Liked: 43
Has anyone been able to update their KS9000 to this new firmware 1180.5 from the tv's menu?
http://www.samsung.com/us/support/ow...-tv-ks9-series
I've tried multiple times to have the tv search for a new update but it keeps saying that 1169 is the most current.
I don't mind updating the tv from a usb stick but rather not if there's a reason why the tv isn't finding it.
Projector - Sony VPL-VW665ES TV - LG OLED55C7P
UHD Player - Oppo UDP-203 Streamer - Nvidia Shield Pro TV (2017)
AVR - Yamaha RX-A3070 HDMI Cables - Audio Quest Cinnamon 2, 8, and 10 meters
FQs19 is offline
post #1627 of 1845 Old 06-17-2017, 09:30 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
I think they delay and stagger over the air updates.
This is a pretty big number jump, any ideas what it fixes?
-Kevin
FQs19 likes this.
kbmb is offline
post #1628 of 1845 Old 06-17-2017, 09:55 AM
FQs19's Avatar
Quoted: 71 Post(s)
Liked: 43
-Kevin
The usual bs...
FQs19 is offline
post #1629 of 1845 Old 06-17-2017, 10:45 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
The usual bs...
Yeah typical......I did manually update without issues.
-Kevin
FQs19 likes this.
kbmb is offline
post #1630 of 1845 Old 06-20-2017, 03:12 PM
georaldc's Avatar
Anyone else think that the Clear LED Motion setting is useless with these TVs? You just get a dimmer picture and a ton of double images on moving content. Not exactly the type of BFI I was expecting, despite some reviews I've read claiming that it should improve image movement blur clarity. Is it true that the ks8000 does this significantly better?
That's probably because of the edge-lit nature of the TV. I have the same problem, my other TV has the same problem, heck even my phone has the same problem. I would love to be corrected but I don't think there's anything you can do about it unfortunately, other than getting a replacement that might have less bleed or a different TV altogether (oled or one of those full array sets).
georaldc is offline
post #1631 of 1845 Old 06-21-2017, 07:25 AM
jhachey's Avatar
Quoted: 58 Post(s)
Liked: 24
I love this TV, but I'm growing tired of setting up the remote to control the cable box nearly every day. Hopefully that gets fixed in one of these software updates soon.
jhachey is offline
post #1632 of 1845 Old 06-21-2017, 08:12 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
So after manually updating to 1180.5 I've noticed a couple things with HDR:
- I don't get the HDR banner anymore for any service. I used to get it on Amazon and FandangoNow on Roku - HDR is still being activated (confirmed by looking at the settings)
- I'm not getting the HDR badge at all in Netflix anymore - with either the Roku or the built in app. HDR still works but the Netflix screen only shows Ultra HD 4K not HDR
-Kevin
kbmb is offline
post #1633 of 1845 Old 06-21-2017, 08:58 AM
Quoted: 110 Post(s)
Liked: 59
-Kevin
Looks like this is happening across the board with all of the KS series running 1180.
Some people have reported slightly better picture quality, but I haven't noticed any changes on my KS9800.
Q8FN
KS9800
F8000
Arctura is offline
post #1634 of 1845 Old 06-21-2017, 09:52 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
Thanks for the info. I haven't noticed any quality changes on my KS9000.
-Kevin
Terminader and Arctura like this.
kbmb is offline
post #1635 of 1845 Old 06-22-2017, 08:00 AM
Infiniti-F1's Avatar
Quoted: 221 Post(s)
Liked: 101
Yeah sometimes it takes awhile for the update to get sent out so the latest one just came out on the 12th of this month so it might take sometime to get the update.
FQs19 likes this.
Infiniti-F1 is offline
post #1636 of 1845 Old 06-22-2017, 08:07 AM
Quoted: 221 Post(s)
Liked: 101
This is Not a TV Issue its most likely a issue with your Cable Provider box Again folks have to Always Remember folks PQ will always vary as well. Due to some people have the latest hardware from their TV Provider and some people will have better hardware or more up to date that works better with the TV. So First who is your TV Provider Second you need to make sure you have their latest hardware if you want to make sure to get the best results. Again this will always vary because some providers have better hardware than others..
post #1637 of 1845 Old 06-22-2017, 08:11 AM
Quoted: 221 Post(s)
Liked: 101
Everyone picture quality Will Always Vary due to some people have better hardware than other it comes down to who they are using as a TV Provider. Some have better hardware than others so not every DVR or 4K Player so forth will vary but especially when it comes to TV Service not everyone is on the latest hardware from their TV Service Provider.
post #1638 of 1845 Old 06-22-2017, 08:19 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
He's referencing people who are calibrating their displays and noticing picture quality differences between firmware revisions I believe. If you have a reference calibration tool, you can measure what each firmware does.
-Kevin
Arctura likes this.
kbmb is offline
post #1639 of 1845 Old 06-22-2017, 09:06 AM
Quoted: 221 Post(s)
Liked: 101
-Kevin
Yeah I have not really messed with calibrating anything so far I have been happy with the PQ my Hopper 3 works well with the TV and my Samsung 4K player and PS4 Pro all look good so far.
post #1640 of 1845 Old 06-22-2017, 12:49 PM
Quoted: 154 Post(s)
Liked: 43
Originally Posted by Billy Williams View Post
I had the same issues with the horizontal lines moving up and down on my first purchase of this model 75KS9000
they came out to replace it because it was out of control on Marco Polo on netflix (that was the best way to demo the issue)
and the new panel is much better but had physical damage and a lot of blooming... oddly enough the blooming seems to have gone away.
But it does have the horizontal line issue but not near as bad as it used to be. and if I turn off smart LED is goes away. Honestly i can't see that Smart LED does anything worth it anyway.
Hopefully the 3rd panel (to replace the one with cosmetic damage) is decent and I can start really enjoying this TV. That said even with all the issues the TV looks amazing on all the 4K and HDR content I have thrown at it. Much improvement over my 70Inch Sharp TV.
all 4 of the TV's that I have had .. have had the SAME issue I hope its not the one connect box.. can't imagine it would be.
but I have a horizontal line especially on the upper left side of the TV that moves. It happens a lot more when Smart LED is set to high
seems like certain darkness it happens too. how is it that all four TV's have done this. I am on my last panel and I am just going to deal with it
but I can't find anyone else that has said much about it other than earlier in the forum someone had the same issue.
you can really see it happen when you are adjusting the backlight too.
Billy Williams is online now
post #1641 of 1845 Old 06-23-2017, 07:03 AM - Thread Starter
Impala1ss's Avatar
Quoted: 23 Post(s)
Suddenly when I turn on my TV it starts with the "Set up the TV" screen that I've done a dozen times now. I can't get it to disappear when I turn on the TV.
Impala1ss is offline
post #1642 of 1845 Old 06-23-2017, 07:12 AM
Quoted: 33 Post(s)
Liked: 24
Your smart TV went "stupid". It happens to me every time I use the my PC through my AVR video switcher. Otherwise no problem.
Cheers
ralarcon1 is offline
post #1643 of 1845 Old 06-26-2017, 05:34 AM
mousetamer's Avatar
Cheers
Same thing happened to me a couple of months ago. It worked fine for almost a year before it stopped. I had a Rogers Cable box which I could operate with the TV's remote. It also allowed me to use the guide and control the recordings on the PVR. Then one day it just stopped. I switched to Bell Fibe and the TV remote does not work with it at all and I get the same set up screen every time I switch to that input. Funny thing is my friend has the same model and the same Fibe set up and his works just fine. I just installed the new firmware btw and I still have the same issue.
mousetamer is offline
post #1644 of 1845 Old 06-26-2017, 07:58 AM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 365
-Kevin
Kevin,
How are you checking to see what signal you are receiving, and are able to display on the KS9000 ?
Glenee
Glenee is offline
post #1645 of 1845 Old 06-26-2017, 08:55 AM
kbmb's Avatar
Quoted: 981 Post(s)
Liked: 769
Kevin,
Glenee
Previous to the 1180.5 firmware, the KS9000 would show an HDR banner that would show at the top of the screen when you watched a program in HDR from Netflix, Amazon, Fandango, etc. Now, that banner doesn't show up. So the only way to verify that the TV switched into HDR mode would either be to go into the settings and see the backlight is at 20 and the contrast is at 100.....or, select the HDMI input on the TV again so it pops up is resolution display, which should show HDR next to the resolution if it's an HDR program.
-Kevin
Glenee and Terminader like this.
kbmb is offline
post #1646 of 1845 Old 06-26-2017, 10:41 AM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 365
-Kevin
All's Good and I appreciate the help.
Glen
Glenee is offline
post #1647 of 1845 Old 06-26-2017, 10:57 AM - Thread Starter
Impala1ss's Avatar
Quoted: 23 Post(s)
Am I the only one who has this problem with my tv?
post #1648 of 1845 Old 06-27-2017, 04:46 AM
mousetamer's Avatar
No. I mentioned the same problem a few posts above.
post #1649 of 1845 Old 06-27-2017, 12:04 PM
Liked: 5
Unhappy Backlight issue
Has anyone had this issue with one section of the back light not coming on right away? a section of the bottom left is dark when I first turn on the set. So far it pops on eventually but it looks to be getting worse. Will be contacting Samsung : |
ID:	2206737   Click image for larger version
weaver3294 is offline
post #1650 of 1845 Old 06-27-2017, 05:16 PM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 365
Contacting Samsung is the thing too do.
Glenee is offline
Reply LCD Flat Panel Displays
KS9000
