Originally Posted by
Jacksomkesoplenty
Good Calibration Disc suggestions anyone
Disney WOW and / or Spears & Munsil
NOTES: This is an entirely new workflow approach. Thanks to
thecool
est and
shoman94
for their suggestions and expertise. Part of learning how to calibrate is knowing what settings to change depending on which calibration page you are working in during the process. There were times in the past where I was changing settings before they should be changed. It made the calibration process a bit of an ordeal as some things looked great and others - not so great. With my newfound knowledge, I finally got great color balance, a decent saturation sweep result and the color matching is excellent; which = color accuracy. Flesh tones are really great now. PQ is the bomb!
As part of the new workflow, I left ALZ ( Active LED Zones ) on through the entire process except for setting peak brightness ( backlight ). This approach took longer to do because I had to wait for the zones to respond and the settings numbers on the top of the screen to disappear; but the results are much better. Also, I used a 10% window with the pattern generator.
One thing you will notice is that color is upped to 56, brightness to 58, and contrast is lowered to 41. There is a combination of factors that went into the "why" I chose those settings; including the fact that the colors were all undersaturated at the 50 setting with the saturation sweep test. So I went back and turned up the color a bit and went from there. One of the benefits is that I didn't have to force things in the color tuner to get better color balance, luminance, saturation. I made relatively small adjustments in the color tuner. The 11 point settings are also pretty mellow except for 10% and 20% and taming things in the 60% to 70% range. Because of all that, these settings should look a least very good on most sets even accounting for variances.
CalMan screenshots attached. The color checker looks awesome. I'm really happy about that because in the past I hated that chart!
M70-D3 Calibration
FW: 3.2.8.3
Start with Calibrated
Basic Settings:
Backlight: 50
Brightness: 58
Contrast: 41
Color: 56
Sharpness: 2* ( *slight edge enhancement for low quality signal; i.e. 1080i/720p/cable/satellite )
Tint: 0
Color Temp: Normal
Black Detail: Off
Active LED Zones: On
Reduce Judder: 1 - 2 ( helps with 3:2 motion issues without introducing SOE )
Reduce Motion Blur: 0
Clear Action: Off
Reduce Signal Noise: Off* ( Set this to Low for crappy signal quality; i.e. same reasons as above ) - Set to “Off” for 1080P/4K/Blu-ray, etc.
Game Low Latency: Off
Film Mode: Auto
Color Space: Auto
Gamma: 2.2
Color Tuner:
Primary Color Enabled: Turn all to On ( default )
Hue: R: 2, G: -13, B: 2, C: 2, M: -2, Y: 5
Sat: R: -9, G: -5, B: -6, C: -2, M: -6, Y: 0
Brt: R: 0, G: 2, B: 8, C: -6, M: 8, Y: -2
Ofs: R: -1, G: 0, B: 3
Gain: R: 0, G: 9, B: -13
11 Point:
5%: No change - zeros
10%: R: -22, G: -22, B: -22
20%: R: -16, G: -10, B: -12
30%: R: -10, G: -7, B: -5
40%: R: -6, G: -7, B: -8
50%: R: -7, G: -4, B: -10
60%: R: -17, G: -13, B: -23
70%: R: -4, G: -12, B: -22
80%: R: -1, G: 0, B: 3
90%: R: 0, G: 0, B: -6
100%: R: 2, G: 0, B: 4
