Originally Posted by
sonoftumble
Sonoftumble Calibration REV 5 SDR + HDR-10
2016 M70-D3
FW 3.2.13.3
NOTES: With REV. 4.5, I encountered block noise when viewing content that had certain shades of yellow and green. The fix was to set the red and green brightness levels in the color tuner to zero. That of course changed certain elements of the calibration, so I decided to run it again leaving the red and green brightness at zero while making more adjustments to the hue and saturation levels to get things to behave. The results were excellent with both the saturation sweeps and color checker pages looking awesome.
Also, Rev. 4.5 was based on FW 3.2.8.3, so just in case there were differences in color behavior with 3.2.13.3, I thought running a new scan was in order.
Finally, I ran an HDR-10 calibration. The amazing thing about that process was just how close my TV tracked with color accuracy. All I needed to do was adjust the 30% and 80% and NOTHING ELSE. Pretty cool.
When you play HDR-10 content, the TV loads a CMS table with zeroed out Color Tuner and 11 point adjustments. Simply play HDR-10 content, and while it’s playing, input the settings below. The TV will save those settings and automatically load them whenever you play HDR-10 content. When you start playing SDR content it will automatically load that table with the SDR settings.
If you don’t have an external HDR-10 playback device, you can cast the second listing of Meridian on Netflix which is HDR-10. It’s a short film, but you should be able to input the very few setting in the 15 minutes that the program plays.
Since some of you will ask, when I tried to do a Dolby Vision calibration, the initial luminance and color readings were so far off, >25% errors - that I need to do a little more research on how to properly setup Calman before trying again.
Enjoy!
Start with Calibrated Picture Mode
Basic Settings:
Backlight: 40
Brightness: 50
Contrast: 50
Color: 50
Sharpness: 2* ( *slight edge enhancement for low quality signal; i.e. 1080i/720p/cable/satellite )
Tint: 0
Color Temp: Normal
Black Detail: Off
Active LED Zones: On
Reduce Judder: 1 - 2 ( helps with 3:2 motion issues without introducing SOE )
Reduce Motion Blur: 0
Clear Action: Off
Reduce Signal Noise: Off* ( Set this to Low for crappy signal quality; i.e. same reasons as above ) - Set to “Off” for 1080P/4K/Blu-ray, etc.
Game Low Latency: Off
Pure Cinema = On
Color Space: Auto
Gamma: 2.1
Color Tuner
Primary Color Enabled: Turn all to On ( default )
Hue: R: 0, G: -4, B: 0, C: 0, M: -5, Y: 0
Sat: R: -5, G: -1, B: -10, C: -3, M: -5, Y: 5
Brt: R: 0, G: 0, B: -12, C: -6, M: -7, Y: -1
Ofs: R: 2, G: 3, B: 5
Gain: R: 16, G: 18, B: -13
11 Point:
5%: to 50%: No change - zeros
60%: R: -4, G: -10, B: -10
70% - No change - zeros
80% - No change - zeros
90% R: 0, G: 0, B: 5
100%: R: 20, G: -15, B: 15
HDR-10
Color Tuner:
Offset: R: -6, G: 1, B: 0
Gain: R: 7, G: 2, B: -17
Excellent, im going to try this evening and will post the results, already loving the decision i made to keep M60-D1 in place of LG 60UH7700, its far better than LG PQ and 500$ less, looks like wise decision
thanks to this forum and members for helping pople like us
