Official 2016 Vizio M-Series Owner's Thread - Page 326 - AVS Forum | Home Theater Discussions And Reviews
 5362Likes
post #9751 of 10236 Old 01-19-2018, 03:29 PM
Ryan1's Avatar
Quoted: 296 Post(s)
Liked: 252
Originally Posted by Sean Groppe View Post
Does anyone have any updated calibration settings for the more recent firmware updates? The colors on my M55-D0 just seem off since the latest updates. Blacks often have a bluish tint and some sources seem to have reddish/purple hue in darker scenes. Never had this issue before. Thanks!
I believe that sonoftumble will update his calibration settings when he has the time, although at this point it may be worth waiting for the next firmware revision, which shouldn't be too long in coming.
Ryan1 is offline
post #9752 of 10236 Old 01-20-2018, 05:48 PM
asolor78's Avatar
Quoted: 61 Post(s)
Is there a new firmware coming.. hope Amazon HDR is added... Also since reading that Forbes article, it looks like Vizio will be revising there DV spec to fix grey blacks thru HDMI.. wonder with SoC on this tv vs DV software how that affect picture... Got lg up970.. was lucky one who upgraded DV in time... We will see
asolor78 is offline
post #9753 of 10236 Old 01-23-2018, 06:00 PM
Yasmany Navas's Avatar
Quoted: 13 Post(s)
Liked: 0
There has to be a firmware issues to be causing so many this particular problem
https://www.reddit.com/r/VizioTV/com..._screen_issue/
Yasmany Navas is offline
post #9754 of 10236 Old 01-24-2018, 09:54 AM
Quoted: 13 Post(s)
Liked: 0
What are the differences between the 2016 M50-D1 and the 2017 M50-E1?
post #9755 of 10236 Old 01-29-2018, 04:18 PM
sonoftumble's Avatar
Quoted: 2692 Post(s)
Liked: 2451
M70-D3 Calibration Rev. 6.5 FW: 3.4.8.15 - JAN. 30, 2018
Hey Guys,
Updated HDR white balance settings ( Offset and Gain + 11 point ) The settings for green were off a bit.
Enjoy. Feedback always welcome! The last two attachments are HDR-10 and DV This is about as good as we are going to get with this hybrid HDR but not WCG panel.
M70-D3 Calibration - Rev. 6.5
FW: 3.4.8.15 - JAN. 29, 2018
Start with “Calibrated” picture mode
Auto Brightness Control: Off
Basic Settings:
Backlight: 40 ( SDR ) 60 ( HDR-10, DV )
Brightness: 50
Contrast: 50
Color: 50
Sharpness: 2* ( *slight edge enhancement for low quality signal; i.e. 1080i/720p/cable/satellite )
Tint: 0
Color Temp: Normal
Black Detail: Off
Extreme Black Engine Plus: On
Reduce Judder: 1 - 2 ( helps with 3:2 motion issues without introducing SOE )
Reduce Motion Blur: 0
Clear Action: Off
Reduce Signal Noise: Off* ( Set this to Low for crappy signal quality; i.e. same reasons as above ) - Set to “Off” for 1080P/4K/Blu-ray, etc.
Game Low Latency: Off
Pure Cinema = On
Color Space: Auto
Gamma: 2.1
SDR
Color Tuner:
Hue: R: 0, G: -5, B: 0, C: 0, M: -5, Y: 3
Sat: R: -5, G: -9, B: -7, C: -6, M: -7, Y: -4
Brt: R: 0, G: 0, B: 0, C: 0, M: 0, Y: 0
Ofs: R: -3, G: -1, B: 3
Gain: R: 1, G: 8, B: -20
11 Point:
10% R: 4, G: 0, B: 0
20% R: -4, G: 0, B: 0
30% R -1, G: 0, B: 0
40% All 0’s
50% All 0’s
60%: R: -10, G: -11, B: -14
70%: R: -5, G: -3 B: -3
80% & 90% - No change - All 0’s
100%: R: 12, G: -8, B: 13
HDR-10
Color Tuner:
Hue: R: 4, G: -3, B: -4, C: -1, M: 0, Y: 0
Sat: R: 6, G: 18, B: 9, C: 0, M: 3, Y: 18
Ofs: R: -3, G: 0, B: 1
Gain: R: 7, G: 4, B: -17
11 Point:
10%: No change - zeros
20%: R: 5, G: -12, B: 5
30% & 40% - No change - zeros
50%: R: 9, G: 0, B: 0
60%: No change - zeros
70%: R: 0, G: 0 B: -1
80% to 100% - No change - zeros
Dolby Vision - Set backlight to 60.
Color Tuner:
Hue: R: 0, G: 0, B: 0, C: 0, M: 0, Y: 0
Sat: R: 0, G: 0, B: 0, C: 0, M: 0, Y: 0
Ofs: R: -14, G: 10, B: -1
Gain: R: 11, G: 15, B: -22
11 Point:
10% to 100%: No change - zeros
Ryan1, wmarkw, skads_187 and 1 others like this.
LG OLED65C7P 4-20-19 Calibration SDR/HDR/DV FW 05.80.15: https://www.avsforum.com/forum/40-ol...l#post57928994
VIZIO M70-D3 Calibration SDR/HDR FW 3.4.8.15: https://www.avsforum.com/forum/166-l...l#post55595700
sonoftumble is offline
post #9756 of 10236 Old 01-29-2018, 05:11 PM
Quoted: 73 Post(s)
Liked: 25
Thanks, @sonoftumble plugging them in now.
Quick question: for SDR, are 11 point 0-50 all zero? I saw that some in that range had valued other than zero.
Roadwarrior123 is online now
post #9757 of 10236 Old 01-29-2018, 05:15 PM
Quoted: 73 Post(s)
Liked: 25
And do you think these settings are ok for an M65-D0? The 2016 model?
post #9758 of 10236 Old 01-29-2018, 05:38 PM
Quoted: 73 Post(s)
Liked: 25
@sonoftumble , Are you sure about the Green values in offset and gain for DV and HDR10? They give me overly green images with the black levels, especially noticeable with widescreen content (2.35:1). Or is this set specific?
post #9759 of 10236 Old 01-29-2018, 06:09 PM
Liked: 2451
Good eye!! That was a typo. I was in too much of a hurry.
post #9760 of 10236 Old 01-29-2018, 06:13 PM
Liked: 2451
They might be panel specific. I spent a ton of time trying to get the RGB balance to behave in the offset and gain settings. If they look really green then you should probably zero them out. I will take another look later in the week.
post #9761 of 10236 Old 01-29-2018, 06:14 PM
Liked: 2451
These should work well on the M65-D0!
post #9762 of 10236 Old 01-30-2018, 01:21 AM
Quoted: 392 Post(s)
Liked: 112
Originally Posted by sonoftumble View Post
Hey Guys,
Thanks for all your patience. Been real busy! Good thing. Lots of minor adjustments with crazy green and blue behaviors in SDR, HDR-10, and DV.
Thanks for this
sonoftumble likes this.
Theater:JVC RS440, Elite 120". 7.1.4:RTi8, CSi5, FXiA4, RTiA3, 620-RT(4) & SVS PB12-NSD. Denon X4300H, UPA-700, Crown XLS1502 & XLS1000(2). Sony UBP-X800, Panasonic DP-UB424, Shield & ATV 4K. Lounge:Vizio M70-D3, Benq HT1075, & Elite 106". 7.1.4:RTi12, CSi5, RTiA1, TSx110, MC60(4), & RBH I-12. Marantz AV7702, Crown XLS1500, XLS1000(2) & Amp 100v2(2). Samsung UBD-K8500, LG BP440, Shield & ATV
shyyour is offline
post #9763 of 10236 Old 01-30-2018, 07:21 AM
Liked: 2451
Hi @Roadwarrior123 ,
I went back and compared my most recent settings ( Rev. 6.0 ) - prior to yesterday's ( Rev. 6.5 ), and there really wasn't much of a difference overall; EXCEPT for the GREEN settings. It's very strange, as I didn't rush through this. But as you will see below, the changes in green - for both offset and gain - are very obvious. By comparison, the other colors show only minor adjustments. Also interesting is that you are seeing more green when most of the new settings show quite a bit of effort on my part to reduce the green readings that I was getting. So it's a head scratcher.
Since the SDR settings were hardly changed, I'm just going to chalk this up to phantom readings and changes in lighting throughout the afternoon when I ran this session. ( The M70 is now in a different room because of the OLED. lol )
I recommend going back to the Rev. 6.0 settings for HDR - specifically the Offset, Gain, and 11 point only; since everything else is very similar to each other. Let me know if that looks better. Pretty sure it will. I will be updating the Rev. 6.5 post after I hear back from you.
Sorry about that.
HDR-10
Previous - Rev. 6.0
New - Rev. 6.5
Ofs: R: -5, G: 13, B: 1
Gain: R: 5, G: -10, B: -15
Previous - Rev. 6.0
11 Point:
New Rev. 6.5
11 Point:
5%: & 10%: No change - zeros
20%: R: 9, G: 0, B: 5
30% - All 0’s
40% R: 4, G: -19, B: 0
60%: All 0’s
Ryan1 and skads_187 like this.
post #9764 of 10236 Old 01-30-2018, 08:53 AM
Quoted: 73 Post(s)
Liked: 25
Thanks @sonoftumble ! I appreciate the update and clarification, and of course the hard work you put in to the calibration. Glad to have you back!
post #9765 of 10236 Old 01-30-2018, 05:10 PM
Quoted: 27 Post(s)
Liked: 25
Thanks @sonoftumble , your sdr calibration is the best yet! I also had the green HDR. Thank you for your time and effort, it's greatly appreciated
Matt0305 is offline
post #9766 of 10236 Old 01-30-2018, 05:19 PM
Liked: 2451
You are very welcome. Just to verify that you are aware, I updated the post today. The new (old) settings should fix the green HDR issue. You are using those settings . . . correct?
post #9767 of 10236 Old 01-30-2018, 06:26 PM
Quoted: 73 Post(s)
Liked: 25
@sonoftumble plugging the updates in meow, will provide feedback.
Quick question: what's the 5% 11 point under SDR? It looks like it might've been cut off. Thanks!
post #9768 of 10236 Old 01-30-2018, 07:53 PM
Liked: 2451
That was an Oooops typo. I just fixed it now. I borrowed the layout from my OLED post. The OLED has a 20 point grey scale.
post #9769 of 10236 Old 01-30-2018, 08:28 PM
asolor78's Avatar
Quoted: 61 Post(s)
You are very welcome. Just to verify that you are aware, I updated the post today. The new (old) settings should fix the green HDR issue. You are using those settings . . . correct? [IMG class=inlineimg]https://www.avsforum.com/forum/images/smilies/smile.gif[/IMG]
Hello great work @sonoftumble ...as previously indicated that green offset goes straight Patty's day on my screen, I own M65 2016..at about 1 setting, on hdr10 I start noticing green tint... Really interesting how ur 70inch calibration is producing high count of 10... Also on DV, that gets green at around -2 ... But I managed to just lower offset.. great work
asolor78 is offline
post #9770 of 10236 Old 01-31-2018, 05:56 AM
solidus28's Avatar
Quoted: 29 Post(s)
I, too, saw the green on HDR10. I just loaded your updated figures and it is definitely better. Thanks!
Sent from my LGLS992 using Tapatalk
solidus28 is offline
post #9771 of 10236 Old 02-02-2018, 12:37 AM
Ryan1's Avatar
Quoted: 296 Post(s)
Liked: 252
Hey Guys,
Thank you! These setting make my M70-D3 look surprisingly good.
Vizio should make you an honorary ambassador, or something.
Ryan1 is offline
post #9772 of 10236 Old 02-02-2018, 05:07 AM
wmarkw's Avatar
Quoted: 469 Post(s)
Liked: 238
@sonoftumble Just to confirm we are to use settings from post 9755 for SDR and DV and then the new REV 6.5 adjustments for HDR from post 9763? I see you edited your original post but the HDR settings there still had the green issue if I'm looking at this correctly? Thanks for the hard work as always!
wmarkw is offline
post #9773 of 10236 Old 02-02-2018, 08:23 AM
Liked: 2451
The settings from post #9755 were edited and the HDR-10 section with the green issue has been corrected.
wmarkw likes this.
post #9774 of 10236 Old 02-02-2018, 08:28 AM
Liked: 2451
I edited the main post, and the new HDR settings fix that pesky green issue. Thank you for your feedback.
post #9775 of 10236 Old 02-02-2018, 10:49 AM
h1pp0's Avatar
Liked: 0
Thanks for your hard work in calibrating @sonoftumble !
I'm wondering if your settings will work on a m55-d0 model.
h1pp0 is offline
post #9776 of 10236 Old 02-02-2018, 11:25 AM
Liked: 2451
I'm not sure. Being that it is a different panel, there will most likely be some variances. It won't hurt to give them a try. You can always reset the color tuner if they don't look good. The best way to determine if they are working well with your panel is to look closely at flesh tones. Disclaimer: Use a well produced movie or other good source. Don't compare with local news flesh tones - as they are always jacked up - the makeup people sometimes get carried away!
post #9777 of 10236 Old 02-02-2018, 04:33 PM
wmarkw's Avatar
Quoted: 469 Post(s)
Liked: 238
Thanks dude. Couple of things. I assume we should leave the default HDR color to 58? And I have a 5% on my color tuner. Also fwiw these settings make my screen look very green for DV content. Also when i was on the roku HDR source my judder was ghosted out??!
wmarkw is offline
post #9778 of 10236 Old 02-02-2018, 05:03 PM
Liked: 2451
For DV, I would just zero everything out and give that a spin. You shouldn't be having all these green problems. I'm going to do a factory reset and start from scratch. I will also make sure that Vizio didn't sneak in a new DVGR while I wasn't looking. Whaaaaaa!
Ryan1 and wmarkw like this.
post #9779 of 10236 Old 02-03-2018, 07:59 AM
Quoted: 34 Post(s)
Liked: 31
I also have the M55-D0 and have been using @sonoftumble settings since I joined this forum. All have looked great, maybe I got lucky on panel selection. You'll just have to plug em in and see for yourself. Just updated from Rev6 to Rev6.5 and still loving it (haven't done HDR-10 settings so can't speak for the green issues). Thanks again tumble and best of luck h1pp0
Sent from my Pixel 2 XL using Tapatalk
wlp3D is offline
post #9780 of 10236 Old 02-03-2018, 09:20 AM
cheapskateaudiophile's Avatar
Quoted: 24 Post(s)
I put the new 6.5 settings into my Oct 16 m55d0 and the initial results look much better. I was having issues with Bosch Season 3 via my Roku Premiere+. Most skin tones were way off (heavy brown? cast)and now are much more normal. I would not say HDR10 is perfect but is better than what I was getting. The same scenes in smartcast SDR are more natural in tint quality but overall saturation is subdued in comparison. I watched the first episode of Godless in DV and three episodes of Longmire (SDR )last night via smartcast and both seem excellent to me. Hopefully Amazon will enable HDR vis smartcast soon for comparison. After writing this it seems I should try more more smartcast HDR10 for comparison. Thanks for your efforts and willingness to share your work.
Display: Vizio M55D0
Sources: Roku Premiere+, Google Fiber TV, Denon DVD-2500BTCI, Sony UBP-X800, Toshiba HD-A35, Sony CDP-222ES
Audio: 7CH system, Denon AVR-2300W, NorthCreekMusic Rhythm L/R/C, Paradigm dipole surrounds, NCM back surrounds
cheapskateaudiophile is offline
Reply LCD Flat Panel Displays
2016 , m-series , m70-d3 , m80-d3 , Vizio
