Official 2016 Vizio M-Series Owner's Thread - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 5367Likes
post #2851 of 10276 Old 11-22-2016, 05:24 PM
talk show host's Avatar
Quoted: 179 Post(s)
Liked: 36
Originally Posted by danbfree View Post
Yes, look here under "input specifications" http://www.rtings.com/tv/reviews/viz...comparison_200
Thank you guys, especially Dan... the problem I was having was not th tv, but rather the xbox. I found a fix for that on another site. I also got a wireless access point to improve the wifi connection for the tablet-tv connection and it's made a world of difference! I'm much happier with the tv now.... picture quality is substantially better. I think it was being downgraded before by trying to connect to a weak wifi signal. I did a factory reset on the tv and never setup the wifi, so I know the tv is using Ethernet and it's much more reliable. Thanks for the help!!
talk show host is offline
post #2852 of 10276 Old 11-22-2016, 05:36 PM
ultraspec's Avatar
What did Vizio add to the 2016s that the 2015s M series does not have?
I have a 2015 M50 and I am wondering if it is worth looking for an upgrade since the 2016s are probably about to get really cheap since its the holidays. Thanks.
ultraspec is offline
post #2853 of 10276 Old 11-22-2016, 05:37 PM
oog500's Avatar
Liked: 7
Can somebody confirm, if mX0-d3 supports 50Hz refresh rate at any resolution?
oog500 is offline
post #2854 of 10276 Old 11-22-2016, 06:24 PM
ffactoryxx's Avatar
Quoted: 543 Post(s)
Liked: 91
Originally Posted by BFJ 96 View Post
At Costco right now. For the price the 65M is a helluva deal. The wife is giving me push back with the old
"We don't need a new TV right now" gag.
Argghhh
Sent from my Pixel XL using Tapatalk
Does she know you just upgraded your phone as well 😎
BFJ 96 likes this.
ffactoryxx is offline
post #2855 of 10276 Old 11-22-2016, 07:45 PM
danbfree's Avatar
Quoted: 812 Post(s)
Liked: 373
Originally Posted by libertyforall View Post
Fireplace TVs don't work so well for a full range sound system, I have a 7.1 set of Polk Audio speakers and like it very much:
https://www.polkaudio.com/collection...io/rtia-series
Originally Posted by Jasonn B View Post
Well, currently I'm using the tv speakers, and the only reason is, I got somehwat lucky, since the tv sits above the mantle, the sounds reflects off the mantle and doesn't sound that bad. I'm though looking to recess a sound bar inside the middle of the mantle with a white speaker fabric custom. This won't be easy, but the way this setup is, seeing a sound bar will NOT look right.
As you can see, a sound bar won't look right. And when I tested this, it's back so far that the sound reflects weird when your ears hear it... So, my next question is, does anyone have the Vizio SmartCast sound bar with this the new M series? Would this work best in terms of functionality with the vizio app, etc. turning the tv on/off and sound bar will automatically just work with no extra remotes???
I still think a soundbar would look great, and there are quite a few now that include the left/right/center in one piece for the front. Then you could easily still do 5.1 or 7.1 and would look good with TV right above it using an extension arm with such a deep mantle. I guess we'll have to agree to disagree but an extension arm to swivel and move the TV side to side is almost mandatory to do a fireplace setup properly. My fireplace has a recessed area but is too small to fit anything other than a 50" probably so an extension arm lets me mount a much bigger TV in that spot.
danbfree is offline
post #2856 of 10276 Old 11-22-2016, 07:47 PM
danbfree's Avatar
Quoted: 812 Post(s)
Liked: 373
Better contrast, double the active FALD zones, HDR and a control tablet. A pretty big jump actually.
danbfree is offline
post #2857 of 10276 Old 11-22-2016, 08:00 PM
danbfree's Avatar
Quoted: 812 Post(s)
Liked: 373
As you can see, a sound bar won't look right:
How deep is your mantle? You posted a couple of different pics, if it's the really deep one you really, really need an arm mount. So far back like that is literally adding almost two feet of viewing distance and wasting the 4k. Also a soundbar would absolutely look and sound right if you did it that way. Anyway, we can agree to disagree I guess but if you want it to look and sound right you gotta bring the TV from way back there.
ID:	1785545   Click image for larger version
danbfree is offline
post #2858 of 10276 Old 11-22-2016, 09:23 PM
Quoted: 21 Post(s)
I guess going back to the tablet casting - I was assuming the tablet is 720p so casting the tablets screen to the tv (which I have to do in order to watch kodi or other things ) it only casts to my tv in 720
My other tv with built in apps, the streaming quality isn't limited by the casting device cables etc it's straight up 4K uhd if possible.
I would like to know how to better use my tablet and how to cast my tablet in higher resolutions.
PS
I am also stuck on a side track observation
My iPhone can "cast" YouTube app and Netflix app in 4K.
But other apps require a device like Apple TV.
Why is that needed if both those other apps could do it just over wifi?
rjhseven likes this.
BlueWaffles is offline
post #2859 of 10276 Old 11-22-2016, 11:51 PM
Liked: 0
Hi, I'm looking for a 65" 4k tv to replace my Vizio e3D470vx. I would love to get another 3d tv, but the LG UH8500 doesn't have as good PQ compared to similar priced Samsung or Vizio and their 3d OLEDs are way out of my price range. I watch 2d far more than 3d so I'm just going to get a 2d tv and hope 3d OLEDs come down in price in maybe 3 or 4 years.
So I'm considering the Vizio M65-D0, but I went to 2 stores (Best Buy and Costco) and BOTH of them had a Vizio M series with 1/4 of the backlight out. That concerns me so I'm also considering the Samsung UN65KU6290, same as the KU6300 but with a basic remote. I'm not all that interested in the smart remote as I'll be using a Harmony.
Which would be the better buy? The Samsung is $120 cheaper also. Thanks.
otrono is offline
post #2860 of 10276 Old 11-23-2016, 12:06 AM
danbfree's Avatar
Quoted: 812 Post(s)
Liked: 373
Vizio has far better motion, which I think is a huge factor, on top of the active dimming and true 120Hz panel seals it on the M series for me... for any less I'd get the Vizio E series which I think is $100 cheaper than the Samsung and pretty much the same performance. Not that the Samsung is a bad TV, but even E series you can control with your own phone or tablet as well... Personally I feel the M series is worth the extra if you can afford it. The backlight being 1/4 out on both demos had to be some fluke, the demo unit I saw and my own is excellent.
danbfree is offline
post #2861 of 10276 Old 11-23-2016, 12:08 AM
danbfree's Avatar
Quoted: 812 Post(s)
Liked: 373
PS
Sounds like you need to use more apps with built in casting, like Plex, then you aren't just doing Android screen mirroring, which is what you are referring to when sending the whole screen. Quality video isn't intended to be watched that way. That's what you're limited to 720p and is a little jumpy to watch. I think it's an apple thing why more apps don't actually cast in iOS, as it's essentially a competing platform.
danbfree is offline
post #2862 of 10276 Old 11-23-2016, 05:37 AM
wmarkw's Avatar
Quoted: 480 Post(s)
Liked: 242
I would as well. I snagged a 2015 M50 back in May when walmart had them closing out for $298. Its a great bedroom TV for us but now if i can find a 2016 M50 on sale I'm going to jump all over that. The 2016 has a better picture by far and also the casting feature to me makes it worthy of an upgrade.
wmarkw is offline
post #2863 of 10276 Old 11-23-2016, 06:19 AM
Kal525's Avatar
Quoted: 53 Post(s)
Hi,
I have an M80-D3 on the way. Two questions:
- The Yamaha RX-V373 receiver I have claims to support a 4K pass-through. Will this work with all content on the new TV?
- Is there any way to stream content in a quality that is close to Blu-ray?
Thank you
Kal525 is offline
post #2864 of 10276 Old 11-23-2016, 08:02 AM
lobosrul's Avatar
Quoted: 1169 Post(s)
Liked: 796
Originally Posted by Kal525 View Post
Hi,
Thank you
To answer your 2nd question:
For non-HDR The Crown on Netflix (2160p) is the best looking show out there, beats any 1080p bluray IMO. I was watching it 2 nights ago and thinking to myself: man practically nothing happens on this show... but I don't care. Marco Polo is the best looking HDR show.
lobosrul is offline
post #2865 of 10276 Old 11-23-2016, 08:53 AM
Balforth's Avatar
Quoted: 41 Post(s)
PS
You might want to check out the Nvidia Shield for Kodi. It works great and you get all of the other benefits of the Shield.
danbfree likes this.
Vizio M80-D3, P55-C1 UHD TV
Yamaha RX-A3060 AVR
Klipsch RP-280FA, RP-450CA LCR
Outlaw LFM-1 Plus Sub
Nvidia Shield Console
Balforth is offline
post #2866 of 10276 Old 11-23-2016, 09:11 AM
Super Moderator
teachsac's Avatar
Quoted: 1316 Post(s)
Liked: 2149
No price talk outside of the designated Deals' areas.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #2867 of 10276 Old 11-23-2016, 10:00 AM
Quoted: 1137 Post(s)
Liked: 982
Note that the 2016 M50 still has 32 led zones, compared to 64 in 55" and up.
LG 65B7 | T95N with CoreELEC | Vizio SB3851-D0 | Calibration + Settings (TBD)
Vizio M60-D1 | T95M with LibreELEC | Calibration + Settings
Dell UP2516D | Le Potato with CoreELEC (Development/testing platform)
Vizio M55-C2 (Ex) | Calibration + Settings
The Coolest is offline
post #2868 of 10276 Old 11-23-2016, 10:19 AM
wmarkw's Avatar
Quoted: 480 Post(s)
Liked: 242
yeah good point but i think the 16 still would produce a better pic with newer tech. or maybe not.
wmarkw is offline
post #2869 of 10276 Old 11-23-2016, 10:21 AM
Liked: 982
It would, probably. I was just saying it's something to think about. I think that the 55" would be a far better choice.
post #2870 of 10276 Old 11-23-2016, 01:11 PM
Jasonn B's Avatar
Quoted: 485 Post(s)
Liked: 173
PLEX USERS
Supposedly there is a way to stream 4k files with the Plex app. Me and a friend are trying to do this but aren't having any luck. The latest version of plex says you can do this. Can anyone give some tips?
Wondering if I should make a new thread about streaming on 2016 Vizios?
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #2871 of 10276 Old 11-23-2016, 07:26 PM
ultraspec's Avatar
So its still the same on the 50"? I cant fit a bigger one right now.
298? The casting feature seems nice....
So the zone number is still the same according to your post for the 50? Then the only difference is the cast tablet or am I missing something?
post #2872 of 10276 Old 11-23-2016, 09:05 PM
Quoted: 21 Post(s)
PLEX USERS
I don't believe the plex app supports casting 4K yet.
freeskier93 is offline
post #2873 of 10276 Old 11-24-2016, 02:34 AM
Liked: 982
@ultraspec
You can check here under tech specs: https://www.vizio.com/m50d1.html
I think the image will still be better than on the 2015 models, also you're getting HDR10\DV and cast support. I just think that with BF deals it's probably worth forking out a little bit extra for the M55 for the additional size and led zones.
post #2874 of 10276 Old 11-24-2016, 03:44 AM
Liked: 982
Has anyone tried LocalCast to cast things to the TV?
post #2875 of 10276 Old 11-24-2016, 06:17 AM
balla01's Avatar
Quoted: 14 Post(s)
Hey everyone, I purchased the m65-d0 on sale for $999 at Costco. I haven't been able to find any good picture settings for this set as of yet. Usually I go off of Cnet's recommendation, but David K. didn't give one on this set. I tried the rtings.com setting and wasn't a fan of it at all. I use the set mostly for gaming in my man cave and I have a Playstation Pro. Any suggestions?
balla01 is offline
post #2876 of 10276 Old 11-24-2016, 06:26 AM
secondhand1's Avatar
Quoted: 85 Post(s)
Liked: 45
Both the Calibrated and Calibrated Dark out-of-the-box settings are pretty good. I use Calibrated with some initial color tweaking from rtngs. I then ran the Disney WoW disc and ended up not making any changes. Of course, this is subjective and may not tickle your fancy.
I would suggest sifting through this thread and playing around with what different folks have done to find what makes you happy.
Sent from my LG-H900 using Tapatalk
secondhand1 is offline
post #2877 of 10276 Old 11-24-2016, 07:17 AM
balla01's Avatar
Quoted: 14 Post(s)
Can I run the Disney Wow through my laptop and calibrate the tv that way or do I need the disc?
balla01 is offline
post #2878 of 10276 Old 11-24-2016, 08:36 AM
Jasonn B's Avatar
Quoted: 485 Post(s)
Liked: 173
I have ALLCAST, which works nice. What's localCast?
It does!
2.6.2
NEW: 4k and HEVC on capable devices with built-in Chromecast support (2016 Vizio TVs and the Nvidia Shield)
Harmony 890 Remote
Jasonn B is offline
post #2879 of 10276 Old 11-24-2016, 09:00 AM
jedurocher's Avatar
Quoted: 110 Post(s)
Liked: 58
Couple of shots of Lucy UHD from the Samsung K8500 4K/UHD player.
I just took a couple a few minutes into the movie. I am sure there are even better shots.
BFJ 96 and MrEdCeD like this.
JD
"Listen to advice and accept instruction, and in the end you will be wise." Proverbs 19:20
jedurocher is offline
post #2880 of 10276 Old 11-24-2016, 09:02 AM
Jasonn B's Avatar
Quoted: 485 Post(s)
Liked: 173
Happy Thanksgiving from one M series owner to another:
Yea, basic comcast HD, not the best....
jedurocher and BFJ 96 like this.
Harmony 890 Remote
Jasonn B is offline
Reply LCD Flat Panel Displays
2016 , m-series , m70-d3 , m80-d3 , Vizio
