**OFFICIAL** Entry Level 2016 Samsung 4K UHD KU6300/6500/6600 Series TV Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 388Likes
post #361 of 2407 Old 11-16-2016, 04:59 AM
WarpSpeed2013's Avatar
Quoted: 150 Post(s)
Liked: 78
Originally Posted by Bond 007 View Post
Originally Posted by WarpSpeed2013 View Post
I'm looking into this TV as it seems to a good "bang for your buck" option. However I've noticed a lot of reviews on Best Buy and a decent amount of reviews on Amazon reference an issue with the screen going black off and on when viewing HDMI sources. Has anyone else experienced this issue and is it still a problem?
HDMI handshake issues.
Not the tvs fault. Could be specific devices, cables, etc.
I figured that would be the case, my only concern was that I see an unusually high amount of complaints around the KU6300. Although I haven't seen a single reference to the issue here.
The complaints seem to indicate that the TV goes black randomly for half a second on some HDMI inputs. Has anyone found higher than normal HDMI handshake issues with this TV? I'm considering this TV but grew concerned with the "black screen flickering" complaints in reviews that don't seem to appear on other TVs.
WarpSpeed2013 is offline
post #362 of 2407 Old 11-16-2016, 05:08 AM
Liked: 0
The dimming issue happens when no devices on the HDMI is connected. The issue is not a deal breaker to be honest. It doesn't happen on the fly or when you are using it. At least for me. Just make sure the eco solution and power options are not on power save mode.
drunkonpiss is offline
post #363 of 2407 Old 11-16-2016, 06:57 AM
Quoted: 37 Post(s)
Liked: 9
Originally Posted by ScAndal View Post
I am also getting the error. Please cross-post here if you here anything from the reddit threads.
Just an update I got from Samsung. They are telling me our TVs are detecting an unreleased version right now and that is why we are getting the error. They are saying to check in a few weeks again when the final version is released.
ras82 is offline
post #364 of 2407 Old 11-16-2016, 07:03 AM
Quoted: 150 Post(s)
Liked: 78
I will make sure those settings are disabled. If you look on Best Buy's site a lot of reviews state it actually just cue to black every few minutes, but has no one here experienced that issue? I trust this site more than BB reviews.
post #365 of 2407 Old 11-16-2016, 09:19 AM
vrsixer's Avatar
My 6300 updated to 1150 successfully yesterday. Unfortunately, now YouTube is broken and will not launch. Netflix is working fine. Haven't noticed much else in limited use.
vrsixer is offline
post #366 of 2407 Old 11-16-2016, 09:44 AM
Liked: 4
Can't speak for anybody else, but I haven't had that particular issue. I've been very pleased with this set, and an issue like that would be a deal breaker for me.
Gregory G Wied Jr is offline
post #367 of 2407 Old 11-16-2016, 09:51 AM
Bond 007's Avatar
Quoted: 3204 Post(s)
Liked: 2514
Try unplugging it for a minute.
Bond 007 is offline
post #368 of 2407 Old 11-16-2016, 09:57 AM
Quoted: 150 Post(s)
Liked: 78
Has it been verified that the KU6290 is the same as the KU6300 except for Bluetooth and remote? Someone on Amazon remaked that they found the build quality on the 6300 to be different. If the panels are the same, I often see the 6290 for $50 less than the 6300.
post #369 of 2407 Old 11-16-2016, 09:58 AM
Quoted: 150 Post(s)
Liked: 78
Thanks! It is the only concern I have with the set as it would be a deal breaker for me too. I'm glad it isn't a design defect that everyone is having. Other than that the reviews look really good. It seems to be a great all around set for the price.
post #370 of 2407 Old 11-16-2016, 10:14 AM
Liked: 4
Those two are literally the same tv, but minus the smart remote and bluetooth. That's why the small deviation in model number.
post #371 of 2407 Old 11-16-2016, 10:19 AM
quamosa's Avatar
Quoted: 100 Post(s)
Liked: 79
I have the 6290 and the only thing missing is Bluetooth. The 6290 comes with the Smart Remote.
My First Build Ever in progress
quamosa is offline
post #372 of 2407 Old 11-16-2016, 12:13 PM
Liked: 1
Just curious is anyone has noticed poor wifi performance on the newer Samsung TVs. I have a 2013 model that works flawlessly and gets excellent throughput but I've tried two new Samsung 6200 and 6300 TVs and the performance has been terrible.
For example, if I run the netflix speed test on 2.4Ghz I get 10Mbps about 15 feet from the router. My phone and laptop at the exact same spot get 40-50mbps. My older TV gets equally good results.
Haven't tested the 5ghz band yet but it seems odd that performance is so bad on a modern TV.
rosmakloma likes this.
Jo Ma is offline
post #373 of 2407 Old 11-16-2016, 01:14 PM
Liked: 4
I can't say I've done a speedtest (didn't even know netflix had one...learned something new...), but in practice everything seems fine. My router is about 4-5 feet away, only running N speeds (on my laptop, throughput typically runs between 39 and 60, but does have occasional drops into the teens or 20s).
As far as practicality, 4k streams load quickly and with no artifacts or buffering, in my experience so far.
post #374 of 2407 Old 11-16-2016, 01:51 PM
Bond 007's Avatar
Liked: 2514
Not for me.
Bond 007 is offline
post #375 of 2407 Old 11-16-2016, 02:44 PM
Liked: 1
Yep, the app does have a speed test or you can use the browser and go to the Netflix speed test site (which I can't link to yet) I ran a few more tests, changed to the 5ghz band which has nothing else on it, still only got 10Mbit. Went back to the old TV and got 30-40Mbit. Really weird. The wired connection works fine but that was just to test since I don't have any drops in the TV rooms. Router is a AC1750 which can push good speeds to my other devices, just not the new TVs. Internet speed is 250Mbit. Might try another router just to see if it changes but since my phones, tables and laptops can get well above 50Mbit seems like it's the TVs.
Jo Ma is offline
post #376 of 2407 Old 11-16-2016, 04:30 PM
Quoted: 14 Post(s)
Liked: 0
Originally Posted by hbutitta View Post
I'm having this same issue while my pc is coming out of sleep mode. mvpcrossxover, have you figured out any solution?
Has anyone figured out a reliable fix for this issue?
Haven't found a fix for it yet. Was hoping for fix through a Samsung update.
mvpcrossxover is offline
post #377 of 2407 Old 11-16-2016, 06:37 PM
gugarci's Avatar
Quoted: 38 Post(s)
Liked: 29
I don't have this issue either.
gugarci is offline
post #378 of 2407 Old 11-16-2016, 08:18 PM
Quoted: 150 Post(s)
Liked: 78
That's what I figured. So panel specs, such as input lag and contrast ratio should be the same in the 6290 as the 6300? I'm considering going together with some friends as a gift for someone, but they game a lot and I wanted to make sure the 6290 would perform similarly to the 6300 which has low input lag and a good contrast ratio due to the VA panel. Otherwise we would try to pull together the last $50 for the 6300.
post #379 of 2407 Old 11-16-2016, 08:21 PM
Quoted: 150 Post(s)
Liked: 78
Is your 6290 the same panel as the 6300? My goal is to find something with a good contrast ratio (VA panel) that also has low input lag in game mode.
post #380 of 2407 Old 11-17-2016, 04:30 AM
Bond 007's Avatar
Liked: 2514
Not even all 6300 have the same panel. However there will be no difference with the 6290.
Bond 007 is offline
post #381 of 2407 Old 11-17-2016, 04:43 AM
Bond 007's Avatar
Liked: 2514
Amazon has the 65" for $1,077.99
Heck of a deal
Bond 007 is offline
post #382 of 2407 Old 11-17-2016, 09:05 AM
Quoted: 150 Post(s)
Liked: 78
Fair point, the Samsung panel lottery means there are usually some panel variations in a given model, I just wanted to make sure they didn't do a drastic switch in the 6290 like move from a VA to an IPS or drastically change the input lag. But it sounds like I can expect similar panel performance and build quality in the 6290.
post #383 of 2407 Old 11-17-2016, 10:23 AM
Quoted: 22 Post(s)
Liked: 3
Was looking at the rtings test for 5.1 passthrough.
http://www.rtings.com/tv/tests/input...io-passthrough
They only list the 70" KU6300 as having 5.1 passthrough over HDMI ARC and optical. What about other models such as KU6290 65" etc.
Anyone have any personal confirmation/test with KU6290 models?
digitaleight is offline
post #384 of 2407 Old 11-17-2016, 10:48 AM
Quoted: 73 Post(s)
Liked: 39
Best Buy has a specific Samsung 55 inch model UN55KU6270FXZA on sale for BF for $479. I cannot seem to find any information about this tv but it looks nearly identical to the UN55KU6300....there are a few questions/answers on the BB website and some seem to think it is the same tv but just marketed exclusively for BB BF sale. Been debating for almost the whole year about getting the 50 or 55 inch 6300 and still just may go get this one at Costco but curious what you all think.
Well wouldn't you know Samsung has finally put this model up on their website...it was not there yesterday. Here are the differences for anyone else that is concerned:
The 6270 lists the following as N/A on the website:
Ultra Clear Panel Smart Hub, Component, Component In, DTS Premium Sound
I did contact Samsung via chat and they indicated both tvs do have the Ultra Clear Panel. The 6270 does not have bluetooth and no smart remote.
Knowing this if I do purchase will probably stick with the 6300 model.
iluvwahoo is offline
post #385 of 2407 Old 11-17-2016, 10:57 AM
Quoted: 150 Post(s)
Liked: 78
Unfortunately with the Black Friday exclusive models it is hard to tell what might be different. If I were to guess I'd say it would be similar to the KU6300/KU6290, but without someone going through a full review of the KU6270 specifically, it is only a guess. It's a good guess that some features have been removed from the KU6290 to create the KU6270, but I don't know what.
post #386 of 2407 Old 11-17-2016, 11:12 AM
Bond 007's Avatar
Liked: 2514
Youre using a soundbar?
Bond 007 is offline
post #387 of 2407 Old 11-17-2016, 02:39 PM
Quoted: 150 Post(s)
Liked: 78
This is funny because the 6290 was supposed to be the model without Bluetooth or the smart remote, but many of users have said the 6290 still comes with the smart remote (but no Bluetooth).
post #388 of 2407 Old 11-17-2016, 02:53 PM
Quoted: 27 Post(s)
Liked: 5
Has anyone been already able to watch Youtube in HDR?
Metsuki is offline
post #389 of 2407 Old 11-17-2016, 04:29 PM
Bond 007's Avatar
Liked: 2514
Anyone else update yet?
Any problems like Youtube that the other poster had?
Bond 007 is offline
post #390 of 2407 Old 11-17-2016, 04:31 PM
Bond 007's Avatar
Liked: 2514
Still having the problem?
Bond 007 is offline
Reply LCD Flat Panel Displays
