**OFFICIAL** Entry Level 2016 Samsung 4K UHD KU6300/6500/6600 Series TV Thread - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
post #2191 of 2437 Old 08-27-2017, 04:48 PM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
Originally Posted by JChin View Post
It display resolution and bitrate (speed) you are getting from Netflix stream. When it show 2160, my Backlight and Contract change to 20 and 100 respectively.
Do you have the same TV I do? What is your firmware version, if you do?
Edit - I have the Curved 6500 model.
Imagination will often carry us to worlds that never were. But without it we go nowhere.
Carl Sagan (1980)
jblank74 is offline
post #2192 of 2437 Old 08-27-2017, 04:58 PM
JChin's Avatar
Quoted: 477 Post(s)
Liked: 255
55KU6500 with firmware 1168.
JChin is offline
post #2193 of 2437 Old 08-27-2017, 05:13 PM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
I've got the MU6500, that might explain the difference in button function. Not sure of my firmware version, I bought the TV Thursday and tried an update but it said no newer version. On another board, someone mentioned an update was pulled so it could be I'm on an older version of firmware.
Carl Sagan (1980)
jblank74 is offline
post #2194 of 2437 Old 08-28-2017, 07:38 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
Interesting. I don't seem to have the ability to see that. Can you tell me what the current firmware version is on your set?
1180.5 is the newest update I have on my 6500.
steve1971 is offline
post #2195 of 2437 Old 08-28-2017, 03:30 PM
dr.ripco's Avatar
Liked: 1
Doesn't work. There's no info OR menu bar. Just numbers.
Maybe you are missing it, when you press the 123 button there should be a number bar that appears at the bottom.
The info is to the right of the blue D button and to the left of the 1 button. It's kind of faint and easy to miss. Just hit the left arrow key 6 times after you press the 123 key.
dr.ripco is offline
post #2196 of 2437 Old 08-28-2017, 03:53 PM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
My firmware version is 1123 and it says no current version is available.
Carl Sagan (1980)
jblank74 is offline
post #2197 of 2437 Old 08-28-2017, 03:58 PM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
No sir, it's not there. Please excuse the poor quality pictures.
Carl Sagan (1980)
jblank74 is offline
post #2198 of 2437 Old 08-28-2017, 07:01 PM
Glidedon's Avatar
Originally Posted by Subliminal87 View Post
So I have a 55ku6300 non curved tv.
I'd like to mount it on the wall. However, I have read alot, and am finding that some of the mounts don't come with the required M8 bolts.
For this tv, do I need M8 45mm bolts? or smaller? Reading online people are saying they had to buy bolts after the fact because the ones that come with any mount are too short. So I'd like to get everything ahead of time.
On amazon with different mounts they said they needed different ones, best buy was the same thing and people specifically stated they needed different bolts for their Samsung.
Now I did a chat with Samsung and got told I needed M8 15mm bolts. Which is the first time I have read that anywhere.
Any help would be great.
I bought my wall mount from monoprice and it came with the proper bolts.
Glidedon is offline
post #2199 of 2437 Old 08-29-2017, 09:25 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
You have the KU6500 curved right? And your firmware version is 1123? That's strange because the newest firmware version is 1180.5 which was just released last month. And your menu layout is different from my KU6500. And dr.ripco is right. When you push the 123 button you should see numbers at the bottom of the screen and at the very far left you should see some colored looking buttons. Red, Yellow, Green and Blue I believe.
post #2200 of 2437 Old 08-29-2017, 09:38 AM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
No, mine is the MU6500 curved.
This one. http://www.samsung.com/us/television...n55mu6500fxza/
Carl Sagan (1980)
jblank74 is offline
post #2201 of 2437 Old 08-29-2017, 09:54 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
Ahhh that explain's it. You have the newer model 6500 series and not the KU series. There was some things the KU6500 had that Samsung for some reason left off the MU series. That's why your menu look's different from mine and it's maybe why you dont see the colored looking buttons dr.ripco and I told you about. And it's also why your firmware is different from mine. I had the 55inch MU6500 and returned it due the bad flashlight bleed ect and went with the KU series instead and so far I have had zero issue with my tv. But since you have the MU6500 and not the KU6500 that may be the reason for not seeing what dr.ripco and I told you about.
post #2202 of 2437 Old 08-29-2017, 10:12 AM
jblank74's Avatar
Quoted: 42 Post(s)
Liked: 25
Oops, I'm sorry for the confusion. I do apologize for that. I guess I got my numbers mixed up and that's a shame because you folks have been very helpful and polite.
steve1971 and Lp85253 like this.
Carl Sagan (1980)
jblank74 is offline
post #2203 of 2437 Old 09-01-2017, 12:08 PM
gbynum's Avatar
Quoted: 104 Post(s)
Liked: 40
Audio/video timing over HDMI
KU6300 ... really 630D but that is unimportant.
Last night, my wife wanted to view a FaceBook video on the TV. I have an HDMI cable from my PC so ... "no problem", or so I thought. I've done video alone many times.
The video and audio have relative timing issues; I played with the audio delay setting; default was 80ms; I saw no difference between the 0-250ms range of settings.
The computer screen was visible; motion on the pc screen occurred before that on the tv; sync appeared correct on the pc, but I didn't play with it. On the TV, lips continued to move after sound stopped.
If I wasn't somewhat hard-of-hearing, this would not be a problem, but I seem to do a little lip reading to augment my hearing. It didn't bother our guests or my wife.
Primarily, does the delay setting work on a computer input? Second, is this sync issue correctable?
gbynum is offline
post #2204 of 2437 Old 09-03-2017, 07:17 PM
GnatGoSplat's Avatar
Is there a way to blank the screen while playing music using Youtube or Pandora? It can be done on all my Sharp (Hisense) and Vizio TVs. It can even be done on my 2015 model Samsung JU7100. I can't seem to find any option for it on this one.
Shawn
GnatGoSplat is offline
post #2205 of 2437 Old 09-04-2017, 04:07 AM
Bond 007's Avatar
Quoted: 3320 Post(s)
Liked: 2622
No
steve1971 likes this.
Bond 007 is online now
post #2206 of 2437 Old 09-05-2017, 04:10 AM
Quoted: 12 Post(s)
Liked: 5
Does KU6300 (KU60xx euro model) youtube app support HDR playback? In my KS series TV youtube app shows HDR label if it is playing HDR video but this KU60xx model does not..
Jogimus is offline
post #2207 of 2437 Old 09-05-2017, 04:20 AM
Bond 007's Avatar
Liked: 2622
Yes. And yes it does notify you if an HDR video is playing.
post #2208 of 2437 Old 09-06-2017, 12:49 AM
Quoted: 12 Post(s)
Liked: 5
Looks like youtube app updated as today HDR label appeared..?!?! (TV has been connected to wifi just since yesterday..)
Jogimus is offline
post #2209 of 2437 Old 09-09-2017, 06:07 PM
Liked: 0
I have the 55'' model. Dose this TV have a PiP (Picture in Picture) setting?
sjromeo is offline
post #2210 of 2437 Old 09-09-2017, 06:54 PM
Bond 007's Avatar
Liked: 2622
No
post #2211 of 2437 Old 09-12-2017, 01:06 AM
sagor's Avatar
Liked: 0
Someone please help me.
I have 55inch ku6000 which is similar to ku6300 only difference is lack of Bluetooth.
The tv is wall mounted & the usb port is not reachable that's why i connect usb extender on usb 1a (HDD) port.Pendrive is working fine.
But my 500 hdd doesn't show.Is my usb extender problem it or is there some sort of tricks to view my hdd.
This hdd perfectly shown on my sony w800c.
sagor is offline
post #2212 of 2437 Old 09-20-2017, 12:15 PM
Dagatassy's Avatar
Is it worth it to activate the UHD/HDR on this set for either cable tv or PS4 (non-Pro)?
Dagatassy is offline
post #2213 of 2437 Old 09-21-2017, 12:13 PM
action_jackson's Avatar
Quoted: 353 Post(s)
Liked: 135
I just picked up a 55 inch KU6290 for $299! It’s got a great picture and I can’t believe the price. I’m currently using it in the bedroom, but I may move this to the living room a use it to save wear on my projector bulbs.
I did a calibration with a color monkey from my PC and it really helped with the skin tones. Before it was slightly screwed towards blue. I need to figure out how to get the same results using the on screen adjustments though because it doesn’t effect any other sources.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is offline
post #2214 of 2437 Old 09-29-2017, 03:44 PM
pixelation's Avatar
Quoted: 25 Post(s)
I just hooked up my Wii to my 65" KU6290 using component cable. The image quality is not good. Very soft (I know it is 480p but it is just too soft) and color looks washed out (should not be caused by resolution). Have anyone tried 480p playback on KU6300/KU6290 can comment on the quality?
pixelation is offline
post #2215 of 2437 Old 09-30-2017, 07:23 AM
jra2k1's Avatar
Quoted: 68 Post(s)
Liked: 33
I think 720p from my cable provider looks mediocre in 65” but I felt the same way when I got my first 50” HDTV in 2008 and played back 480p cable tv shows. It looked horrifying! Lol!
You could increase the sharpness and or use dynamic picture mode but it really isn’t going to improve it much. The problem too is the bigger the tv you get the worse any lower quality feed is gonna look.
jra2k1 is offline
post #2216 of 2437 Old 10-01-2017, 08:01 AM
jra2k1's Avatar
Quoted: 68 Post(s)
Liked: 33
Now mind you I should say the further you sit back the better it is or the less you notice the lack of resolution, compression artifacts and other flaws in cable tv.
jra2k1 is offline
post #2217 of 2437 Old 10-01-2017, 08:28 PM
JChin's Avatar
Quoted: 477 Post(s)
Liked: 255
Did KU6300/6500 get HDR10 Plus support through a firmware update yet? If so, any detail how to tell if the set has it? And what titles on Amazon Prime Video are HDR10 Plus?
JChin is offline
post #2218 of 2437 Old 10-01-2017, 09:09 PM
pixelation's Avatar
Quoted: 25 Post(s)
I still think that the 480p quality is worse than it should. FWIW, I read the review from rtings on the KU6300 and upscaling is one of the feature that I was looking for because I was planning on hooking up some of my old consoles.
post #2219 of 2437 Old 10-02-2017, 02:40 AM
Bond 007's Avatar
Liked: 2622
From my understanding 6300/6500 are not and never will be HDR10. What makes you think different?
joe221 likes this.
post #2220 of 2437 Old 10-02-2017, 09:02 AM
JChin's Avatar
Quoted: 477 Post(s)
Liked: 255
Hi Bond 007, agree but wasn't sure after reading this.
All of Samsung’s 2017 UHD TVs, including its premium QLED TV lineup, support HDR10+. In the second half of this year, Samsung’s 2016 UHD TVs will gain HDR10+ support through a firmware update.
JChin is offline
Reply LCD Flat Panel Displays
KU6300/6500/6600
