**OFFICIAL** Entry Level 2016 Samsung 4K UHD KU6300/6500/6600 Series TV Thread - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 388Likes
post #2401 of 2409 Old 04-12-2019, 05:53 PM
foghorn2's Avatar
Quoted: 147 Post(s)
Liked: 243
A word of caution on the latest firmwares. My set updated itself to ver 1231 months ago and starting having issues with HDMI CEC with my Onkyo receiver.
After shutting the TV off it would shut off the receiver. and then within a minute the receiver would turn itself on with the TV still off.
If I removed the network cable, this would go away. I even put a magnetic shield on the HDMI and Ethernet cable and still same issue. I reset the receiver and TV to factory and still same problem.
This started with the autoupdate to 1231. If I checked for new updates with this firmware, it would say it had the latest update already.
On the support site theres a newer update: ver 1232.4 released late last month. I updated it using the USB method and the problem went away.
The flockers over at Samsung are screwing things up big time! My recommendation is to stop the auto updates if everything is working fine the way it is.
foghorn2 is offline
post #2402 of 2409 Old 05-08-2019, 01:51 PM
Bond 007's Avatar
Quoted: 3246 Post(s)
Liked: 2551
My set just updated itself to 1233.
Bond 007 is offline
post #2403 of 2409 Old 05-08-2019, 05:32 PM
foghorn2's Avatar
Quoted: 147 Post(s)
Liked: 243
I set it to not autoupdate and it did it anyway, go figure!
foghorn2 is offline
post #2404 of 2409 Old 05-08-2019, 05:59 PM
Bond 007's Avatar
Liked: 2551
Same here.
Bond 007 is offline
post #2405 of 2409 Old 05-13-2019, 01:34 PM
Bill Broderick's Avatar
Quoted: 18 Post(s)
The new firmware appears to have solved the problem with both of my sets reverting back to the TV source every time that it's turned on, rather than saving and returning to the last app (or source) that it was set to when the TV was previously turned off.
Bill Broderick is offline
post #2406 of 2409 Old 05-24-2019, 05:20 PM
Bond 007's Avatar
Liked: 2551
Anyone else having major problems with YouTube?
Bond 007 is offline
post #2407 of 2409 Old 05-29-2019, 01:18 AM
NeoandGeo's Avatar
What kind of problems? The Youtube app is probably nearing EOL and will more than likely stop working altogether for no reason other than to persuade an upgrade.
NeoandGeo is offline
post #2408 of 2409 Old 07-10-2019, 03:18 AM
Bond 007's Avatar
Liked: 2551
Just got software version 1240 on my tv.
Bond 007 is offline
post #2409 of 2409 Old 07-14-2019, 12:57 PM
GordonT's Avatar
How do I free up memory on this TV?
I have the UN55MU6300. Today, I was trying to install a new app which uses about 18 MB of memory. I received an indication that there was no free memory available. Specifically, when I go to the Settings menu in the Apps page for the TV, it says that 816.8 MB are in use and that 0MB are free.
I then proceeded to delete 2 apps that each use several MB. The used/free spece numbers did not change! I tried exiting the Apps page and going back. Still no change.
How do I free up memory?
GordonT is offline
Reply LCD Flat Panel Displays
