OFFICIAL Sony XBR-65Z9D Owner's Thread [no price talk please] - Page 723 - AVS Forum | Home Theater Discussions And Reviews
 54440Likes
post #21661 of 21784 Old 07-16-2019, 07:46 AM
petetherock's Avatar
Quoted: 1694 Post(s)
Liked: 890
Originally Posted by pbz06 View Post
Yes, that's how it works unfortunately. Sorry I wasn't able to respond to your earlier question.
The Z9D (I think all the other Sony's are the same) remember the settings per HDMI input on the TV, so if you have all your sources coming in from a receiver/soundbar and go into HDMI 3 ARC, for example, then it will use the Preset you had last selected (i.e. Cinema Home). And then the Cinema Home uses mostly the same subsettings whether it's HDR or SDR. The only ones that it remembers and changes between HDR and SDR are Xtended Dynamic Range (high for HDR, preference for SDR), Gamma (0 for HDR, -1 or -2 for SDR), and the backlight (Max for HDR, preference for SDR).
I am under the impression that if you calibrate for SDR (or maybe HDR first), then you wouldn't need to make any other changes since they track similar.
I had someone who was doing a favor - visiting me in my humble den and this is a industry pro, and she did some very detailed settings, with changes to the REC, gamma and advanced color adjustments, so many of these did not track between SDR and HDR. She also made some changes for DV.
I guess I had to stick to using two inputs - HDMI 2 for SDR and HDMI 3 (with ARC) for HDR & DV. But the money spent on the calibration is worth it. Even for the sheer geek factor, I was very impressed. Imagine a female Vincent Teoh doing his pro thing in your home for the better part of a Saturday...
petetherock is offline
post #21662 of 21784 Old 07-16-2019, 07:59 AM
pbz06's Avatar
Quoted: 982 Post(s)
Liked: 822
On my next TV, I will calibrate
It would be interesting to see what the differences were in the major settings for each of DV, HDR10, and SDR (i.e. Contrast) and if she used Home/Pro/Custom.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is offline
post #21663 of 21784 Old 07-16-2019, 09:34 AM
kee68's Avatar
Quoted: 31 Post(s)
Liked: 25
I found something about the Z9D from this site:
https://www.hdtvtest.co.uk/news/kd65...1610164372.htm
If Vincent Teoh (the ultimate pro calibrator) noticed it, then there's nothing I can do I guess..
"Our Sony KD65ZD9BU review sample presented a few quirks for calibration. First, many of the settings including [Colour] and [Adv. colour temperature] are shared between SDR, HDR and 3D modes within the same picture preset on the same HDMI port. This means that if you use a single source player (for example the Panasonic UB900) to watch regular Blu-ray, 4K BD and 3D Blu-rays on the Z9D, you’d have to manually switch to different (calibrated) picture presets if you’d like to experience the best image quality from each format."
So you do need to use two inputs for the best settings for SDR and HDR... odd quirk...
I have the same issue but I don't have enough hours to pay for a pro cal. I bought one of the last ones on Walmart.com from DELL.com. I would never trust them again (DELL that is) but I don't want to go off topic. If I understand this I have to have a SDR picture on a picture preset and use the settings from 10Kand then have a HDR movie or a streamed picture on the same preset and do the same as SDR?
Any help would be greatly appreciated. Bob
kee68 is offline
post #21664 of 21784 Old 07-16-2019, 10:36 AM
10k
10k's Avatar
Quoted: 2143 Post(s)
Liked: 2379
"Our Sony KD65ZD9BU review sample presented a few quirks for calibration. First, many of the settings including [Colour] and [Adv. colour temperature] are shared between SDR, HDR and 3D modes within the same picture preset on the same HDMI port. This means that if you use a single source player (for example the Panasonic UB900) to watch regular Blu-ray, 4K BD and 3D Blu-rays on the Z9D, you’️d have to manually switch to different (calibrated) picture presets if you’️d like to experience the best image quality from each format."
although the settings are shared for white balance between sdr and her, the tv has an internal offset matrix which gives the correct picture in each mode.
This is regardless of whether white balance was calibrated in sdr or hdr, I did it both ways and got basically the same result. As a matter of convenience I started with sdr and then confirmed hdr.
I never investigated 3D since I don’t use this feature but I wouldn’t be surprised if it required a different input/set of settings as the impact of the glasses cannot be known by the tv.
10k is offline
post #21665 of 21784 Old 07-16-2019, 11:18 AM
mutelight's Avatar
Quoted: 2210 Post(s)
Liked: 2495
Yup! The way the Z9D handles this is actually vastly preferable IMO and saved a lot of time when I had it and my A1E calibrated. Dial everything in with a SDR signal then some quick "fact checking" sending and HDR signal and you're good to go.
mutelight is offline
post #21666 of 21784 Old 07-16-2019, 11:26 AM
10k
10k's Avatar
Liked: 2379
yea exactly, pretty much the only thing to do in hdr is dial in contrast for desired tone mapping 👍
10k is offline
post #21667 of 21784 Old 07-16-2019, 02:04 PM
Liked: 890
I used to do that, but the settings were different enough that I could discern that the color was off and using two inputs was easier than pressing at least a dozen buttons.
I could see the calibration pro getting a good workout
post #21668 of 21784 Old 07-16-2019, 02:47 PM
mutelight's Avatar
Liked: 2495
Then there is something wrong with your set or eyes because there should not be a difference and the pro that did my TVs verified it with his Klein K10-A.
10k likes this.
post #21669 of 21784 Old 07-16-2019, 08:29 PM
Liked: 890
Err...
You mean you cannot tell the different in colors and brightness between SDR and HDR? Then I'm afraid you are the one who needs to visit the optometrist mate...
The settings were quite different, and anyone can see them very easily. I had four friends with me who saw the differences instantly.
post #21670 of 21784 Old 07-16-2019, 08:44 PM
mutelight's Avatar
Liked: 2495
Err...
Uhm... I can tell the difference in colors and brightness because HDR brings wide color gamut (more color data) and a larger range in luminance or high dynamic range. That is by design, the advantage to the tech/format, and the whole point of HDR, brother.
If they are seeing the difference in SDR content vs HDR, that means you have a great HDR capable set, congrats!
The average dE with both SDR and HDR signals on my Z9D is .4dE for grayscale and .5dE for color. There was no drift between a SDR nor HDR signal under a very high end colorimeter sending native SDR and HDR signals and measuring. The Z9D scales wonderfully from a SDR calibration to HDR.
post #21671 of 21784 Old 07-16-2019, 10:32 PM
Liked: 890
Cheers mate
When I have a minute or two, I'll post about the marathon session.. I'm a geek, so it was very interesting watching the pros work..
post #21672 of 21784 Old 07-17-2019, 01:01 AM
Quoted: 282 Post(s)
Liked: 92
Page 9 of this document illustrates how Sony calibration parameters are organised.
http://sonyglobal.akamaized.net/is/c...AN-updated.pdf
White balance settings are related only to color temperature mode and independent from input or picture mode.
10k, mutelight and shark91962 like this.
priitv8 is offline
post #21673 of 21784 Old 07-18-2019, 07:46 AM
BLMN's Avatar
Quoted: 48 Post(s)
It’s about time the Oreo update was available last night. So far so good, no issues.
Living Room: Mitsubishi WD82738 1080p 3D, Onkyo HT-9400 THX 7.1, Oppo DV-980H, Sony BDP-S6500 (Multi Region), Roku 2 XS
Bedroom: Sony XBR-65-850E 4K, PS4 launch edition, Sony UBP-X800
Basement: Sony XBR-75-Z9D 4K 3D, Marantz SR-8012 11.2, B&W 7.1 set, KEF Q50AB, Marantz TT-15S1, CA CXUHD, PS4 Pro, PSVR Bundle, PS3 60GB 1st gen.
BLMN is offline
post #21674 of 21784 Old 07-18-2019, 08:05 AM
Stereodude's Avatar
Quoted: 4284 Post(s)
Liked: 3006
Does the Prime Video app on the Z9D support Dolby Vision?
Stereodude is offline
post #21675 of 21784 Old 07-18-2019, 01:20 PM
rlb
rlb's Avatar
Quoted: 2250 Post(s)
Liked: 1900
Yes. However, there aren't very many. One good example is their original Tom Clancey's Jack Ryan.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #21676 of 21784 Old 07-18-2019, 02:46 PM
Stereodude's Avatar
Liked: 3006
But no Atmos...
post #21677 of 21784 Old 07-18-2019, 04:10 PM
chi_guy50's Avatar
Quoted: 2195 Post(s)
Liked: 2248
But no Atmos...
And a cheesy script.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #21678 of 21784 Old 07-18-2019, 05:16 PM
Stereodude's Avatar
Liked: 3006
I meant the Z9D app doesn't support Atmos. Tom Clancy's Jack Ryan does have Atmos.
I enjoyed the show.
post #21679 of 21784 Old 07-18-2019, 06:56 PM
chi_guy50's Avatar
Liked: 2248
I enjoyed the show.
I'm glad you enjoyed it, and I'm sure you're not alone. But . . . the writing is trite and hokey. I wanted to like this series for the video and audio quality alone, but I couldn't make it past the first two episodes due to the stereotypically inauthentic story line, affected acting, and clumsy directing.
Full disclosure: I'm both a cinephile and a retired military intelligence professional, so maybe I'm more sensitive to these things than the average viewer.
shark91962 likes this.
post #21680 of 21784 Old 07-19-2019, 04:17 AM
Liked: 890
+1 on the plot, the hobby and the past ... I enjoy it when the chaps in Hollywood get it right, and cringe when they wing it...
chi_guy50 likes this.
post #21681 of 21784 Old 07-19-2019, 05:21 AM
chi_guy50's Avatar
Liked: 2248
Well, in all fairness, we're not talking about documentaries here or even an honest attempt to create a realistic portrayal of the craft. These are entertainment vehicles designed to attract a wide audience (and/or to sell a franchise).
But I was nonetheless very disappointed in the mundane nature of Amazon's feeble Jack Ryan, having expected more.
As an illustration and just for contrast, one of my favorite spy movies of all time based on cinematic excellence combined with a sense of authenticity is The Spy Who Came In From the Cold (1965) (Richard Burton and Martin Ritt team up to bring David John Moore Cornwell (John le Carré)'s cold war masterpiece to life).
Some other titles, in no particular order are: The Conversation (1974), Tinker, Tailor, Soldier, Spy (2011), Ronin (1998), and The Tailor of Panama (2001). Not to mention, just for the sheer fun of it, North By Northwest (1959) and From Russia With Love (1963) (both plots are outrageously silly, but what grand entertainment and exceptional movie-making!).
post #21682 of 21784 Old 07-19-2019, 08:04 AM
pbz06's Avatar
Quoted: 982 Post(s)
Liked: 822
As an illustration and just for contrast, one of my favorite spy movies of all time based on cinematic excellence combined with a sense of authenticity is The Spy Who Came In From the Cold (1965) (Richard Burton and Martin Ritt team up to bring John Carré's cold war masterpiece to life).
Tailor of Panama and Tinker, Tailor, Soldier, Spy are 2 of my favorite sleepers of all time! Ronin too of course, but that one was more mainstream. TTSS got me into John le Carré and I've enjoyed every movie based off his books.
p.s.- I enjoyed Jack Ryan because it's still good entertainment for weeknight to plow through shows with the wife. It had good pace and production values. And at least it seemed like he held his gun correctly, which most shows do not portray it accurately I just can't stand hollywood touches like making the wife more "pretty" and Americanized for us to relate to. Oh, and look at that cute kid kicking the soccer ball around so gently!
pbz06 is offline
post #21683 of 21784 Old 07-19-2019, 10:19 AM
chi_guy50's Avatar
Liked: 2248
If you enjoyed those two, and you missed The Conversation, then you owe it to yourself to check out this last film. Written and directed by Francis Ford Coppola and starring a maniacally intense Gene Hackman, this masterpiece expertly captures the paranoia (not to mention the mind-numbing tedium) involved in genuine intelligence and security work.
And for some illuminating reading on the subject of (counter)espionage, I recommend David Wise's excellent Molehunt: The Secret Search for Traitors That Shattered the CIA (and his subsequent Nightmover: How Aldrich Ames Sold the CIA to the KGB for $4.6 Million). Both books accurately (IMHO) portray the sometimes inept and self-defeating nature of our intelligence services in a way that Hollywood blockbusters never will. In point of fact, the greatest intelligence successes and most disastrous failures seldom come to light.
pbz06 likes this.
post #21684 of 21784 Old 07-21-2019, 03:54 AM
TomcatTLC's Avatar
Quoted: 467 Post(s)
Liked: 665
WTF (Frick) ! In CT. and still waiting ………….
Sony 75Z9D, Yamaha 3060, Oppo 203, Oppo 103D, LG 65E7P, Sony UBP-X800
TomcatTLC is offline
post #21685 of 21784 Old 07-21-2019, 07:15 PM
BLMN's Avatar
Quoted: 48 Post(s)
It’️s about time the Oreo update was available last night. So far so good, no issues.
WTF (Frick) ! In CT. and still waiting ………â€&#16 6;. [IMG class=inlineimg]/forum/images/smilies/rolleyes.gif[/IMG] [IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
It took months to show up on my Z9D. I had this update on my 850E since February.
BLMN is offline
post #21686 of 21784 Old 07-22-2019, 01:06 PM
Stereodude's Avatar
Liked: 3006
The Oreo update showed up on mine last week. The TV basically seems the same (I'm not using any of the "smart" functionality).
post #21687 of 21784 Old 07-22-2019, 03:11 PM
bwillcox's Avatar
Quoted: 869 Post(s)
Liked: 497
Same here, I haven't noticed any changes. But then, like you (I suspect) I just use my TVs as monitors.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is online now
post #21688 of 21784 Old 07-22-2019, 09:55 PM
Craig Mecak's Avatar
Quoted: 321 Post(s)
Liked: 248
I mainly use mine as a monitor too.
The only thing I've noticed is that they look to have fixed the raised black levels when replaying Dolby Vision content via HDMI. I used to have to reduce my Black Level when watching DV to around 47. Now I can leave it on the nominal 50.
But DV content is still dimmer than the same content playing as HDR10. They didn't fix that. Very little 'pop' in comparison. Pity.
I've now abandoned DV on this set and changed all my replay devices back to HDR10. The 'pop' and specular highlights which are a hallmark of this 1800 nit set have returned.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is offline
post #21689 of 21784 Old 07-23-2019, 05:26 AM
Quoted: 440 Post(s)
Liked: 123
Hi guys. I'm transporting my tv cross country today. Anyone have the best method for cleaning the 65 z9d? Audioquestz monster or just a microfiber. Seems like the microber by itself is not doing much. Thanks in advance.
MLM87 is online now
post #21690 of 21784 Old 07-23-2019, 10:05 AM
Quoted: 440 Post(s)
Liked: 123
Hi guys. The movers just came to pick up my tv. Does this look okay? They didn't use the clips and I'm a little paranoid. They used tape instead. I attached a photo of the clips.
ID:	2593680   Click image for larger version
MLM87 is online now
Reply LCD Flat Panel Displays
sony xbr-75z9d , XBR-65Z9D , xbr-940d
