Vizio TV or Display Owner's Firmware 2.2.7.4 Issues and Concerns - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By CleCakYngMfd
post #1 of 29 Old 10-26-2016, 04:49 PM - Thread Starter
CleCakYngMfd's Avatar
Quoted: 2054 Post(s)
Liked: 726
Notice: All Beta and Wide Release Firmware discussions
for older and current Firmware now take place here:
Beta Bug / General Firmware Release Discussion
Message Thread.
Please do not post here anymore
and
Do not Add Serial Number Requests here.
Use the above location from now on.
The above link will instruct how to get on
the Beta/Early Firmware Release List.
This '2274' Message Thread at some point will be
Locked or Deleted.
____________________________________________
Special Notice:
Vizio released another Short-Term,
Beta Firmware for the 2016 P-Series and M-Series.
Jump there now, to this Message Post.
If you never posted your Serial Number
to Matt McRae, see This Post over in the 3.0.6.4 Thread.
Hi All Vizio Owners,
with Firmware
2.2.7.4
For Your Vizio Model TV or Display:
P50-C1,
P55-C1,
P65-C1,
P75-C1.
M50-D1, M50-E1,
M55-D0, M55-E0,
M60-D1,
M65-D0, M65-E0,
M70-D3, M70-E3,
M75-E1,
M80-D3.
E40-E0, E43-E2, E43u-D2, E48u-D0,
E50-E1, E50-E3, E50u-D2, E50x-E1,
E55-E1, E55-E2, E55u-D0, E55u-D2,
E60-E3, E60u-D3,
E65-E0, E65-E1, E65-E3, E65u-D3,
E70-E3, E70u-D3,
E75-E1, E75-E3,
E80-E3, E80u-D3.
This will be a time-sensitive Message Thread per Firmware release.
There will be some overlap whenever Vizio releases a new Firmware,
so there will be a mix of owners on the older and new Firmware.
I'll then start a new Message Thread for any new Firmware release.
Over the few weeks when most owners will be off of the older, previous
Firmware, that Message Thread should not continue with posts.
Please jump-in to post any concerns with this latest firmware.
Please, only post if you are an owner or the main caretaker of a Vizio
TV or Display with the above-mention Firmware number.
If posting or replying about an issue, please post your Model Series
as listed in this post.
This first post here may be edited in the future with updated info,
so perhaps you may wish to bookmark it.
Thank you.
Vizio's 2.2.7.4 Firmware Page for Your Model (Does not include the Special Beta 3.0.6.4).
Main Concerns That I'm Aware of:
a) Motion Issues*.
b) Scene Flashing.
c) ALZ 'Pulsing' being reported by some owners.
@Matt McRae
* Motion Issue Update Oct 28, 2016
By Casting a YouTube Judder Test Video, I notice that Judder 10 is the same as either 1 or perhaps 0. The maximum Reduce Judder is setting is therefore 9, at least with my P50-C1.
The higher the Reduce Judder setting, the more video tearing/distortion/missing parts of fast moving objects, from what I see in this Judder Test Video. A setting of 1 or 2 is best. A compromise setting of 4 is another choice. The setting of 0 has the shakiest and finer image-trailing type artifacts.
Whenever the Motion/Judder problem shows up, and if GLL On is used, even though Reduce Judder slider is grayed-out, it is still active with it's last setting value, which can be changed by tapping in between the slider and its value setting.
Clear Action: If using this feature, it's probably for gaming and sports, but to me, it's ugly for series and movie watching. Using this for shows/movies only exaggerates the multi-ghost-like trailing of people and all other fast-moving objects.
I did not get around to further investigate the on-again/off-again Judder/Motion Issue last night. Next week.
YouTube Judder and other Test/Calibration Videos links for Casting, to be added soon.
From Vizio's Firmware Information Page:
This article applies to the VIZIO SmartCast Home Theater Displays and SmartCast HDTVs and is intended to help you understand how to get the most current version of your Home Theater Display or HDTV's Firmware. This article currently applies to the below models:
P50-C1,
P55-C1,
P65-C1,
P75-C1.
M50-D1,
M50-E1,
M55-D0,
M55-E0,
M60-D1,
M65-D0,
M65-E0,
M70-D3,
M70-E3,
M75-E1,
M80-D3.
E40-E0,
E43-E2,
E43u-D2,
E48u-D0,
E50-E1,
E50-E3,
E50u-D2,
E50x-E1,
E55-E1,
E55-E2,
E55u-D0,
E55u-D2,
E60-E3,
E60u-D3,
E65-E0,
E65-E1,
E65-E3,
E65u-D3,
E70-E3,
E70u-D3,
E75-E1,
E75-E3,
E80-E3,
E80u-D3.
Current Firmware Version: 2.2.7.4
Release Notes:
  • Improvements on HDR10 picture quality
  • Fix for "green tint" issue on PlayStation 4 when in Deep Color
  • Fixed pairing issue with iPhone 7
  • Fixed more instances of split screen
  • Fixed instances of stuttering or frame drops
  • Sharpness setting fixed (doesn't revert)
  • Clear Action scanning improvements for 60Hz
  • 40IRE adjustment fixed in Calibrated Dark
  • Fixes for ARC and dropped audio
  • Wake on CAST improvements
  • Fixes for freezing seen in Hulu app
  • Improvements in OOBE and pairing during setup
  • General stability and PQ improvements across the system
More on How to install current and future Firmware Releases by WiFi or USB Thumb Drive.
Courtesy From Jasonn_B (Has a Special High-Level Vizio Contact):
Upcoming Firmware (Nov or Dec) 2.6.2?
New:
  • 4k and HEVC on capable devices with built-in Chromecast support (2016 Vizio TVs and the Nvidia Shield)
Fixes:
  • Massively improved start up time, which should fix occasional timeouts when casting from Chrome.
  • Fixed issues with Watch Later and Recommended videos.
  • Fixed performance issue after the post-play timer is displayed multiple times.
- PjThis is The End-Age GenerationTime is Running OutQuakes, Sinkholes, Meteors
EvilutionMankind Was CreatedWe Didn't Come From ApesThere Was a Worldwide Flood!
The End of This Age is Near!I'm Ready For The Rapture!Are You Ready?The Time is Now!
Last edited by CleCakYngMfd; 02-05-2017 at 01:39 AM. Reason: Added More Stuff... And Yet More Stuff. Getting Stuffy Around Here :D&=;
CleCakYngMfd is offline
post #2 of 29 Old 10-26-2016, 05:58 PM
Kadath's Avatar
Quoted: 568 Post(s)
Liked: 340
My tablet just rebooted, I am assuming new firmware. No black flashes on PS4 so far, will keep an eye out for them
Buncha savages in this town.... - Clerks
Sam Posten
Kadath is offline
post #3 of 29 Old 10-26-2016, 07:03 PM - Thread Starter
Liked: 726
No black flashes on PS4 so far, will keep an eye out for them.
Not really. My Tabby had been rebooting almost daily a bit ago, but in recent weeks, the reboot frequency has slowed down. Reboots don't necessarily mean new Firmware.
There's probably new Firmware coming from Vizio in November. However, I don't think it addresses any of the issues I mentioned in the first post.
Kadath likes this.
post #4 of 29 Old 10-26-2016, 07:05 PM
Quoted: 845 Post(s)
Liked: 364
Definitely motion blur on my P50-C1. Not sure when it started, but seems to be worst with the latest firmware update.
65JS8500, P50-C1, K8500, SB3851 Soundbar, Nvidia Shield, PS4
buju22 is offline
post #5 of 29 Old 10-27-2016, 06:30 AM
jtrosky's Avatar
Quoted: 857 Post(s)
Liked: 402
Definitely noticed motion-related issues on my M70-D3 as well. Not on all content though. Some shows have severe motion issues during the ENTIRE show, some shows exhibit motion-related issues just during certain parts and yet other shows don't exhibit any motion-related issues.
In the M-Series thread, I posted about "jerkier" motion immediately after the 2.2.7.4 firmware update. At the time, I had only owned by M70 for a week or 2 and was still keeping a close eye on things - and like I said I noticed the difference immediately - in general, things just weren't as smooth as they were before the update.
I made some videos of 2 shows that I *really* notice motion issues - during the entire show (Gold Rush and The Wire). However, I did not watch these shows before the firmware update, so I can't say for sure if these particular shows had such bad motion before the update or not - but I definitely never had these motion issues on other TVs.
Actually, in a little bit, I'll test the same shows on a few different LCD TV's in the house - but I never had any motion issues like this on the 55" Vizio M3D550SL set that was my main TV before upgrading to the 70" M70-D3. I still have that 55" Vizio (and it still works perfectly), so I'll test the exact same content on that TV (and at least one other LCD TV) a little later today.
What's really interesting is that when I cast the same episode of The Wire via the HBO Go application, I have no motion issues. However, I get a Vertical Frequency of 60 when watching via my Verizon FIOS On-Demand (where I do get the motion issues) and I get a Vertical Frequency of 30 when casting it via the HBO Go application. Not sure if that it just a coincidence or if it's meaningful to this problem.
Will post a follow-up later today after I test the same content on other LCD TV's in the house...
@CleCakYngMfd - thank you for starting this thread after my input was apparently not wanted in the P-Series thread. Never been on a forum where only owners of a certain device were allowed to post in certain threads... Very "close minded", in my opinion. I can understand not wanting owners of other sets to come to the thread saying "your TV sucks, my TV is awesome", but that is obviously not the case for all non-owner posts!
Sent from my HP SlateBook 10 x2 PC using Tapatalk
jtrosky is online now
post #6 of 29 Old 10-27-2016, 01:59 PM
jtrosky's Avatar
Quoted: 857 Post(s)
Liked: 402
Well, I had my M70-D3 exchange delivered today and while I haven't had any time to watch anything on it yet, I noticed right away that it's at firmware level 1.1.12.2 - sounds pretty old... So before I turn it off and let it update the firmware, I'll make sure to test some of the same content that I had issues with before the exchange, on firmware 2.2.7.4.
Will report my findings....
post #7 of 29 Old 10-27-2016, 04:36 PM
jtrosky's Avatar
Quoted: 857 Post(s)
Liked: 402
FYI - even on this old firmware (1.1.12.2), both The Wire and Gold Rush still look horrible from a motion aspect (when played via cable).
I think that I've decided to just return the M70-D3 for a refund and go with something else - the exchange unit still has the banding-while-panning issue and I just can't accept that. I think Ill be trying a Samsung KS-8000 next (I want an edge-lit display since they don't seem to have he banding issue in my experience). I'll gladly trade the deep blacks for no banding.
post #8 of 29 Old 10-27-2016, 08:21 PM - Thread Starter
Liked: 726
Originally Posted by jtrosky View Post
CleCakYngMfd - Thank you for starting this thread after
Hi again, JT.
Look at it this way. I imagine, especially with this HUGE Thread, that one or more complained to the Moderator of lots of posts who may have been 'shopping' and some to 'rag' on about the Displays. I can see where a person may want to purchase, and it's quite inviting to inquiry an Owner's Thread for info, but I can see why it should be just for Owners, also.
I assume there are other Message Threads for potential owners or someone can start one if none exist. (Check first for any existing Thread.)
Please don't feel slighted, as some forums out there in InterNut Land are more relaxed and run the forums their own way and here things need to be run tighter, as this AVS Forum is HUGE with a KaBoomGillion posts.
I would like to have the Forum software setup for sub-Threads, where under this main 2016 P-Series Thread for example, would be other Threads, like for Gamers, PC Gamers, Shoppers, Streamers, TV-Tuners, etc. Or it could be a select choice like a Forum Settings, where you click which the above categories you want including in the main Thread, thus all those posts show up. If you didn't click on Gamers and Shoppers, these posts won't show up in the Thread according to your preferences. Don't pay any attention... It was just me thinking.
Oh, I date-upped the first post with Vizio's Firmware and Model Info.
post #9 of 29 Old 10-28-2016, 06:27 AM - Thread Starter
Liked: 726
New Updated Info in
Message Post 1.
post #10 of 29 Old 10-28-2016, 06:37 AM
jtrosky's Avatar
Quoted: 857 Post(s)
Liked: 402
I noticed that the M70-D3 wasn't listed in the list of sets that this firmware applies to. I did get 2.2.7.4 on my M70-D3.... Just an FYI in case it was missed.
post #11 of 29 Old 10-28-2016, 07:05 AM - Thread Starter
Liked: 726
List of Models with Firmware 2.2.7.4
List Corrected.
post #12 of 29 Old 10-28-2016, 07:33 AM
jtrosky's Avatar
Quoted: 857 Post(s)
Liked: 402
It's interesting... I just went to the firmware page for the M70-D3 (still version 2.2.7.4), and here are the models that it applies to (which are completely different from the models you have listed):
This article applies to the VIZIO SmartCast Home Theater Displays and SmartCast HDTVs and is intended to help you understand how to get the most current version of your Home Theater Display or HDTV's Firmware. This article currently applies to the below models.
E50-E3
E60-E3
E60u-D3
E65-E3
E65u-D3
E70-E3
E70u-D3
E75-E3
E80-E3
E80u-D3
M70-D3
M70-E3
M80-D3
Release Notes:
Fix for "green tint" issue on Playstation 4 when in Deep Color
Apparently, there is different firmware for different sets within the same "series"??? Not really sure...
These are all -D3/-E3 sets - which I *thought* were the 2016 Series 4k sets? I'm confused now! :-) Also, this firmware doesn't include any P?? models!
post #13 of 29 Old 10-28-2016, 08:40 AM
DJ Lushious's Avatar
Quoted: 328 Post(s)
Liked: 117
I'd like to chime in on the motion issues. I see it most flagrantly in Overwatch on the PS4. It's a double-image effect and it's ugly. It's akin to the issues that cropped up when the P-Series first came out.
One step forward, two steps back...
DJ Lushious is offline
post #14 of 29 Old 10-28-2016, 03:52 PM - Thread Starter
Liked: 726
I just went to the firmware page for the M70-D3...
I updated the Model List.
It's strange, because when entering a Model, it spits-out the Model you have and bunch of others, though not all. I did a search on the Firmware Number, and supposedly, all Models involved are then listed.
post #15 of 29 Old 10-28-2016, 09:16 PM
hwalker84's Avatar
Wait 2.6.2 doesn't fix the HDR10 on Xbox One S gaming? I still don't see anything related to HDMI-ARC audio lag? Is this just never going to be fixed?
hwalker84 is offline
post #16 of 29 Old 10-28-2016, 10:04 PM - Thread Starter
Liked: 726
Originally Posted by hwalker84 View Post
Wait, 2.6.2 doesn't fix the HDR10 on Xbox One S gaming?
My guess is, I don't think the posted 2.6.2 Firmware List is a complete list of everything.
This is Matt's Tweet on Oct 24th:
"Update on Xbox firmware... in house and working.
Team is doing regression testing and PQ/performance tuning.
Will keep updating you.
Looks to be 2-to-4 weeks, maybe a bit quicker. Matt will post an update on
how it's going next week or weekend.
post #17 of 29 Old 10-28-2016, 10:14 PM - Thread Starter
Liked: 726
How does it look if Reduce Noise/Block are both OFF, GLL OFF, Clear Action is OFF, and Judder is 1?
I don't have Motion Blur, so if you do, you may want to tinker with that.
post #18 of 29 Old 11-01-2016, 02:29 PM
Liked: 0
Someone needs to reach out to this high-level contact at Vizio and have them put some work into getting CEC to work properly. Doesn't work with my Apple TV 4.
acascianelli is offline
post #19 of 29 Old 11-15-2016, 05:26 PM - Thread Starter
Liked: 726
post #20 of 29 Old 11-17-2016, 10:31 AM
ffactoryxx's Avatar
Quoted: 543 Post(s)
Liked: 91
Is Vizio able to update the firmware for Auto HDR detect similar to the Samsung models so you don't need to turn on subsampling?
ffactoryxx is offline
post #21 of 29 Old 11-19-2016, 07:13 AM
Liked: 0
Did this update enable hdr10 on the e43u-d2?
Sent from my ZTE ZMAX PRO. Still can't believe this phone only cost $99.
k28king1 is offline
post #22 of 29 Old 11-19-2016, 01:44 PM - Thread Starter
Liked: 726
The 2274 Firmware has an improvement for HDR-10. It's already there for HDMI devices. I think HDR-10 comes later for non-HDMI streaming.
post #23 of 29 Old 11-27-2016, 12:25 PM
Liked: 0
M55-D0 has left side if image cut off alert 2.2.7.4 update
My M55-D0 has just been updated automatically to firmware 2.2.7.4. After the update the left edge of the image is cut off by about 2". It does this on all sources including Cast if the Picture Mode is set to Calibrated or Calibrated Dark. Any other Picture Mode it is not cut off. I called Vizio Support and they are sending me new set. While support has been great this is will be the fourth M55-D0 I have had since I purchased early this September. The first two were bad right out of the box(brand new not open box) from Best Buy. This current one has been working perfectly for the last two month until the 2.2.7.4 firmware update. All three were completely different issues. My set has always been on UPS conditioned power so it is not a power issue. I am attaching two images as an example one with the picture set to Calibrated and the other Vivid so you can see what I am talking about. While the company support has been great, have just lost all confidence in Vizio quality control.
Name:	Cast Calibrated.jpg
Name:	Cast Vivid.jpg
hclyatt is offline
post #24 of 29 Old 11-27-2016, 12:41 PM
Jasonn B's Avatar
Quoted: 485 Post(s)
Liked: 173
Is anyone in here on the special beta? I think that one adds support for Google home voice commands.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is online now
post #25 of 29 Old 11-28-2016, 08:35 PM
Liked: 0
Attachment 1792945
Attachment 1792953
Same issue here, should be caused by the firmware I guess
zixiao is offline
post #26 of 29 Old 12-10-2016, 05:02 AM - Thread Starter
Liked: 726
New Updated Info About an
Perhaps Just Days Away from Now.
Message Post 1.
post #27 of 29 Old 12-16-2016, 02:37 AM - Thread Starter
Liked: 726
New Updated Info!
Another Short-Term, Beta Firmware Release
Released on Dec 15th, 2016.
Message Post 1.
post #28 of 29 Old 12-23-2016, 07:01 PM - Thread Starter
Liked: 726
Updated: Dec 23rd, 2016
A new Message Thread for
Any Wide Release and Beta Firmware Version
for the 2016 P-Series and M-Series:
Vizio 2016 P-Series & M-Series Beta Bug and General Firmware Release Discussion
post #29 of 29 Old 02-05-2017, 01:41 AM - Thread Starter
Liked: 726
Message Thread.
and
Locked or Deleted.
Reply LCD Flat Panel Displays
