Bias Lighting? - AVS Forum | Home Theater Discussions And Reviews
 337Likes
post #1 of 827 Old 02-18-2017, 10:43 PM - Thread Starter
ax75f92's Avatar
Quoted: 37 Post(s)
Liked: 4
Bias Lighting?
Just curious on people's experience/suggestions regarding bias lighting. I've read it provides a noticeable contrast improvement in dark viewing conditions.
I see there's a bunch of $20 options on Amazon with a couple more expensive $60-90 listings that claim to be more accurate. I read a few reviews that the cheap versions may have a slight blueish hue. I believe the correct color temp should be 6500k.
Any feedback?
I apologize if this is in the wrong section.
Cheers.
ax75f92 is offline
post #2 of 827 Old 02-18-2017, 10:55 PM
Quoted: 2996 Post(s)
Liked: 2846
This site have great info ,they also sale accurate 6500k bias light .
http://www.cinemaquestinc.com
lwien123 and King Richard like this.
TV: 65” Sony A9G TV:65” LG B6 HT: Revel Performa3 1 Sub:PSA 15” XS30 2 Sub:Dayton HO 15”
losservatore is offline
post #3 of 827 Old 02-19-2017, 08:11 AM
lwien123's Avatar
Quoted: 65 Post(s)
Liked: 65
I've been using their Ideal-Lume for a few years now and it's great. It not only helps to eliminate eyestrain but it also gives me the impression of increased contrast and black levels.
Not all of these lights though are created equal and some of them can actually degrade picture quality rather than improve it.
Black05Hemi likes this.
lwien123 is offline
post #4 of 827 Old 02-19-2017, 09:26 AM
Otto Pylot's Avatar
Quoted: 4032 Post(s)
Liked: 2893
I use MediaLight Bias lighting http://biaslighting.com. Very easy to install regardless of how your panel is installed (wall mount or console) and works extremely well. The LEDs are accurate at 6500k with a CRI of 90.
Otto Pylot is online now
post #5 of 827 Old 02-21-2017, 09:49 PM
Blackman's Avatar
Quoted: 417 Post(s)
Liked: 196
Any feedback?
Cheers.
This cost me $50 to do all from ebay on our LG Hecto a 100 Inch Short throw Projector.. Its Led strip lights (3528 LED) with Radio Freqencies 10 stage dimmer. It Attracted some interest from the Manufactures. Who know maybe Hisense 100 Inch Cast Short Throw Projector like it and they reproduced it. Had it for2.1/2 years Haaa.
lwien123 and h1pst3r88 like this.
Main Room Sony KD-75X9400E Display, AMP. Yamaha RX-A3050. Front Mains, 2x Dali Concept 8. Klipsch Center, Surround and Rear Surrounds, 4X Dali Ikon 1. Ceiling 4X B&W CCM 382. Subs, 2x Kef C200 for the rear and 2X Kenwood SW-07HT for the fronts. Lounge Shakers, Dayton Audio SA 230 Sub Amp with 4 AST-2B-4 lounge Shakers. The other Tv room the Hecto live there the Hecto 100 inch Short throw projector,
Blackman is offline
post #6 of 827 Old 02-21-2017, 09:53 PM
Blackman's Avatar
Quoted: 417 Post(s)
Liked: 196
Yes, Yes Yes
lwien123 likes this.
Blackman is offline
post #7 of 827 Old 02-21-2017, 10:02 PM
AVmanic's Avatar
Quoted: 472 Post(s)
Liked: 533
I use these on my JS9500 and there great and they're a ture accurate 6500k bias lighting. To me it's the best out there. Great for eye strain and helps for TV'S that don't have the best black levels.
I don't use any on my 75Z9D but I have it in a dark controlled lighting room. And I only use the ones in that room for eye strain.
Sent from my Pixel XL using Tapatalk
AVmanic is offline
post #8 of 827 Old 02-21-2017, 10:05 PM
Quoted: 70 Post(s)
I use this too. Love it. It's on all the time. Much easier on the eyes and makes the contrast look better.
remush, lwien123 and King Richard like this.
NAD D1050 > NAD C320BEE / MiniDSP 2x4 > PSB X2T's / Rythmik FVX15
dcolaco is offline
post #9 of 827 Old 02-21-2017, 10:14 PM
Blackman's Avatar
Quoted: 417 Post(s)
Liked: 196
All stuff I purchase from Ebay, the Same Radio Frequencies Controller that the other mob sells excepted its painted differently The Connection the same LOL, Yes mine is about 6500K Temp and make it easier on your eyes..
I used 3528 Leds but for our New 86 Inch TV I will use these (2835) Run cooler
http://www.ebay.com.au/itm/231007817...%3AMEBIDX%3AIT
The dimmer
http://www.ebay.com.au/itm/330976487...%3AMEBIDX%3AIT
Blackman is offline
post #10 of 827 Old 02-21-2017, 10:15 PM
Blackman's Avatar
Quoted: 417 Post(s)
Liked: 196
Originally Posted by AVmanic View Post
I u Great for eye strain and helps for TV'S that don't have the best black levels.
Very Very true
Blackman is offline
post #11 of 827 Old 02-22-2017, 09:10 AM
Otto Pylot's Avatar
Liked: 2893
The MediaLight does come with a tiny remote control that you can set for 10%, 20%, 40%, 60%, 80%, and 100% brightness. You can either use an extra USB port on the tv for power or use the included ac adapter. I use the adapter and have it connected to an outlet that I can control from a light switch on an adjacent wall. We only use it at night and just hit the switch on the wall in the evening.
King Richard likes this.
post #12 of 827 Old 02-22-2017, 11:03 AM
Quoted: 99 Post(s)
Liked: 74
I use this kit that I found suggested on this forum. I've been really happy with em. I have them plugged into a power strip that turns them off/on when I turn the TV off/on.
http://www.orangetreetrade.com/shop/...kit-p-853.html
Jmhockey23 is offline
post #13 of 827 Old 02-22-2017, 09:02 PM - Thread Starter
ax75f92's Avatar
Quoted: 37 Post(s)
Liked: 4
Bias Lighting?
Great options! The thing I'm concerned about with the medialight and cinemaquest offerings is the fact that they do not cover the entire perimeter of the display, only the sides. Looking at the installed photos I can see the non uniformity with the top/bottom looking less intense than the sides. Worried this might annoy my ocd.
Still looking at the other great options y'all posted. Hopefully this can serve as a list of all the legit bias lighting options available so others can easily weed out the low quality units.
ax75f92 is offline
post #14 of 827 Old 02-23-2017, 10:01 AM
Otto Pylot's Avatar
Liked: 2893
^^^^ my MediaLight equally covers the sides as well as the top on my panel. It's not a complete semi-circle but certainly achieves the desired effect.
post #15 of 827 Old 02-24-2017, 12:18 PM
Quoted: 99 Post(s)
Liked: 74
Here's the power strip I used so that my bias lighting turns off/on with the TV.
http://www.staples.com/Staples-7-Out...product_199686
post #16 of 827 Old 03-03-2017, 06:53 AM
anthonymoody's Avatar
Quoted: 933 Post(s)
Liked: 687
Yet another vote for the MediaLight 6500K. I have a single strip running along the top half of my 88" Samsung and even though the blacks the TV generates are amazing, the perception of them is that much improved, and eye strain is greatly alleviated. Looks great and highly recommended.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
post #17 of 827 Old 03-03-2017, 10:48 AM
tezster's Avatar
Quoted: 660 Post(s)
Liked: 554
I've used bias lighting with all my 3 LCD displays with positive results. For wall-mounted displays, wrapping the lights around the entire perimeter of the panel yields the most uniform result. TVs further from the wall can use single strips, since the light has sufficiently diffused by the time it reaches the wall.
tezster is offline
post #18 of 827 Old 03-04-2017, 02:02 PM
Quoted: 103 Post(s)
Bias Lighting?
Bias lighting is coming out with 4 sided lights for wall mounted sets
Does any one know their CS AND RETURN policy?
zibaji is offline
post #19 of 827 Old 03-04-2017, 10:47 PM
Quoted: 286 Post(s)
Liked: 223
I use Philips Hue strip lighting and it works great! And it has apps that allow you to control the colors from your phone.
zibaji likes this.
Radvlad is offline
post #20 of 827 Old 03-05-2017, 01:21 AM
Quoted: 103 Post(s)
What mode do you use equivalent to 6500K
zibaji is offline
post #21 of 827 Old 03-05-2017, 02:02 AM
Quoted: 286 Post(s)
Liked: 223
No specific modes, I opt for various 'scenes' pre-loaded on the app or colors that please the eye and accent the mood of the film. For example, dark red is effective when watching horror and a deep blue is excellent for sci-if, while green works well for Walking Dead. You can lower or raise the brightness of the light as you desire. And there is also an app that allows you to have your iPhone or iPad's camera face whatever you are watching on your TV so that the bias light changes colors automatically to match the color scheme of the scene that you are watching. It's pretty cool.
pilotart likes this.
Radvlad is offline
post #22 of 827 Old 03-05-2017, 06:20 AM
Quoted: 933 Post(s)
Liked: 687
Where did you hear about this?
Double True!
post #23 of 827 Old 03-05-2017, 05:42 PM
Otto Pylot's Avatar
Liked: 2893
Colors? Bias Lighting should be 6500k, not blue, green, red or any other color. At least if you want to use them the way bias lighting is intended against a neutral colored wall.
post #24 of 827 Old 03-05-2017, 07:28 PM
Quoted: 286 Post(s)
Liked: 223
Yes, I understand. However, it's nice to have options ;-)
ez1dog and residentsystems like this.
Radvlad is offline
post #25 of 827 Old 03-05-2017, 07:48 PM
Otto Pylot's Avatar
Liked: 2893
^^^ options are good.
ez1dog and pilotart like this.
post #26 of 827 Old 03-15-2017, 09:29 PM - Thread Starter
ax75f92's Avatar
Quoted: 37 Post(s)
Liked: 4
Bias Lighting?
Do you have info on this? I really want a setup that covers the entire perimeter.
ax75f92 is offline
post #27 of 827 Old 03-15-2017, 11:51 PM
Quoted: 103 Post(s)
Jason told me to wait for upcoming Quattro set up
zibaji is offline
post #28 of 827 Old 03-16-2017, 05:58 AM
remush's Avatar
Quoted: 181 Post(s)
Liked: 185
Its very useful for HDR content, there is more noticeable light bleed on my KS8000 with HDR with the lights off, with the BL on its hard to notice at all.
these are pics of an HDR demo
remush is offline
post #29 of 827 Old 03-18-2017, 07:07 PM
Quoted: 103 Post(s)
I still dont still see quads available?
zibaji is offline
post #30 of 827 Old 04-19-2017, 04:59 PM - Thread Starter
ax75f92's Avatar
Quoted: 37 Post(s)
Liked: 4
Quads are up on their site now
ax75f92 is offline
Reply LCD Flat Panel Displays
