**OFFICIAL** 2017 SONY XBR-X930E (Owner's Thread)(No Price Talk) - Page 279 - AVS Forum | Home Theater Discussions And Reviews
 15250Likes
post #8341 of 10981 Old 07-21-2018, 09:03 AM
doyoid's Avatar
Quoted: 36 Post(s)
Liked: 40
Originally Posted by halon View Post
Anyone else have remote problems? I've had my tv for 5 months or so and the buttons might respond or not or takes many presses. It's at the point now I want to throw against a wall. Just started like a week ago. Tried changing batteries. Anywhere to get a cheap replacement?
Hard to say if it's your remote or something else. But remotes aren't that expensive. I bought a spare within weeks of getting the TV since I wasn't sure how long they would be available in the future. You might find cheaper alternatives, but this is what I bought:
https://www.replacementremotes.com/s...remote-control
doyoid is offline
post #8342 of 10981 Old 07-21-2018, 12:23 PM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
Originally Posted by Hogfan2502 View Post
Just got my 65X930E delivered yesterday. I have been debating on what to get for my so called "man cave" for the past 2 months and I started out and tried the LG 65" B7A. It was just to dark of a picture for my taste, but the picture was amazing, super clear, excellent blacks, and highlights were very bright, but the overall the picture was way to dark for me. I like a bright picture, with pop, plus I was worried about burn in when playing games from some of the reviews I read. Then I was debating on the 900F and the 930E. I ended up getting the 930E because it was the brightest and got great reviews, plus I got it a little cheaper than the 900F. Anyway, I was going through the TV apps and when I used the Amazon Prime app the black bars on top and bottom were gray or even a light gray, is this normal? None of the other apps do this that I've noticed so far and I just wanted to make sure my TV wasn't bad or something haha. I've never seen that from the black bars before so it just concerned me so I thought I'd ask.
Haven't yet seen that on ours w/amazon prime, which we do watch often; we have the t&b bars but they're dark black. But we also have bias lighting behind our 930, and supposedly that helps make blacker blacks and more brilliant colour accuracy etc.
Was it that way with just one movie/show, or with several on prime?
WinMod21 is offline
post #8343 of 10981 Old 07-21-2018, 01:47 PM
Quoted: 55 Post(s)
Liked: 40
Originally Posted by vpn75 View Post
I'm having same issue as OP and tried unplugging the set to reset it but the menu lag persists for me. Maybe I need to leave it unplugged for a few minutes? I just tried 30 seconds before.
If you Tried power reset and replacing batteries. Try clearing the app cache as explained in a post above go to settings/storage&reset/device storage/cached data. Click and clear cache when instructed.
Hold home button down see how many apps you have running. Remove the ones you aren’t using at the moment.
Other than that your stopping services from running. Vincent Teoh has a YouTube titled “How to speed up slow Sony android tv & disable samba interactive”. Not tried it but I would lay money down it will be re enabled on a software update.
gyates11 is offline
post #8344 of 10981 Old 07-22-2018, 08:28 PM
lmartinijr1's Avatar
Quoted: 299 Post(s)
Liked: 254
Well I fought the good fight and lost . After two weeks,After two soft resets and one hard reset, the 930 continues to turn on by itself. Today there was a red line across the screen also. I hope the exchanged tv will be as good panel wise. The pq was outstanding with only the slightest of blooming ......in noticeable unless you were really looking for it. Wish me luck on the replacement. B and H customer service has been great so far.
lmartinijr1 is offline
post #8345 of 10981 Old 07-23-2018, 05:39 AM
Quoted: 63 Post(s)
Liked: 7
I know I may be a little late to the party with this suggestion, but did you try turning Bluetooth off? I recall somewhere in these many pages where someone else had the same problem with their TV turning on by itself and that seemmed to solve the problem. I think with it off it disables the voice search from the remote, but as a troubleshooting aid, you may want to try it.
gant1080 is offline
post #8346 of 10981 Old 07-23-2018, 07:46 AM
Quoted: 299 Post(s)
Liked: 254
Yes thanx. Turned everything off like that. Like Sony said if the resets didn’t fix it there is a problem. Going to exchange for another one and hope I don’t have the same problem. Really want this tv and model,especially with the Dolby vision. It looked awesome,especially on Netflix. If it happens with new set I think I’ll switch to the qled. Fingers crossed. Thanx again.
post #8347 of 10981 Old 07-23-2018, 04:19 PM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
Best of luck to you for an excellent panel and all.
WinMod21 is offline
post #8348 of 10981 Old 07-23-2018, 11:12 PM
Quoted: 299 Post(s)
Liked: 254
Thanx!
post #8349 of 10981 Old 07-24-2018, 10:41 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7299 Post(s)
Liked: 7330
Depending how much you got this for out the door, The XBR-65Z9D are really not that much more on the street....
Cleveland Plasma is offline
post #8350 of 10981 Old 07-24-2018, 08:37 PM
mutelight's Avatar
Quoted: 2358 Post(s)
Liked: 2732
Just a head up and YMMV but I ran the following to debloat my Z9D, 930E and, A1E and all is well.
https://www.reddit.com/r/bravia/comm..._disable_apps/
Blorton, NTC and m_snow like this.
mutelight is online now
post #8351 of 10981 Old 07-26-2018, 09:48 AM
Quoted: 299 Post(s)
Liked: 254
Of course since I ordered the exchange ,my tv has not turned itself on. Learned how to disable apps that were running Coincidence? SONY had said that should have nothing to do with the problem. Hmm. New tv to be delivered next week. Hope it’s a good one.
post #8352 of 10981 Old 07-27-2018, 01:10 PM
retro124's Avatar
Quoted: 1427 Post(s)
Liked: 1154
Hey guy quick question. I have also like many here 930E and Oppo 203 and seems like new update should be able to finaly be able to use DV from 4K disks. I’m trying all and still no luck. Any recommendations or tips?
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Apple 4K TV, Mac mini, Sony UBP-X800, PS3
retro124 is offline
post #8353 of 10981 Old 07-28-2018, 07:03 AM
Morac's Avatar
Quoted: 373 Post(s)
Liked: 103
This web site is claiming that all 2017, 2018 and some 2016 Sony Bravia TVs will be getting Android Oreo by the end of the year.
https://ausdroid.net/2018/06/26/conf...6-models-also/
I find that suspect as if we were getting Oreo this year I would expect more info to have been put out there besides to some obscure Australia website. Though I guess that could explain the complete lack of updates the past 4 months.
Also the article states Google Assistant is coming to the same, but we already got that in November.
m_snow likes this.
Morac is offline
post #8354 of 10981 Old 07-28-2018, 09:12 AM
Quoted: 2152 Post(s)
Liked: 1419
Good news if true.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #8355 of 10981 Old 07-28-2018, 11:14 AM
Quoted: 520 Post(s)
Liked: 149
Originally Posted by m_snow View Post
Good news if true.
Yes it’s true. As I’ve stated before they support tv for at least 3 years with major updates as well as minor if the hardware can handle it. My tv before the 930 was the 2015 850c and it still gets minor updates, it was also update to Marshmallow and then Nugat in nov 17 which was probably the last major update as the internals are outdated. Hell that tv was sold with out hdr anc the even patched that in in mid 2016. I wouldn’t worry about getting Oreo lol
fssfguy is offline
post #8356 of 10981 Old 07-28-2018, 11:31 AM
Quoted: 299 Post(s)
Liked: 254
So since I’ve learned to disable the streaming apps from running,the tv has not turned itself on once. I now think that was the problem. Exchange already in progress. Going to exchange since I also was having some lan connectivity problems that I didn’t have before with any of my other tvs here.
post #8357 of 10981 Old 07-28-2018, 12:03 PM
Liked: 1419
There’s one very important part of what you said “if the hardware can handle it” and that’s absolutely true. Based on the Oreo specs for free memory alone makes me skeptical but if it happens and makes the OS faster I’ll be very happy. But Sony can still support Android 7 with patches and security updates without going to Oreo and they will.
Mike
post #8358 of 10981 Old 07-28-2018, 04:40 PM
Morac's Avatar
Quoted: 373 Post(s)
Liked: 103
There’s been a few posts about using Chromecast to get YouTube 4K HDR and originally I mentioned that it works, but today I discovered that it actually does not. The TV will show “HDR” in the the picture adjustments screen, but the TV won’t actually kick into HDR mode.
I first noticed this when playing this HDR test video and realizing the white nit test images looked nearly identical.
That’s when I realized that despite showing HDR in the picture adjustment screen, the brightness didn’t actually change, nor was the ability to adjust it for ambient brightness disabled like it is when showing HDR. Basically the TV is falsely reporting that it’s displaying HDR.
Morac is offline
post #8359 of 10981 Old 07-30-2018, 05:01 AM
Indiana627's Avatar
Quoted: 98 Post(s)
Liked: 24
My internal Netflix stopped working this weekend. Now when pushing the Netflix button on the remote or trying to access it from the Home screen all I get is a black screen. I don’t even get a login screen as if I was logged out. All other internal apps I tested are working fine. It says the Netflix app was recently updated. Any ideas how to get Netflix working again?
Mark
"We named the dog Indiana."
Directv since '03
Indiana627 is offline
post #8360 of 10981 Old 07-30-2018, 05:49 AM
Liked: 1419
Try rebooting the TV. I’ve got the updated NF and it works fine so far.
Mike
post #8361 of 10981 Old 07-30-2018, 07:06 AM
Quoted: 559 Post(s)
Liked: 136
https://youtu.be/XEtUF7RT3pw
You have to change HDR settings to HDR 10 and color space to BT2020. Then it works. A little dumb, but it works. google play movies look good. Phantom Thread looks fantastic, as good as itunes.
MLM87 is offline
post #8362 of 10981 Old 07-30-2018, 07:07 AM
Indiana627's Avatar
Quoted: 98 Post(s)
Liked: 24
I’ve never had to reboot it before. How do I reboot it? Just pull the plug for a minute or is there a menu option to reboot?
Mark
Directv since '03
post #8363 of 10981 Old 07-30-2018, 07:14 AM
mutelight's Avatar
Liked: 2732
Hold the power button on the remote until you see the Sony logo and Google boot animation.
m_snow likes this.
post #8364 of 10981 Old 07-30-2018, 08:44 AM
Morac's Avatar
Quoted: 373 Post(s)
Liked: 103
Manually changing the HDR settings doesn’t actually make something HDR. The TV should automatically detect HDR. In this case the app is indicating that the video is HDR, but the TV doesn’t seem to know how to handle it.
Morac is offline
post #8365 of 10981 Old 07-30-2018, 09:59 AM
Indiana627's Avatar
Quoted: 98 Post(s)
Liked: 24
Doing so just reboots the tv right? It does not reset it to factory settings and erase all my custom settings?
Mark
Directv since '03
post #8366 of 10981 Old 07-30-2018, 10:19 AM
mutelight's Avatar
Liked: 2732
Right, just reboots and all settings are preserved.
Indiana627 likes this.
post #8367 of 10981 Old 07-30-2018, 10:23 AM
Indiana627's Avatar
Quoted: 98 Post(s)
Liked: 24
Thank you! Will do this tonight. If reboot doesn’t fix Netflix app, then what should I do?
Mark
Directv since '03
post #8368 of 10981 Old 07-30-2018, 10:39 AM
Morac's Avatar
Quoted: 373 Post(s)
Liked: 103
There’s an update in the Google Play Store. You can try downloading that or removing the update and downloading it again.
Morac is offline
post #8369 of 10981 Old 07-30-2018, 11:42 AM
Quoted: 559 Post(s)
Liked: 136
The HDR is actually working, but for some reason the Chromecast Ultra and built-in Sony x930e chromecast will not play in BT2020. It has to be forced. Check out the Chromecast Ultra forums.
MLM87 is offline
post #8370 of 10981 Old 07-30-2018, 12:19 PM
Morac's Avatar
Quoted: 373 Post(s)
Liked: 103
It's not a matter of just changing the color space. All the settings that normally get set for HDR are not being done so. Basically the TV is showing SDR, but lying and displaying the HDR indicator. I'd have to manually change the brightness, turn off ambient lightning and set HDR to HDR10. Having to do all that likely indicates that the app isn't actually sending HDR data. In any case, that's not something I'd want to do every time I use YouTube anyway. It's a lot simpler to just switch over to my Roku.
Morac is offline
Reply LCD Flat Panel Displays
jimmyhigh; solzun; zachfeen; johnerz
