**OFFICIAL** 2017 SONY XBR-X930E (Owner's Thread)(No Price Talk) - Page 357 - AVS Forum | Home Theater Discussions And Reviews
 15227Likes
post #10681 of 10804 Old 07-07-2019, 04:48 PM
Quoted: 49 Post(s)
Originally Posted by m_snow View Post
It’s a known issue with the ATV4K and using the new TV app. It also can happen on DoVi. Try watching it in the iTunes Movie app instead. It is a temporary workaround until Apple fixes it. It is not your TV.
Oh, interesting. The only thing is that I’m not using the TV app. I’m starting the movie directly from the iTunes Movies app.
EDIT: So I did a bit of research and you’re totally right. Looks like it’s an Apple TV issue that was introduced with 12.3. It’s weird that the workaround of using the iTunes Movies app is not working for me, though. I did could temporarily resolve the issue for a movie by switching back and forth between the TV app and the iTunes app a few times until it stopped flickering.
What a mess, I really hope this will be resolved in the next ATV firmware update.
m_snow likes this.
ForecastV is offline
post #10682 of 10804 Old 07-07-2019, 06:16 PM
denizenKRIM's Avatar
Quoted: 24 Post(s)
Have you tried the latest ATV beta? That resolved my black stuttering issues on HDR10.
Tangentially related, but unfortunately there's still no improvement on the dimming issues with DV playback (through ATV). I've had to resort to using the native TV VUDU app (in the few times my iTunes 4k purchases transfer).
denizenKRIM is offline
post #10683 of 10804 Old 07-07-2019, 06:55 PM
Quoted: 49 Post(s)
That’s good news! I might go ahead and install the beta firmware then. Is it stable enough?
post #10684 of 10804 Old 07-07-2019, 06:57 PM
Quoted: 24 Post(s)
That’s good news! I might go ahead and install the beta firmware them. Is it stable enough?
Been running the beta for 2 years now, never ran into issues. It helps when tvOS is a lot less complicated. I suppose you always run the risk of something going awry, but the beta updates are frequent enough it’s never bothered me.
post #10685 of 10804 Old 07-07-2019, 09:03 PM
Morac's Avatar
Quoted: 356 Post(s)
Liked: 102
I reported this issue to Apple awhile back and got a response in June that they could not reproduce the issue.
I went back and forth between Sony Netflix and Apple TV Netflix; if there is any difference, it is subtle and will require test patterns and a spectrometer to isolate. We definitely did not see “way too dull” and “definitely too dull” as the Reddit posts say. Black is black on both. I double checked that the Sony TV is on the latest firmware (v6.5805), used HDMI 2 and reset the picture settings to default. We watched the opening scenes of “Marco Polo: One Hundred Eyes” which go from inside darkness to outside daylight. The TV professed to be in Dolby mode. Thank you for your feedback.
Morac is offline
post #10686 of 10804 Old 07-07-2019, 09:37 PM
Quoted: 24 Post(s)
How did you get in touch with them? I'll give it a shot as I've been testing this for a while.
They should test on the same source as to remove any variables. A simple switch between DV and HDR10 on any of their iTunes movies would yield the required results.
Crazy to me no one has worked on this when the problem has been reported for so long.
post #10687 of 10804 Old 07-08-2019, 04:55 AM
Morac's Avatar
Quoted: 356 Post(s)
Liked: 102
I reported it on their bug reporter page. They’ve since replaced that with the feedback assistance app, so if you are running the beta you should be able to use that.
https://developer.apple.com/bug-reporting/
https://feedbackassistant.apple.com/
Morac is offline
post #10688 of 10804 Old 07-09-2019, 11:02 AM
BoboBrazil's Avatar
Quoted: 58 Post(s)
Installed the new July 2019 update with no issues. Everything seems to be running well. Hoping this set gets Android 9.0 or 10.0 as well.
blackie333 likes this.
BoboBrazil is offline
post #10689 of 10804 Old 07-14-2019, 12:39 PM
Quoted: 240 Post(s)
Liked: 73
I have a 2017 930E, located in Canada. How do I get the Android 8 update?
Canuck Sonido is offline
post #10690 of 10804 Old 07-14-2019, 01:48 PM
Quoted: 1711 Post(s)
Liked: 1007
Here is the download site for the USB update and instructions for North America. You could also try and update from your TV but it could take weeks or even months to get it.
https://www.sony.com/electronics/sup...loads/00016213
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #10691 of 10804 Old 07-14-2019, 01:55 PM
jev7266's Avatar
Quoted: 76 Post(s)
Liked: 53
You can download the self-install update file (v6.6520) from the Sony x930e support site here.
Be sure to check your model number against the list at the very top of the page before you download and install the update.
Complete instructions for performing the update are on the site. Note that this is a self-install update. You'll have to get the update file onto a USB flash drive and plug the drive into one of the USB ports on the rear of the set. If you've done these first steps correctly, the TV will automatically recognize the update file and give you the option to proceed.
TVs: Sony XBR65X930E (2017), v8.0.0 (6.6510) / Samsung UN50JU7100 (2015) w/ IA02 panel, sw v.1530.1
AVR: Yamaha RX-v581, sw v.2.65
Speakers 5.1.2: Polk Audio RM6750 (surround) + Pioneer SP-T22A-LR Atmos height
jev7266 is offline
post #10692 of 10804 Old 07-15-2019, 03:46 AM
Quoted: 24 Post(s)
Liked: 3
Anyone tested the new 2019-line aluminium remote RMF-TX600E whether it's working on older TVs like our X930E ?
m_snow likes this.
blackie333 is offline
post #10693 of 10804 Old 07-15-2019, 10:52 AM
Liked: 1
Messed up my 930e screen and need help
We just moved from Houston to Santa Fe, about 900 miles. I packed the 930e carefully in its original box and it was placed in the movers van. During the trip it went through ambient temperatures as high as 109 deg. F. Must have been a lot hotter in the van.
When I opened the box I found that the plastic bag around the set had been pushed out of the way by a piece of stickyback foam and it had left a layer of adhesive about 6"x 3" in the bottom right of the screen. It must have happened when we lowered it into the base foam mount. The heat probably melted it on to the screen.
Now the stupid part. No excuses.
I tried to remove it with Goo Gone and a microfiber cloth. It removed most of the glue alright, but left a distinct matt smudge on the glass. My wife went ballistic on me when she saw what I'd done so I stopped immediately. So how do I get rid of the smudge, or have I damaged the coating permanently?
It is not visible when the set is on, so there's that, but looks like crap when it is off.
Vandellyn is offline
post #10694 of 10804 Old 07-15-2019, 11:59 AM
Jim Kiler's Avatar
Quoted: 214 Post(s)
Liked: 123
Glad to hear it did not damage the finish when watching content. I would try dish soap and water (several times if one is not enough) before you try anything exotic.
TV - Sony 65XBR-930e | Receiver - Yamaha RX-V577 | 4K player - Sony UBP-X700 | PS3 | Router - Asus RT-AC86U | SVS SB-2000 sub | Paradigm Monitor SE 6000F L/R | Paradigm Monitor SE 2000C center | Paradigm ADP-170 v.3 rears
Jim Kiler is offline
post #10695 of 10804 Old 07-15-2019, 03:03 PM
Madmax67's Avatar
Quoted: 2217 Post(s)
Liked: 2515
From the product description the stuff looks like something we used to use in the auto industry called Orange. It's very acidic but works fine on window glass carpet and the like. Problem with TV screens though are anti reflective coatings on top of the glass screen. It's why we never used the stuff on windows with aftermarket tint. I'd try a micro fiber cloth soaked in some soapy distilled water. Not a lot and move in a light circular motion around the affected area. Follow that up with clean distilled water on a cloth and dry accordingly. That's about all you can do but unfortunately the coating is probably going to stay permanently discolored.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is online now
post #10696 of 10804 Old 07-16-2019, 10:26 AM
Ericwilley's Avatar
Use plain old peanut butter to remove adhesive residue.... spread some over the area... let it sit for awhile then wipe off
Ericwilley is offline
post #10697 of 10804 Old 07-16-2019, 11:56 AM
Liked: 1007
Creamy or crunchy?
Mike
m_snow is offline
post #10698 of 10804 Old 07-16-2019, 12:01 PM
Ericwilley's Avatar
Creamy or crunchy?
creamy is easier but I have used crunchy when that's all I had
m_snow likes this.
post #10699 of 10804 Old 07-16-2019, 02:00 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
So did the update over the weekend. Monday had to pull the plug to get the unit to turn on. Today had the same thing happen again. Hopefully it's not a new issue.
4KTV: Sony 65 930E Receiver: Pioneer VSX-LX101 7.2 Channel ATMOS/DTS-X Speakers: JAMO S 807(2) Fronts, Andrew Jones SP-FS52 (2) Rears, Center:SP-C22, Klipsch R-14SA Atmos Subwoofer: SVS PB-3000 Subwoofer 4K Player and Misc: Panasonic UB-820, Sony X700, Sony X800, Samsung UBD-K8500, Comcast Arris AX014ANM and Extreme 150 Internet and PS4 (6TB Edition)
Bodyslide is offline
post #10700 of 10804 Old 07-18-2019, 04:34 PM
Quoted: 240 Post(s)
Liked: 73
Turned on my 930E last evening and was notified that the update was available, installed without any problems. I run my set through a Sony AVR1080 7.2 home theatre with multiple devices including ATV 4K and so far no issues. I like the new Android, feels snappier.
m_snow likes this.
post #10701 of 10804 Old 07-18-2019, 05:20 PM
Liked: 1007
It's always better (and easier) to get it automatically like you did. I usually want it right away so the USB route works better for me. Yes, the new Android OS is much quicker.
Mike
m_snow is offline
post #10702 of 10804 Old 07-18-2019, 07:27 PM
Morac's Avatar
Quoted: 356 Post(s)
Liked: 102
I normally download it via USB as I frequently go over a month before my TV gets updates. This time I already had installed 6.6510 so I didn’t bother downloading 6.6520. I got a notification today that my TV downloaded 6.6520 so I choose to install it. I’ll mention it’s easy to miss that notification if you aren’t paying attention.
I guess I haven’t seen the new Android 8 automatic update process. After choosing to install, it said it would do so when I turned the Tv off, but it didn’t actually do so without again prompting if I wanted to do the install now or later. I guess that’s nice, but that’s a lot of prompting. Anyway after the update, the TV turned itself back off, so you can basically start an update and leave and the rest is automated.
On a side note, Sony’s web site now mentions it can take several weeks to get an update after it’s released if you go the automatic or manual check method. It’s about time they did that.
leonmckee and m_snow like this.
Morac is offline
post #10703 of 10804 Old 07-18-2019, 08:12 PM
JD23's Avatar
Quoted: 558 Post(s)
Liked: 328
Since a couple of updates ago, the automatic update function on my TV is semi-broken and reports an error unless I run it immediately after restarting the TV.
JD23 is offline
post #10704 of 10804 Old 07-19-2019, 02:38 PM
Quoted: 59 Post(s)
Liked: 7
I would also like to know the answer to this. That remote is so much better than the standard X930E remote, much better layout of buttons, not as close together and just a much sleeker remote overall.
Modicen and blackie333 like this.
gant1080 is offline
post #10705 of 10804 Old 07-19-2019, 06:29 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
So the tv has now needed to be unplugged and then plugged back in everyday this week except Wed. So looks like I will be doing a full reset in the next few days. Hopefully this will correct the issue I'm having.
post #10706 of 10804 Old 07-20-2019, 11:23 AM
Jim Kiler's Avatar
Quoted: 214 Post(s)
Liked: 123
There are two different resets as well. I forgot how to do a forced reset but I am sure it is in this thread.
post #10707 of 10804 Old 07-21-2019, 06:38 AM
Modicen's Avatar
Quoted: 126 Post(s)
Liked: 53
Have you tried the reset yet? I hope it works when you do. This is the reason I haven't done the last couple of updates, my 930E works perfect and I would hate to have these little bugs crop up. Someone convince me otherwise please. Lol
Modicen is offline
post #10708 of 10804 Old 07-21-2019, 05:14 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
I know about the 2 ways to reset. I still haven't done it yet. It's such a pain to redo all the settings. I'll update once I complete it. Thanks
post #10709 of 10804 Old 07-22-2019, 07:50 AM
JD23's Avatar
Quoted: 558 Post(s)
Liked: 328
I have been an X930E owner for almost two years and recently bought an A9G. I still have the X930E set up in another room and can provide a comparison between the X930E and an OLED for those considering an OLED as a replacement. The A9G is noticeably better for dark room viewing because of its perfect black levels and lack of blooming, but the X930E holds its own for all other types of viewing. I actually think it is a better all-purpose TV, given its lack of burn-in risk and dramatically higher HDR brightness. The X930E also has better color uniformity, with no tinting, unlike the OLED, which has a slight magenta tint on the edges of the screen, like most other 2019 OLEDs. Both TVs are more than bright enough for SDR content and I don't run either of them anywhere near max brightness.
The main point for X930E owners is that your TV is competitive with the TV that has arguably the best overall picture quality of 2019. I went with an OLED because I could not find an LCD that was significantly better than the X930E (unfortunately, the Z9D was already out of stock by the time I was shopping) and wanted to experience a different display type.
JD23 is offline
post #10710 of 10804 Old 07-22-2019, 12:34 PM
Bodyslide's Avatar
Quoted: 30 Post(s)
Not sure why But got an update just now for v6.6520, I thought that's what I update last week. So now I'll see what happens over the next few days with the TV not turning on.
Reply LCD Flat Panel Displays
jimmyhigh; solzun; zachfeen; johnerz
