Samsung MU8000 (No Price Talk) - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 978Likes
post #811 of 1546 Old 02-25-2018, 12:04 PM
MrRoy's Avatar
Quoted: 74 Post(s)
Liked: 42
Originally Posted by Polako View Post
I have 55MU8000 and I noticed a strange issue while playing the PS4 PRO. Several times during the game, the image disappears for 1-2 seconds and reappears - just like when we turn on HDR games. The image gets completely black, 1-2 seconds and the picture returns.
What could it be ? Something in the settings? I have the game mode enabled, the UHD option is enabled in the TV options...
Anyone have solution for this ?
Maybe an HDMI handshake issue. What cable are you using?
Sent from my iPhone using Tapatalk Pro
MrRoy is online now
post #812 of 1546 Old 02-25-2018, 04:34 PM
Quoted: 75 Post(s)
Liked: 41
Known issue with PS4 pro, it has something to do with PS4 sending an invalid hdmi packet with HDCP 2.2 which forces the samsung TV to resync the signal. According to hdmi specs that's what you're supposed to do, Sony refuse to fix it and Samsung refuse to change their handling of the bad packet. This happens on all samsung TVs the last 2-3 years.
Zero issues with Xbox, nvidia cards. Turning off HDCP or switching to HDCP 1.4 on the PS4 resolves it.
mozmo is offline
post #813 of 1546 Old 02-25-2018, 07:45 PM
MrRoy's Avatar
Quoted: 74 Post(s)
Liked: 42
Ive had zero problems with my PS4 pro on my ju7100, ks8000 and mu8000. Are we sure this isn't something that can be fixed? I am not using the HDMI cable that came with the PS4 pro.
MrRoy is online now
post #814 of 1546 Old 02-25-2018, 08:56 PM
Quoted: 75 Post(s)
Liked: 41
Cables aren't the issue. You probably have HDCP turned off. Like I said before, turning it off or forcing the PS4 pro to use HDCP 1.4 solves it.
https://us.community.samsung.com/t5/...een/td-p/85321
mozmo is offline
post #815 of 1546 Old 02-26-2018, 01:08 AM
Liked: 0
Unfortunately, in my case the image also disappears when the hdcp is off...
Maybe I should try use HDCP 1.4...
Polako is offline
post #816 of 1546 Old 02-26-2018, 06:55 AM
Chuck666's Avatar
Quoted: 296 Post(s)
Liked: 76
My 82MU8000 also has the black screen flash; but only occurs about 5-10 minutes on startup. Sometimes twice. Then, not again for my morning viewing. This may be the cause??? I donot have a PS4; I do have a NVidia card and it occurred while reading your post, ha. Thanks for the info. Starting each morning doing these updates on my HTPC. About 10 hours from now, I will start my OTA Tivo for normal TV watching and it will occur again. UHD requires 2.2, so, turning that off is not going to happen...
Thanks, again.
Samsung UN82MU8000 4K UHD TV | Yamaha RX-A2070 9.2 AVR with Klipsch R-15M L&R and R-34C front stage speakers | Klipsch G-12 surrounds | 4 Atrium 5 front & rear Tops | Dual BIC RtR EV-1200 Subs | 5.1.4 Atmos system | Samsung UBD M9500 BD Player | FireTV 4K | Logitech Harmony 750 | TIVO BOLT OTA 849000 | AppleTV 4K | miniDSP 2 X 4 |
Chuck666 is offline
post #817 of 1546 Old 02-27-2018, 08:18 AM
gnk1's Avatar
Use TV or Blu-Ray player for Netflix, Amazon?
The MU8000 65" is being delivered this weekend. I also just got the Samsung UBD-KM85c Blu-Ray player.
I plan to connect the KM85c to the TV with one HDMI for video and to my Denon X2000 AVR for audio since the AVR does not deal with HDCP 2.2. This should allow 4K video for Blu-Rays.
Wondering about streaming apps like Netflix and Amazon and whether the apps work/perform better/worse/same in the TV since it is newer than the UBD. I know there is not a lot of content in 4K yet but want the best overall experience given the limitations. If I used the TV to stream the apps then I would connect to the AVR via optical (HDMI ARC sounds problematic). Using the UBP to stream would involve the same two HDMI paths as for Blu-Rays to TV and AVR.
Does anyone have experience to share with these or similar devices and a recommendation? Thanks.
gnk1 is offline
post #818 of 1546 Old 02-27-2018, 02:38 PM
SkyYYZ's Avatar
Quoted: 266 Post(s)
Liked: 204
I think you will find a wealth of information about setup options and the player in general in the Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread. As for apps on your MU8000, Tizen 3 is pretty slick and responsive.
SkyYYZ is offline
post #819 of 1546 Old 03-02-2018, 08:51 AM
Quoted: 33 Post(s)
Liked: 6
Do you think I should call Samsung support because of the way my screen looks:
This shadow is only visible on some variations of grey (not all), the pinkish tint at the middle of the screen is exaggerated from my camera, but still there (50% grey uniformity .png)
Cannot see any of those while watching movies...
SpAwN_BG is offline
post #820 of 1546 Old 03-02-2018, 11:34 AM
Quoted: 33 Post(s)
Liked: 6
Originally Posted by cb86 View Post
It looks normal and if you can't see any issues when watching movies, it doesn't matter.
Thanks for the response!
Can this be considered as an issue or pretty much all of the led TVs have it?
SpAwN_BG is offline
post #821 of 1546 Old 03-03-2018, 12:17 AM
FarmerBob's Avatar
Quoted: 130 Post(s)
Liked: 108
Originally Posted by SpAwN_BG View Post
Do you think I should call Samsung support . . .
Looks like you have the dark gray bezel. When I got my KS800D, the D and dark grey were Costco only. And if it is an MU800D and your TV was purchased at Costco, call Costco's Concierge service. They are incredible in helping with any situation. They will try to deal with it, if they can't have a backdoor to the right people at Samsung.
If not a Costco unit, never mind. Then if you really think you have an issue, call Samsung. It never hurts to investigate.
. . . fb
FarmerBob is offline
post #822 of 1546 Old 03-04-2018, 11:10 PM
Synomenon's Avatar
Quoted: 93 Post(s)
Liked: 36
UN65MU8000 here. Which apps. built into this TV are 4K and / or HDR?
Synomenon is offline
post #823 of 1546 Old 03-05-2018, 05:26 AM
Quoted: 33 Post(s)
Liked: 6
Youtube, Netflix..
Synomenon likes this.
SpAwN_BG is offline
post #824 of 1546 Old 03-05-2018, 05:41 AM
Quicksilv3r's Avatar
Quoted: 481 Post(s)
Liked: 369
Amazon Prime also has 4K and still debating about HDR10+ on Amazon
Sent from my SM-G935W8 using Tapatalk
tv: Samsung UN75MU800, Receiver: Denon AVR 730H, speakers: 4x M&K S-1B and M&K S85c for center, sub: MKsound V12 HTPC, Samsung UBP-K8500, Rogers Digital PVR, Chromecast Ultra
Quicksilv3r is offline
post #825 of 1546 Old 03-05-2018, 08:08 AM
Super Moderator
markrubin's Avatar
Quoted: 1811 Post(s)
Liked: 3582
posts deleted
if you are not here to help other members, consider not posting
Teeter, Hairsonfire and Synomenon like this.
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess HDCP = Hollywood's Draconian Copy Protection system
LG C9 OLED owner
markrubin is offline
post #826 of 1546 Old 03-05-2018, 11:06 AM
poop-dog's Avatar
I have an issue, had the tv for a little over a week now. When there is a bright to dark difference on the screen, and the image moves quickly, there is noticeable ghosting or trails on the screen from the darker image. Almost exactly like if you set trails to on, on your mouse. Very noticeable on Rick and Morty to the point of not being able to watch. Over the weekend it was bad on Top Gear when they were in the snow and Jeremy was wearing all black.
What on my settings could be causing this? I pretty much used the rtings settings but not on movie, on standard.
Also I haven't really noticed while playing games like Forza, or 4K blurays. Just 1080i content.
Edit: this is on the 82" btw
poop-dog is offline
post #827 of 1546 Old 03-05-2018, 11:56 AM
Quoted: 14 Post(s)
Liked: 2
I had the same issue if you look a couple of pages back i made a post about it
Mine was so bad that i had to return it. The new i have now does the same thing but not nearly as bad as the first one i had. The video below I recorded shows it on my first model. You notice it more with amimated cartoons.
(Video recorded in 4k) - Might have to download it to see what i am talking about. Pay attention to the eye and head area you will see it for sure
https://drive.google.com/open?id=18t...31LxSxd-AZYjPt
IPHANT0MI is offline
post #828 of 1546 Old 03-05-2018, 12:20 PM
poop-dog's Avatar
Ha, I read the whole thread and remember the my little pony reference but I read it before I got my set. That sucks, hope I don't have to replace it. My motion settings are also all set to 0.
poop-dog is offline
post #829 of 1546 Old 03-06-2018, 01:27 PM
TheZoof's Avatar
Quoted: 149 Post(s)
Liked: 54
I was looking to pull the trigger on one of these 82" size. This sounds like a major issue to me.
Does the same issue occur if running through the AVR?
Are there any other major issues with this model TV?
Zoof
Theater || 82NU8000 | Pioneer SC-LX901 | Paradigm 85F - 55C - 15B - E80R | Syzygy SLF870
Rec || Pioneer KRP 500m | Pioneer SC-25 | PSB B25
Casual || LC-65LBU591C
TheZoof is offline
post #830 of 1546 Old 03-06-2018, 07:43 PM
Synomenon's Avatar
Quoted: 93 Post(s)
Liked: 36
I had the same issue with my PS4 Pro. and UN65MU8000. Swapped the HDMI cable out with a premium certified one from Monoprice and updated firmware / software of the TV and PS4 and this seems to have fixed the issue.
post #831 of 1546 Old 03-06-2018, 08:05 PM
WCW1's Avatar
Liked: 1
Question Great TV for the money
I have had this set mu8000 55 inch for several months and it has been exceptional. Very happy with the TV.
One thing I notice is what I call a Flashbulb Effect. Every once in a while the picture will flash like a camera flash going off. It does not happen very often or channel specific. I am inclined to think that it is a provider problem, Dish Network, more so than the TV.
WCW1 is offline
post #832 of 1546 Old 03-07-2018, 07:09 AM
SkyYYZ's Avatar
Quoted: 266 Post(s)
Liked: 204
Does it happen with other sources, such as streaming Netflix or watching a movie from external HDMI sources (i.e. BDP, AppleTV, Roku, etc.)
The reason I ask is you could try different HDMI cables for your Cable TV box and Satellite receiver. I wasted so much time trying to troubleshoot a recent issue because I believed the supplied HDMI cable for one of my devices was of good quality. Wrong! Turns out that when I swapped it out with my own certified cable the issue vanished.
Just a thought... that or just try reseating your current HDMI cables at both ends to ensure full and proper connection.
SkyYYZ is offline
post #833 of 1546 Old 03-07-2018, 02:15 PM
Liked: 8
Is the one connect feature a good or bad thing?
DesiD is offline
post #834 of 1546 Old 03-07-2018, 02:18 PM
Quoted: 481 Post(s)
Liked: 369
I personally love it as it has all the connections in one spot and 1 cable to the tv. Mind you, what is a plus is also a minus as some people hate it as maybe they had HDMI in wall installed for the tv and not realizing it’s a completely different cable.
DesiD likes this.
post #835 of 1546 Old 03-07-2018, 02:59 PM
Quoted: 44 Post(s)
It's probably the TV hidden camera taking it's weekly picture of you
I'm joking of course.
SkyYYZ comment is right. The HDMI cables can cause various issues. Make sure you are using "Certified" HDMI cables. Depending on how long you need the cables, Belkin has a 6.6 ft Ultra High Speed HDMI Cable. Monoprice has longer "Certified" High Speed HDMI cables. There may be other cables out now that other forum members can recommend.
Also, buy an extra HDMI cable to use for future troubleshooting. You can swap out the HDMI cables to see if one has gone bad. Just make sure to label at least one of them.
4K Samsung MU9000 TV | Pioneer SC-LX502 | Sony X700 | Apple 4K TV
Streaming Vudu (TV App) with Atmos
PacificCoast1 is offline
post #836 of 1546 Old 03-07-2018, 04:11 PM
josh6113's Avatar
Quoted: 263 Post(s)
Liked: 117
I agree with the above.I just bought a 65 inch mu8000 and love the picture it displays.So far it's been flawless as I've only had it a few days.I will update more in the coming weeks with pics.Wonderful picture so far...really an amazing picture.
Sent from my MHA-L29 using Tapatalk
Hairsonfire likes this.
Doing what I do best...LIVIN!
josh6113 is offline
post #837 of 1546 Old 03-08-2018, 01:02 PM
Liked: 8
HELP!!
Can someone who has their set (65 inch) on the stand; how many inches is it from the surface it sits on to the bottom of the screen.
My entertainment center is 30" and I am afraid it will be too high to sit on.
DesiD is offline
post #838 of 1546 Old 03-08-2018, 03:39 PM
Teeter's Avatar
Quoted: 32 Post(s)
Liked: 36
Being a new owner of an 82MU8000, I thought I’d weigh in. So far, I’m thoroughly impressed! I set out to buy a Sony 75x900e (which theoretically is a better television) but I saw them side by side at Best Buy and the Sammy simply looked better with the exact same content. Ultimately, we don’t watch features and specs, we view images, colors, etc., and this tv is really good. The extra real estate makes a huge difference, too, particularly with UHD content. I also like the way it works in tandem with my Samsung Blu-ray player (M9500) to automatically select the best settings on both tv and br to get the best picture. Given the reasonable price tag, I’m blown away by the quality of images I’m seeing. Yay!
5.2.2 HT: Denon AVR-x3400h receiver, Definitive Mythos speakers (One’s front, Three center, Gems rear, Di 6.5R’s in ceiling), Dual Rythmik FV18 subs, Samsung UN82MU8000 tv, Samsung UBD-M9500 blu-ray, Sonos Connect music streamer
Teeter is offline
post #839 of 1546 Old 03-08-2018, 06:57 PM
SkyYYZ's Avatar
Quoted: 266 Post(s)
Liked: 204
82" would look ridiculous in my place! Seriously hahaha. The largest TV I could accommodate even in my living room would be a 65". The only reason I was able to pull off a 55" MU8500 in the bedroom was because of the curve. Zero regrets and the only real issue that comes to mind is some minor flashlighting.
Judging by the relatively quiet Owner's Thread it signifies to me that most of us are pretty content with our price/performance ratio. I bought mine last November and it still makes me happy every time I turn it on
MrRoy, Hairsonfire and Synomenon like this.
SkyYYZ is offline
post #840 of 1546 Old 03-09-2018, 05:29 AM
Quoted: 33 Post(s)
Liked: 6
Really nobody can help me understand, why the hell my screen keeps flashing like this randomly between two scenes in movies?
SpAwN_BG is offline
Reply LCD Flat Panel Displays
2017 model , high dynamic range , Samsung
