*OFFICIAL* 2017 Sony XBR-X940E - Owner's ONLY Thread (No Price Talk) - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 8519Likes
post #4171 of 9084 Old 11-30-2017, 08:39 AM
chunon's Avatar
Quoted: 3750 Post(s)
Liked: 3562
Originally Posted by Czickefoose View Post
So yes, hooking up directly to the TV worked. It's weird, I hadn't had that issue before. I guess maybe a firmware update somewhere in the chain caused it. Doesn't really matter since I would have had to hook it to the TV anyway to get DV as the receiver doesn't look like it will get the update for it.
Glad you got it resolved
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is online now
post #4172 of 9084 Old 11-30-2017, 10:56 AM
kennyob46's Avatar
There was a software update this morning.Anybody know what it was for?
kennyob46 is offline
post #4173 of 9084 Old 11-30-2017, 11:00 AM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
Sony website still only shows the early November Google Assistant update.
ROMIL is offline
post #4174 of 9084 Old 11-30-2017, 04:30 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5804
Well, Chad B finished up today with an SDR, HDR and audio cal. Took about 5.5 hours. Will post charts for HDR and SDR, do not @me for explicit settings, that is what Chad works hard for.
Some bits:
  • The SDR cal I did in Cinema Pro with my Calman setup was pretty dang good and about what I expected. Chad has better stuff and used 10pt and dialed SDR home in Cinema Pro. As I found, if you flip over to HDR and use the SDR white balance settings, it maps over pretty good but he did a separate pic mode for HDR to really dial it in.
  • Put up a pattern with a small zero black box in middle and white everywhere else, MLL was 0.001 fL (better than a VT60) and contrast ratio was 48k to 1, the thing is a beast.
  • Got her dialed in for HDR mode, taught me a few tricks for settings to get the most out of the mode, stuff I never would have thought of. As always great service.
HDR before and after charts:
Name:	HDR White Balance.png
ID:	2323816   Click image for larger version
ID:	2323818   Click image for larger version
Name:	HDR Luminance.png
ID:	2323820   Click image for larger version
Name:	HDR Gamut.png
MCaugusto, njfoses, chunon and 1 others like this.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP502S / FV15HP
gadgtfreek is offline
post #4175 of 9084 Old 11-30-2017, 04:36 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5804
SDR info below. He sacrificed a little on the gamut to get better color checker results, mainly for fleshtones. Keep in mind the before White Balance is pretty good because that is after I used my meter, when I did it, it was real blue.
Name:	SDR White Balance.png
ID:	2323826   Click image for larger version
Name:	SDR Gamma.png
ID:	2323828   Click image for larger version
Name:	SDR Gamut.png
chunon and audiofan1 like this.
XBR65A9G / XBR65A8F
post #4176 of 9084 Old 11-30-2017, 10:13 PM
Champion14's Avatar
Liked: 1
Question about sound. I have a Denon AVR X3300W. along with my XBR940E. I also have DirectTV. My DirectTV remote. I can push power on it and t.v. and the DirectTV receiver will power on. A few seconds later the receiver will power on and It will say switching to audio receiver speakers. Then I get sound. Sometimes when I do the same process I get no sound. I can do several different things. I can go into t.v. settings to switch sound to tv speakers. Then sometimes that gets me sound thru the t.v. speakers and I can switch it back to audio speakers and then it plays thru that. Sometimes it takes going back and forth between the two different speakers or powering off the receiver to finally get it to come on automatically. What settings should I check? Thanks Brian
Sony XBR X940E
Denon AVR X3300W
Champion14 is offline
post #4177 of 9084 Old 12-01-2017, 03:58 AM
njfoses's Avatar
Quoted: 310 Post(s)
Liked: 180
Some bits:
Did Chad calibrate with dimming on or off?
njfoses is offline
post #4178 of 9084 Old 12-01-2017, 05:07 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5804
Cal with it off. Turn it on when done.
chunon likes this.
XBR65A9G / XBR65A8F
post #4179 of 9084 Old 12-01-2017, 05:43 AM
Liked: 4
Got mine on Wednesday. I went from a cheapo 2012 E-Series Vizio 55" 1080p to this baby.
I expected a great picture, but I am simply blown away by this TV! Paired with my Apple TV 4K, this TV just is... awe-inspiring. AND I haven't done any calibration or tweaks yet (except switch smooth motion off)...
I am amazed by the inky blacks, which leads me to question - how much better are OLED's if this TV can do this well? Wow. Admittedly, my frame of reference might be a little skewed since I've transitioned from such a ****ty TV.
Funnily enough, even though I was all up in arms about the lack of DV on this TV, so far - viewing DV content in HDR10, looks A-OK to me. :P When the DV update does roll in, it will be the icing on the proverbial cake.
Now, back to watching Spider-man:Homecoming.
MCaugusto, slinger45 and audiofan1 like this.
timothevs is offline
post #4180 of 9084 Old 12-01-2017, 10:44 AM
619liquid's Avatar
Originally Posted by chunon View Post
Most people go for day, night hdr and maybe a mode for games. Sports is usually not a separate cal .
Thanks Chunon.
I found 2 calibrators here in SD $199 & $129. Does anyone else have recommendations? Thanks in advance.
619liquid is offline
post #4181 of 9084 Old 12-01-2017, 10:58 AM
chunon's Avatar
Liked: 3562
Originally Posted by 619liquid View Post
Thanks Chunon.
Thats pretty cheap, make sure you get some references . if one is Geek Squad I do not recommend them .
LG 77C8
LG 55B7A
post #4182 of 9084 Old 12-01-2017, 11:25 AM
BDP33's Avatar
Quoted: 113 Post(s)
Liked: 44
Hello,
I've been an AVS member for years now and it's that time for me to upgrade my home theater TV to something else. Mainly to take advantage of the Xbox One X I recently purchased and to start watching 4K movies via Amazon and Netflix. I've currently got a 60" Panny GT50 in there and want to go BIGGER! Imagine that! At any rate the 940E is on my short list largely because it sits between the 900E and Z9D and is much cheaper than the Z9D. Plus from what I've read while it does have less zones than the Z9D it puts up a pretty remarkable picture.
Couple questions that I have if anyone can help...How is gaming on this TV? I'm not a "hardcore" gamer but I'm known to chew through some games. Shockingly my GT50 has managed over the last 4 years to not experience any burn in but it does exhibit IR which quickly goes away. I want to make sure from actual owners what their experiences are. I've seen some people return this set because of the motion issues in gaming.
Also, how is the viewing angle in comparison to other FALD sets. I'm "assuming" it can't be any worse than my 2015 Vizio P series....maybe better? Does its size make the the viewable angle better?
Last question, how is blooming? More specifically into the black bars of movies? One thing that kills the immersive nature of viewing for me is blooming into the bars or light bleed.
BDP33 is offline
post #4183 of 9084 Old 12-01-2017, 11:41 AM
Quoted: 53 Post(s)
Liked: 6
Originally Posted by BDP33 View Post
Hello,
Also, how is the viewing angle in comparison to other FALD sets. I'm "assuming" it can't be any worse than my 2015 Vizio P series....maybe better? Does it' size make the the viewable angle better?
I too am very interested on recent updates on gaming, specifically 4k gaming. Do you experience any blur from this particular type of gaming?
Mre_man is offline
post #4184 of 9084 Old 12-01-2017, 02:54 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6316 Post(s)
Liked: 6321
Thanks Chunon.
Thats real cheap, watch yourself......... Chad B and D-Nice are no where near that price and "usually" you get what you pay for......
Cleveland Plasma is online now
post #4185 of 9084 Old 12-01-2017, 03:11 PM
619liquid's Avatar
Thanks guys. Anybody use this guy: http://www.coastcalibration.com/
post #4186 of 9084 Old 12-01-2017, 03:17 PM
Liked: 0
Hello,
So I had my TV replaced after it came DOA and I am now having an issue where it really seems like I suffer from pretty bad dirty screen effect.
How might I test this? Can other users report?
I do see a pretty noticable color change when a scene pans or changes view points.
Wesley Balmer is offline
post #4187 of 9084 Old 12-01-2017, 03:44 PM
Liked: 1
Originally Posted by Wesley Balmer View Post
Hello,
I’ve now had the X940e for 5 days, and my biggest complaint is DSE. Overall, this is an excellent TV, though I’m struggling with the vertical banding that shows up in panning scenes. I think it’s been mentioned before that poor uniformity is inherent of these large screens, and varies between panels. Coming from a flawless plasma, I’m a little disappointed. I think I’ll just learn to live with this flaw (and because my store has discontinued this model, I can’t exchange for the same TV).
BadBanana is offline
post #4188 of 9084 Old 12-01-2017, 03:50 PM
chunon's Avatar
Liked: 3562
I rarely see DSE but have seen it on a rare occasion .
LG 77C8
LG 55B7A
post #4189 of 9084 Old 12-01-2017, 03:57 PM
audiofan1's Avatar
Quoted: 2275 Post(s)
Liked: 2775
DSE is a fact but to what degree varies , how is the 940e discontinued seeing it was only released in the spring
audiofan1 is offline
post #4190 of 9084 Old 12-01-2017, 04:12 PM
Liked: 1
The X940e isn’t discontinued. The small electronics chain that I bought it from has decided to stop carrying the model. I have no idea why, but they gave me their last one at a clearance discount - I’m not complaining
audiofan1 likes this.
post #4191 of 9084 Old 12-01-2017, 04:38 PM
Liked: 1
Here are shots of my screen using a 50% grey background
ID:	2324232   Click image for larger version
post #4192 of 9084 Old 12-01-2017, 04:39 PM
Alby00003's Avatar
Quoted: 34 Post(s)
Liked: 37
Hello,
Regarding black bars......they are black!
and
Viewing angles are better that what you might have read about.....I mostly sit near head on to the display but they seem quite good.
Alby00003 is offline
post #4193 of 9084 Old 12-01-2017, 08:35 PM
antennahead's Avatar
Quoted: 335 Post(s)
Liked: 242
I too came from an excellent ZT60. I think what you're seeing is not dirty screen effect, but clouding..... something inherent to LED, most noticeable when viewing at an angle, but sometimes visible depending on the color and background of the image on the screen. This drove me crazy at first on my 940E, but it isn't visible at all on my set during normal viewing from my prime seating position. If I go considerably off axis I can still see it on a scene with a solid overcast sky, for example. I stopped worrying about it because I virtually never watch at that extreme of an angle. YMMV :
https://www.rtings.com/tv/tests/pict...-flashlighting
chunon likes this.
antennahead is offline
post #4194 of 9084 Old 12-01-2017, 09:52 PM
LoudDad's Avatar
Quoted: 72 Post(s)
Liked: 56
I suspect it's mostly related to viewing angle which is a known issue with all LCD panels.
It's also possible that the 4 corners will have slightly dimmer whites, but not sure if that is also because of viewing angle.
For that head-on shot, if you back up in your room (if possible) does the difference get less?
LoudDad is offline
post #4195 of 9084 Old 12-02-2017, 10:22 AM
619liquid's Avatar
Just want to say thank you for those that helped me with my drop out issue with the ps4 pro while gaming, I haven't had the problem since Now I want to get my tv calibrated, however i'm debating on getting new HDMI cables. My buddy who works for AT&T gave me the ones he uses for at work. What do you think?
post #4196 of 9084 Old 12-02-2017, 11:29 AM
gdfein's Avatar
Quoted: 100 Post(s)
Liked: 49
Hi all. I just joined the club with my new 75” 940e. I have skimmed the 420 pages of posts so likely missed it but can someone direct me to a post# that has settings that many of you use for picture? I know in the Z9 thread D-nice and others have some recommended settings so curious if the same here.
gdfein is offline
post #4197 of 9084 Old 12-02-2017, 11:31 AM
chunon's Avatar
Liked: 3562
There is a spreadsheet that was posted by ht guy within the last month that is probably the best source of settings .
LG 77C8
LG 55B7A
post #4198 of 9084 Old 12-02-2017, 02:12 PM
Liked: 5
I have the virtually the same setup except with Dish Network. Are you using ARC/CEC? I use a Harmony 650 to control the TV, receiver and Dish. I use two setups, one goes through a soundbar mainly for news, and the other through the receiver for more serious watching. I do not use ARC as in the past its only caused me grief. Unless you're really fond of the DirecTV remote I'd suggest the Logitech. Its inexpensive and easily programmed for just about anything you could need including power on sequence, input selection for your TV and receiver and assignment for which device to use for channel switching and volume.
GPMAZ is offline
post #4199 of 9084 Old 12-02-2017, 04:14 PM
Liked: 1
The banding/DSE/clouding (which ever it is) is fortunately not visible in the majority of content. I took the off angle photo to highlight the issue, but it is still very visible at small angles from center. The darkish bands show up mostly in bright panning scenes with uniform background (i.e. sky shots), or snowy scenes (i.e. ski films).
I think this flaw is a minor trade-off for all the other excellent qualities of this TV. I wont be returning it.
I had originally walked into the store to buy a Panasonic OLED, and somehow walked out with the X940E instead - no regrets!
post #4200 of 9084 Old 12-02-2017, 04:28 PM
Quoted: 16 Post(s)
Liked: 5
Hi everyone, any thoughts on the new HDMI standard and how this set could benefit from it?
Sent from my SM-N950U using Tapatalk
AKG1 is offline
Reply LCD Flat Panel Displays
signal loss
