*OFFICIAL* 2017 Sony XBR-X940E - Owner's ONLY Thread (No Price Talk) - Page 309 - AVS Forum | Home Theater Discussions And Reviews
 8646Likes
post #9241 of 9348 Old 07-19-2019, 01:00 PM
no_cure's Avatar
Quoted: 187 Post(s)
Liked: 135
@ggw2000 : makes sense what you're saying, angle of the panel could make a drastic difference.
However, it all depends on the height of the TV and how far away the main viewing position is. Both my 940Es are hanging on the wall, I'd say about 16-17 cm (about 42 inches) from the floor, measured from the bottom of TV frame. I slightly tilt the panel towards the main viewing position, and that minimizes any light reflections and ensures I'm looking straight on.
no_cure is offline
post #9242 of 9348 Old 07-19-2019, 01:36 PM
Quoted: 38 Post(s)
Originally Posted by Gillietalls View Post
Have you tried the built in Kodi app? That's what I use to stream all my ripped content from a networked attached storage. The video app is terrible IMO.
Thanks for the tip. Maybe I'll try this. I'd prefer this kind of solution. I've bought android boxes in the past (KDlinks A300), and they're not bad, but I find they got outdated pretty quick.
Will try to set this to link with my desktop that I download my content to.
thanks.
Gillietalls likes this.
WabbaJ is offline
post #9243 of 9348 Old 07-19-2019, 03:18 PM
ggw2000's Avatar
Quoted: 845 Post(s)
Liked: 431
I'm about 10' from TV. Also about level with the middle of the screen as I built my stand to be that way .
Gerry
[email protected] likes this.
Sony XBR 75X940E - Sony STR-DH790 ATMOS - Sony UBP-X700 UHD BD Player - ATV 4K
ggw2000 is online now
post #9244 of 9348 Old 07-19-2019, 03:46 PM
Quoted: 90 Post(s)
Liked: 66
With the latest update came a long laundry list agreement to sign off on. I was surprised to see that the remote control microphone can be activated so that it is always "listening". Who in the world would want that? I sometimes think my cell phone is doing it.
[email protected] is offline
post #9245 of 9348 Old 07-19-2019, 09:46 PM
Liked: 0
Originally Posted by ggw2000 View Post
Since buying my 940E in March/18 it always had quite a bit of lean back to it. Way more than it should or necessary. Today I decided to make 2 pads for under the back two feet to correct the problem. I started with two 3/8" pieces but that brought it to a little more than past straight. Although it was still stable I decided to make a couple more at 1/4". That worked as it just very slightly leans back from straight..
I swear that the PQ looks even better now [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]... Placebo i'm sure but whatever works..
Gerry
ps: I see that it went back up 200 on Amazon. If I had more storage room I swear I would buy a backup instead of dreaming about a 77 OLED if it goes back down to where it was the other day...
Thats very worrisome to me. My 940e stands perfectly straight up. Zero lean. Maybe you should consider looking over the stand installation. Its a very heavy TV, any lean could place a lot of unnecessary stress on the build.
VCarnage is offline
post #9246 of 9348 Old 07-20-2019, 05:45 PM
Quoted: 242 Post(s)
Liked: 172
Mine leans back on top too but I assume its to keep the weight towards the rear, if it was vertical it would be easier to tip forward. Otherwise it has to be quite a bit of force to push it off the center of gravity and then up and over the angled feet. I would be scared to make it level.
boosted330 is offline
post #9247 of 9348 Old 07-21-2019, 07:40 AM
kanti123's Avatar
Quoted: 73 Post(s)
Liked: 51
Originally Posted by boosted330 View Post
Watching 4k movies in hdr from my samsung player seem dim. Is there a setting I dont realize needs set? Brightness is maxed, local dimming high, all motion settings off, and all that, watching on cinema home, I have Eco turned off but maybe I’m missing something?
For HDR and Dolby vision, brightness need to be at max, local diming: medium, xtended dynamic range: high. Smoothness: Max, clear:min. Recommendation from Calman calibration guide.
kanti123 is offline
post #9248 of 9348 Old 07-22-2019, 01:20 PM
Quoted: 242 Post(s)
Liked: 172
Turns out its just my 4k version of Arrival. I havent watched it in a while and the whole movie is darker. Mad Max can get blinding bright so its not the TV
Sony 75x940e l LG B6 65" | Denon X4000 | Definitive Technology SM65 (L/R) | Definitive Technology Mythos 10 (C) | HSU VTF-3 MK5 HP
post #9249 of 9348 Old 07-29-2019, 09:59 PM
Liked: 0
Hello everyone!
There’s been quite a few major firmware updates released since I personally chose user @10k calibration settings. I was just wondering, if after all these firmware updates, is 10k ‘s settings still current/valid? Is there a clear choice on what settings are now preferred?
Thank you so much!!
agilis is offline
post #9250 of 9348 Old 07-30-2019, 11:50 AM
Quoted: 242 Post(s)
Liked: 172
Originally Posted by agilis View Post
Hello everyone!
Thank you so much!!
10k settings are for a z9D and its actually a different panel than the x940E. You can use any settings from anyone other than color correction, those vary from screen to screen and it may hurt your grey scale more than help.
post #9251 of 9348 Old 08-02-2019, 02:39 PM
Quoted: 242 Post(s)
Liked: 172
I have found very good results playing with Reality Creation and Black level. Reality Creation around 70-80 really makes the image look great and Black Level at 48 seems to really enhance the blacks the TV can produce.
On the Interstellar Blu-ray on a all star field picture space 50 is to high of a setting and is very dark greyish black, 47 really is black but starts crush blacks, 48 is best of both worlds shadow detail and retains most shadow detail. 50 shows too much shadow detail and blacks are not black enough.
post #9252 of 9348 Old 08-03-2019, 07:50 AM
Quoted: 90 Post(s)
Liked: 66
More on dual layer LCD panels.
antennahead likes this.
post #9253 of 9348 Old 08-05-2019, 12:45 PM
atabea's Avatar
Quoted: 769 Post(s)
Liked: 650
Soooo, I was finally able to pick up my 940E from my friend in Bufallo. Crossing the Border back into Canada was smooth and, for some reason, I was only charged half the amount I was supposed to pay even though I provided full disclosure via the printed invoice. You guys weren't kidding; this TV is a beast both in terms of size and weight. You really need at least two people to move, unpack and set up this unit. After a quick calibration (I used my i1Display 3 pro colorimeter and Chromapure software to do a 10 point greyscale) I ended up with low 0.8 DE average. Based on before and after measurements, the 940E does not need extensive adjustments to get color and gamma squared away, but if you have the tools to make those final little tweaks, it is well worth the effort.
So far, I have sampled a variety of material and this TV does NOT disappoint!!!. Upscaled 1080P bluray and even DVDs look amazing. However, where the 940E really shines is with well authored 4k/HDR discs. This TV was made for HDR. I was afraid that, being LED/LCD, the black levels would be too much of a weakness but unless you have a OLED TV right next to it, I have to say the blacks are more than acceptable and even --impressive. The ONE area that I have found to be noticeably weak is --motion. I find that it is more noticeable in streaming content and significantly less of a problem with watching good ole blu ray and 4K discs.
Overall, the 940E is a wickedly good set and easily the best I have ever owned. At the price for which it is currently available I am surprised there are any left. Anyone still on the fence about picking up one of these last remaining samples should jump at it. At even twice the current price, I would still consider it a bargain.
MCaugusto and tysonmax like this.
atabea is online now
post #9254 of 9348 Old 08-05-2019, 01:08 PM
ggw2000's Avatar
Quoted: 845 Post(s)
Liked: 431
What are you using for motion settings?
Gerry
post #9255 of 9348 Old 08-05-2019, 01:19 PM
atabea's Avatar
Quoted: 769 Post(s)
Liked: 650
Gerry
Will confirm when I get home, but as of last night I think I started using Motionflow: Custom, Clearness: 0, and Cinemotion: Off.
post #9256 of 9348 Old 08-05-2019, 01:31 PM
JohnnytheSkin's Avatar
Quoted: 83 Post(s)
Liked: 53
What did you settle on with the color and grayscale controls? Care to post your settings?
Enjoy the set!
Sent from my Pixel 3 XL using Tapatalk
JohnnytheSkin is offline
post #9257 of 9348 Old 08-05-2019, 01:41 PM
atabea's Avatar
Quoted: 769 Post(s)
Liked: 650
Enjoy the set!
Sure, will post later.
JohnnytheSkin likes this.
post #9258 of 9348 Old 08-05-2019, 02:25 PM
Gillietalls's Avatar
Quoted: 1531 Post(s)
Liked: 1587
I could be wrong but Interstellar is not a good movie to adjust settings to. Especially the black level. This movie is known for having elevated blacks (mastered incorrectly). Or actually could be on purpose. Only Nolan knows. But adjusting your settings to this movie could throw off the picture in other movies...
LG 77C8, Sony 75x940E, LG 65B7, LG 65EF9500, LG 55E6, LG 55UB8200, 2 TCL 49S515's
2 Apple 4K TVs, 2 LG UP970's, 2 Samsung UBD-K8500s, WD 4TB NAS
Nvidia Shield, Wii U, Playstation 3
Gillietalls is offline
post #9259 of 9348 Old 08-05-2019, 03:08 PM
ggw2000's Avatar
Quoted: 845 Post(s)
Liked: 431
Try: Custom/ Smoothness 3/ Clearness Min....
Gerry
post #9260 of 9348 Old 08-05-2019, 03:36 PM
atabea's Avatar
Quoted: 769 Post(s)
Liked: 650
Gerry
Will do. Thanks!
post #9261 of 9348 Old 08-05-2019, 08:31 PM
Quoted: 242 Post(s)
Liked: 172
Gerry
Will do. Thanks!
Personally I find
Motionflow True Cinema
CineMotion High
To be very nice for motion. Smoothness at 3 has Soap Opera Effect in my opinion but with my settings above its below my level of sensitivity.
post #9262 of 9348 Old 08-05-2019, 08:35 PM
Quoted: 242 Post(s)
Liked: 172
I was unaware of this, however other space things I have watched like the free copy of Passangers I got with the play store also looked better at 48 over 50 as did the UHD of Pacific Rim. Do you know of a good movie to adjust to? I don't have a test pattern DVD. I just know what my OLED shows vs my Sony at 50 and at 48 I have more shadow detail than my B6 (which crushes blacks anyway) and the black level is much closer to the OLED at 48.
post #9263 of 9348 Old 08-05-2019, 09:08 PM
Quoted: 242 Post(s)
Liked: 172
Sorry for multiple postings,
Rewatched the opening to Gravity Bluray. I use the scene where the camera is on George Clooney and then pans to earth. The camera then slowly pans over earth and back to George for motion. My LG is either soap opera or stutter fest. With my motion settings above it has very very slight stutter but anymore smoothness and I get soap opera and I’m fairly sensitive to it and dislike it. To me these are perfect settings.
For black level I check at the scene where Sandra Bullock is spinning away from the camera(16:29 time stamp). A second the camera adjusts and the stars in the gas field become elevated and stars get brighter. On OLED this is the one of the most amazing scenes an OLED can render in my opinion. On the X940e I paused it at this scene and went between black level at 50, 49, 48 and 47. I took my hand and covered the menu on screen so my eyes would adjust to the black level and again 48 seems the best mix of deeper blacks without losing details. I think at 50 it reveals a little to much shadow detail and makes space appear lighter and grayish. At 48 space is darker and black bars appear to be a little darker too. I feel this matches my OLED better as this scene doesn't have crushed blacks on the OLED.
This is all preference not reference but blacks seem better to me without loosing details.
post #9264 of 9348 Old 08-06-2019, 02:52 AM
Liked: 1587
Unfortunately, I do not. And I don't have a pattern disc as well. But it's like you said, it's preference over reference. I just remember a long time ago the Interstellar movie was a big issue in the Master HDR thread. A lot of people were commenting negatively on how Nolan mastered that movie. No biggie though. As long as you like what you're seeing, is all that matters! Enjoy my friend!!!
post #9265 of 9348 Old 08-07-2019, 11:40 AM
Liked: 1
Please help!
Thin vertical blue line appeared on the right side of my XBR75x940E.
I bought this thing from buydig.com in January 2017, so 1 year warranty is over.
The VISA i used to buy it with only covers its an additional 1 year? So that would mean Jan 2019, its already August so thats probably a no go as well im assuming.
Called a few repair shops in my area.
Without inspecting the TV, one shop told me over the phone that this was a Screen issue and it'll cost too much to fix (better off buying a new TV). He also mentioned this was a very common problem with this specific model.
another shop said it could be the screen or one of the boards inside and wanted to charge me $75 to open it up and inspect.
What are my options here. anything i haven't thought of with regards to the warranty? is it even worth it having it inspected to see if the problem is fixable?
really sucks. TV is barely 2.5 years old. was hoping this thing would last me at least 7 years
pennypincher10 is offline
post #9266 of 9348 Old 08-08-2019, 07:23 AM
Quoted: 90 Post(s)
Liked: 66
in the troubleshooting guide, colored lines most likely defect is the panel. The secondary possible failures could be B*board, Tcon board or V By One FFC. but I would think if a board failed you would have blinking red lights on the front display. Can I ask if this TV is mounted on a wall or is it on a stand?
post #9267 of 9348 Old 08-08-2019, 11:12 AM
Liked: 0
When viewing a solid gray screen (the welcome screen of Amazon Prime Video), I can see image retention from a news logo from a station I watched earlier. If I turn the TV off for several hours, it looks like the ghost image goes away. Is this normal and has anyone suffered permanent screen burn in from cable news channel logos and ticker feeds?
fixmysony is offline
post #9268 of 9348 Old 08-08-2019, 12:17 PM
bwillcox's Avatar
Quoted: 932 Post(s)
Liked: 539
I have never seen this on my set. But then, I don't watch any news feeds with permanent junk on the screen. From what I've read in the past LCD displays can have short term retention, but unlike OLED it isn't permanent and does go away in a while.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is online now
post #9269 of 9348 Old 08-08-2019, 01:26 PM
Seryl's Avatar
Quoted: 160 Post(s)
Liked: 105
That has been my experience, the image retention will go away. A few months ago I posted here with a similar question. My house sitter must have watched a lot of ESPN because I could see the ghostly logo on some screens after I returned home. I thought it was burn-in but someone here clued me in about image retention. I was very happy to learn the difference.
Seryl is offline
post #9270 of 9348 Old 08-08-2019, 03:43 PM
Cam1977's Avatar
Quoted: 3053 Post(s)
Liked: 3761
^I see IR on my 940e all the time, especially after watching letterbox movies, but it quickly goes away.
Cam1977 is online now
Reply LCD Flat Panel Displays
signal loss
