Vizio Smartcast 2016/2017 E-Series Thread (Now HDR10 Compatible via HDMI & Cast) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 88 Old 02-10-2018, 03:11 PM
Liked: 0
Where can i find the setting for a E55-E1?
joeam is offline
post #32 of 88 Old 02-12-2018, 03:14 PM
rjhseven's Avatar
Quoted: 639 Post(s)
Liked: 103
Can these new SmartCast Vizios get screen burn in? Went down to basement TV room and new Vizio had been left on the Cast input with nothing playing and there evidently is no screensaver on these units. Had a nature image up and Had been that way 3-4 days.
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
post #33 of 88 Old 02-20-2018, 09:27 AM
lewinr's Avatar
settings
Just wondering what people's recommendations are for settings for color calibration and other picture quality features for the best picture for home cinema on the E70-E3? (sources are generally 4k or 1080p HDR, either from disc or streaming).
Do you use "calibrated" or "dark calibrated"? Have any of you done a real calibration using testing equipment?
I'm interested in whether it makes sense to turn on: Black Detail, Xtreme Black Engine, Clear Action, Reduce Signal Noise, Reduce Black Noise, and Pure Cinema. I generally turn all these things off, but I wonder if anybody has done any real testing to understand which of these features it is reasonable to enable.
lewinr is offline
post #34 of 88 Old 03-11-2018, 05:48 PM
David Biagas's Avatar
Quoted: 154 Post(s)
Liked: 46
Since only hdmi 1 (arc) supports hdr can I connect all of my devices to an hdr-capable receiver using the arc port to get hdr support on all of them? I would like my 4K Blu-ray player and ps4 to both be hdr capable. When I hook them up to the receiver (hdmi inputs) do they all play on hdmi one arc of the tv now? Do I switch devices using the av receiver remote?
Vizio M75-E1 || Onkyo TX-SR393 || Sanyo 4k Blu-Ray || Apple TV 4k || DCM TP160 TP160C
Vizio M70-D3 || Onkyo TX-NR686 || Xbox One X || Apple TV 4k || DCM TP260 TP160C
Optoma UHL55 || Pioneer SC-95 || Sanyo 4k Blu-Ray || Apple TV 4k || DCM TFE100 TFE60 TP160 Crown XLI1500
David Biagas is offline
post #35 of 88 Old 08-15-2018, 10:37 AM
vincentfam's Avatar
The Start of the Settings: Vizio E65-E1
Greetings Colleagues,
I am the Vincentfam, newly owner of the Vizio and formerly owner of a plasma hdtv, thanks to the daughter.
I am here to post settings for the Vizio E65-E1, using hcfr free software and the colormunki colorimeter for a slightly dim viewing room. I made many attempts before posting these settings, trying first setting gamma at 2.2 and targeting color temperature for D65. The initial picture appeared too dark with possible black crush, so I reset gamma at 2.4 and targeted a color temperature at 8000K for red and blue levels, set the brightness setting using the pluge pattern from the DVE HD disc and the sharpness setting with the DVE pattern. The contrast setting was adjusted for a measurement of 55 ftL @ 100% window pattern in a slightly dim viewing room. The color and tint settings were checked using DVE's color filters and the color pattern from the free AVS Forum disc. Field patterns were used from the AVS Forum disc as well. I had to slightly adjust blue offset in the color tuner section to level out the gamma curve. All enhancements were turned off.
As I become more familiar with Vizio's menu settings, I will post more settings. Please let me know if you want me to post the hcfr graphs, etc.
Here are the settings:
Aspect Ratio: Normal
Picture Mode: Standard
Auto Brightness: Off
Backlight: 100
Brightness: 51
Contrast: 43
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Temperature: Normal
Turn off all enhancements
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Red Gain: -47
Green Gain: 0
Blue Gain: 14
Red Offset: 0
Green Offset: 0
Blue Offset: 1
Your colleague in picture quality,
The Vincentfam
vincentfam is offline
post #36 of 88 Old 08-16-2018, 04:48 PM
vincentfam's Avatar
Settings Using Color Tuner
Greetings Again Colleagues,
Herein is another updated posting of settings for the Vizio E65-E1, this time primarily using Vizio's color tuner instead of DVE's color filters to adjust primary and secondary colors and using "Calibration For Dummies" as a reference. The contrast was set for 50 ftL @ 100% White window pattern. I think that the picture quality improved.
Here are the updated settings:
Input Settings: HDMI-1, Full UHD Color: Off
Backlight: 100
Brightness: 50
Contrast: 41
Color: 50
Tint: 0
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -44, Green 0, Blue 15
Offset: Red 0, Green 0, Blue 0
Saturation: Red 17, Green -9, Blue 0
Hue: Cyan 7, Magenta 11, Yellow -12
The Vincentfam
Tbrooks330 likes this.
post #37 of 88 Old 08-18-2018, 05:27 PM
vincentfam's Avatar
Updated Settings
I made some observations and adjustments to improve picture quality. I tried adjusting the settings to D65 (standard calibration target) but the picture appeared too dark for me. I kept the color temperature at 8000K which gives the picture a slight 3D effect. I turned the tint setting back to 0 (the default setting) and that put the measurements for primary and secondary colors back within standard ranges for these parameters. The hue and saturation settings in the color tuner were set back to 0. Brightness settings in the color tuner were adjusted to bring the color primaries (Red, Green and Blue) to their proper amplitude ranges. This tv has a near perfect tint control. I have abandoned DVE's color filters and adjusted the colors with the HCFR software. I adjusted the contrast setting to 32 to lower the luminance @ 100% white window to 39 ftL, from 55 ftL in the first posting. This reduced my eye strain in looking at the tv is a semi dark room. I will look at more adjustments next weekend and may tweak these settings further.
Herein are the new settings (and thanks for the liked)
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 0
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Brightness: Red 34, Green -5, Blue 1
Gain: Red -48, Green 0, Blue 18
Offset: Red 1, Green 0, Blue 1
Saturation: Red 0, Green 0, Blue 0
Hue: Cyan 0, Magenta 0, Yellow 0
The Vincentfam
post #38 of 88 Old 08-18-2018, 05:37 PM
vincentfam's Avatar
The Vocabulary of Terms
If you are not familiar with the terms or words that I am using in my postings, google "calibration for dummies" the old version, which provides detailed descriptions on the terms used.
As always, your colleague in picture quality,
The Vincentfam
post #39 of 88 Old 08-19-2018, 02:22 PM
vincentfam's Avatar
Brightness Setting in Color Tuner
The picture looks better if you do not adjust the brightness setting in the color tuner.
The updated settings are as follows (changes in bold):
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 0
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Brightness: Red 0, Green 0, Blue 0
The Vincentfam
post #40 of 88 Old 08-19-2018, 02:28 PM
Otto Pylot's Avatar
Quoted: 3870 Post(s)
Liked: 2765
^^^^^ which light meter are you using?
Otto Pylot is online now
post #41 of 88 Old 08-19-2018, 03:45 PM
vincentfam's Avatar
I am using the colormunki colorimeter. It appears to be accurate for greyscale measurements, but either this equipment is lousy on primary/secondary color measurement or this Vizio's color settings are pretty accurate without the need to use a colorimeter. That's why I suggest using only the gain/offset adjustments in the color tuner settings.
Brightness was adjusted using the DVE pluge pattern where the 4% below black bar just disappears. Contrast was reduced to a luminance of 39 ftL @ 100% white window to reduce eye strain in a dim viewing room. Gamma 2.4 setting was used to darken the picture a little while increasing definition. And, the color target was 8000K to keep the colors in the white space of the CIE graph. This creates a 3D effect.
post #42 of 88 Old 08-20-2018, 09:31 AM
vincentfam's Avatar
Final or Near Final Settings
Herein are the final or near final settings for my Vizio E65-E1. I adjusted only the gains and offsets in the color tuner settings and left all other settings in that section to 0. Please note that tint was adjusted to 1 by using the (not abandoned) DVE color filters.
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Leave all other settings in the color turner to 0.
The Vincentfam
post #43 of 88 Old 08-20-2018, 04:54 PM
Otto Pylot's Avatar
Liked: 2765
Colormunki is a decent entry-level colorimeter. Hopefully your settings will be of use to others because component tolerances can vary considerably from tv to tv. At least it's a place to start for those who choose not to learn how to calibrate, or even adjust their panels themselves.
post #44 of 88 Old 08-31-2018, 01:56 PM
vincentfam's Avatar
The UHD Settings
Herein are the UHD settings for my Vizio E65-E1, which will work only on the HDMI-1 input setting. To turn on the UHD, go into the Input Settings for HDMI-1 and you should see the Full UHD Color Setting, and just turn that setting to On. I think that this setting provides a wider color spectrum. I made minor adjustments to the gain and offset settings in the color tuner settings. Changes below are in bold.
Input Settings: HDMI-1, Full UHD Color: On
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -46, Green 0, Blue 9
Offset: Red -1, Green -1, Blue 0
The Vincentfam
rjhseven likes this.
post #45 of 88 Old 08-31-2018, 07:51 PM
vincentfam's Avatar
The UHD Settings - Corrected
The above initial settings for UHD were corrected to avoid black crush, which is the brightness setting too low. If your eyes were hurting while watching the tv with this brightness setting, this may be the reason why. Offsets were adjusted for consistent color temperature of 8000K between 0% and 50% Window patterns.
Please let me know if you want me to readjust the brightness setting for the August 20, 2018 posting. The brightness setting in that posting may be too low as well.
Backlight: 100
Brightness: 52
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Offset: Red -3, Green -2, Blue 0
The Vincentfam
post #46 of 88 Old 09-01-2018, 07:04 PM
vincentfam's Avatar
The UHD Settings - Lighter Picture
To lighten up the picture a bit, gamma setting was changed to 2.2, with a target luminance of 40.5 ftL @ 100% Field White pattern and color temperature @ 8000K. I felt that gamma 2.4 setting may be good for a dark viewing room, but too dark for me. Changes in bold. I think that the picture looks better.
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Gain: Red -46, Green -3, Blue 11
Offset: Red -4, Green -2, Blue -1
The Vincentfam
Last edited by vincentfam; 09-03-2018 at 06:17 PM. Reason: Small changes in Settings
post #47 of 88 Old 09-03-2018, 06:15 PM
vincentfam's Avatar
The UHD Settings - Higher RGB levels
The RGB levels using HCFR software were increased, still targeting color temperature of 8000K. Blue level was adjusted to approximately 127% and Red was raised to 100%, which produced a color temperature of 8000K. (On the previous posting, Blue was at 120% and Red at 90%). I think the color looks better. Changes in Bold.
Backlight: 100
Brightness: 51
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Gain: Red -12, Green 0, Blue 35
Offset: Red -2, Green 0, Blue 1
The Vincentfam
Last edited by vincentfam; 09-05-2018 at 06:51 PM. Reason: Slightly amend settings
post #48 of 88 Old 09-03-2018, 09:37 PM
Bigchingan's Avatar
I bought a 2017 Vizio M75-E1 last fall and put it in my barely used basement. I've started to actually do stuff with it in the last month and have noticed serious backlight and color inconsistencies that may or may not be normal, so I wanted to check with other owners or those familiar with these types of sets before I initiate any type of return or warranty repair. This TV is a LED backlit with multiple dimming zones (cannot remember how many, but not as many as the P-Series)
Symptoms :
1) Solid colors look terrible and are inconsistent across the entire screen
2) When there is a contrasting color, especially with motion, I see a halo or ghosting effect around it. For example, moving white lettering on a black background will have a halo surrounding it, and it's always fluctuating
3) I get a random flicker about once every 60 seconds that lasts for less than a second. More like a random flash or artifact. This happens on both native (TV built-in netflix) and external (HDR HDMI Input)
This thing was a nightmare to transport and get installed, so I keep hoping there's a software fix for this, but I wanted to check here to see if anyone was familiar with similar issues. I've never owned a local dimming LED set before (all plasma and edge lit before), so I'm not sure if the ghosting and backlight/color inconsistencies are just something that I need to live with. I purchased from Costco and have like another 5 years of coverage between the costco CC and squaretrade.
Bigchingan is offline
post #49 of 88 Old 09-04-2018, 03:42 AM
vincentfam's Avatar
Vizio Problems
Bigchingan,
I am not totally familiar with problems with the Vizio, as I am recently a former dedicated owner of plasma tvs. I did have one nagging picture problem that was resolved by unplugging the tv for two minutes to reset the tv. If you do this, make sure that you do a subsequent check for software updates. Also, although our models are different, you should have the option in the system settings to restore the default settings on the tv. You may want to do a system restore and also check for software updates afterwards. Another option is to switch out the hdmi cable to see that is the problem.
If these options do not work, thank goodness that you have a warranty. The next step will be to contact your warranty company, unless you can find another potential solution.
Good luck,
Vincentfam
post #50 of 88 Old 09-08-2018, 04:48 AM
vincentfam's Avatar
The Non UHD Settings - Higher RGB Levels
Herein are my Non UHD settings, with an added adjustment to the Clear Action setting. The UHD settings appeared to be too saturated and these settings below appear to be more normal. Luminance @ 100% Window is 41.5 ftL. Changes in Bold.
Backlight: 100
Brightness: 50
Contrast: 32
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Clear Action: On
Turn off all other enhancements
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Offset: Red -2, Green 1, Blue 1
The Vincentfam
post #51 of 88 Old 09-14-2018, 07:07 PM
vincentfam's Avatar
The Non UHD Settings - Higher RGB Levels & Luminance
Went into a local automotive store and noticed the nice looking bright picture. So I decided to increase the luminance to increase contrast ratio and thus picture quality. This is a brighter picture that may cause eye fatigue in a dark room viewing environment. Herein are the updated settings. Color Tuner settings were adjusted to level out the gamma curve, & sharpness setting also adjusted. Luminance of 50.5 ftL @ 100% window.
Backlight: 100
Brightness: 50
Contrast: 40
Color: 50
Tint: 1
Sharpness: 4
More Picture:
Clear Action: On
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Gain: Red -12, Green 0, Blue 37
Offset: Red 1, Green 3, Blue 3
The Vincentfam
post #52 of 88 Old 10-29-2018, 07:13 PM
vincentfam's Avatar
Luminance 60 ftL Better Day Time Settings
The Non UHD Settings - Higher RGB Levels & Luminance Day Time Settings
This is a brighter picture that may be better viewing in day time environment. Herein are the updated settings. Color Tuner settings were adjusted to level out the gamma curve. Luminance of 60 ftL @ 100% window.
Backlight: 100
Brightness: 50
Contrast: 45
Color: 50
Tint: 1
Sharpness: 4
More Picture:
Clear Action: On
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Gain: Red -14, Green -2, Blue 35
The Vincentfam
post #53 of 88 Old 12-25-2018, 01:45 PM
vincentfam's Avatar
Day Time Settings (Gamma Curve Adjusted)
Seasons Greetings Colleagues,
I attempted today to adjust the picture for better detail in dark scenes. I unsuccessfully attempted to use the black detail setting, but that threw gamma way off. So I adjusted the offset settings to lower the gamma curve between 0 and 50% grey scale patterns to mimic BT.1886 calibration to get more detail in dark scenes. (See gamma graph attached). I may have to adjust the offset settings a little more. Contrast setting was reduced to 44 to keep luminance at 60 ftL to avoid eye fatigue. I switched the input setting to HDMI-2 because HDMI-1 is used for a sonos sound bar.
Input Settings: HDMI-2,
Backlight: 100
Brightness: 50
Contrast: 44
Color: 50
Tint: 1
Sharpness: 2
More Picture:
Clear Action: On
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Offset: Red 9, Green 10, Blue 9
Happy Holidays!
The Vincentfam
Name:	vizio gamma correction.jpg
post #54 of 88 Old 12-26-2018, 06:07 PM
vincentfam's Avatar
Improved Picture Quality (Active Full Array Setting)
Greetings Colleagues:
I think that you will like these settings. Manipulated gamma curve a little more by adjusting offset settings. Sharpness setting raised to 3 using 720p sharpness pattern. Edit: Not recommending active full array: Turned on Active Full Array setting to improve contrast ratio. Raised contrast setting to 45 (Luminance increased to 62 ftL). Color temperature measured at 8000K in the white space of the CIE graph.
Backlight: 100
Brightness: 50
Contrast: 45
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Active Full Array: On This setting negatively impacts gamma curve - not recommended
Clear Action: On
Color Space: Auto
Gamma: 2.2
Color Calibration:
Color Tuner:
Offset: Red 12, Green 12, Blue 11
As always,
The Vincentfam
Last edited by vincentfam; 12-29-2018 at 03:39 PM. Reason: Not recommending active full array setting
post #55 of 88 Old 12-29-2018, 03:48 PM
vincentfam's Avatar
Good Movie Viewing Settings - attached gamma graph
Manipulated gamma curve a little more by adjusting the 11 point white balance settings. Changed gamma setting to 2.4 for movie viewing. Gamma curve is similar to BT.1886 measurement - See graph attached. Turned OFF Active Full Array setting because it negatively impacts gamma curve. Colors appear to be bolder.
Backlight: 100
Brightness: 50
Contrast: 45
Color: 50
Tint: 1
Sharpness: 3
More Picture:
Active Full Array: OFF
Clear Action: On
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
11 Point White Balance Settings:
Gain = 5%: Red: 15; Green: 15; Blue: 15
Gain = 10%: Red: 9; Green: 9; Blue: 9
Gain = 20%: Red: 8; Green: 8; Blue: 8
Gain = 30%: Red: 5; Green: 5; Blue: 5
All other settings = 0
As always,
The Vincentfam
Name:	vizio gamma curve bt1886.jpg
Last edited by vincentfam; 05-04-2019 at 09:04 AM. Reason: To correct errors in white balance setting descriptions (green and blue)
post #56 of 88 Old 01-10-2019, 04:45 PM
Tbrooks330's Avatar
Quoted: 102 Post(s)
Liked: 44
Thanks @TheV incentfam for sharing these calibration settings. Also quick questions. Do you have any recent calibrations for HDR? They dont seem to carry over well when watching content with HDR active
Tbrooks330 is offline
post #57 of 88 Old 01-10-2019, 08:00 PM
vincentfam's Avatar
The HDR Settings
Tbrooks330,
HDR adjustments do not appear to be complicated but may require additional equipment to complete this task. I will do some more research and perhaps take a trip to a local electronics store to purchase a few items for this. I will let you know soon.
As I am,
The Vincentfam
post #58 of 88 Old 01-11-2019, 03:19 PM
vincentfam's Avatar
The HDR Settings - Pending
During the time that it may take me to figure out HDR settings, I would recommend turning on the active full array setting. Although this setting may negatively impact gamma, it will nonetheless provide some "punch" to the picture, which I am anticipating will be similar to HDR settings.
As I am,
The Vincentfam
post #59 of 88 Old 01-13-2019, 08:49 AM
vincentfam's Avatar
Views on HDR Settings
Per my limited investigation, HDR adjustments or calibrations are made to the particular tv but not to any type of standard. Usually, the adjustments are only made to contrast, brightness, sharpness, color and tint. Some professional calibrators may also use more complicated adjustments.
Any 4K adjustments to this tv require video source (blue ray player, xbox, etc) that can deliver a 4K signal to the tv, which I do not have and can be expensive. I do have an xbox1 console but it is not compatible with 4K tvs (xbox1x and xbox1s are compatible). If you do have an xbox1x or xbox1s console, these consoles have internal settings to show how to calibrate your 4K TV.
If, in the event that I would come across a 4K compatible video source, I will indeed look at 4K HDR adjustments for this tv and post them in this forum.
The Vincentfam
post #60 of 88 Old 04-18-2019, 12:25 PM
vincentfam's Avatar
Lower Backlight Setting
I recently replaced the backlight strip panels in a co-worker's LG TV which has similar backlights to our TV. The co-worker had her TV on "torch mode"
or the vivid mode, which is not recommended. One of the 60+ backlights went out and caused the picture to go black. Another thing that was recommended was to lower the backlight setting to 30.
To help out the "longevity" of our tv, I adjusted the backlight setting in the standard picture mode and I think that the picture looks better @ a luminance of 50 ftL. The gamma curve, which is posted below, is pretty close to BT.1886. Changes are in bold.
Backlight: 64
Brightness: 50
Contrast: 50
Color: 50
Tint: 1
Sharpness: 1
More Picture:
Clear Action: On
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -10, Green 1, Blue 41
Offset: Red 13, Green 14, Blue 13
As always,
The Vincentfam
Name:	Vizio BL Gamma.jpg
Last edited by vincentfam; 05-04-2019 at 09:05 AM. Reason: To correct errors in white balance setting descriptions (green and blue)
Reply LCD Flat Panel Displays
