Vizio Smartcast 2016/2017 E-Series Thread (Now HDR10 Compatible via HDMI & Cast) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #61 of 100 Old 04-22-2019, 10:35 AM
Quoted: 28 Post(s)
Liked: 9
Originally Posted by LVNeptune View Post
Just picked up the 65" E65-E1 and for whatever reason BB's site lists it as no HDR capability, Vizio and everywhere else do. Very odd. Set up TV last night with a new Denon S730H receiver and was immediately blown away. Had issues getting HDR to function correctly over HDMI. Found out that it has to be plugged into HDMI and you need to go into the input settings and turn on "Full UHD Color" to enable it. PS4 and Roku detect it fine. TV natively plays back x265/HEVC content and has Plex so the Roku Ultra I recently purchased wasn't even required (although to be fair I am not entirely sure if it sends all decoder formats over ARC). I am blown away by this TV. Blacks are black. Played Horizon Zero Dawn on my PS4 Pro for a bit and the lighting is amazing. It's pretty difficult to get me excited about something these days but I am just blown away at the quality of this screen. Picked it up for $699.99 during the BB Cyber Monday Sale and spent an extra $159 on a 5 year extended GSP so I'll be set for awhile now.
EDIT: The only thing I am unsure of is what the best video settings are to try. At some point I plan on getting a calibration tool but would like to know what everyone suggests to confirm that any weird motion blur is turned off. I think it *might* be on but it's also possible these videos I've been watching were actually in 4K/60
Where did you go to find out this information?
How Bout That is offline
post #62 of 100 Old 04-22-2019, 11:48 AM
vincentfam's Avatar
Vizio should have an online manual for instructions for its tvs. Also, on this thread's model, I recall some where in the menu that lists HDMI input 1 as the only input for this content. Go to the menu section for the inputs and to the HDMI-1 input for the options. You should see the option to turn on the UHD setting.
Last edited by vincentfam; 04-22-2019 at 11:52 AM. Reason: Additional Explaination
vincentfam is offline
post #63 of 100 Old 04-30-2019, 06:31 PM
vincentfam's Avatar
BT 1886 Setting - Lower Backlight Setting
Greetings Colleagues,
I have been reviewing many calibration/measuring techniques and one seasoned recommended a BT1886 type of method where the gamma curve on the graph is near 2.4 except around 0% white with a target gamma between 2.1 and 2.2. Backlight setting was lowered to achieve this measurement, with additional changes noted below. These settings are probably better for movie viewing in a dark room environment. Color is a little more vibrant and punchier. Luminance is about 36.9 ftL @ 100% White pattern. Changes are in bold. Gamma graph attached for your convenience.
Input Settings: HDMI-2,
Aspect Ratio: Normal
Picture Mode: Standard
Auto Brightness: Off
Backlight: 40
Brightness: 50
Contrast: 50
Color: 50
Tint: 1
Sharpness: 1
More Picture:
Color Temperature: Normal
Active Full Array: OFF
Clear Action: On
Turn off all other enhancements
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -11, Green 1, Blue 41
Offset: Red 12, Green 14, Blue 13
Leave all other settings in the color turner to 0.
11 Point White Balance Settings:
Gain = 5%: Red: 5; Green: 5; Blue: 5
Gain = 10%: Red: 6; Green: 6; Blue: 6
Gain = 20%: Red: 8; Green: 8; Blue: 8
Gain = 30%: Red: 5; Green: 5; Blue: 5
Gain = 40%: Red: 5; Green: 5; Blue: 5
Gain = 50%: Red: 9; Green: 9; Blue: 9
Gain = 60%: Red: 10; Green: 10; Blue: 10
Gain = 70%: Red: 13; Green: 13; Blue: 13
Gain = 80%: Red: 15; Green: 15; Blue: 15
Gain = 90%: Red: 18; Green: 18; Blue: 18
Gain = 100%: Red: 19; Green: 19; Blue: 19
As always,
Your colleague in picture quality,
The Vincentfam
Name:	Non Trad BT1886 Gamma.jpg
Last edited by vincentfam; 05-04-2019 at 09:03 AM. Reason: To correct errors in white balance setting descriptions (green and blue)
post #64 of 100 Old 05-03-2019, 08:27 PM
vincentfam's Avatar
Color Adjustments on Gamma Graph
I have discovered that the 11 point white balance settings can be used to adjust color settings on the gamma graph using hcfr software. After gray scale measurements, I opened up the color measurement graph to see the gamma curve, which in this case was 2.3 with 2.1 targeted near 5% IRE. I also turned on the red, green and blue level colors to see that they were not even in some of the IRE intervals. I then adjusted the individual IRE levels with their respective colors to even out the red, green and blue to equal levels.
I reset the backlight level at 60 to get luminance of 50 ftL at 100 IRE. The contrast setting above 51 does not increase lumance. Measured gamma is about 2.3 and goes down towards 2.1 near 5% and 10% IRE to obtain BT.1886 effect. The settings are below, with changes in bold. Gamma & RGB graph is also attached.
Backlight: 60
Brightness: 50
Contrast: 51
Color: 50
Tint: 1
Sharpness: 2
More Picture:
Clear Action: Off
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -32, Green 1, Blue 29
Offset: Red 13, Green 14, Blue 13
Gain = 5%: Red: 5; Blue: 5; Green: 5
Gain = 10%: Red: 1; Green: 1; Blue: 6
Gain = 20%: Red: 0; Green: 0; Blue: 0
Gain = 30%: Red: 0; Green: 0; Blue: 0
Gain = 40%: Red: 3; Green: 3; Blue: 3
Gain = 50%: Red: 7; Green: 5; Blue: 3
Gain = 60%: Red: 3; Green: 3; Blue: 0
Gain = 70%: Red: 4; Green: 2; Blue: 0
Gain = 80%: Red: 0; Green: 0; Blue: -4
Gain = 90%: Red: -2; Green: -3; Blue: -4
Gain = 100%: Red: 0; Green: 0; Blue: 0
As always,
The Vincentfam
Name:	Vizio RGB Gamma.jpg
Last edited by vincentfam; 05-04-2019 at 09:01 AM. Reason: To correct errors in white balance setting descriptions (green and blue)
post #65 of 100 Old 05-04-2019, 08:54 AM
vincentfam's Avatar
Gamma Graph RGB Adjustments
I readjusted the settings to make measured gamma at the high end at 2.3 to give the picture a punchier appearance, and to provide neutral settings for day and night viewing. I turned the Clear Action setting back to ON because it had no impact on the measurements. Luminance is at 51.22 ftL at 100 IRE. The gamma graph with RGB levels is attached. Changes to settings are in bold.
Backlight: 60
Brightness: 50
Contrast: 51
Color: 50
Tint: 1
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -31, Green 1, Blue 29
Offset: Red 14, Green 14, Blue 12
Gain = 5%: Red: 6; Green: 6; Blue: 6
Gain = 10%: Red: 3; Green: 3; Blue: 8
Gain = 30%: Red: 1; Green: 0; Blue: 0
Gain = 40%: Red: 6; Green: 4; Blue: 3
Gain = 50%: Red: 10; Green: 7; Blue: 3
Gain = 60%: Red: 8; Green: 6; Blue: 0
Gain = 70%: Red: 11; Green: 7; Blue: 1
Gain = 80%: Red: 9; Green: 6; Blue: 3
Gain = 90%: Red: 6; Green: 2; Blue: 3
Gain = 100%: Red: 5; Green: 4; Blue: 5
As always,
The Vincentfam
Name:	Vizio RGB Gamma 2.3.jpg
Last edited by vincentfam; 05-04-2019 at 08:59 AM. Reason: To correct errors in white balance setting descriptions (green and blue)
post #66 of 100 Old 05-04-2019, 09:07 AM
vincentfam's Avatar
Please note recent edits for white balance settings. For some unknown reason, I had incorrectly switched the settings for blue and green. The settings are now corrected. Apologies.
post #67 of 100 Old 05-08-2019, 01:09 PM
vincentfam's Avatar
Tweaked Settings
I tweaked the recent settings. Luminance is at 48.3 ftL at 100 IRE. Changes to settings are in bold.
Backlight: 60
Brightness: 50
Contrast: 51
Color: 50
Tint: 1
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain = 5%: Red: 7; Green: 7; Blue: 7
Gain = 10%: Red: 3; Green: 4; Blue: 10
Gain = 20%: Red: -2; Green: -1; Blue: 2
Gain = 30%: Red: 0; Green: 0; Blue: 1
Gain = 40%: Red: 5; Green: 3; Blue: 3
Gain = 50%: Red: 9; Green: 6; Blue: 3
Gain = 60%: Red: 5; Green: 2; Blue:-1
Gain = 70%: Red: 4; Green: 2; Blue: -1
Gain = 80%: Red: 1; Green: 0; Blue: -2
Gain = 90%: Red: -1; Green: -2; Blue: -2
Gain = 100%: Red: 2; Green: 2; Blue: 2
As always,
The Vincentfam
post #68 of 100 Old 05-27-2019, 09:37 AM
vincentfam's Avatar
The CMS & CIE Graph Measurements
I think that I figured out how to use all of the settings in the color tuner section. Initially, I measured the primaries (red, green, blue) and secondaries (cyan, magenta, yellow) using HCFR software and a colorimeter. After this measurement, I could see that this tv's CIE graph was not matching up with reference points for the standard CIE. I noticed that each point for the standard primaries and secondaries had reference numbers (x,y,Y). If you run the HCFR in continuous mode with the primary or secondary color displayed, you can adjust in the color tuner the hue (x), saturation (y), and brightness (Y) for each color to get close to the reference numbers. After my measurements, I got very close to the reference numbers but not a perfect CIE. I then adjusted the color and tint settings with a blue filter to account for the imperfections. (See the CIE graph attached)
Changes to these measurements do not affect the white balance greyscale measurements for offsets, gains, or 11 point white balance settings. Some minor changes were made to previous measurements for greyscale.
Backlight: 60
Brightness: 50
Contrast: 51
Color: 54 (Adjusted with blue filter)
Tint: 1 (Adjusted with blue filter)
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Gain: Red -32, Green 2, Blue 34
Offset: Red 13, Green 14, Blue 12
Hue: Red 2, Green 50, Blue -13, Cyan -6, Magenta 10, Yellow -8
Saturation: Red 13, Green 22, Blue 1, Cyan -2, Magenta 26, Yellow -15
Brightness: Red 30, Green -6, Blue 6, Cyan 6, Magenta -15, Yellow 9
Gain = 10%: Red: 3; Green: 4; Blue: 8
Gain = 50%: Red: 8; Green: 4; Blue: 3
Gain = 60%: Red: 5; Green: 2; Blue: 0
Gain = 70%: Red: 6; Green: 2; Blue: 0
Gain = 80%: Red: 3; Green: 2; Blue: 0
Gain = 90%: Red: 4; Green: 1; Blue: 1
As always,
The Vincentfam
Name:	Vizio CIE Graph.jpg
post #69 of 100 Old 05-31-2019, 06:54 AM
vincentfam's Avatar
CMS Settings - Blue Filter Not Recommended
In looking at the adjustments after using the blue filter method for readjusting color and tint, I noticed that this adjustment negatively affected the secondary colors (yellow, cyan, and magenta), which is probably due to adjusting the color temperature to 8000K rather than the standard D65 or 6500K. I use the 8000K to brighten up the picture for day and night viewing. The greyscale target is still in the white space of the CIE graph.
So I set the color and tint settings to their default values (50 and 0) and readjusted the primary and secondary colors, as indicated below. I did not use the blue filter method this time. Changes from previous settings are in bold.
(Also, for curiosity, I set the color setting to 54 to see the impact on picture quality. The colors were more vivid, but it looked like everybody had a sun tan. These settings are not posted)
Backlight: 60
Brightness: 50
Contrast: 50
Color: 50
Tint: 0
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
Hue: Red 3, Green 50, Blue -11, Cyan -3, Magenta 10, Yellow -6
Saturation: Red 15, Green 22, Blue 4, Cyan 3, Magenta 26, Yellow -15
Brightness: Red 28, Green -6, Blue 0, Cyan 6, Magenta -16, Yellow 8
As always,
I am The Vincentfam
post #70 of 100 Old 07-16-2019, 08:16 AM
Quoted: 28 Post(s)
Liked: 9
Does anybody know if it's possible to resume a video being watched from a thumb drive? If I've watched the first two hours of three-hour movie, I don't want to have to fast forward to get back where I was.
post #71 of 100 Old 07-16-2019, 09:00 AM
Jasonn B's Avatar
Quoted: 486 Post(s)
Liked: 173
I dont think. It just plays automatic.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #72 of 100 Old 07-28-2019, 03:10 PM
David Biagas's Avatar
Quoted: 203 Post(s)
Liked: 64
I bought an Apple TV for my e series to watch iTunes movies. Have the exact same setup on my m series TVs but for some reason Netflix won’t play in hdr over the Apple TV! Works just fine on my m series models. It also worked when I had a roku connected. Not exactly sure what’s happening. iTunes movies play in hdr as does smartcast content.
I’ve tried resetting the Apple TV to factory settings and adjusting the video settings on the Apple TV.... I also tried switching the Apple TV to different inputs and no luck.... What gives? Anyone else have this problem??!
Optoma UHL55 || Marantz SR6013 & Outlaw 7000x || Panasonic UB420 || Apple TV 4k || DCM 7.2.4 setup
Vizio M70-D3 || Marantz SR6012 & Outlaw 5000 & Onkyo M282(x3) || Panasonic UB820 || Apple TV 4k || DCM 7.2.4 setup
Vizio M75-E1 || Onkyo TX-NR686 || LG UBK80 || Apple TV 4k || DCM 3.2 setup
David Biagas is offline
post #73 of 100 Old 08-17-2019, 08:56 AM
vincentfam's Avatar
The CMS & Color and Tint Dilemma
I have been reviewing the use of the cms and adjustments to color and tent settings. Some of the reviewed materials indicated suggestions from some notable avsforum members that use of the color filter cannot be totally discounted, depending on the display, adding that the blue filter may be used after adjusting the cms. I used the blue filter (after cms) and saw that the color was off. Below is the previous settings with the only change to color.
The tint setting was not affected.
Over the next few days I will be looking at other methods for adjusting color and tint and will post my results, if any.
Backlight: 60
Brightness: 50
Contrast: 50
Color: 53
Tint: 0
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.4
Color Calibration:
Color Tuner:
As always,
I am The Vincentfam
Tbrooks330 likes this.
post #74 of 100 Old 08-18-2019, 06:19 PM
vincentfam's Avatar
Internal SMPTE Pattern
I used Vizio's internal smpte pattern to assess the color and tint settings using the blue filter method, which verified the color setting at 53 and the tint setting at 0. I also noticed that Vizio has field patterns for calibration, something that I may look at down the road to see if the picture settings need tweaking.
The picture looks better to me.
As always, your colleague in picture quality,
I am the Vincentfam
post #75 of 100 Old 08-22-2019, 09:07 PM
vincentfam's Avatar
The GCD 75% Luminance/Saturation Patterns
I looked at the internal Vizio calibration tests but the picture did not improve much. At the recommendations of learned forum members, I will set the hcfr software preference for color space to rec 709 (75%) and use the GCD disc's 75% color field patterns to adjust the color settings and report back to you shortly.
As always,
I am the Vincentfam
post #76 of 100 Old 08-23-2019, 07:05 PM
vincentfam's Avatar
The Recommended Settings
The recommended settings are the last ones posted on August 17, 2019, with the exception of color which should be set at 54. This is one notch above the balanced colors using the avsforum color pattern with the blue filter. This color should add a little saturation to give the picture some pop without overly saturating colors. The primaries and secondaries are still within their targets for the CIE graph. The tint setting remains unchanged at 0.
I did try using the GCD's disc with the 75% (luminance/saturation) patterns to adjust the primaries and secondaries, but this tv did not work well with these patterns. I also tried changing the power mode, but this did not affect the picture settings. I did read a comment in the forum about the difficulty of adjusting color for a particular Vizio model, but I think it comes down to patience and experience in adjusting these settings. I also tried using the internal "calibration tests" patterns, but these patterns did not work as well as the avsforum rec 709 patterns.
So my recommended change in the settings is:
Color: 54
You may increase this color setting without impacting the other settings, but the picture's colors may become over saturated and the picture may not look that well.
Good luck.
I am the Vincentfam
post #77 of 100 Old 08-29-2019, 03:48 PM
vincentfam's Avatar
The Sharpness Factor
Greetings Once Again Colleagues,
A long long time ago when hdtvs started coming out, I recall a respected calibrator actually stating that some "sharpness" should be added to the picture and the setting should not automatically be set to zero. With this statement in mind, I thought I would look into the sharpness setting a little more.
The current sharpness setting of 2 is where artifacts do not appear on the sharpness pattern from a "viewing" distance from where the tv is normally watched. A sharpness setting of 3 is the setting where the artifacts are just starting to bloom (where the artifacts just start to appear but still barely visible). With this setting you may get some artifacts but it may not be noticeable. It makes the picture pop a little more, especially with the recent color setting that adds a little more color saturation to the picture.
Recommended Sharpness setting: 3
See what you think.
I am the Vincentfam
post #78 of 100 Old 08-29-2019, 07:37 PM
vincentfam's Avatar
Re Sharpness
Please disregard the last post regarding sharpness. increasing the setting to 3 doesn't look right to me. You may want to use the sharpness setting to 3 if it looks good to you. Apologies
The Vincentfam
post #79 of 100 Old 10-02-2019, 02:52 PM - Thread Starter
tattootearz's Avatar
Had to dig this one out of the grave...
As of lately, I am unable to get anything from YouTube to playback in 4K. I've tried via smartcast as well as the YouTube app on the TV. This was certainly not an issue before. I used to be able to get 4K as well as HDR for years now.
Anyone else experiencing this?
tattootearz is offline
post #80 of 100 Old 10-02-2019, 05:14 PM
vincentfam's Avatar
Vizio Reset
Greetings Tattoo:
You may have some options available with some of the technical problems with Vizio TVs. You may want to review the TV's manual prior to attempting anything. One of the options I use the soft reset technique is when, for example, my WIFI doesn't connect with the TV. I do a soft reset by unplugging the TV for at least 10-20 seconds. The TV works fine after plugging it back in. There is also admin reset/soft reset options in the user menu under system settings that may be useful, but I never had to use these options for anything. I think that the admin reset may reset all TV settings to factory default. These suggestions may or may not work, but may be worth a try, IMHO. Google "Vizio TV reset" for other options.
Good Luck,
As always,
I am the Vincentfam
post #81 of 100 Old 10-02-2019, 08:59 PM
vincentfam's Avatar
Also, make sure that your internet connection is working fine with a minimum speed of 25 Mbps.
Vincentfam
post #82 of 100 Old 11-11-2019, 12:51 PM
vincentfam's Avatar
Substantial Improvement - Gamma Setting 2.2
Recent calibrations involved using Gamma setting of 2.4 for BT 1886 standard, but this setting created what I noticed today as the dreaded black crush, which is lack of detail in dark scenes and this setting may not be appropriate with some displays.
Therefore, I reverted to using the time proven gamma setting at 2.2, which brightens up the picture a bit. I also set brightness using the 2nd brightness AVSForum disc pattern where level 19 is barely flashing, per instructions. I readjusted all of the other settings accordingly and the gamma graph level is flat right at 2.1 (which I will post upon request). The picture pops out without excessive color saturation. The primary and secondary color settings did not need to be readjusted.
Measured color temperature is 8000K and Luminance @ 100% White Pattern is 45 ftL. The new settings below are bolden.
Backlight: 60
Brightness: 49
Contrast: 50
Color: 53
Tint: 0
Sharpness: 2
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.2
Please disregard the below settings due to calculation errors
Color Calibration:
Color Tuner:
Offset: Red 14, Green 3, Blue 12
Gain = 5%: Red: -8; Green: -10; Blue: -5
Gain = 10%: Red: -9; Green: -10; Blue: -5
Gain = 20%: Red: -2; Green: -2; Blue: -1
Gain = 30%: Red: 3; Green: 2; Blue: 1
Gain = 40%: Red: 6; Green: 3; Blue: 3
Gain = 60%: Red: 5; Green: 2; Blue: -1
Gain = 70%: Red: 6; Green: 3; Blue: -1
Gain = 80%: Red: 4; Green: 4; Blue: 0
Gain = 90%: Red: 3; Green: 2; Blue: 1
As always,
I am The Vincentfam
post #83 of 100 Old 02-17-2020, 06:21 AM
vincentfam's Avatar
The Observation Settings
Greetings once again Colleagues:
In recently observing the PQ and settings, the picture appeared to be dull compared to the calibrated and calibrated dark tv modes. The respective luminance (100%) were 70 ftL and 60 ftL. So I raised my backlight setting to 82 to obtain 60 ftL luminance.
Next I noticed the impact of the Clear Action setting and turned it off.
I changed the gamma setting to 2.0 because this was the best setting that provided greater detail without "washing out" the picture quality. The hcfr gamma curve is flat just above 1.9. Color temperature is 8000K.
Finally, I used the recommended 75% saturation field patterns (instead of 100%) to adjust the primary and secondary colors. It appears that this TV has an imperfect CMS. I noticed that the previous settings were way off.
The blue filter method was used to adjust more the tint and color settings.
The changes are in bold:
Backlight: 82
Brightness: 49
Contrast: 50
Color: 57 (50 without the blue filter)
Tint: 2 (0 without the blue filter)
Sharpness: 2
More Picture:
Clear Action: OFF EDIT: Turn On for smoother picture quality
Color Space: Auto
Gamma: 2.0
Color Calibration:
Color Tuner:
Offset: Red 14, Green 13, Blue 12
Hue: Red 3, Green 50, Blue -6, Cyan -8, Magenta 10, Yellow -1
Saturation: Red 15, Green 28, Blue 3, Cyan -22 Magenta 23, Yellow 4
Brightness: Red -9, Green -35, Blue -5, Cyan -8, Magenta -35, Yellow -7
As always,
I am The Vincentfam
post #84 of 100 Old 02-23-2020, 03:44 PM
vincentfam's Avatar
Observations Update
Greetings:
It is hereby recommended that the Clear Action setting be turned ON to provide a much smoother picture with little impact to picture quality.
I am the Vincentfam
post #85 of 100 Old 03-18-2020, 09:59 AM
vincentfam's Avatar
HDMI Cable Hardware and Ferrite Cores
I am currently looking at changing my hdmi cable to a 2.0 (which has a higher data transfer rate) with CL2 (in wall installation). Currently I have a standard hdmi cable (probably a 1.4) and I am seeing small artifacts in the picture. This could be due to clouding, which can occur on lcd tvs, or electrical interference due to the hdmi cable running near the power cord behind the wall. While I am waiting for the new 2.0 hdmi cable from Monoprice, I have installed ferrite cores near the ends of the old hdmi cable which seems to have improved the picture quality.
I will keep you updated,
I am, once again, the Vincentfam
post #86 of 100 Old 03-25-2020, 05:09 PM
vincentfam's Avatar
Updates and Corrected Settings
Greetings Colleagues:
I installed the new 4k hdmi cable and it may have made some slight improvements to picture quality, especially with using ferrite cores near the ends of the cable. At least I am now prepared to watch 4k video content when it comes out.
During the install, I noticed that the hue, saturation and brightness settings in the color tuner section were off. I took my time and re-calculated the settings for D65 calibration and Color Temperature 8000K, as posted below:
The D65 Settings (Movie Mode)
These settings are for REC 709 standards with a color temperature of 6500K for movie mode. Luminance @ 100% IRE is 60 ftL. Gamma setting was changed to 1.8 to brighten up the picture. The measured gamma graph was flat at 1.7. Delta E's for the grayscale were between 0.1 to 1.5 (below 4 is good). Delta E's for primary and secondary colors were between 0.4 and 5.1 (below 10 is good). No changes to 11 point white balance settings.
Backlight: 84
Brightness: 50
Contrast: 49
Color: 50
Tint: 0
Sharpness: 3 (0 with new technique posted below)
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 1.8
Color Calibration:
Color Tuner:
Offset: Red 14, Green 14, Blue 13
Gain: Red -15, Green 2, Blue -22
Hue: Red 9, Green 36, Blue -6, Cyan 13, Magenta 5, Yellow -2
Saturation: Red 31, Green 8, Blue 3, Cyan -1, Magenta 29, Yellow -14
Brightness: Red -14, Green -11, Blue -49, Cyan -1, Magenta -27, Yellow 1
The 8000K Corrected Settings (Standard Mode)
These settings are for a color temperature of 8000K for standard mode. Luminance @ 100% IRE is 60 ftL. Gamma setting is 2.0. The measured gamma graph was flat at 1.9. No changes to 11 point white balance settings.
Backlight: 84
Brightness: 50
Contrast: 49
Color: 50
Tint: 0
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.0
Color Calibration:
Color Tuner:
Offset: Red 13, Green 15, Blue 13
Gain: Red -27, Green 5, Blue 35
Hue: Red 9, Green 28, Blue -6, Cyan 4, Magenta 11, Yellow -5
Saturation: Red 31, Green 2, Blue 3, Cyan 24, Magenta 13, Yellow -12
Brightness: Red -7, Green -7, Blue -50, Cyan -12, Magenta -10, Yellow 3
Apologies for earlier posted erroneous settings.
The Vincentfam
Last edited by vincentfam; 03-30-2020 at 08:22 PM. Reason: Correcting Sharpness Setting Using Pausing Picture
post #87 of 100 Old 03-30-2020, 08:21 PM
vincentfam's Avatar
The Sharpness Setting by Pausing Picture
In reviewing comments regarding Sharpness setting by some of our learned avsforum members, it was suggested that one method of determining proper sharpness setting is to freeze or pause a picture on the television and adjust the sharpness setting when looking at straight or sharp edged objects in the picture. When I did this for our television I noticed artifacts when setting the sharpness setting at 1 or above, and that the 0 setting had no artifacts. Perhaps my old calibration disc sharpness pattern was not sufficient for the new 4k technology.
Using this described "pausing picture" technique, I recommend setting the sharpness setting at 0.
As I am,
The Vincentfam
post #88 of 100 Old 04-01-2020, 05:27 PM
vincentfam's Avatar
I have been looking at the differences between the recent settings for D65 (movie mode) and 8000K (standard mode), and I believe that the colors in the D65 settings are more vibrant. The gamma setting at 1.8 brightens the TV's picture and does not "wash out" the colors. I am recommending the D65 settings over the 8000k settings for viewing. Edit: I change the gamma setting to 2.0 for better day and nite viewing which does not affect other settings.
I am The Vincentfam
Last edited by vincentfam; 04-04-2020 at 10:02 AM. Reason: Added Gamma Setting Suggestion
post #89 of 100 Old 04-15-2020, 10:06 AM
vincentfam's Avatar
Vizio's Internal Calibration Patterns
Greetings once again Colleagues,
I examined calibration results from using Vizio's internal calibration patterns and they were significantly different from my results using my old 2007 Samsung Blu-ray player with the Avsforum Rec 709 patterns. One of the main reasons I looked at the internal patterns is because many learned avsforum member indicated that calibration settings from different sources (like Blu-ray players, etc) may be different due to different technologies and other variants.
For our tv, I mainly used the flat patterns for greyscale calibration, but disregarded the internal SMPTE color bars pattern for color and tint calibrations. The SMPTE pattern appeared to be 75% saturation colors and "paled" the picture quality a little. Instead, I used the Avsforum 100% flat color patterns for color and tint, which resulted in more vibrant colors.
The calibration results made changes to color calibration settings and some in the 11 point white balance settings to level out the gamma curve. Max luminance at white 100% IRE is 61.17 ftL. The gamma curve on the graph was flat at 1.85. Delta E for grayscale was between 0.1 and 1.4 and Delta E for primary and secondary colors was between 1.2 and 5.1. Changes from the last settings are in bold but you should check all of the settings to make sure that they are updated with the below results. Picture does look better.
The Updated D65 Settings (Movie Mode)
Tweaked on April 27, 2020 with using HCFR Target Images for Primary and Secondary Colors. Delta E for grayscale 0 to 0.9, Delta E for primary secondary colors 1 to 3.6. Changes in Bold
Input Settings: HDMI-1,
Backlight: 84
Brightness: 50
Contrast: 49
Color: 50 (55 with blue filter - recommended)
Tint: 0 (-1 with blue filter - recommended)
Sharpness: 3 (Recommended)
More Picture:
Clear Action: ON
Color Space: Auto
Gamma: 2.0
Color Calibration:
Color Tuner:
Offset: Red 14, Green 15, Blue 13
Gain: Red -16, Green 6, Blue -17
Hue: Red 10, Green 32, Blue -11, Cyan 6, Magenta 12, Yellow -2
Saturation: Red 31, Green 3, Blue 3, Cyan 22, Magenta 32, Yellow -37
Brightness: Red -6, Green -8, Blue -9, Cyan -10, Magenta -25, Yellow 2
Gain = 30%: Red: 3; Green: 2; Blue: 2
Gain = 50%: Red: 8; Green: 4; Blue: 4
Gain = 60%: Red: 4; Green: 1; Blue: 0
Gain = 70%: Red:5; Green: 1; Blue:1
Gain = 80%: Red: 3; Green: 2; Blue: 1
Gain = 90%: Red: 1; Green: -2; Blue: -2
Gain = 100%: Red: 0; Green: 0; Blue: 1
As always and once again,
I am The Vincentfam
Last edited by vincentfam; 04-27-2020 at 01:40 PM. Reason: Add Blue Filter Changes to Color and Tint - Tweaked
post #90 of 100 Old 04-16-2020, 03:40 PM
vincentfam's Avatar
The Blue Filter - Color and Tint
Briefly, in applying the blue filter to the avsforum color/tint pattern, the following adjustments were made for the last posted settings:
Tweaked
Color: 55
Tint: -1
The Vincentfam
Last edited by vincentfam; 04-27-2020 at 01:43 PM. Reason: Edit color and tint settings Tweaked
Reply LCD Flat Panel Displays
