*Official* 2017 TCL P-Series (55P607) Owners Thread (No Price Talk) - Page 207 - AVS Forum | Home Theater Discussions And Reviews
 4315Likes
post #6181 of 6334 Old 11-11-2018, 04:53 PM
gilles1's Avatar
OTA programs blink off
Anyone seeing OTA channels just randomly blank out for a few seconds, then come back on with the info bar at the bottom? First I thought weak signal, saw two bars on chn 12 but chn 6 has 5 bars.
Then I thought, maybe this tuner is not very sensitive so I watched my bedroom set on the same channel. Bedroom set not blinking off, but I noticed the was a lag between the two sets, the 607 was a little behind.
So now I started thinking maybe this has to do with time shifting and how this set saves programing for this. So I paused the TCL for a few seconds, now it's playing a few seconds behind, for a while, then it blanks again but when it comes back on it's back to live. OK, then I pulled the flash drive out, live TV pause is disabled and my set now plays fine, no more blinking out.
I did a search here with no luck, so I posted this. Anyone have any knowledge about this problem?
gilles1 is offline
post #6182 of 6334 Old 11-12-2018, 01:32 PM
blade005's Avatar
Quoted: 239 Post(s)
Liked: 234
I had this exact issue when my FLASH DRIVE was plugged into a very basic 2-Port USB adapter/splitter. Wanted a second USB connection for normal video viewing. Initial set up worked fine, but about 6 months and numerous OS updates later I had the issue you described. It seemed having it going thru a USB splitter all of sudden was introducing lag that was not there before. My initial solution was to remove the splitter and install the FLASH DRIVE directly into USB port of TV and the issue was gone. Since then I have added a more robust 4-Port hub with individual ON/OFF switches for each port. I keep the LIVE TV PAUSE flash drive active and ON and can use the other 3 ports for normal video viewing and the buffering / performance issue has not returned for LIVE TV. If your situation did not include any type of USB hub to begin with, then I might suggest trying a different FLASH DRIVE or perhaps going thru the LIVE TV PAUSE set up again and allow it to FORMAT the flash drive as if it were new to the installation. Perhaps that may clear up any speed / performance issues that seem to create the start / stop behavior.
TCL Roku-TV 55P605 (4K HDR & DV) | VIZIO SmartCast SB3651‑E6 Soundbar
TCL Roku-TV 43S425 (4K HDR) | TCL Roku-TV 32S301 (720p)
blade005 is offline
post #6183 of 6334 Old 11-12-2018, 05:15 PM
gilles1's Avatar
OK, thanks Blade005, I took the drive out and formated it using a Chromebook. I inserted it again into the tv and it started using it right off. The problem is still there, so I'll try getting another flash drive.
gilles1 is offline
post #6184 of 6334 Old 11-13-2018, 02:28 PM
blade005's Avatar
Quoted: 239 Post(s)
Liked: 234
Not sure if it matters, but perhaps try setting up LIVE TV PAUSE from the Roku OS again and let it do the formatting of the flash drive instead of doing it externally from another device. If you highlight the ANTENNA TV source from the MAIN Roku screen and press the ASTERISK (*) button there is an option to select SET UP LIVE TV PAUSE and it will guide you through the process again and format the flash drive. Worth a try before investing in another flash drive if you don't have one already available.
blade005 is offline
post #6185 of 6334 Old 11-13-2018, 06:57 PM
crcostel's Avatar
Quoted: 99 Post(s)
Liked: 43
Anyone else get another 8.2 update today? 4170
crcostel is offline
post #6186 of 6334 Old 11-14-2018, 06:43 AM
solarrdadd's Avatar
Quoted: 292 Post(s)
Liked: 185
i got 8.2 a week ago. everything still works fine. i do notice the bookshelf speaker is the icon for audio now!
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XPA5,UPA2, UPA200 & Mini X Amps
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is offline
post #6187 of 6334 Old 11-14-2018, 09:28 AM
crcostel's Avatar
Quoted: 99 Post(s)
Liked: 43
As did I. This is a new/second build of 8.2
solarrdadd likes this.
crcostel is offline
post #6188 of 6334 Old 11-14-2018, 10:42 AM
rockaway1836's Avatar
Quoted: 254 Post(s)
Liked: 256
Getting it now.
rockaway1836 is online now
post #6189 of 6334 Old 11-14-2018, 10:46 AM
solarrdadd's Avatar
Quoted: 292 Post(s)
Liked: 185
so what's new in this new/second build of 8.2?
post #6190 of 6334 Old 11-14-2018, 10:51 AM
Quoted: 254 Post(s)
Liked: 256
I think it may have to do with the new speakers. I read somewhere that they were released yesterday or today. Just checked and my 32 S series, 55 S series and 55 6 series, got it as well
post #6191 of 6334 Old 11-14-2018, 11:37 AM
shesha's Avatar
Quoted: 150 Post(s)
Liked: 52
I just pulled the trigger form Amazon. Will be delivered Friday. Luck be with me and the panel lottery.
shesha is offline
post #6192 of 6334 Old 11-14-2018, 03:19 PM
blade005's Avatar
Quoted: 239 Post(s)
Liked: 234
The first release of 8.2 build 4167 provided support for Roku Wireless speakers with additions in the menu system that allow you to pair the newly released wireless speakers. I would guess that the 8.2 build 4170-30 includes bug fixes and not any feature additions.
blade005 is offline
post #6193 of 6334 Old 11-14-2018, 04:53 PM
gilles1's Avatar
I got my Roku TV Speakers and 8.2.2-build 4093-30
I think it's mostly audio changes like
Sound mode <bass boost> <normal> <reduce bass>
Speech clarity <high> <low> <off>
Volume mode <leveling> <Night> <off>
gilles1 is offline
post #6194 of 6334 Old 11-14-2018, 05:03 PM
jakejm79's Avatar
Quoted: 102 Post(s)
Liked: 95
I don't know if this was the recent 8.2 update or before, but when I had to repair a remote today, its now remote and devices and allows pairing of BT devices and the Roku speakers.
jakejm79 is offline
post #6195 of 6334 Old 11-15-2018, 05:28 PM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 484 Post(s)
Liked: 396
Can the picture be turned off while listening to Pandora?
Sony 75Z9D, Denon 4300H, Sony 65Z9D, Denon X4311, OPPO UDP-203, ATV4K, X1X Scorpio
davehale is offline
post #6196 of 6334 Old 11-15-2018, 05:56 PM
gilles1's Avatar
Yes, I have my favorite iheart radio channel programed in the little remote puck. It has two quick set buttons and when I push 1 my music starts without the set coming on. Of course this has to be initiated first with a voice command. Fast TV start is enabled and needs to be for this to work.
davehale likes this.
gilles1 is offline
post #6197 of 6334 Old 11-17-2018, 05:42 PM
exm
exm's Avatar
Quoted: 227 Post(s)
Liked: 107
Is this thread also for the 2018 series like the TCL 55R613?
exm is offline
post #6198 of 6334 Old 11-18-2018, 07:36 AM
solarrdadd's Avatar
Quoted: 292 Post(s)
Liked: 185
the thread is titled "2017 TCL P-Series (55P607) Owners Tread", what do you think? i mean, your not even trying, are you?!?
post #6199 of 6334 Old 11-18-2018, 01:14 PM
snak3y3z1001's Avatar
I'm currently having problem with my set. Bought it last year and has been running great. For the last week though, I would have sound but no picture from the TV. Unplugging and/or factory resetting will fix it. Now the bandaid doesn't seem to work anymore. I still have sound but no picture. It just a dim black screen. Anyone know how to fix this or I'm out of luck?
snak3y3z1001 is offline
post #6200 of 6334 Old 11-20-2018, 07:31 AM
jeffmd's Avatar
Quoted: 25 Post(s)
Didnt see a conclusion to this but, is the usb stick a 3.0 with a tested good write speed of at least 20mb a second?
jeffmd is offline
post #6201 of 6334 Old 11-20-2018, 03:20 PM
Liked: 1
Hi everyone!!! I have a tcl p607 mainly used with a PC. Just updated to the latest firmware 8.2.0 build 4170-30 and have some visual interference (artifacts) once in the * menu and i press any button on roku remote as well as random artifacts while not using the menu. All that happening while hdmi mode is set to 2.0 and if switched to 1.4 mode there is no problem.
dharmaboy likes this.
justd000it is offline
post #6202 of 6334 Old 11-20-2018, 04:22 PM
gilles1's Avatar
It's a MUF-64BA/AM which is a Samsung 64G usb 3.0 They claim 120mb/s don't know tested speed.
I did a format on my windows 10 pc and I plugged it back into the tv, this time it went through the whole set up.
It still glitches and won't stay paused.
So I got another stick from fry's. It's a Patriot Slate 32GB 3.1 and so far, so good.
gilles1 is offline
post #6203 of 6334 Old 12-01-2018, 09:42 AM
web1b's Avatar
I have had my P-Series for almost a year and it had been working fine with my Logitech Harmony remote until a few weeks ago.
Nothing changed on the remote side, so there must have been a TCL/Roku update that made a change.
Now, when I select the button to turn on the TV, soundbar and select the DVR input, it only highlights the DVR option on the Roku home screen so it plays in a small window. I have to press the button a second time to select the DVR option again to get full screen video.
Is there a fix for this?
web1b is offline
post #6204 of 6334 Old 12-03-2018, 06:03 PM
helvetica bold's Avatar
Quoted: 1716 Post(s)
Liked: 1077
Maybe I’m behind but my 605 just updated to
8.2.0 build 4170. Is this a recent build?
LG65C9, XBOX ONE X, PS4PRO, APPLE 4K, SONY STRDN1070, TAKE CLASSIC 5.1
helvetica bold is offline
post #6205 of 6334 Old 12-04-2018, 02:50 PM
blade005's Avatar
Quoted: 239 Post(s)
Liked: 234
That is the current version on TCL Roku TV's. I believe that the OS 9 version that is currently going out to standalone Roku devices is planned for Roku TV's in the first part of 2019.
blade005 is offline
post #6206 of 6334 Old 12-04-2018, 11:12 PM
PanGalacticGargleBlaster's Avatar
I just checked and I'm on 8.2.2 build 4109-30. I also have the Roku Wireless speakers (don't know if that makes a difference on which update you get) and I love them. Totally worth the money. I hope they come out with a subwoofer and surround speakers.
PanGalacticGargleBlaster is offline
post #6207 of 6334 Old 12-05-2018, 03:26 AM
gilles1's Avatar
Roku OS Release Notes
Here are Roku OS release notes, up to, and including OS 9 (as said by someone already) to be included to ALL Roku TVs.
Also a list of all stand alone Roku devices getting OS 9.
Sorry, for some reason I can't link to the Roku blog. But if you go to www.roku.com , then support, then setup and troubleshooting, scroll way down to Miscellaneous support, the release notes are in there.
gilles1 is offline
post #6208 of 6334 Old 12-05-2018, 05:17 AM
Liked: 24
https://support.roku.com/article/228...-release-notes
Supported Roku devices receiving Roku OS 9:
Roku Streaming Players – 4661X, 4660X, 4640X, 4630X, 4620X, 4400X, 4230X, 4210X, 4200X, 3921X, 3920X, 3910X, 3900X, 3810X, 3800X, 3710X, 3700X, 3600X, 3500X, 3420X, 3400X, 3100X, 3050X, 3000X, 2720X, 2710X, 2700X, 2500X, 2450X, 2400X
Roku TV – All Roku TV models are expected to receive Roku OS 9.
patrck744 is offline
post #6209 of 6334 Old 12-16-2018, 10:42 AM
Fieryphoenix's Avatar
Here too. Unfortunately I need 2.0 to get 4k 60Hz HDR. I got a new cable trying to fix the problem before I found out it was on TCL's end. Oh well, at least the new cable is of a more convenient length.
Fieryphoenix is offline
post #6210 of 6334 Old 01-07-2019, 02:30 PM
musicmaniac's Avatar
Quoted: 36 Post(s)
Antenna guide too dark since update
Does anybody else have an issue with their antenna guide being too dark to read? I believe it's been like this since the last update 8.2.0 build 4170. I've contacted TCL but no help really other than restoring it to factory default.
musicmaniac is offline
Reply LCD Flat Panel Displays
